[MOAB-dev] r1626 - MOAB/trunk
tautges at mcs.anl.gov
Fri Feb 29 12:46:33 CST 2008
Author: tautges
Date: 2008-02-29 12:46:32 -0600 (Fri, 29 Feb 2008)
New Revision: 1626
Added:
MOAB/trunk/RangeMap.hpp
Modified:
MOAB/trunk/MBRange.cpp
MOAB/trunk/MBRange.hpp
MOAB/trunk/Makefile.am
MOAB/trunk/mbparallelcomm_test.cpp
Log:
Changed parallel communication to not require that entities be restored remotely with the same handles as the sending proc. Adding RangeMap (from Jason) for mapping between ranges of handles.
Modified: MOAB/trunk/MBRange.cpp
--- MOAB/trunk/MBRange.cpp 2008-02-28 20:25:04 UTC (rev 1625)
+++ MOAB/trunk/MBRange.cpp 2008-02-29 18:46:32 UTC (rev 1626)
@@ -819,11 +819,19 @@
-MBEntityHandle MBRange::operator[](MBEntityID index) const
+int MBRange::index(MBEntityHandle handle) const
- MBRange::const_iterator i = begin();
- i += index;
- return *i;
+ if (handle < *begin() || handle > *rbegin()) return -1;
+ unsigned int i = 0;
+ MBRange::const_pair_iterator pit = const_pair_begin();
+ while (handle > (*pit).second && pit != const_pair_end()) {
+ i += (*pit).second - (*pit).first + 1;
+ pit++;
+ if (handle < (*pit).first || pit == const_pair_end()) return -1;
+ return i + handle - (*pit).first;
//! return a subset of this range, by type
Modified: MOAB/trunk/MBRange.hpp
--- MOAB/trunk/MBRange.hpp 2008-02-28 20:25:04 UTC (rev 1625)
+++ MOAB/trunk/MBRange.hpp 2008-02-29 18:46:32 UTC (rev 1626)
@@ -330,6 +330,8 @@
MBEntityHandle operator[](MBEntityID index) const;
+ int index(MBEntityHandle handle) const;
MBRange::iterator insert( MBRange::iterator prev,
MBEntityHandle first,
@@ -750,6 +752,13 @@
inline bool operator!=( const MBRange& r1, const MBRange& r2 )
{ return !(r1 == r2); }
+inline MBEntityHandle MBRange::operator[](MBEntityID index) const
+ MBRange::const_iterator i = begin();
+ i += index;
+ return *i;
#endif // MB_RANGE_HPP
Modified: MOAB/trunk/Makefile.am
--- MOAB/trunk/Makefile.am 2008-02-28 20:25:04 UTC (rev 1625)
+++ MOAB/trunk/Makefile.am 2008-02-29 18:46:32 UTC (rev 1626)
@@ -148,6 +148,7 @@
MeshTopoUtil.cpp \
PolyElementSeq.cpp \
PolyElementSeq.hpp \
+ RangeMap.hpp \
ReadGmsh.cpp \
ReadGmsh.hpp \
ReadSTL.cpp \
Copied: MOAB/trunk/RangeMap.hpp (from rev 1624, MOAB/branches/range_map/RangeMap.hpp)
--- MOAB/trunk/RangeMap.hpp (rev 0)
+++ MOAB/trunk/RangeMap.hpp 2008-02-29 18:46:32 UTC (rev 1626)
@@ -0,0 +1,199 @@
+ * MOAB, a Mesh-Oriented datABase, is a software component for creating,
+ * storing and accessing finite element mesh data.
+ * Copyright 2004 Sandia Corporation. Under the terms of Contract
+ * DE-AC04-94AL85000 with Sandia Coroporation, the U.S. Government
+ * retains certain rights in this software.
+ * This library is free software; you can redistribute it and/or
+ * modify it under the terms of the GNU Lesser General Public
+ * License as published by the Free Software Foundation; either
+ * version 2.1 of the License, or (at your option) any later version.
+/**\file RangeMap.hpp
+ *\author Jason Kraftcheck (kraftche at cae.wisc.edu)
+ *\date 2007-04-25
+#ifndef RANGE_MAP_HPP
+#define RANGE_MAP_HPP
+#include <vector>
+#include <algorithm>
+/**\brief Map ranges of values
+ * This class provides a map between ranges of values, such as
+ * a map between file IDs and MBEntityHandles. It is intended
+ * for use in situations where there are relatively few insertions
+ * of large contiguous ranges of values.
+template <typename KeyType, typename ValType, ValType NullVal>
+class RangeMap
+public:
+ struct Range {
+ KeyType begin, count;
+ ValType value;
+ bool operator<( const Range& other ) const
+ { return begin + count <= other.begin; } // equal if overlapping!
