[MOAB-dev] r1517 - MOAB/trunk
kraftche at mcs.anl.gov
Mon Jan 14 13:07:07 CST 2008
Author: kraftche
Date: 2008-01-14 13:07:07 -0600 (Mon, 14 Jan 2008)
New Revision: 1517
Modified:
MOAB/trunk/MBCore.cpp
MOAB/trunk/MBTypes.h
Log:
Add new error codes: MB_INVALID_SIZE and MB_VARIABLE_LENGTH_DATA, and new constant MB_VARIABLE_LENGTH
Modified: MOAB/trunk/MBCore.cpp
--- MOAB/trunk/MBCore.cpp 2008-01-14 19:05:55 UTC (rev 1516)
+++ MOAB/trunk/MBCore.cpp 2008-01-14 19:07:07 UTC (rev 1517)
@@ -90,6 +90,8 @@
"MB_FILE_WRITE_ERROR",
"MB_NOT_IMPLEMENTED",
"MB_ALREADY_ALLOCATED",
+ "MB_VARIABLE_DATA_LENGTH",
+ "MB_INVALID_SIZE",
"MB_FAILURE",
Modified: MOAB/trunk/MBTypes.h
--- MOAB/trunk/MBTypes.h 2008-01-14 19:05:55 UTC (rev 1516)
+++ MOAB/trunk/MBTypes.h 2008-01-14 19:07:07 UTC (rev 1517)
@@ -50,8 +50,15 @@
MB_FILE_WRITE_ERROR,
MB_NOT_IMPLEMENTED,
MB_ALREADY_ALLOCATED,
+ MB_VARIABLE_DATA_LENGTH,
+ MB_INVALID_SIZE,
MB_FAILURE};
+/** Misc. integer constants, declared in enum for portability */
+enum MBConstants {
+ MB_VARIABLE_LENGTH = -1 /**< Length value for variable-length tags */
/** Specify storage type for tags. See MOAB users guide for more information. */
enum MBTagType {
MB_TAG_BIT = 0, /**< size measured in bits instead of bytes, otherwise identical to sparse */
