[MOAB-dev] r1627 - MOAB/trunk/parallel
tautges at mcs.anl.gov
Fri Feb 29 12:47:17 CST 2008
Author: tautges
Date: 2008-02-29 12:47:12 -0600 (Fri, 29 Feb 2008)
New Revision: 1627
Modified:
MOAB/trunk/parallel/MBParallelComm.cpp
MOAB/trunk/parallel/MBParallelComm.hpp
MOAB/trunk/parallel/gs.c
MOAB/trunk/parallel/types.h
Log:
Changed parallel communication to not require that entities be restored remotely with the same handles as the sending proc. Adding RangeMap (from Jason) for mapping between ranges of handles.
Also added resolution of vertex handles on remote processors when finding shared vertices.
Modified: MOAB/trunk/parallel/MBParallelComm.cpp
--- MOAB/trunk/parallel/MBParallelComm.cpp 2008-02-29 18:46:32 UTC (rev 1626)
+++ MOAB/trunk/parallel/MBParallelComm.cpp 2008-02-29 18:47:12 UTC (rev 1627)
@@ -12,6 +12,7 @@
#include "MBError.hpp"
#include "ElementSequence.hpp"
#include "MBCN.hpp"
+#include "RangeMap.hpp"
#include <iostream>
@@ -362,11 +363,12 @@
if (myBuffer.capacity() == 0) return MB_FAILURE;
unsigned char *buff_ptr = &myBuffer[0];
- MBErrorCode result = unpack_entities(buff_ptr, entities);
+ HandleMap handle_map;
+ MBErrorCode result = unpack_entities(buff_ptr, entities, handle_map);
RRA("Unpacking entities failed.");
- result = unpack_sets(buff_ptr, entities);
+ result = unpack_sets(buff_ptr, entities, handle_map);
RRA("Unpacking sets failed.");
- result = unpack_tags(buff_ptr, entities);
+ result = unpack_tags(buff_ptr, entities, handle_map);
RRA("Unpacking tags failed.");
return MB_SUCCESS;
@@ -556,7 +558,8 @@
MBErrorCode MBParallelComm::unpack_entities(unsigned char *&buff_ptr,
- MBRange &entities)
+ MBRange &entities,
+ HandleMap &handle_map)
MBErrorCode result;
bool done = false;
@@ -583,69 +586,67 @@
// unpack coords
int num_verts = this_range.size();
std::vector<double*> coords(3);
- for (MBRange::const_pair_iterator pit = this_range.const_pair_begin();
- pit != this_range.const_pair_end(); pit++) {
- // allocate handles
- int start_id = mbImpl->handle_utils().id_from_handle((*pit).first);
- int start_proc = mbImpl->handle_utils().rank_from_handle((*pit).first);
- MBEntityHandle actual_start;
- int tmp_num_verts = (*pit).second - (*pit).first + 1;
- result = ru->get_node_arrays(3, tmp_num_verts, start_id, start_proc, actual_start,
- coords);
- RR("Failed to allocate node arrays.");
+ MBEntityHandle actual_start;
+ result = ru->get_node_arrays(3, num_verts, 0, proc_config().proc_rank(),
+ actual_start, coords);
+ RR("Failed to allocate node arrays.");
+ entities.insert(actual_start, actual_start+num_verts-1);
+ // unpack the buffer data directly into coords
+ for (int i = 0; i < 3; i++)
+ memcpy(coords[i], buff_ptr+i*num_verts*sizeof(double),
+ num_verts*sizeof(double));
+ buff_ptr += 3*num_verts * sizeof(double);
- if (actual_start != (*pit).first)
- RR("Warning: actual vertex handle different from requested handle in unpack_entities.");
- entities.insert((*pit).first, (*pit).second);
- // unpack the buffer data directly into coords
- for (int i = 0; i < 3; i++)
- memcpy(coords[i], buff_ptr+i*num_verts*sizeof(double),
- tmp_num_verts*sizeof(double));
