[MOAB-dev] r1560 - MOAB/trunk
kraftche at mcs.anl.gov kraftche at mcs.anl.gov
Thu Jan 24 17:38:12 CST 2008
Author: kraftche
Date: 2008-01-24 17:38:12 -0600 (Thu, 24 Jan 2008)
New Revision: 1560
Added:
   MOAB/trunk/SparseTagCollection.cpp
   MOAB/trunk/SparseTagCollection.hpp
   MOAB/trunk/SparseTagSuperCollection.cpp
   MOAB/trunk/SparseTagSuperCollection.hpp
Removed:
   MOAB/trunk/SparseTagCollections.cpp
   MOAB/trunk/SparseTagCollections.hpp
Modified:
   MOAB/trunk/Makefile.am
   MOAB/trunk/TagServer.cpp
Log:
split two classes defined in SparseTagCollections.?pp into separate files
Modified: MOAB/trunk/Makefile.am
--- MOAB/trunk/Makefile.am	2008-01-24 22:31:26 UTC (rev 1559)
+++ MOAB/trunk/Makefile.am	2008-01-24 23:38:12 UTC (rev 1560)
@@ -161,8 +161,10 @@
   SequenceData.cpp \
   SequenceManager.cpp \
   SequenceManager.hpp \
-  SparseTagCollections.cpp \
-  SparseTagCollections.hpp \
+  SparseTagSuperCollection.cpp \
+  SparseTagSuperCollection.hpp \
+  SparseTagCollection.cpp \
+  SparseTagCollection.hpp \
   StructuredElementSeq.cpp \
   StructuredElementSeq.hpp \
   TagInfo.cpp \
Copied: MOAB/trunk/SparseTagCollection.cpp (from rev 1555, MOAB/trunk/SparseTagCollections.cpp)
--- MOAB/trunk/SparseTagCollection.cpp	                        (rev 0)
+++ MOAB/trunk/SparseTagCollection.cpp	2008-01-24 23:38:12 UTC (rev 1560)
@@ -0,0 +1,159 @@
+ * MOAB, a Mesh-Oriented datABase, is a software component for creating,
+ * storing and accessing finite element mesh data.
+ * Copyright 2004 Sandia Corporation.  Under the terms of Contract
+ * DE-AC04-94AL85000 with Sandia Coroporation, the U.S. Government
+ * retains certain rights in this software.
+ * This library is free software; you can redistribute it and/or
+ * modify it under the terms of the GNU Lesser General Public
+ * License as published by the Free Software Foundation; either
+ * version 2.1 of the License, or (at your option) any later version.
+ * Filename   :     SparseTagCollection.cpp
+ * Purpose    :     To store any size data with
+ *                  any entity handle
+ * Creator    :     Clinton Stimpson
+ * Date       :     3 April 2002
+#include <memory.h>
+#include <algorithm>
+#include "SparseTagCollection.hpp"
+#include "MBRange.hpp"
+#include "TagCompare.hpp"
+SparseTagCollection::SparseTagCollection(int data_size)
+  mDataSize = data_size;
+SparseTagCollection::~SparseTagCollection()
+  void* tag_data = NULL;
+  std::map<MBEntityHandle, void*>::iterator tag_iterator;
+  for(tag_iterator = mData.begin(); tag_iterator != mData.end(); ++tag_iterator)
+    tag_data = tag_iterator->second;
+    if (mDataSize == MB_VARIABLE_LENGTH)
+      reinterpret_cast<VarLenTag*>(tag_data)->clear();
+    if(tag_data != NULL)
+      mAllocator.destroy(tag_data);
+  mData.clear();
+MBErrorCode SparseTagCollection::set_data(const MBEntityHandle entity_handle, const void* data)
+  MBErrorCode ret_val = MB_TAG_NOT_FOUND;
+  std::map<MBEntityHandle, void*>::iterator iterator =
+    mData.lower_bound(entity_handle);
+  // data space already exists
+  if (iterator!= mData.end() && iterator->first == entity_handle)
+    memcpy( iterator->second, data, mDataSize);
+    ret_val = MB_SUCCESS;
+  // we need to make some data space
+  else
+    void* new_data = mAllocator.allocate(mDataSize);
+    memcpy(new_data, data, mDataSize);
+    mData.insert(iterator, std::pair<const MBEntityHandle,void*>(entity_handle, new_data));
+  return ret_val;
+MBErrorCode SparseTagCollection::get_data(const MBEntityHandle entity_handle, void* data)
+  std::map<MBEntityHandle, void*>::iterator iter =
+    mData.find(entity_handle);
+  if(iter == mData.end())
+    return MB_TAG_NOT_FOUND;
+  memcpy(data, iter->second, mDataSize);
+  return MB_SUCCESS;
+MBErrorCode SparseTagCollection::remove_data( const MBEntityHandle entity_handle )
+  if(iterator != mData.end())
+      reinterpret_cast<VarLenTag*>(iterator->second)->clear();
