[MOAB-dev] r1518 - MOAB/trunk
kraftche at mcs.anl.gov kraftche at mcs.anl.gov
Mon Jan 14 13:09:31 CST 2008
Author: kraftche
Date: 2008-01-14 13:09:31 -0600 (Mon, 14 Jan 2008)
New Revision: 1518
Added:
   MOAB/trunk/TagInfo.cpp
   MOAB/trunk/TagInfo.hpp
Modified:
   MOAB/trunk/Makefile.am
   MOAB/trunk/TagServer.cpp
   MOAB/trunk/TagServer.hpp
Log:
Separate TagInfo source from TagServer source
Modified: MOAB/trunk/Makefile.am
--- MOAB/trunk/Makefile.am	2008-01-14 19:07:07 UTC (rev 1517)
+++ MOAB/trunk/Makefile.am	2008-01-14 19:09:31 UTC (rev 1518)
@@ -164,6 +164,8 @@
   SparseTagCollections.hpp \
   StructuredElementSeq.cpp \
   StructuredElementSeq.hpp \
+  TagInfo.cpp \
+  TagInfo.hpp \
   TagServer.cpp \
   TagServer.hpp \
   Tqdcfr.cpp \
Added: MOAB/trunk/TagInfo.cpp
--- MOAB/trunk/TagInfo.cpp	                        (rev 0)
+++ MOAB/trunk/TagInfo.cpp	2008-01-14 19:09:31 UTC (rev 1518)
@@ -0,0 +1,24 @@
+#include "TagInfo.hpp"
+int TagInfo::size_from_data_type( MBDataType t )
+  static const int sizes[] = { 1,
+                               sizeof(int),
+                               sizeof(double),
+                               1,
+                               sizeof(MBEntityHandle),
+                               0 };
+   return sizes[t];
+void TagInfo::invalidate()
+  mTagName.clear();
+  isValid = false;
+  delete [] mDefaultValue;
+  mDefaultValue = 0;
+  delete [] mMeshValue;
+  mMeshValue = 0;
Added: MOAB/trunk/TagInfo.hpp
--- MOAB/trunk/TagInfo.hpp	                        (rev 0)
+++ MOAB/trunk/TagInfo.hpp	2008-01-14 19:09:31 UTC (rev 1518)
@@ -0,0 +1,174 @@
+#ifndef TAG_INFO_HPP
+#define TAG_INFO_HPP
+#include "MBTypes.h"
+#include <string>
+#include <string.h>
+// ! stores information about a tag
+class TagInfo
+public:
+  //! constructor
+  TagInfo() : mTagName(""),
+              mDataSize(0),
+              isValid(false),
+              mDefaultValue(NULL),
+              mMeshValue(NULL),
+              dataType(MB_TYPE_OPAQUE)
+  //! destructor
+  inline ~TagInfo();
+  //! copy constructor
+  inline TagInfo(const TagInfo&);
+  //! constructor that takes all parameters
+  inline TagInfo(const char *, int, MBDataType type, const void *);
+  //! assignment operator
+  inline TagInfo &operator=(const TagInfo &rhs);
+  //! set the name of the tag
+  void set_name( const std::string& name) { mTagName = name; }
+  //! set the size of the data
+  void set_size( const int size ) { mDataSize = size; }
+  //! get the name of the tag
+  const std::string& get_name() const { return mTagName; }
+  //! get the size of the data
+  int get_size() const { return mDataSize; }
+    //! get the default data
+  const void *default_value() const  { return mDefaultValue;}
+    //! set mesh value
+  void set_mesh_value( const void* data );
+    //! get mesh value
+  const void* get_mesh_value() const { return mMeshValue; }
+    //! remove mesh value
+  void remove_mesh_value();
+  inline MBDataType get_data_type() const     { return dataType; }
+  inline void set_data_type( MBDataType t )   { dataType = t; }
+  static int size_from_data_type( MBDataType t );
+  bool is_valid() const { return isValid; }
+  void invalidate();
+private:
+  MBErrorCode reserve_mesh_tag_id( int& id_out );
