[MOAB-dev] r1559 - MOAB/trunk
    kraftche at mcs.anl.gov
    Thu Jan 24 16:31:27 CST 2008
Author: kraftche
Date: 2008-01-24 16:31:26 -0600 (Thu, 24 Jan 2008)
New Revision: 1559
Modified:
   MOAB/trunk/SequenceManager.cpp
   MOAB/trunk/SequenceManager.hpp
Log:
o Add documentation for SequenceManager member functions
o Add low-level functions to get and set variable-length dense tag data
Modified: MOAB/trunk/SequenceManager.cpp
--- MOAB/trunk/SequenceManager.cpp	2008-01-24 21:56:18 UTC (rev 1558)
+++ MOAB/trunk/SequenceManager.cpp	2008-01-24 22:31:26 UTC (rev 1559)
@@ -756,7 +756,7 @@
                                            const void* value,
                                            const void* default_value )
-  if (tag_id >= tagSizes.size() || !tagSizes[tag_id])
+  if (tag_id >= tagSizes.size() || tagSizes[tag_id] < 1)
     return MB_TAG_NOT_FOUND;
   EntitySequence* seq = 0;
@@ -775,12 +775,40 @@
 MBErrorCode SequenceManager::set_tag_data( MBTagId tag_id,
+                                           MBEntityHandle handle,
+                                           const void* value,
+                                           const void* default_value,
+                                           int length )
+  if (tag_id >= tagSizes.size() || !tagSizes[tag_id])
+    return MB_TAG_NOT_FOUND;
+  if (tagSizes[tag_id] != MB_VARIABLE_LENGTH && length != tagSizes[tag_id])
+    return MB_INVALID_SIZE;
+  EntitySequence* seq = 0;
+  MBErrorCode rval = find( handle, seq );
+  if (MB_SUCCESS != rval)
+    return rval;
+  void* tag_array = seq->data()->get_tag_data( tag_id );
+  if (!tag_array)
+    tag_array = seq->data()->create_tag_data( tag_id, sizeof(VarLenTag), default_value );
+  VarLenTag* tag_data = reinterpret_cast<VarLenTag*>(tag_array) +
+                        (handle - seq->data()->start_handle());
+  memcpy( tag_data->resize(length), value, length );
+  return MB_SUCCESS;
+MBErrorCode SequenceManager::set_tag_data( MBTagId tag_id,
                                            const MBRange& handles,
                                            const void* values,
   MBErrorCode rval, result = MB_SUCCESS;
+    // NOTE: Comparison of size to 1 should also catch
+    //       case where tag is variable-length.
   const char* data = reinterpret_cast<const char*>(values);
@@ -825,7 +853,9 @@
                                            void* value ) const
   const EntitySequence* seq = 0;
@@ -844,6 +874,37 @@
 MBErrorCode SequenceManager::get_tag_data( MBTagId tag_id,
+                                           const void*& value,
+                                           int& length ) const
+  const EntitySequence* seq = 0;
+    return rval;
+  const void* tag_array = seq->data()->get_tag_data( tag_id );
+  if (!tag_array)
+  length = tagSizes[tag_id];
+  if (length == MB_VARIABLE_LENGTH) {
+    const VarLenTag* tag_data = reinterpret_cast<const VarLenTag*>(tag_array) +
+    length = tag_data->size();
+    value = tag_data->data();
+  else {
+    value = reinterpret_cast<const char*>(tag_array) +
+                   length * (handle - seq->data()->start_handle());
+MBErrorCode SequenceManager::get_tag_data( MBTagId tag_id,
                                            void* values,
                                            const void* default_value ) const
Modified: MOAB/trunk/SequenceManager.hpp
--- MOAB/trunk/SequenceManager.hpp	2008-01-24 21:56:18 UTC (rev 1558)
+++ MOAB/trunk/SequenceManager.hpp	2008-01-24 22:31:26 UTC (rev 1559)
@@ -21,47 +21,93 @@
       /** Delete all contained data */
     void clear();
+      /** Find entity sequence containing specified handle.
