[MOAB-dev] r1571 - MOAB/trunk
kraftche at mcs.anl.gov
Thu Jan 31 13:56:52 CST 2008
Author: kraftche
Date: 2008-01-31 13:56:52 -0600 (Thu, 31 Jan 2008)
New Revision: 1571
Modified:
MOAB/trunk/MBBits.hpp
MOAB/trunk/TagServer.cpp
Log:
More bit tag fixes:
- Make low-level code fail to get non-existant tag values.
- Make higher-level code test for failure and return default
value if available or zero otherwise.
Default value now works for bit tags, but old behavior (implicit default
value of zero) is kept if no default value is specified.
Modified: MOAB/trunk/MBBits.hpp
--- MOAB/trunk/MBBits.hpp 2008-01-31 19:37:10 UTC (rev 1570)
+++ MOAB/trunk/MBBits.hpp 2008-01-31 19:56:52 UTC (rev 1571)
@@ -401,7 +401,7 @@
if(which_page >= mBitPagesSize)
bits = 0;
- return MB_SUCCESS;
+ return MB_TAG_NOT_FOUND;
// return bits from bit page
Modified: MOAB/trunk/TagServer.cpp
--- MOAB/trunk/TagServer.cpp 2008-01-31 19:37:10 UTC (rev 1570)
+++ MOAB/trunk/TagServer.cpp 2008-01-31 19:56:52 UTC (rev 1571)
@@ -226,7 +226,18 @@
if(TYPE_FROM_HANDLE(entity_handle) >= MBMAXTYPE)
return MB_TYPE_OUT_OF_RANGE;
- return mBitServer->get_bits(ID_FROM_TAG_HANDLE(tag_handle), entity_handle, data);
+ MBErrorCode rval = mBitServer->get_bits(ID_FROM_TAG_HANDLE(tag_handle), entity_handle, data);
+ if (MB_TAG_NOT_FOUND == rval) {
+ const TagInfo* info = get_tag_info( tag_handle );
+ if (!info)
+ return MB_FAILURE;
+ if (info->default_value())
+ data = *reinterpret_cast<const unsigned char*>(info->default_value());
+ else
+ data = '\0';
+ return MB_SUCCESS;
+ return rval;
MBErrorCode TagServer::set_mesh_data( const MBTag tag_handle,
