[MOAB-dev] r1521 - MOAB/trunk
kraftche at mcs.anl.gov kraftche at mcs.anl.gov
Mon Jan 14 13:50:39 CST 2008
Author: kraftche
Date: 2008-01-14 13:50:39 -0600 (Mon, 14 Jan 2008)
New Revision: 1521
Added:
   MOAB/trunk/TagCompare.hpp
Modified:
   MOAB/trunk/SequenceManager.cpp
   MOAB/trunk/SequenceManager.hpp
   MOAB/trunk/SparseTagCollections.cpp
   MOAB/trunk/SparseTagCollections.hpp
   MOAB/trunk/TagServer.cpp
   MOAB/trunk/TagServer.hpp
   MOAB/trunk/VarLenTag.hpp
Log:
- Add new tag comparison code that
   a) works for variable-length tags
   b) has correct behavior for positive/negative 0.0
   c) is faster for some tag searches
- Call new tag comparison code for sparse and dense tags
- Update low-level tag APIs to support new tag comparison code
  and searching for variable-length tag values.
Modified: MOAB/trunk/SequenceManager.cpp
--- MOAB/trunk/SequenceManager.cpp	2008-01-14 19:48:15 UTC (rev 1520)
+++ MOAB/trunk/SequenceManager.cpp	2008-01-14 19:50:39 UTC (rev 1521)
@@ -7,6 +7,7 @@
 #include "HomXform.hpp"
 #include "PolyElementSeq.hpp"
 #include "MBSysUtil.hpp"
+#include "TagCompare.hpp"
 #include <assert.h>
 #include <new>
@@ -927,9 +928,11 @@
 MBErrorCode SequenceManager::get_entities_with_tag_value( MBTagId id,
+                                                          const TagInfo& tag_info,
                                                           MBEntityType type,
                                                           MBRange& entities_out,
-                                                          const void* value ) const
+                                                          const void* value,
+                                                          int size ) const
   if (id >= tagSizes.size() || !tagSizes[id])
     return MB_TAG_NOT_FOUND;
@@ -938,10 +941,10 @@
   const TypeSequenceManager& map = entity_map( type );
   for (TypeSequenceManager::const_iterator i = map.begin(); i != map.end(); ++i) {
     if (const void* data = (*i)->data()->get_tag_data(id)) {
-      const char* bytes = reinterpret_cast<const char*>(data);
-      for (MBEntityHandle h = (*i)->start_handle(); h <= (*i)->end_handle(); ++h)
-        if (!memcmp( bytes + tagSizes[id] * (h - (*i)->data()->start_handle()), value, tagSizes[id] ))
-          insert = entities_out.insert( insert, h, h );
+      ByteArrayIterator start( (*i)->data()->start_handle(), data, tag_info );
+      ByteArrayIterator end( (*i)->end_handle() + 1, 0, 0 );
+      start += (*i)->start_handle() - (*i)->data()->start_handle();
+      find_tag_values_equal( tag_info, value, size, start, end, entities_out );
@@ -950,9 +953,11 @@
 MBErrorCode SequenceManager::get_entities_with_tag_value( const MBRange& range,
                                                           MBTagId id,
                                                           MBEntityType type,
+                                                          int size ) const
   MBErrorCode rval;
@@ -975,11 +980,10 @@
       const MBEntityHandle finish = std::min( p->second, seq->end_handle() );
       const void* tag_array = seq->data()->get_tag_data( id );
       if (tag_array) {
-        const char* tag_data = reinterpret_cast<const char*>(tag_array);
-        for (MBEntityHandle h = start; h <= finish; ++h) {
-          if (!memcmp( tag_data + tagSizes[id] * (h - seq->data()->start_handle()), value, tagSizes[id] ))
+        ByteArrayIterator start( seq->data()->start_handle(), tag_array, tag_info );
+        ByteArrayIterator end( seq->end_handle() + 1, 0, 0 );
+        start += seq->start_handle() - seq->data()->start_handle();
       start = finish + 1;
Modified: MOAB/trunk/SequenceManager.hpp
--- MOAB/trunk/SequenceManager.hpp	2008-01-14 19:48:15 UTC (rev 1520)
+++ MOAB/trunk/SequenceManager.hpp	2008-01-14 19:50:39 UTC (rev 1521)
@@ -3,6 +3,7 @@
 #include "TypeSequenceManager.hpp"
 #include "MBHandleUtils.hpp"