+ typedef typename std::vector<Range> RangeList;
+ typedef typename RangeList::const_iterator iterator;
+ /**\brief Insert mapping between range of keys and range of values
+ * Insert mapping from [first_key, first_key+count) to [first_val, first_val+count)
+ * Input range of keys many not overlap any other input range. If it does overlap
+ * an existing range, false is returned and the internal map is not changed.
+ inline iterator insert( KeyType first_key, ValType first_val, KeyType count );
+ /** Find the value corresponding to the specified key. Returns NullVal if not found */
+ inline ValType find( KeyType key ) const;
+ /** Remove a block of values */
+ inline iterator erase( KeyType beg, KeyType count );
+ inline unsigned num_ranges() const { return data.size(); }
+ inline iterator begin() const { return data.begin(); }
+ inline iterator end() const { return data.end(); }
+ inline iterator lower_bound( KeyType key ) const
+ Range b = { key, 1, NullVal };
+ return std::lower_bound( begin(), end(), b );
+ inline iterator upper_bound( KeyType key ) const
+ return std::upper_bound( begin(), end(), b );
+ inline std::pair<iterator,iterator>
+ equal_range( KeyType key ) const
+ return std::equal_range( begin(), end(), b );
+ inline void clear() { data.clear(); }
+protected:
+ RangeList data;
+inline typename RangeMap<KeyType,ValType,NullVal>::iterator
+RangeMap<KeyType,ValType,NullVal>::insert( KeyType first_key, ValType first_val, KeyType count )
+ Range block = { first_key, count, first_val };
+ typename RangeList::iterator i = std::lower_bound( data.begin(), data.end(), block );
+ if (i == data.end()) {
+ if (i != data.begin()) {
+ --i;
+ if (i->begin + i->count == first_key &&
+ i->value + i->count == first_val) {
+ i->count += count;
+ return i;
+ data.push_back( block );
+ return data.end() - 1;
+ if (i->begin < first_key + count)
+ return data.end();
+ if (i->begin == first_key + count &&
+ i->value == first_val + count) {
+ i->begin = first_key;
+ i->value = first_val;
+ count = i->count;
+ --i;
+ ++i;
+ i = data.erase(i);
+ --i;
+ return i;
+ --i;
+ return i;
+ ++i;
+ return data.insert( i, block );
+template <typename KeyType, typename ValType, ValType NullVal> inline
+ValType RangeMap<KeyType,ValType,NullVal>::find( KeyType key ) const
+ Range search = { key, 1, NullVal };
+ typename RangeList::const_iterator i = std::lower_bound( data.begin(), data.end(), search );
+ if (i == data.end() || i->begin > key)
+ return NullVal;
+ return i->value + key - i->begin;
+RangeMap<KeyType,ValType,NullVal>::erase( KeyType key, KeyType count )
+ typename RangeList::iterator i, j;
+ i = std::lower_bound( data.begin(), data.end(), search );
+ return i;
+ if (key > i->begin) {
+ KeyType offset = key - i->begin;
+ // special case - split existing entry
+ if((offset + count) < i->count) {
+ Range ins = { i->begin, offset, i->value };
+ offset += count;
+ i->begin += offset;
+ i->value += offset;
+ i->count -= offset;
+ return data.insert( i, ins ) + 1;
+ // otherwise remove the latter part of i
+ i->count = offset;
+ ++i;
+ // remove any entries entirely convered by the input range
+ for (j = i; j != data.end() && (j->begin + j->count) <= (key + count); ++j);
+ i = data.erase(i,j);
+ // remove beginning of last block
+ if (i != data.end() && (key + count) >= i->begin) {
+ KeyType offset = key + count - i->begin;
+ return i;
+#endif
Modified: MOAB/trunk/mbparallelcomm_test.cpp
--- MOAB/trunk/mbparallelcomm_test.cpp 2008-02-28 20:25:04 UTC (rev 1625)
+++ MOAB/trunk/mbparallelcomm_test.cpp 2008-02-29 18:46:32 UTC (rev 1626)
@@ -74,7 +74,7 @@
<< "=== =====" << std::endl
<< " 1 <linear_ints> <shared_verts> " << std::endl
<< " 2 <n_ints> " << std::endl
- << " 3* <file_name> [<tag_name>=\"MATERIAL_SET\" [tag_val] [distribute=true] ]" << std::endl
+ << " 3* <file_name> [<tag_name>=\"MATERIAL_SET\" [tag_val] [distribute=1] ]" << std::endl
<< "*Note: if opt 3 is used, it must be the last one." << std::endl;
err = MPI_Finalize();