+    mAllocator.destroy(iterator->second);
+    mData.erase(iterator);
+  return MB_ENTITY_NOT_FOUND;
+//! get number of entities of type
+MBErrorCode SparseTagCollection::get_number_entities(MBEntityType type, int& num_entities)
+  num_entities = 0;
+  std::map<MBEntityHandle, void*>::iterator iter;
+  for(iter = mData.begin(); iter != mData.end(); ++iter)
+    if(TYPE_FROM_HANDLE(iter->first) == type)
+      num_entities++;
+//! gets all entity handles that match a type and tag
+MBErrorCode SparseTagCollection::get_entities(MBEntityType type, MBRange &entities)
+      entities.insert(iter->first);
+//! gets all entity handles that match a type, tag and tag value
+MBErrorCode SparseTagCollection::get_entities_with_tag_value(
+                                                    const TagInfo& tag_info,
+                                                    MBEntityType type,
+                                                    MBRange &entities,
+                                                    const void* tag_value,
+                                                    int value_size)
+  std::map<MBEntityHandle, void*>::iterator iter, end;
+  int junk;
+  iter = mData.lower_bound( CREATE_HANDLE( type, MB_START_ID, junk ) );
+  end = mData.upper_bound( CREATE_HANDLE( type, MB_END_ID, junk ) );
+  find_tag_values_equal( tag_info, tag_value, value_size, iter, end, entities );
Copied: MOAB/trunk/SparseTagCollection.hpp (from rev 1555, MOAB/trunk/SparseTagCollections.hpp)
--- MOAB/trunk/SparseTagCollection.hpp	                        (rev 0)
+++ MOAB/trunk/SparseTagCollection.hpp	2008-01-24 23:38:12 UTC (rev 1560)
@@ -0,0 +1,145 @@
+ * Filename   :     SparseTagCollection.hpp
+#ifndef SPARSE_TAG_COLLECTION_HPP
+#define SPARSE_TAG_COLLECTION_HPP
+#ifndef IS_BUILDING_MB
+#error "SparseTagCollection.hpp isn't supposed to be included into an application"
+#endif
+#ifdef WIN32
+#pragma warning(disable : 4786)
+#endif
+#include <map>
+#include <vector>
+#include "MBTypes.h"
+#include "MBInternals.hpp"
+#include "TagInfo.hpp"
+//! allocator for tag data
+class SparseTagDataAllocator
+public:
+  //! constructor
+  SparseTagDataAllocator(){}
+  //! destructor
+  ~SparseTagDataAllocator(){}
+  //! allocates memory of size and returns pointer
+  void* allocate(size_t data_size) { return malloc(data_size); }
+  //! frees the memory
+  void destroy(void* p){ free(p); }
+//! collection of tag data associated with entity ids
+class SparseTagCollection
+public:
+  //! constructor takes tag data size
+  SparseTagCollection(int data_size);
+  //! destructor
+  ~SparseTagCollection();
+  //! set the tag data for an entity id
+  MBErrorCode set_data(const MBEntityHandle entity_handle, const void* data);
+  //! get the tag data for an entity id
+  MBErrorCode get_data(const MBEntityHandle entity_handle, void* data);
+  //! removes the data
+  MBErrorCode remove_data(const MBEntityHandle entity_handle);
+  //! get number of entities of type
+  MBErrorCode get_number_entities(MBEntityType type, int& num_entities);
+  unsigned long get_number_entities()
+    { return mData.size(); }
+  //! gets all entity handles that match a type and tag
+  MBErrorCode get_entities(MBEntityType type, MBRange &entities);
+  //! gets all entity handles that match a tag
+  MBErrorCode get_entities(MBRange &entities) const;
+  //! gets all entity handles that match a type, tag, tag_value
+  MBErrorCode get_entities_with_tag_value( const TagInfo& info,
+                                           int value_size);
+  //! if this collection contains this entity, return true, otherwise false
+  bool contains(const MBEntityHandle entity) const;
+  int tag_size() const { return mDataSize; }
+protected:
+  //! hidden constructor
+  SparseTagCollection(){}
+  //! size of the data
+  int mDataSize;
+  //! allocator for this collection
+  SparseTagDataAllocator mAllocator;