+#include "TagInfo.hpp"
 class HomCoord;
 class TagServer;
@@ -154,14 +155,18 @@
                                        int& result ) const;
     MBErrorCode get_entities_with_tag_value( MBTagId id,
                                              MBEntityType type,
-                                             const void* value ) const;
+                                             int value_size ) const;
     MBErrorCode get_entities_with_tag_value( const MBRange& range,
                                              MBTagId id,
                                              MBEntityType type,
     MBErrorCode get_tag_memory_use( MBTagId id,
                                     unsigned long& total,
Modified: MOAB/trunk/SparseTagCollections.cpp
--- MOAB/trunk/SparseTagCollections.cpp	2008-01-14 19:48:15 UTC (rev 1520)
+++ MOAB/trunk/SparseTagCollections.cpp	2008-01-14 19:50:39 UTC (rev 1521)
@@ -32,6 +32,7 @@
 #include "SparseTagCollections.hpp"
 #include "MBRange.hpp"
   SparseTagSuperCollection functions -----------------------------
@@ -158,27 +159,38 @@
 //! gets all entity handles that match a type and tag
-MBErrorCode SparseTagSuperCollection::get_entities_with_tag_value(const MBTagId tag_handle, const MBEntityType type,
-        MBRange &entities, const void* tag_value)
+MBErrorCode SparseTagSuperCollection::get_entities_with_tag_value(
+                           const MBTagId tag_handle,
+                           const MBEntityType type,
+                           MBRange &entities,
+                           const void* tag_value,
+                           int value_size)
   SparseTagCollection* coll = get_collection(tag_handle);
   if (!coll)
-  return coll->get_entities_with_tag_value(type, entities, tag_value);
+  return coll->get_entities_with_tag_value(tag_info, type, entities, tag_value, value_size);
-MBErrorCode SparseTagSuperCollection::get_entities_with_tag_value(const MBRange &range,
-        const MBTagId tag_handle, const MBEntityType type,
+                          const MBRange &range,
+                          int value_size)
   if (!coll)
   MBRange dum_range;
-  MBErrorCode result = coll->get_entities_with_tag_value(type, dum_range, tag_value);
+  MBErrorCode result = coll->get_entities_with_tag_value(
+                           tag_info, type, dum_range, tag_value, value_size);
     // do this the hard way to preserve order in the vector
   std::set_intersection(range.begin(), range.end(),
@@ -355,29 +367,22 @@
 //! gets all entity handles that match a type, tag and tag value
-MBErrorCode SparseTagCollection::get_entities_with_tag_value(MBEntityType type,
+MBErrorCode SparseTagCollection::get_entities_with_tag_value(
+                                                    MBEntityType type,
+                                                    int value_size)
-  std::map<MBEntityHandle, void*>::iterator iter;
-  for(iter = mData.begin(); iter != mData.end(); ++iter)
-    if(TYPE_FROM_HANDLE(iter->first) == type) {
-#ifndef NDEBUG
-      MBEntityHandle this_ent = iter->first;
-      void *this_tag = iter->second;
-        // coupla meaningless statements to get rid of compiler warnings
-      if (this_ent);
-      if (this_tag);
-#endif
-      if( memcmp( iter->second, tag_value, mDataSize ) == 0)
-        entities.insert(iter->first);
+  std::map<MBEntityHandle, void*>::iterator iter, end;
+  int junk;
+  iter = mData.lower_bound( CREATE_HANDLE( type, MB_START_ID, junk ) );
+  end = mData.upper_bound( CREATE_HANDLE( type, MB_END_ID, junk ) );
+  find_tag_values_equal( tag_info, tag_value, value_size, iter, end, entities );
   return MB_SUCCESS;
Modified: MOAB/trunk/SparseTagCollections.hpp
--- MOAB/trunk/SparseTagCollections.hpp	2008-01-14 19:48:15 UTC (rev 1520)
+++ MOAB/trunk/SparseTagCollections.hpp	2008-01-14 19:50:39 UTC (rev 1521)
@@ -45,6 +45,7 @@
 #include "MBTypes.h"
 #include "MBInternals.hpp"