+  //! stores the tag name
+  std::string mTagName;
+  //! stores the size of the data for this tag
+  unsigned short mDataSize;
+  //! flag to mark unused entries
+  bool isValid;
+  //! stores the default data, if any
+  unsigned char *mDefaultValue;
+  //! store the mesh value, if any
+  unsigned char *mMeshValue;
+  //! type of tag data
+  MBDataType dataType;
+inline TagInfo::TagInfo(const TagInfo& copy)
+  : mTagName( copy.mTagName ),
+    mDataSize( copy.mDataSize ),
+    isValid( copy.isValid ),
+    mDefaultValue( 0 ),
+    mMeshValue( 0 ),
+    dataType( copy.dataType )
+  if (copy.mDefaultValue) {
+    mDefaultValue = new unsigned char[mDataSize];
+    memcpy(mDefaultValue, copy.mDefaultValue, mDataSize);
+  if (copy.mMeshValue) {
+    mMeshValue = new unsigned char[mDataSize];
+    memcpy(mMeshValue, copy.mMeshValue, mDataSize);
+inline TagInfo::TagInfo( const char* name,
+                         int size,
+                         MBDataType type,
+                         const void* default_value)
+ : mTagName( name ),
+   mDataSize( size ),
+   isValid( true ),
+   mMeshValue( 0 ),
+   dataType( type )
+  if (default_value) {
+    mDefaultValue = new unsigned char[size];
+    memcpy(mDefaultValue, default_value, size);
+inline TagInfo &TagInfo::operator=(const TagInfo &rhs)
+  mTagName = rhs.mTagName;
+  mDataSize = rhs.mDataSize;
+  isValid = rhs.isValid;
+  mMeshValue = 0;
+  if (rhs.mDefaultValue) {
+    memcpy( mDefaultValue, rhs.mDefaultValue, mDataSize );
+  if (rhs.mMeshValue) {
+    memcpy( mMeshValue, rhs.mMeshValue, mDataSize );
+  return *this;
+inline TagInfo::~TagInfo()
+  // clean up default value
+inline void TagInfo::set_mesh_value( const void* data )
+  if (!mMeshValue)
+  memcpy( mMeshValue, data, mDataSize );
+inline void TagInfo::remove_mesh_value()
+  mMeshValue = 0;
+#endif
Modified: MOAB/trunk/TagServer.cpp
--- MOAB/trunk/TagServer.cpp	2008-01-14 19:07:07 UTC (rev 1517)
+++ MOAB/trunk/TagServer.cpp	2008-01-14 19:09:31 UTC (rev 1518)
@@ -46,28 +46,6 @@
 #include "SequenceManager.hpp"
 using namespace std;
-int TagInfo::size_from_data_type( MBDataType t )
-  static const int sizes[] = { 1,
-                               sizeof(int),
-                               sizeof(double),
-                               1,
-                               sizeof(MBEntityHandle),
-                               0 };
-   return sizes[t];
-void TagInfo::invalidate()
-  mTagName.clear();
-  isValid = false;
-  delete [] mDefaultValue;
-  mDefaultValue = 0;
-  delete [] mMeshValue;
-  mMeshValue = 0;
Modified: MOAB/trunk/TagServer.hpp
--- MOAB/trunk/TagServer.hpp	2008-01-14 19:07:07 UTC (rev 1517)
+++ MOAB/trunk/TagServer.hpp	2008-01-14 19:09:31 UTC (rev 1518)
@@ -40,96 +40,13 @@
 #include "MBInternals.hpp"
 class MBRange;
 class SparseTagSuperCollection;
 class SequenceManager;
 class MBBitServer;
-// ! stores information about a tag
-class TagInfo
-public:
-  //! constructor
-  TagInfo() : mTagName(""),
-              mDataSize(0),
-              isValid(false),
-              mDefaultValue(NULL),
-              mMeshValue(NULL),
-              dataType(MB_TYPE_OPAQUE)
-  //! destructor
-  inline ~TagInfo();
-  //! copy constructor
-  inline TagInfo(const TagInfo&);