+  //! map of entity id and tag data
+  std::map<MBEntityHandle /*entity_handle*/ , void* /*data*/ > mData;
+inline bool SparseTagCollection::contains(const MBEntityHandle entity) const
+  return (mData.find(entity) == mData.end() ? false : true);
+inline MBErrorCode SparseTagCollection::get_entities(MBRange &entities) const
+  for (std::map<MBEntityHandle,void*>::const_iterator mit = mData.begin();
+       mit != mData.end(); mit++)
+    entities.insert((*mit).first);
+#endif //SPARSE_TAG_COLLECTION_HPP
Deleted: MOAB/trunk/SparseTagCollections.cpp
--- MOAB/trunk/SparseTagCollections.cpp	2008-01-24 22:31:26 UTC (rev 1559)
+++ MOAB/trunk/SparseTagCollections.cpp	2008-01-24 23:38:12 UTC (rev 1560)
@@ -1,370 +0,0 @@
- * MOAB, a Mesh-Oriented datABase, is a software component for creating,
- * storing and accessing finite element mesh data.
- * Copyright 2004 Sandia Corporation.  Under the terms of Contract
- * DE-AC04-94AL85000 with Sandia Coroporation, the U.S. Government
- * retains certain rights in this software.
- * This library is free software; you can redistribute it and/or
- * modify it under the terms of the GNU Lesser General Public
- * License as published by the Free Software Foundation; either
- * version 2.1 of the License, or (at your option) any later version.
- * Filename   :     SparseTagCollections.cpp
- * Purpose    :     To store any size data with
- *                  any entity handle
- * Creator    :     Clinton Stimpson
- * Date       :     3 April 2002
-#include <memory.h>
-#include <algorithm>
-#include "SparseTagCollections.hpp"
-#include "MBRange.hpp"
-#include "TagCompare.hpp"
-  SparseTagSuperCollection functions -----------------------------
-SparseTagSuperCollection::~SparseTagSuperCollection()
-  std::vector<SparseTagCollection*>::iterator tag_iterator;
-  for(tag_iterator = mDataTags.begin(); tag_iterator != mDataTags.end(); ++tag_iterator)
-    delete *tag_iterator;
-  mDataTags.clear();
-void SparseTagSuperCollection::reset_data()
-    if (*tag_iterator) {
-      int data_size = (*tag_iterator)->tag_size();
-      *tag_iterator = new SparseTagCollection(data_size);
-MBErrorCode SparseTagSuperCollection::reserve_tag_id(int data_size, MBTagId tag_id)
-  if(data_size<=0)
-    return MB_FAILURE;
-  if (tag_id >= mDataTags.size())
-    mDataTags.resize( tag_id+1, 0 );
-  if (mDataTags[tag_id])
-  mDataTags[tag_id] = new SparseTagCollection(data_size);
-  return MB_SUCCESS;
-MBErrorCode SparseTagSuperCollection::release_tag_id(MBTagId tag_id)
-  if (tag_id >= mDataTags.size() || !mDataTags[tag_id])
-    return MB_TAG_NOT_FOUND;
-  delete mDataTags[tag_id];
-  mDataTags[tag_id] = 0;
-int SparseTagSuperCollection::tag_size(const MBTagId tag_id) const
-  SparseTagCollection* coll = get_collection(tag_id);
-  return coll ? coll->tag_size() : 0;
-MBErrorCode SparseTagSuperCollection::set_data(const MBTagId tag_handle,
-    const MBEntityHandle entity_handle, const void* data)
-  SparseTagCollection* coll = get_collection(tag_handle);
-  return coll ? coll->set_data( entity_handle, data ) : MB_TAG_NOT_FOUND;
-MBErrorCode SparseTagSuperCollection::get_data(const MBTagId tag_handle,
-    const MBEntityHandle entity_handle, void* data)
-  return coll ? coll->get_data( entity_handle, data ) : MB_TAG_NOT_FOUND;
-MBErrorCode SparseTagSuperCollection::remove_data( const MBTagId tag_handle,
-    const MBEntityHandle entity_handle )
-  return coll ? coll->remove_data( entity_handle ) : MB_TAG_NOT_FOUND;
-//! gets all entity handles that match a type and tag
-MBErrorCode SparseTagSuperCollection::get_entities(const MBTagId tag_handle, const MBEntityType type,
-                                                    MBRange &entities)
-  return coll ? coll->get_entities(type, entities) : MB_TAG_NOT_FOUND;
-MBErrorCode SparseTagSuperCollection::get_entities(const MBRange &range,
