[MOAB-dev] r1520 - MOAB/trunk
kraftche at mcs.anl.gov
Mon Jan 14 13:48:15 CST 2008
Author: kraftche
Date: 2008-01-14 13:48:15 -0600 (Mon, 14 Jan 2008)
New Revision: 1520
Modified:
MOAB/trunk/MBTest.cpp
Log:
update for new error codes: replace switch on error code with call to MBCore::get_error_string
Modified: MOAB/trunk/MBTest.cpp
--- MOAB/trunk/MBTest.cpp 2008-01-14 19:13:42 UTC (rev 1519)
+++ MOAB/trunk/MBTest.cpp 2008-01-14 19:48:15 UTC (rev 1520)
@@ -5733,22 +5733,7 @@
else if (MB_FAILURE == error)
std::cout << "Failure" << std::endl;
else {
- std::cout << "Failed: ";
- switch (error) {
- case MB_INDEX_OUT_OF_RANGE: std::cout << "Index out of range"; break;
- case MB_TYPE_OUT_OF_RANGE: std::cout << "Type out of range"; break;
- case MB_MEMORY_ALLOCATION_FAILED: std::cout << "Mem. Alloc. Failed"; break;
- case MB_ENTITY_NOT_FOUND: std::cout << "Entity Not Found"; break;
- case MB_MULTIPLE_ENTITIES_FOUND: std::cout << "Multiple Ents. Found"; break;
- case MB_TAG_NOT_FOUND: std::cout << "Tag Not Found"; break;
- case MB_FILE_DOES_NOT_EXIST: std::cout << "File doesn't exist"; break;
- case MB_FILE_WRITE_ERROR: std::cout << "File Write Error"; break;
- case MB_NOT_IMPLEMENTED: std::cout << "Not implemented error";break;
- case MB_ALREADY_ALLOCATED: std::cout << "Already Allocated"; break;
- // these instead of default so gcc warns of unhandled error code
- case MB_FAILURE: case MB_SUCCESS: break;
- std::cout << std::endl;
+ std::cout << "Failed: " << moab.get_error_string( error ) << std::endl;
if (MB_SUCCESS != error) {