+       *\return MB_SUCCESS or MB_ENTITY_NOT_FOUND
     MBErrorCode find( MBEntityHandle handle, EntitySequence*& sequence_out )
         return typeData[TYPE_FROM_HANDLE(handle)].find( handle, sequence_out );
     MBErrorCode find( MBEntityHandle handle, const EntitySequence*& sequence_out ) const
-    void get_entities( MBEntityType type, MBRange& entities_out ) const
+      /** Get all entities of a given MBEntityType */
+   void get_entities( MBEntityType type, MBRange& entities_out ) const
       { typeData[type].get_entities( entities_out ); }
+      /** Count entities of a given MBEntityType */
     MBEntityID get_number_entities( MBEntityType type ) const
       { return typeData[type].get_number_entities(); }
+      /**\brief Replace subset of existing sequence with new
+       *        sequence (splits existing sequence)
+       * Used for converting number of nodes for fixed-connectivity-length
+       * elements.  Input sequence must be a non-strict subset of an existing
+       * sequence.  Existing sequence will be removed, modified, or split
+       * into two prevent it from overlapping the new sequence.
     MBErrorCode replace_subsequence( EntitySequence* new_seq, TagServer* ts );
+      /** Check if passed entity handles are valid */
     MBErrorCode check_valid_entities( const MBRange& entities ) const;
+      /** Delete an entity.  Deletes sequence if only contained entity. */
     MBErrorCode delete_entity( MBEntityHandle entity );
+      /** Delete entities */
     MBErrorCode delete_entities( const MBRange& entities );
+      /** Allocate a vertex (possibly in an existing sequence) and
+       *  assign it the passed coordinate values.
     MBErrorCode create_vertex( unsigned processor_id,
                                const double coords[3],
                                MBEntityHandle& handle_out );
+      /** Allocate a element (possibly in an existing sequence) and
+       *  assign it the passed connectivity.
     MBErrorCode create_element( MBEntityType type,
                                 const MBEntityHandle* conn_array,
                                 unsigned num_vertices,
+      /** Allocate an entity set (possibly in an existing sequence) */
     MBErrorCode create_mesh_set( unsigned processor_id,
                                  unsigned flags,
+      /** Allocate an entity set with the specified handle.
+       *\return MB_ALREADY_ALLOCATED if handle is in use, MB_SUCCESS otherwise.
     MBErrorCode allocate_mesh_set( MBEntityHandle at_this_handle,
                                    unsigned flags );
+      /**\brief Allocate a block of consecutive entity handles
+       * Allocate a block of consecutive entity handles.  Handles
+       * may be appended or prepended to an existing entity sequence.
+       *\param type The type of of entity for which to allocate handles
+       *\param num_entities Number of entities to allocate
+       *\param nodes_per_entity Number of nodes in connectivity for elements,
+       *                    ignored MBVERTEX, MBPOLYGON, MBPOLYHEDRON, and
+       *                    MBENTITYSET types.
+       *\param start_id_hint Preferred ID portion for first handle.
+       *                    May be ignored if not available.
+       *\param processor_id Processor ID to embed in handles
+       *\param first_handle_out First allocated handle.  Allocated handles
+       *                    are [first_handle_out, first_handle_out+num_entities-1].
+       *\param sequence_out The sequence in which the entities were allocated.
+       *                    NOTE: first_handle_out may not be first handle in
+       *                    sequence.
     MBErrorCode create_entity_sequence( MBEntityType type,
                                         MBEntityID num_entities,
                                         int nodes_per_entity,
@@ -70,6 +116,23 @@
                                         MBEntityHandle& first_handle_out,
                                         EntitySequence*& sequence_out );
+      /**\brief Allocate a block of consecutive mesh sets
+       *\param num_sets     Number of entities to allocate
+       *\param flags        Array of length 'num_sets' containing entity set
+       *                    creating flags.
+       *                    sequence.