-                                                    const MBTagId tag_handle, const MBEntityType type,
-  if (!coll)
-  MBRange dum_range;
-  MBErrorCode result = coll->get_entities(type, dum_range);
-  std::set_intersection(dum_range.begin(), dum_range.end(),
-                        range.begin(), range.end(),
-                        mb_range_inserter(entities));
-  return result;
-MBErrorCode SparseTagSuperCollection::get_tags(const MBEntityHandle entity,
-                                                std::vector<MBTag> &all_tags)
-  for (MBTagId id = 0; id < mDataTags.size(); ++id)
-    if (mDataTags[id] && mDataTags[id]->contains(entity))
-      all_tags.push_back( TAG_HANDLE_FROM_ID( id, MB_TAG_SPARSE ) );
-MBErrorCode SparseTagSuperCollection::get_entities_with_tag_value(
-                           const TagInfo& tag_info,
-                           const MBEntityType type,
-                           MBRange &entities,
-                           const void* tag_value,
-                           int value_size)
-  if (!coll)
-  return coll->get_entities_with_tag_value(tag_info, type, entities, tag_value, value_size);
-                          const MBRange &range,
-                          int value_size)
-  if (!coll)
-  MBErrorCode result = coll->get_entities_with_tag_value(
-                           tag_info, type, dum_range, tag_value, value_size);
-    // do this the hard way to preserve order in the vector
-  std::set_intersection(range.begin(), range.end(),
-                        dum_range.begin(), dum_range.end(),
-  return result;
-MBErrorCode SparseTagSuperCollection::get_number_entities(const MBTagId tag_handle, const MBEntityType type,
-                                                           int& num_entities)
-  return coll ? coll->get_number_entities( type, num_entities ) : MB_TAG_NOT_FOUND;
-MBErrorCode SparseTagSuperCollection::get_number_entities(const MBRange &range,
-  MBErrorCode result = get_entities(range, tag_handle, type, dum_range);
-  num_entities = dum_range.size();
-  return result;
-MBErrorCode SparseTagSuperCollection::get_memory_use( MBTagId tag_id,
-                                              unsigned long& total,
-                                              unsigned long& per_entity )
-  if (!coll)
-    // 3*sizeof(void*)                      - std::map RB tree node
-    // sizeof(void*)*sizeof(MBEntityHandle) - data in std::map node
-    // coll->tag_size()                     - the actual tag data
-  per_entity = 4*sizeof(void*)+sizeof(MBEntityHandle)+coll->tag_size();
-    // Count number of occupied slots in mDataTags vector
-  unsigned num_coll =0;
-  for (unsigned i = 0; i < mDataTags.size(); ++i)
-    if (mDataTags[i])
-      ++num_coll;
-    // amortized space in mDataTags vector
-  total = sizeof(SparseTagCollection*) * mDataTags.capacity() / num_coll;
-    // SparseTagCollection object for this tag
-  total += sizeof(SparseTagCollection);
-    // Per-entity data in SparseTagCollection
-  total += per_entity * coll->get_number_entities();
-  SparseTagCollection functions ----------------------------------
-SparseTagCollection::SparseTagCollection(int data_size)
-  mDataSize = data_size;
-SparseTagCollection::~SparseTagCollection()
-  void* tag_data = NULL;
-  std::map<MBEntityHandle, void*>::iterator tag_iterator;
-  for(tag_iterator = mData.begin(); tag_iterator != mData.end(); ++tag_iterator)
-    tag_data = tag_iterator->second;
-    if (mDataSize == MB_VARIABLE_LENGTH)
-      reinterpret_cast<VarLenTag*>(tag_data)->clear();
-    if(tag_data != NULL)
-      mAllocator.destroy(tag_data);
-  mData.clear();
-MBErrorCode SparseTagCollection::set_data(const MBEntityHandle entity_handle, const void* data)
-  MBErrorCode ret_val = MB_TAG_NOT_FOUND;
-  std::map<MBEntityHandle, void*>::iterator iterator =
-    mData.lower_bound(entity_handle);
-  // data space already exists