-  //! constructor that takes all parameters
-  inline TagInfo(const char *, int, MBDataType type, const void *);
-  //! assignment operator
-  inline TagInfo &operator=(const TagInfo &rhs);
-  //! set the name of the tag
-  void set_name( const std::string& name) { mTagName = name; }
-  //! set the size of the data
-  void set_size( const int size ) { mDataSize = size; }
-  //! get the name of the tag
-  const std::string& get_name() const { return mTagName; }
-  //! get the size of the data
-  int get_size() const { return mDataSize; }
-    //! get the default data
-  const void *default_value() const  { return mDefaultValue;}
-    //! set mesh value
-  void set_mesh_value( const void* data );
-    //! get mesh value
-  const void* get_mesh_value() const { return mMeshValue; }
-    //! remove mesh value
-  void remove_mesh_value();
-  inline MBDataType get_data_type() const     { return dataType; }
-  inline void set_data_type( MBDataType t )   { dataType = t; }
-  static int size_from_data_type( MBDataType t );
-  bool is_valid() const { return isValid; }
-  void invalidate();
-private:
-  MBErrorCode reserve_mesh_tag_id( int& id_out );
-  //! stores the tag name
-  std::string mTagName;
-  //! stores the size of the data for this tag
-  unsigned short mDataSize;
-  //! flag to mark unused entries
-  bool isValid;
-  //! stores the default data, if any
-  unsigned char *mDefaultValue;
-  //! store the mesh value, if any
-  unsigned char *mMeshValue;
-  //! type of tag data
-  MBDataType dataType;
 //! SparseTagServer class which associates tag data with entities
 class TagServer
@@ -294,89 +211,6 @@
-inline TagInfo::TagInfo(const TagInfo& copy)
-  : mTagName( copy.mTagName ),
-    mDataSize( copy.mDataSize ),
-    isValid( copy.isValid ),
-    mDefaultValue( 0 ),
-    mMeshValue( 0 ),
-    dataType( copy.dataType )
-  if (copy.mDefaultValue) {
-    mDefaultValue = new unsigned char[mDataSize];
-    memcpy(mDefaultValue, copy.mDefaultValue, mDataSize);
-  if (copy.mMeshValue) {
-    mMeshValue = new unsigned char[mDataSize];
-    memcpy(mMeshValue, copy.mMeshValue, mDataSize);
-inline TagInfo::TagInfo( const char* name,
-                         int size,
-                         MBDataType type,
-                         const void* default_value)
- : mTagName( name ),
-   mDataSize( size ),
-   isValid( true ),
-   mMeshValue( 0 ),
-   dataType( type )
-  if (default_value) {
-    mDefaultValue = new unsigned char[size];
-    memcpy(mDefaultValue, default_value, size);
-inline TagInfo &TagInfo::operator=(const TagInfo &rhs)
-  mTagName = rhs.mTagName;
-  mDataSize = rhs.mDataSize;
-  isValid = rhs.isValid;
-  mMeshValue = 0;
-  if (rhs.mDefaultValue) {
-    memcpy( mDefaultValue, rhs.mDefaultValue, mDataSize );
-  if (rhs.mMeshValue) {
-    memcpy( mMeshValue, rhs.mMeshValue, mDataSize );
-  return *this;
-inline TagInfo::~TagInfo()
-  // clean up default value
-inline void TagInfo::set_mesh_value( const void* data )
-  if (!mMeshValue)
-  memcpy( mMeshValue, data, mDataSize );
-inline void TagInfo::remove_mesh_value()
-  mMeshValue = 0;
 inline const TagInfo* TagServer::get_tag_info( const char *tag_name ) const
   const MBTag handle = get_handle( tag_name );