 #define get_collection( A ) ((A) < mDataTags.size() ? mDataTags[(A)] : 0)
@@ -100,9 +101,11 @@
   MBErrorCode get_entities(MBRange &entities) const;
   //! gets all entity handles that match a type, tag, tag_value
-  MBErrorCode get_entities_with_tag_value(MBEntityType type,
+  MBErrorCode get_entities_with_tag_value( const TagInfo& info,
                                            MBRange &entities,
-                                           const void* tag_value);
+                                           int value_size);
   //! if this collection contains this entity, return true, otherwise false
   bool contains(const MBEntityHandle entity) const;
@@ -189,15 +192,21 @@
                        std::vector<MBTag> &all_tags);
   //! gets all entity handles that match a tag
-  MBErrorCode get_entities_with_tag_value(const MBTagId tag_handle, const MBEntityType type,
+  MBErrorCode get_entities_with_tag_value( const MBTagId tag_handle,
                                            MBRange &entities,
+                                           int value_size);
-  MBErrorCode get_entities_with_tag_value(const MBRange &range,
+  MBErrorCode get_entities_with_tag_value( const MBRange &range,
                                            MBRange &entities,
+                                           int value_size);
   //! gets the number of entities that match a tag
   MBErrorCode get_number_entities(const MBTagId tag_handle, const MBEntityType type, int& num_ent);
Added: MOAB/trunk/TagCompare.hpp
--- MOAB/trunk/TagCompare.hpp	                        (rev 0)
+++ MOAB/trunk/TagCompare.hpp	2008-01-14 19:50:39 UTC (rev 1521)
@@ -0,0 +1,358 @@
+#ifndef TAG_COMPARE_HPP
+#define TAG_COMPARE_HPP
+#include "VarLenTag.hpp"
+/* OPAQUE FUNCTORS */
+/** Test fixed-length opaque tags for equality */
+class TagBytesEqual {
+  private:
+    const void* value;
+    int size;
+  public:
+    TagBytesEqual( const void* v, int s ) : value(v), size(s) {}
+    bool operator()( const void* data ) const
+      { return !memcmp(value, data, size); }
+/** Test if fixed-length opaque tag values are less than a value */
+class TagBytesLess {
+  private:
+    int size;
+  public:
+    TagBytesLess( const void* v, int s ) : value(v), size(s) {}
+      { return 0 < memcmp(value, data, size); }
+/** Test variable-length opaque tags for equality */
+class TagVarBytesEqual {
+  private:
+    int size;
+  public:
+    TagVarBytesEqual( const void* v, int s ) : value(v), size(s) {}
+    bool operator()( const void* data ) const {
+      const VarLenTag* vdata = reinterpret_cast<const VarLenTag*>(data);
+      return (int)vdata->size() == size && !memcmp(value, vdata->data(), size);
+/** Test if variable-length opaque tag values are less than a value */
+class TagVarBytesLess {
+  private:
+    int size;
+  public:
+    TagVarBytesLess( const void* v, int s ) : value(v), size(s) {}
+      if ((int)vdata->size() < size)
+        return 0 <= memcmp( vdata->data(), value, vdata->size() );
+      else
+        return 0 < memcmp( vdata->data(), value, size );
+/* TEMPLATE FUNCTORS */
+/** Compare fixed-length tags containing a known data type */
+template <typename T>
+class TagTypeEqual {
+  private:
+    const T* value;
+    int size;
+  public:
+    TagTypeEqual( const void* v, int s )
+      : value(reinterpret_cast<const T*>(v)),
+        size(s/sizeof(T))
+      const T* ddata = reinterpret_cast<const T*>(data);
+      for (int i = 0; i < size; ++i)
+        if (value[i] != ddata[i])
+          return false;
+      return true;
+class TagTypeLess {
+  private:
+    const T* value;
+    int size;
+  public:
+    TagTypeLess( const void* v, int s )
+        size(s/sizeof(T))
+        if (value[i] <= ddata[i])
+          return false;
+      return true;
+/** Compare single-value tags containing a known data type
+ * Optimization of TagTypeEqual for 1-value case.