-  if (iterator!= mData.end() && iterator->first == entity_handle)
-    memcpy( iterator->second, data, mDataSize);
-    ret_val = MB_SUCCESS;
-  // we need to make some data space
-  else
-    void* new_data = mAllocator.allocate(mDataSize);
-    memcpy(new_data, data, mDataSize);
-    mData.insert(iterator, std::pair<const MBEntityHandle,void*>(entity_handle, new_data));
-  return ret_val;
-MBErrorCode SparseTagCollection::get_data(const MBEntityHandle entity_handle, void* data)
-  std::map<MBEntityHandle, void*>::iterator iter =
-    mData.find(entity_handle);
-  if(iter == mData.end())
-  memcpy(data, iter->second, mDataSize);
-MBErrorCode SparseTagCollection::remove_data( const MBEntityHandle entity_handle )
-  if(iterator != mData.end())
-      reinterpret_cast<VarLenTag*>(iterator->second)->clear();
-    mAllocator.destroy(iterator->second);
-    mData.erase(iterator);
-  return MB_ENTITY_NOT_FOUND;
-//! get number of entities of type
-MBErrorCode SparseTagCollection::get_number_entities(MBEntityType type, int& num_entities)
-  num_entities = 0;
-  std::map<MBEntityHandle, void*>::iterator iter;
-  for(iter = mData.begin(); iter != mData.end(); ++iter)
-    if(TYPE_FROM_HANDLE(iter->first) == type)
-      num_entities++;
-MBErrorCode SparseTagCollection::get_entities(MBEntityType type, MBRange &entities)
-      entities.insert(iter->first);
-//! gets all entity handles that match a type, tag and tag value
-MBErrorCode SparseTagCollection::get_entities_with_tag_value(
-                                                    MBEntityType type,
-                                                    int value_size)
-  std::map<MBEntityHandle, void*>::iterator iter, end;
-  int junk;
-  iter = mData.lower_bound( CREATE_HANDLE( type, MB_START_ID, junk ) );
-  end = mData.upper_bound( CREATE_HANDLE( type, MB_END_ID, junk ) );
-  find_tag_values_equal( tag_info, tag_value, value_size, iter, end, entities );
Deleted: MOAB/trunk/SparseTagCollections.hpp
--- MOAB/trunk/SparseTagCollections.hpp	2008-01-24 22:31:26 UTC (rev 1559)
+++ MOAB/trunk/SparseTagCollections.hpp	2008-01-24 23:38:12 UTC (rev 1560)
@@ -1,235 +0,0 @@
- * Filename   :     SparseTagCollections.hpp
-#ifndef SPARSE_TAG_COLLECTIONS_HPP
-#define SPARSE_TAG_COLLECTIONS_HPP
-#ifndef IS_BUILDING_MB
-#error "SparseTagCollections.hpp isn't supposed to be included into an application"
-#endif
-#ifdef WIN32
-#pragma warning(disable : 4786)
-#endif
-#include <map>
-#include <vector>
-#include "MBTypes.h"
-#include "MBInternals.hpp"
-#include "TagInfo.hpp"
-#define get_collection( A ) ((A) < mDataTags.size() ? mDataTags[(A)] : 0)
-//! allocator for tag data
-class SparseTagDataAllocator
-public:
-  //! constructor
-  SparseTagDataAllocator(){}
-  //! destructor
-  ~SparseTagDataAllocator(){}
-  //! allocates memory of size and returns pointer
-  void* allocate(size_t data_size) { return malloc(data_size); }
-  //! frees the memory
-  void destroy(void* p){ free(p); }
-//! collection of tag data associated with entity ids
-class SparseTagCollection
-public:
-  //! constructor takes tag data size
-  SparseTagCollection(int data_size);
-  //! destructor
-  ~SparseTagCollection();
-  //! set the tag data for an entity id
-  MBErrorCode set_data(const MBEntityHandle entity_handle, const void* data);
-  //! get the tag data for an entity id
-  MBErrorCode get_data(const MBEntityHandle entity_handle, void* data);
-  //! removes the data
-  MBErrorCode remove_data(const MBEntityHandle entity_handle);
-  //! get number of entities of type
-  MBErrorCode get_number_entities(MBEntityType type, int& num_entities);
-  unsigned long get_number_entities()
-    { return mData.size(); }
-  //! gets all entity handles that match a type and tag
-  MBErrorCode get_entities(MBEntityType type, MBRange &entities);
-  //! gets all entity handles that match a tag
-  MBErrorCode get_entities(MBRange &entities) const;