- buff_ptr += tmp_num_verts * sizeof(double);
- // increment the buffer ptr beyond the y and z coords
- buff_ptr += 2 * num_verts * sizeof(double);
+ // pack the range map to map from source to local handles
+ pack_range_map(this_range, actual_start, handle_map);
else {
int verts_per_entity;
// unpack the nodes per entity
UNPACK_INT(buff_ptr, verts_per_entity);
+ int num_elems = this_range.size();
+ MBEntityHandle *connect;
+ result = ru->get_element_array(num_elems, verts_per_entity, this_type,
+ 0, proc_config().proc_rank(), actual_start,
+ connect);
+ RR("Failed to allocate element arrays.");
// unpack the connectivity
- // allocate handles, connect arrays
- int num_elems = (*pit).second - (*pit).first + 1;
- MBEntityHandle *connect;
- result = ru->get_element_array(num_elems, verts_per_entity, this_type,
- start_id, start_proc, actual_start,
- connect);
- RR("Failed to allocate element arrays.");
- RR("Warning: actual entity handle different from requested handle in unpack_entities.");
+ UNPACK_EH(buff_ptr, connect, (num_elems*verts_per_entity));
+ entities.insert(actual_start, actual_start+num_elems);
- // copy connect arrays
- UNPACK_EH(buff_ptr, connect, (num_elems*verts_per_entity));
+ // change the connectivity to be in terms of local handles
+ for (int i = 0; i < verts_per_entity*num_elems; i++) {
+ connect[i] = handle_map.find(connect[i]);
+ assert(0 != connect[i]);
+ // pack the range map for these elems
return MB_SUCCESS;
+MBErrorCode MBParallelComm::pack_range_map(MBRange &key_range, MBEntityHandle val_start,
+ for (MBRange::const_pair_iterator key_it = key_range.const_pair_begin();
+ key_it != key_range.const_pair_end(); key_it++) {
+ int tmp_num = (*key_it).second - (*key_it).first + 1;
+ handle_map.insert((*key_it).first, val_start, tmp_num);
+ val_start += tmp_num;
+ return MB_SUCCESS;
MBErrorCode MBParallelComm::pack_sets(MBRange &entities,
MBRange::const_iterator &start_rit,
MBRange &whole_range,
@@ -702,19 +703,20 @@
else {
+ // set handle range
+ PACK_RANGE(buff_ptr, setRange);
+ // option values
+ PACK_VOID(buff_ptr, &optionsVec[0], setRange.size()*sizeof(unsigned int));
std::vector<unsigned int>::const_iterator opt_it = optionsVec.begin();
std::vector<MBRange>::const_iterator rit = setRanges.begin();
std::vector<int>::const_iterator mem_it = setSizes.begin();
static std::vector<MBEntityHandle> members;
- // set handle range
- PACK_RANGE(buff_ptr, setRange);
for (MBRange::const_iterator set_it = setRange.begin(); set_it != setRange.end();
set_it++, opt_it++) {
- // option value
- PACK_VOID(buff_ptr, &(*opt_it), sizeof(unsigned int));
if ((*opt_it) & MESHSET_SET) {
// pack entities as a range
PACK_RANGE(buff_ptr, (*rit));
@@ -729,10 +731,7 @@
PACK_EH(buff_ptr, &members[0], *mem_it);
mem_it++;
- for (MBRange::const_iterator set_it = setRange.begin(); set_it != setRange.end();
- set_it++, opt_it++) {
// pack parents
members.clear();
result = mbImpl->get_parent_meshsets(*set_it, members);
@@ -760,61 +759,76 @@
MBErrorCode MBParallelComm::unpack_sets(unsigned char *&buff_ptr,
// now the sets; assume any sets the application wants to pass are in the entities list