+class TagOneTypeEqual {
+  private:
+    T value;
+    int size;
+  public:
+    TagOneTypeEqual( const void* v )
+      : value(*reinterpret_cast<const T*>(v))
+      return *ddata == value;
+ * Optimization of TagTypeLess for 1-value case.
+class TagOneTypeLess {
+  private:
+    T value;
+    int size;
+  public:
+    TagOneTypeLess( const void* v )
+      return *ddata < value;
+/** Compare variable-length tags containing a known data type */
+class TagVarTypeEqual
+  private:
+    const T* value;
+    int size;
+  public:
+    TagVarTypeEqual( const void* v, int s )
+        size(s/sizeof(T))
+      if (vdata->size() != size * sizeof(T))
+        return false;
+      const T* ddata = reinterpret_cast<const T*>(vdata->data());
+          return false;
+      return true;
+class TagVarTypeLess
+  private:
+    const T* value;
+    int size;
+  public:
+    TagVarTypeLess( const void* v, int s )
+        size(s/sizeof(T))
+      if ((int)vdata->size() < sizeof(T)*size) {
+        for (int i = 0; i < vdata->size()/sizeof(T); ++i)
+          if (value[i] < ddata[i])
+            return false;
+      else {
+            return false;
+      return true;
+/* TYPE FUNCTORS */
+typedef TagBytesEqual        TagIntsEqual;
+typedef TagVarBytesEqual     TagVarIntsEqual;
+typedef TagTypeLess    <int> TagIntsLess;
+typedef TagVarTypeLess <int> TagVarIntsLess;
+typedef TagOneTypeEqual<int> TagOneIntEqual;
+typedef TagOneTypeLess <int> TagOneIntLess;
+typedef TagBytesEqual                   TagHandlesEqual;
+typedef TagVarBytesEqual                TagVarHandlesEqual;
+typedef TagTypeLess    <MBEntityHandle> TagHandlesLess;
+typedef TagVarTypeLess <MBEntityHandle> TagVarHandlesLess;
+typedef TagOneTypeEqual<MBEntityHandle> TagOneHandleEqual;
+typedef TagOneTypeLess <MBEntityHandle> TagOneHandleLess;
+typedef TagTypeEqual   <double> TagDoublesEqual;
+typedef TagVarTypeEqual<double> TagVarDoublesEqual;
+typedef TagTypeLess    <double> TagDoublesLess;
+typedef TagVarTypeLess <double> TagVarDoublesLess;
+typedef TagOneTypeEqual<double> TagOneDoubleEqual;
+typedef TagOneTypeLess <double> TagOneDoubleLess;
+/* SEARCHING */
+template <class Functor,
+          class IteratorType>
+void find_tag_values( Functor compare,
+                      IteratorType begin,
+                      IteratorType end,
+                      MBRange& results )
+  MBRange::iterator insert = results.begin();
+  for (IteratorType i = begin; i != end; ++i)
+    if (compare( i->second ))
+      insert = results.insert( insert, i->first, i->first );
+                      IteratorType end,
+                      std::vector<MBEntityHandle>& results )
+      results.push_back( i->first );
+/** Find all entities for which a tag has a specific value
+ *\param IteratorType : an iterator that has map behavior:
+ *                      the value of 'first' is the entity handle.