-  //! gets all entity handles that match a type, tag, tag_value
-  MBErrorCode get_entities_with_tag_value( const TagInfo& info,
-                                           int value_size);
-  //! if this collection contains this entity, return true, otherwise false
-  bool contains(const MBEntityHandle entity) const;
-  int tag_size() const { return mDataSize; }
-protected:
-  //! hidden constructor
-  SparseTagCollection(){}
-  //! size of the data
-  int mDataSize;
-  //! allocator for this collection
-  SparseTagDataAllocator mAllocator;
-  //! map of entity id and tag data
-  std::map<MBEntityHandle /*entity_handle*/ , void* /*data*/ > mData;
-inline bool SparseTagCollection::contains(const MBEntityHandle entity) const
-  return (mData.find(entity) == mData.end() ? false : true);
-inline MBErrorCode SparseTagCollection::get_entities(MBRange &entities) const
-  for (std::map<MBEntityHandle,void*>::const_iterator mit = mData.begin();
-       mit != mData.end(); mit++)
-    entities.insert((*mit).first);
-//! a collection of SparseTagCollections
-class SparseTagSuperCollection
-public:
-  //! constructor
-  SparseTagSuperCollection(){}
-  //! destructor
-  virtual ~SparseTagSuperCollection();
-  void reset_data();
-  //! allocate new tag id
-  MBErrorCode reserve_tag_id(int data_size, MBTagId tag_id);
-  //! releases an MBTagId
-  MBErrorCode release_tag_id(MBTagId tag_id);
-  //! size of data tag
-  int tag_size(const MBTagId tag_id) const;
-  //! set the data of a tag
-  MBErrorCode set_data(const MBTagId tag_handle, const MBEntityHandle entity_handle, const void* data);
-  //! get the data of a tag
-  MBErrorCode get_data(const MBTagId tag_handle, const MBEntityHandle entity_handle, void* data);
-  //! removes data
-  MBErrorCode remove_data(const MBTagId tag_handle, const MBEntityHandle entity_handle);
-  MBErrorCode get_entities(const MBTagId tag_handle, MBRange &entities);
-  MBErrorCode get_entities(const MBTagId tag_handle, const MBEntityType type,
-                            MBRange &entities);
-  MBErrorCode get_entities(const MBRange &range,
-  //! gets all tags on a given entity handle
-  MBErrorCode get_tags(const MBEntityHandle entity,
-                       std::vector<MBTag> &all_tags);
-  MBErrorCode get_entities_with_tag_value( const MBTagId tag_handle,
-                                           int value_size);
-  MBErrorCode get_entities_with_tag_value( const MBRange &range,
-                                           int value_size);
-  //! gets the number of entities that match a tag
-  MBErrorCode get_number_entities(const MBTagId tag_handle, const MBEntityType type, int& num_ent);
-  MBErrorCode get_number_entities(const MBRange &range,
-                                   const MBTagId tag_handle, const MBEntityType type, int& num_ent);
-  MBErrorCode get_memory_use( MBTagId tag_id,
-                              unsigned long& per_entity );
-private:
-  std::vector<SparseTagCollection*> mDataTags;
-inline MBErrorCode SparseTagSuperCollection::get_entities(const MBTagId tag_handle,
-  return coll ? coll->get_entities(entities) : MB_TAG_NOT_FOUND;
-#endif //SPARSE_TAG_COLLECTIONS_HPP
Copied: MOAB/trunk/SparseTagSuperCollection.cpp (from rev 1559, MOAB/trunk/SparseTagCollections.cpp)
--- MOAB/trunk/SparseTagSuperCollection.cpp	                        (rev 0)
+++ MOAB/trunk/SparseTagSuperCollection.cpp	2008-01-24 23:38:12 UTC (rev 1560)
@@ -0,0 +1,253 @@
+ * Filename   :     SparseTagSuperCollection.cpp
+#include "SparseTagSuperCollection.hpp"
+  SparseTagSuperCollection functions -----------------------------
+SparseTagSuperCollection::~SparseTagSuperCollection()
+  std::vector<SparseTagCollection*>::iterator tag_iterator;
+  for(tag_iterator = mDataTags.begin(); tag_iterator != mDataTags.end(); ++tag_iterator)
+    delete *tag_iterator;
+  mDataTags.clear();
+void SparseTagSuperCollection::reset_data()