MBErrorCode result;
- std::vector<unsigned int>::const_iterator opt_it = optionsVec.begin();
- std::vector<MBRange>::const_iterator rit = setRanges.begin();
- std::vector<int>::const_iterator mem_it = setSizes.begin();
MBRange set_handles, new_sets;
UNPACK_RANGE(buff_ptr, set_handles);
int num_ents;
+ optionsVec.resize(set_handles.size());
+ // option value
+ UNPACK_VOID(buff_ptr, &optionsVec[0], set_handles.size()*sizeof(unsigned int));
- // unpack set contents before parent/child relations, to make sure
- // sets exist before being referenced
- for (MBRange::const_iterator rit = set_handles.begin();
- rit != set_handles.end(); rit++) {
+ // create sets
+ unsigned int i;
+ MBRange::const_iterator rit;
+ for (rit = set_handles.begin(), i = 0;
+ rit != set_handles.end(); rit++, i++) {
- // option value
- unsigned int opt;
- UNPACK_VOID(buff_ptr, &opt, sizeof(unsigned int));
// create the set
- MBEntityHandle set_handle = *rit;
- result = sequenceManager->allocate_mesh_set(set_handle, opt);
+ MBEntityHandle set_handle;
+ result = mbImpl->create_meshset(optionsVec[i], set_handle);
RR("Failed to create set in unpack.");
new_sets.insert(set_handle);
- if (opt & MESHSET_SET) {
+ // make sure new sets handles are contiguous
+ assert(*new_sets.rbegin() - *new_sets.begin() + 1 == new_sets.size());
+ pack_range_map(set_handles, *new_sets.begin(), handle_map);
+ // now unpack entities and parent/child links; can go through new_sets in same
+ // order as set_handles, since they were created contiguously and set_handles
+ // were iterated as a range
+ for (rit = new_sets.begin(), i = 0; rit != new_sets.end(); rit++, i++) {
+ if (optionsVec[i] & MESHSET_SET) {
// unpack entities as a range
- MBRange set_range;
- UNPACK_RANGE(buff_ptr, set_range);
+ MBRange set_range, tmp_range;
+ UNPACK_RANGE(buff_ptr, tmp_range);
+ for (MBRange::iterator rit2 = tmp_range.begin(); rit2 != tmp_range.end(); rit2++) {
+ MBEntityHandle tmp_ent = handle_map.find(*rit2);
+ assert(0 != tmp_ent);
+ set_range.insert(tmp_ent);
result = mbImpl->add_entities(*rit, set_range);
RR("Failed to add ents to set in unpack.");
- else if (opt & MESHSET_ORDERED) {
+ else if (optionsVec[i] & MESHSET_ORDERED) {
// unpack entities as vector, with length
UNPACK_INT(buff_ptr, num_ents);
members.resize(num_ents);
UNPACK_EH(buff_ptr, &members[0], num_ents);
+ for (int j = 0; j < num_ents; j++) {
+ members[j] = handle_map.find(members[j]);
+ assert(0 != members[j]);
result = mbImpl->add_entities(*rit, &members[0], num_ents);
RR("Failed to add ents to ordered set in unpack.");
- // now unpack parent/child links
// unpack parents/children
for (int i = 0; i < num_ents; i++) {
+ members[i] = handle_map.find(members[i]);
+ assert(0 != members[i]);
result = mbImpl->add_parent_meshset(*rit, members[i]);
RR("Failed to add parent to set in unpack.");
@@ -822,6 +836,8 @@
result = mbImpl->add_child_meshset(*rit, members[i]);
RR("Failed to add child to set in unpack.");
@@ -883,21 +899,15 @@
if (0 == this_count) continue;
// ok, we'll be sending this tag
+ allTags.push_back(*tag_it);
- // tag handle
- allTags.push_back(*tag_it);
- count += sizeof(MBTag);