+ *                      the value of 'second' is a pointer to the tag data.
+ *\param ContainerType : std::vector<MBEntityHandle> or MBRange
+template <class IteratorType, class ContainerType>
+void find_tag_values_equal( const TagInfo& tag_info,
+                            int size,
+                            IteratorType end,
+                            ContainerType& results )
+  switch (tag_info.get_data_type()) {
+    case MB_TYPE_INTEGER:
+      switch (tag_info.get_size()) {
+        case MB_VARIABLE_LENGTH:
+          find_tag_values( TagVarIntsEqual( value, size ), begin, end, results );
+          break;
+        case sizeof(int):
+          find_tag_values( TagOneIntEqual( value ), begin, end, results );
+          break;
+        default:
+          find_tag_values( TagIntsEqual( value, size ), begin, end, results );
+          break;
+      break;
+    case MB_TYPE_DOUBLE:
+          find_tag_values( TagVarDoublesEqual( value, size ), begin, end, results );
+          break;
+        case sizeof(double):
+          find_tag_values( TagOneDoubleEqual( value ), begin, end, results );
+          break;
+        default:
+          find_tag_values( TagDoublesEqual( value, size ), begin, end, results );
+          break;
+      break;
+    case MB_TYPE_HANDLE:
+          find_tag_values( TagVarHandlesEqual( value, size ), begin, end, results );
+          break;
+        case sizeof(MBEntityHandle):
+          find_tag_values( TagOneHandleEqual( value ), begin, end, results );
+          break;
+        default:
+          find_tag_values( TagHandlesEqual( value, size ), begin, end, results );
+          break;
+      break;
+    default:
+      if (tag_info.get_size() == MB_VARIABLE_LENGTH)
+        find_tag_values( TagVarBytesEqual( value, size ), begin, end, results );
+      else
+        find_tag_values( TagBytesEqual( value, size ), begin, end, results );
+      break;
+/** Iterator to use in find_tag_values_equal for arrays of data */
+class ByteArrayIterator
+  private:
+    size_t step;
+    typedef std::pair<MBEntityHandle, const char*> data_type;
+    data_type data;
+  public:
+    ByteArrayIterator( MBEntityHandle start_handle,
+                       const void* data_array,
+                       size_t tag_size )
+      : step(tag_size),
+        data(start_handle, reinterpret_cast<const char*>(data_array))
+                       const TagInfo& tag_info )
+      : step(tag_info.get_size() == MB_VARIABLE_LENGTH ? sizeof(VarLenTag) : tag_info.get_size()),
+    bool operator==( const ByteArrayIterator& other ) const
+      { return data.first == other.data.first; }
+    bool operator!=( const ByteArrayIterator& other ) const
+      { return data.first != other.data.first; }
+    ByteArrayIterator& operator++()
+      { ++data.first; data.second += step; return *this; }
+    ByteArrayIterator operator++(int)
+      { ByteArrayIterator result(*this); operator++(); return result; }
+    ByteArrayIterator& operator--()
+      { --data.first; data.second -= step; return *this; }
+    ByteArrayIterator operator--(int)
+      { ByteArrayIterator result(*this); operator--(); return result; }
+    ByteArrayIterator& operator+=(size_t amt)
+      { data.first += amt; data.second += amt*step; return *this; }
+    ByteArrayIterator& operator-=(size_t amt)
+      { data.first -= amt; data.second -= amt*step; return *this; }
+    MBEntityHandle operator-( const ByteArrayIterator& other ) const
+      { return data.first - other.data.first; }
+    const data_type& operator*() const
+      { return data; }
+    const data_type* operator->() const
+      { return &data; }
+#endif
Modified: MOAB/trunk/TagServer.cpp