+    if (*tag_iterator) {
+      int data_size = (*tag_iterator)->tag_size();
+      *tag_iterator = new SparseTagCollection(data_size);
+MBErrorCode SparseTagSuperCollection::reserve_tag_id(int data_size, MBTagId tag_id)
+  if(data_size<=0)
+    return MB_FAILURE;
+  if (tag_id >= mDataTags.size())
+    mDataTags.resize( tag_id+1, 0 );
+  if (mDataTags[tag_id])
+  mDataTags[tag_id] = new SparseTagCollection(data_size);
+MBErrorCode SparseTagSuperCollection::release_tag_id(MBTagId tag_id)
+  if (tag_id >= mDataTags.size() || !mDataTags[tag_id])
+  delete mDataTags[tag_id];
+  mDataTags[tag_id] = 0;
+int SparseTagSuperCollection::tag_size(const MBTagId tag_id) const
+  SparseTagCollection* coll = get_collection(tag_id);
+  return coll ? coll->tag_size() : 0;
+MBErrorCode SparseTagSuperCollection::set_data(const MBTagId tag_handle,
+    const MBEntityHandle entity_handle, const void* data)
+  SparseTagCollection* coll = get_collection(tag_handle);
+  return coll ? coll->set_data( entity_handle, data ) : MB_TAG_NOT_FOUND;
+MBErrorCode SparseTagSuperCollection::get_data(const MBTagId tag_handle,
+    const MBEntityHandle entity_handle, void* data)
+  return coll ? coll->get_data( entity_handle, data ) : MB_TAG_NOT_FOUND;
+MBErrorCode SparseTagSuperCollection::remove_data( const MBTagId tag_handle,
+    const MBEntityHandle entity_handle )
+  return coll ? coll->remove_data( entity_handle ) : MB_TAG_NOT_FOUND;
+MBErrorCode SparseTagSuperCollection::get_entities(const MBTagId tag_handle,
+                                                   MBRange &entities)
+  return coll ? coll->get_entities(entities) : MB_TAG_NOT_FOUND;
+MBErrorCode SparseTagSuperCollection::get_entities(const MBTagId tag_handle, const MBEntityType type,
+  return coll ? coll->get_entities(type, entities) : MB_TAG_NOT_FOUND;
+MBErrorCode SparseTagSuperCollection::get_entities(const MBRange &range,
+                                                    const MBTagId tag_handle, const MBEntityType type,
+  if (!coll)
+  MBRange dum_range;
+  MBErrorCode result = coll->get_entities(type, dum_range);
+  std::set_intersection(dum_range.begin(), dum_range.end(),
+                        range.begin(), range.end(),
+                        mb_range_inserter(entities));
+  return result;
+MBErrorCode SparseTagSuperCollection::get_tags(const MBEntityHandle entity,
+                                                std::vector<MBTag> &all_tags)
+  for (MBTagId id = 0; id < mDataTags.size(); ++id)
+    if (mDataTags[id] && mDataTags[id]->contains(entity))
+      all_tags.push_back( TAG_HANDLE_FROM_ID( id, MB_TAG_SPARSE ) );
+MBErrorCode SparseTagSuperCollection::get_entities_with_tag_value(
+                           const MBEntityType type,
+                           int value_size)
+  if (!coll)
+  return coll->get_entities_with_tag_value(tag_info, type, entities, tag_value, value_size);
+                          const MBRange &range,
+                          int value_size)
+  if (!coll)
+  MBErrorCode result = coll->get_entities_with_tag_value(
+                           tag_info, type, dum_range, tag_value, value_size);
+    // do this the hard way to preserve order in the vector
+  std::set_intersection(range.begin(), range.end(),
+                        dum_range.begin(), dum_range.end(),
+  return result;
+MBErrorCode SparseTagSuperCollection::get_number_entities(const MBTagId tag_handle, const MBEntityType type,
+                                                           int& num_entities)
+  return coll ? coll->get_number_entities( type, num_entities ) : MB_TAG_NOT_FOUND;
+MBErrorCode SparseTagSuperCollection::get_number_entities(const MBRange &range,
+  MBErrorCode result = get_entities(range, tag_handle, type, dum_range);
+  num_entities = dum_range.size();
+  return result;
+MBErrorCode SparseTagSuperCollection::get_memory_use( MBTagId tag_id,