// default value
count += sizeof(int);
if (NULL != tinfo->default_value()) count += tinfo->get_size();
- // size, data type
- count += sizeof(int);
+ // size, type, data type
+ count += 3*sizeof(int);
- // data type
- count += sizeof(MBDataType);
// name
count += 64;
@@ -925,11 +935,11 @@
const TagInfo *tinfo = tagServer->get_tag_info(*tag_it);
- // tag handle
- PACK_EH(buff_ptr, &(*tag_it), 1);
PACK_INT(buff_ptr, tinfo->get_size());
+ MBTagType this_type;
+ result = mbImpl->tag_get_type(*tag_it, this_type);
+ PACK_INT(buff_ptr, this_type);
PACK_INT(buff_ptr, tinfo->get_data_type());
// default value
@@ -959,7 +969,8 @@
MBErrorCode MBParallelComm::unpack_tags(unsigned char *&buff_ptr,
// tags
// get all the tags
@@ -971,16 +982,17 @@
int num_tags;
UNPACK_INT(buff_ptr, num_tags);
std::vector<int> tag_data;
+ std::vector<MBEntityHandle> tag_ents;
for (int i = 0; i < num_tags; i++) {
// tag handle
MBTag tag_handle;
- UNPACK_EH(buff_ptr, &tag_handle, 1);
// size, data type
- int tag_size, tag_data_type;
+ int tag_size, tag_data_type, tag_type;
UNPACK_INT(buff_ptr, tag_size);
+ UNPACK_INT(buff_ptr, tag_type);
UNPACK_INT(buff_ptr, tag_data_type);
// default value
@@ -997,26 +1009,21 @@
buff_ptr += 64;
// create the tag
- MBTagType tag_type;
- result = mbImpl->tag_get_type(tag_handle, tag_type);
- RR("Failed to get tag type in unpack_tags.");
- result = mbImpl->tag_create(tag_name, tag_size, tag_type,
+ result = mbImpl->tag_create(tag_name, tag_size, (MBTagType) tag_type,
(MBDataType) tag_data_type, tag_handle,
def_val_ptr);
if (MB_ALREADY_ALLOCATED == result) {
// already allocated tag, check to make sure it's the same size, type, etc.
const TagInfo *tag_info = tagServer->get_tag_info(tag_name);
+ result = mbImpl->tag_get_type(tag_handle, this_type);
if (tag_size != tag_info->get_size() ||
+ tag_type != this_type ||
tag_data_type != tag_info->get_data_type() ||
(def_val_ptr && !tag_info->default_value() ||
!def_val_ptr && tag_info->default_value())) {
RR("Didn't get correct tag info when unpacking tag.");
- MBTagType this_type;
- result = mbImpl->tag_get_type(tag_handle, this_type);
- if (MB_SUCCESS != result || this_type != tag_type) {
- RR("Didn't get correct tag type when unpacking tag.");
else if (MB_SUCCESS != result) return result;
@@ -1024,7 +1031,28 @@
// values, as those aren't sent
MBRange tag_range;
UNPACK_RANGE(buff_ptr, tag_range);
- result = mbImpl->tag_set_data(tag_handle, tag_range, buff_ptr);
+ // if it's a handle type, need to convert handles to local values
+ if (MB_TYPE_HANDLE == tag_type) {
+ int *tag_vals = (int*) buff_ptr;
+ for (unsigned int i = 0; i < tag_range.size(); i++) {
+ if (0 != tag_vals[i]) {
+ tag_vals[i] = handle_map.find(tag_vals[i]);
+ assert(0 != tag_vals[i]);
+ // also need to convert the actual entities on which the tag is set
+ tag_ents.resize(tag_range.size());
+ std::vector<MBEntityHandle>::iterator vit = tag_ents.begin();
+ for (MBRange::iterator rit = tag_range.begin(); rit != tag_range.end(); rit++, vit++) {
+ *vit = handle_map.find(*rit);
+ assert(0 != *vit);
+ result = mbImpl->tag_set_data(tag_handle, &tag_ents[0],
+ tag_range.size(), buff_ptr);