--- MOAB/trunk/TagServer.cpp	2008-01-14 19:48:15 UTC (rev 1520)
+++ MOAB/trunk/TagServer.cpp	2008-01-14 19:50:39 UTC (rev 1521)
@@ -759,19 +759,27 @@
 MBErrorCode TagServer::get_entities_with_tag_value( const MBEntityType type,
-                                                     const MBTag tag_handle,
-                                                     const void* value,
-                                                     MBRange &entities )
+                                                    const MBTag tag_handle,
+                                                    int value_size )
   MBErrorCode result = MB_TAG_NOT_FOUND;
   MBTagId id = ID_FROM_TAG_HANDLE(tag_handle);
+  const TagInfo* info = get_tag_info( tag_handle );
+  if (!info)
+    return MB_TAG_NOT_FOUND;
+  if (!value_size && info->get_size() != MB_VARIABLE_LENGTH)
+    value_size = info->get_size();
   switch (PROP_FROM_TAG_HANDLE(tag_handle)) {
     case MB_TAG_SPARSE:
-      result = mSparseData->get_entities_with_tag_value(id, type, entities, value);
+      result = mSparseData->get_entities_with_tag_value(id, *info, type, entities, value, value_size);
       break;
     case MB_TAG_DENSE:
-      result = sequenceManager->get_entities_with_tag_value(id, type, entities, value);
+      result = sequenceManager->get_entities_with_tag_value(id, *info, type, entities, value, value_size);
       break;
     case MB_TAG_BIT:
       result = mBitServer->get_entities_with_tag_value(id, type,
@@ -790,17 +798,25 @@
                                                     const void* value,
+                                                    int value_size )
+  if (!info)
     case MB_TAG_SPARSE:
-      result = mSparseData->get_entities_with_tag_value(range, id, type, entities, value);
+      result = mSparseData->get_entities_with_tag_value(range, id, *info, type, entities, value, value_size);
       break;
     case MB_TAG_DENSE:
-      result = sequenceManager->get_entities_with_tag_value(range, id, type, entities, value);
+      result = sequenceManager->get_entities_with_tag_value(range, id, *info, type, entities, value, value_size);
       break;
     case MB_TAG_BIT:
       result = mBitServer->get_entities_with_tag_value(range, id, type,
Modified: MOAB/trunk/TagServer.hpp
--- MOAB/trunk/TagServer.hpp	2008-01-14 19:48:15 UTC (rev 1520)
+++ MOAB/trunk/TagServer.hpp	2008-01-14 19:50:39 UTC (rev 1521)
@@ -132,14 +132,16 @@
   MBErrorCode get_entities_with_tag_value( const MBEntityType type,
                                             const void* value,
-                                            MBRange &entities );
+                                            int value_size = 0 );
   MBErrorCode get_entities_with_tag_value( const MBRange &input_range,
                                             const void* value,
   MBErrorCode get_entities_with_tag_values( const MBRange &input_range,
Modified: MOAB/trunk/VarLenTag.hpp
--- MOAB/trunk/VarLenTag.hpp	2008-01-14 19:48:15 UTC (rev 1520)
+++ MOAB/trunk/VarLenTag.hpp	2008-01-14 19:50:39 UTC (rev 1521)
@@ -196,19 +196,19 @@
   mData.mPointer.size = 0;
-inline VarLenTag( const VarLenTag& copy )
+inline VarLenTag::VarLenTag( const VarLenTag& copy )
   : VarLenTagData( copy )
-#ifdef
+#ifdef VAR_LEN_TAG_ELIDE_DATA
   if (size() > INLINE_COUNT)
 #endif
-    copy.mData.mPointer.array = reinterpret_cast<unsigned char*>(malloc(size()));
+    mData.mPointer.array = reinterpret_cast<unsigned char*>(malloc(size()));
     memcpy( copy.mData.mPointer.array, mData.mPointer.array, size() );
-inline VarLenTag( unsigned size, void* data )
+inline VarLenTag::VarLenTag( unsigned size, void* data )
   if (size)