+                                              unsigned long& total,
+                                              unsigned long& per_entity )
+  if (!coll)
+    // 3*sizeof(void*)                      - std::map RB tree node
+    // sizeof(void*)*sizeof(MBEntityHandle) - data in std::map node
+    // coll->tag_size()                     - the actual tag data
+  per_entity = 4*sizeof(void*)+sizeof(MBEntityHandle)+coll->tag_size();
+    // Count number of occupied slots in mDataTags vector
+  unsigned num_coll =0;
+  for (unsigned i = 0; i < mDataTags.size(); ++i)
+    if (mDataTags[i])
+      ++num_coll;
+    // amortized space in mDataTags vector
+  total = sizeof(SparseTagCollection*) * mDataTags.capacity() / num_coll;
+    // SparseTagCollection object for this tag
+  total += sizeof(SparseTagCollection);
+    // Per-entity data in SparseTagCollection
+  total += per_entity * coll->get_number_entities();
Copied: MOAB/trunk/SparseTagSuperCollection.hpp (from rev 1559, MOAB/trunk/SparseTagCollections.hpp)
--- MOAB/trunk/SparseTagSuperCollection.hpp	                        (rev 0)
+++ MOAB/trunk/SparseTagSuperCollection.hpp	2008-01-24 23:38:12 UTC (rev 1560)
@@ -0,0 +1,139 @@
+ * Filename   :     SparseTagSuperCollection.hpp
+#ifndef SPARSE_TAG_SUPER_COLLECTION_HPP
+#define SPARSE_TAG_SUPER_COLLECTION_HPP
+#error "SparseTagSuperCollection.hpp isn't supposed to be included into an application"
+#endif
+#ifdef WIN32
+#endif
+#include <map>
+#include <vector>
+#define get_collection( A ) ((A) < mDataTags.size() ? mDataTags[(A)] : 0)
+class SparseTagCollection;
+//! a collection of SparseTagCollections
+class SparseTagSuperCollection
+public:
+  //! constructor
+  SparseTagSuperCollection(){}
+  //! destructor
+  virtual ~SparseTagSuperCollection();
+  void reset_data();
+  //! allocate new tag id
+  MBErrorCode reserve_tag_id(int data_size, MBTagId tag_id);
+  //! releases an MBTagId
+  MBErrorCode release_tag_id(MBTagId tag_id);
+  //! size of data tag
+  int tag_size(const MBTagId tag_id) const;
+  //! set the data of a tag
+  MBErrorCode set_data(const MBTagId tag_handle, const MBEntityHandle entity_handle, const void* data);
+  //! get the data of a tag
+  MBErrorCode get_data(const MBTagId tag_handle, const MBEntityHandle entity_handle, void* data);
+  //! removes data
+  MBErrorCode remove_data(const MBTagId tag_handle, const MBEntityHandle entity_handle);
+  MBErrorCode get_entities(const MBTagId tag_handle, MBRange &entities);
+  MBErrorCode get_entities(const MBTagId tag_handle, const MBEntityType type,
+                            MBRange &entities);
+  MBErrorCode get_entities(const MBRange &range,
+  //! gets all tags on a given entity handle
+  MBErrorCode get_tags(const MBEntityHandle entity,
+                       std::vector<MBTag> &all_tags);
+  MBErrorCode get_entities_with_tag_value( const MBTagId tag_handle,
+                                           int value_size);
+  MBErrorCode get_entities_with_tag_value( const MBRange &range,
+                                           int value_size);
+  //! gets the number of entities that match a tag
+  MBErrorCode get_number_entities(const MBTagId tag_handle, const MBEntityType type, int& num_ent);
+  MBErrorCode get_number_entities(const MBRange &range,
+                                   const MBTagId tag_handle, const MBEntityType type, int& num_ent);
+  MBErrorCode get_memory_use( MBTagId tag_id,
+                              unsigned long& per_entity );
+private:
+  std::vector<SparseTagCollection*> mDataTags;
+#endif //SPARSE_TAG_SUPER_COLLECTION_HPP
Modified: MOAB/trunk/TagServer.cpp
--- MOAB/trunk/TagServer.cpp	2008-01-24 22:31:26 UTC (rev 1559)
+++ MOAB/trunk/TagServer.cpp	2008-01-24 23:38:12 UTC (rev 1560)
@@ -40,7 +40,7 @@
 #include <assert.h>
 #include "TagServer.hpp"
 #include "MBBits.hpp"
 #include "MBInterface.hpp"
 #include "SequenceManager.hpp"