RR("Trouble setting range-based tag data when unpacking tag.");
buff_ptr += tag_range.size() * tag_size;
@@ -1173,7 +1201,7 @@
gs_data *gsd;
if (sizeof(int) != sizeof(long)) {
std::vector<long> lgid_data(gid_data.size());
- std::copy(gid_data.begin(), gid_data.end(), std::back_inserter(lgid_data));
+ std::copy(gid_data.begin(), gid_data.end(), lgid_data.begin());
gsd = gs_data_setup(skin_ents[0].size(), &lgid_data[0], (ulong_*)&handle_vec[0], 2,
1, 1, cd);
@@ -1569,7 +1597,7 @@
if (0 != sharedproc_tag) {
result = mbImpl->get_entities_by_type(0, this_type, tmp_ents);
RR("Trouble getting entities for shared entities.");
- proc_tags.resize(2*tmp_ents.size());
+ proc_tags.resize(tmp_ents.size());
if (!tmp_ents.empty()) {
result = mbImpl->tag_get_data(sharedproc_tag,
tmp_ents, &proc_tags[0]);
@@ -1577,7 +1605,7 @@
int i;
MBRange::iterator rit;
- for (i = 0, rit = tmp_ents.begin(); rit != tmp_ents.end(); i+=2, rit++)
+ for (i = 0, rit = tmp_ents.begin(); rit != tmp_ents.end(); i++, rit++)
if (proc_tags[i] > -1) shared_ents.insert(*rit);
if (0 != sharedprocs_tag) {
Modified: MOAB/trunk/parallel/MBParallelComm.hpp
--- MOAB/trunk/parallel/MBParallelComm.hpp 2008-02-29 18:46:32 UTC (rev 1626)
+++ MOAB/trunk/parallel/MBParallelComm.hpp 2008-02-29 18:47:12 UTC (rev 1627)
@@ -39,6 +39,8 @@
class TagServer;
class SequenceManager;
+template <typename KeyType, typename ValType, ValType NullVal> class RangeMap;
+typedef RangeMap<MBEntityHandle, MBEntityHandle, 0> HandleMap;
class MBParallelComm
@@ -165,7 +167,8 @@
const bool just_count);
MBErrorCode unpack_entities(unsigned char *&buff_ptr,
- MBRange &entities);
+ HandleMap &handle_map);
MBErrorCode pack_sets(MBRange &entities,
@@ -175,7 +178,8 @@
MBErrorCode unpack_sets(unsigned char *&buff_ptr,
MBErrorCode pack_adjacencies(MBRange &entities,
@@ -195,7 +199,8 @@
MBErrorCode unpack_tags(unsigned char *&buff_ptr,
MBErrorCode tag_shared_verts(tuple_list &shared_verts,
MBRange *skin_ents,
@@ -210,6 +215,11 @@
MBErrorCode create_interface_sets(std::map<int, MBRange> &proc_ranges,
std::map<std::vector<int>, MBRange> *proc_nranges);
+ //! pack a range map with keys in this_range and values a contiguous series
+ //! of handles starting at actual_start
+ MBErrorCode pack_range_map(MBRange &this_range, MBEntityHandle actual_start,
//! MB interface associated with this writer
MBInterface *mbImpl;
Modified: MOAB/trunk/parallel/gs.c
--- MOAB/trunk/parallel/gs.c 2008-02-29 18:46:32 UTC (rev 1626)
+++ MOAB/trunk/parallel/gs.c 2008-02-29 18:47:12 UTC (rev 1627)
@@ -427,7 +427,7 @@
nzi[0]=i;
unsigned int j;
for (j = 0; j < nlabels; j++)
- nzl[i*nlabels+j]=label[nlabels*i+j];
+ nzl[j]=label[nlabels*i+j];
for (j = 0; j < nulabels; j++)
nzul[j]=label[nulabels*i+j];
nzi++, nzl+= nlabels, nzul+=nulabels, nonzero.n++;
Modified: MOAB/trunk/parallel/types.h
--- MOAB/trunk/parallel/types.h 2008-02-29 18:46:32 UTC (rev 1626)
+++ MOAB/trunk/parallel/types.h 2008-02-29 18:47:12 UTC (rev 1627)
@@ -17,6 +17,8 @@
# define GLOBAL_INT long long
#elif defined(USE_GLOBAL_LONG)
+#else
+# define GLOBAL_INT long
#endif
/* floating point type to use for everything */