     MBErrorCode create_meshset_sequence( MBEntityID num_sets,
                                          MBEntityID start_id_hint,
                                          int processor_id,
@@ -77,6 +140,10 @@
+       * Alternate form that creates all mesh sets with same flags.
                                          int processor_id,
@@ -84,6 +151,7 @@
+      /** Create structured mesh */
     MBErrorCode create_scd_sequence( int imin, int jmin, int kmin,
                                      int imax, int jmax, int kmax,
                                      MBEntityType type,
@@ -92,6 +160,7 @@
     MBErrorCode create_scd_sequence( const HomCoord& coord_min,
                                      const HomCoord& coord_max,
                                      MBEntityType type,
@@ -100,10 +169,11 @@
+      /** Get data for a specific MBEntityType */
     TypeSequenceManager& entity_map( MBEntityType type )
       { return typeData[type]; }
     const TypeSequenceManager& entity_map( MBEntityType type ) const
@@ -122,47 +192,109 @@
     /* Dense Tag Functions */
+      /** Release all dense tag data storage */
     void reset_tag_data();
+      /** Allocate a tag ID
+       *\param tag_id   The ID to allocate/reserve
+       *\param tag_size The size of the tag value for each entity
     MBErrorCode reserve_tag_id( int tag_size, MBTagId tag_id );
+      /** Release a reserved tag ID any any associated storage */
     MBErrorCode release_tag( MBTagId tag_id );
+      /** If tag data is allocated for the specified entity,
+       *  change it to the passed default value.  Otherwise
+       *  do nothing.
     MBErrorCode remove_tag_data( MBTagId tag_id,
                                  const void* default_tag_value,
                                  int default_value_size = 0 );
+      /** Set fixed-length tag value for a single entity.
+       *\NOTE Default value must be given because it is often
+       *      necessary to allocate storage for other entities
     MBErrorCode set_tag_data( MBTagId tag_id,
                               const void* value,
                               const void* default_value );
+      /** Set variable-length tag value for a single entity.
+                              int length );
+      /** Set fixed-length tag value an MBRange of entities
+    MBErrorCode set_tag_data( MBTagId tag_id,
                               const void* values,
+      /** Get fixed-length tag value for a single entity
     MBErrorCode get_tag_data( MBTagId tag_id,
                               void* value ) const;
+      /** Get variable-length tag size and pointer to internal data storage.
+       *\param value Reference at which to store pointer to tag data.
+                              const void*& value_ptr,
+                              int& length ) const;
+      /** Get fixed-length tag value for an MBRange of entities
+    MBErrorCode get_tag_data( MBTagId tag_id,
                               void* values,
                               const void* default_value ) const;
+      /** Get all tags for which values (possibly the default value)
+       *  have been allocated for a given entity
     MBErrorCode get_entity_tags( MBEntityHandle entity,
                                  std::vector<MBTag>& tags_out ) const;
+      /** Get all entities for which storage for a specific tag has
+       *  been allocated.
     MBErrorCode get_tagged_entities( MBTagId tag_id,
                                      MBEntityType type,
                                      MBRange& entities_out ) const;
+      /** Count all entities for which storage for a specific tag has
+       *  been allocated.
     MBErrorCode count_tagged_entities( MBTagId tag,
                                        MBEntityType type,
                                        int& result ) const;
+      /** Get entities by type and tag value (intersection) */
     MBErrorCode get_entities_with_tag_value( MBTagId id,
                                              const TagInfo& tag_info,
                                              MBEntityType type,
                                              MBRange& entities_out,
                                              const void* value,
                                              int value_size ) const;
+      /** Get subset of entities with a type and a tag value (intersection)
+       *\param range Intersect result with this range
+       *\param id    The ID of the tag to match
+       *\param type  Only check entities of this type
+       *\param entities_out Result (subset of input 'range')
+       *\param value The tag value
     MBErrorCode get_entities_with_tag_value( const MBRange& range,
                                              MBTagId id,
