[MOAB-dev] r2302 - MOAB/trunk/tools/dagmc
Tim Tautges
tautges at mcs.anl.gov
Wed Dec 3 11:42:35 CST 2008
Why is it necessary to know that it's an occ file, e.g. why the brep
file type stuff? Shouldn't this be down in cgm somewhere?
- tim
kraftche at mcs.anl.gov wrote:
> Author: kraftche
> Date: 2008-12-03 11:29:55 -0600 (Wed, 03 Dec 2008)
> New Revision: 2302
> Modified:
> MOAB/trunk/tools/dagmc/cgm2moab.cc
> MOAB/trunk/tools/dagmc/main.cc
> Log:
> o Correctly identify OCC BREP files
> o Use default geometry engine, rather than requesting ACIS
> o Check for invalid data in GMem object for surface facets
> Modified: MOAB/trunk/tools/dagmc/cgm2moab.cc
> --- MOAB/trunk/tools/dagmc/cgm2moab.cc 2008-12-03 17:19:10 UTC (rev 2301)
> +++ MOAB/trunk/tools/dagmc/cgm2moab.cc 2008-12-03 17:29:55 UTC (rev 2302)
> @@ -419,8 +419,13 @@
> for (int i = 0; i < data.fListCount; i += data.facet_list()[i]+1) {
> int* facet = data.facet_list() + i;
> corners.resize( *facet );
> - for (int j = 1; j <= *facet; ++j)
> + for (int j = 1; j <= *facet; ++j) {
> + if (facet[j] >= (int)verts.size()) {
> + std::cerr << "ERROR: Invalid facet data for surface " << face->id() << std::endl;
> + return false;
> corners[j-1] = verts[facet[j]];
> MBEntityType type;
> if (*facet == 3)
> type = MBTRI;
> Modified: MOAB/trunk/tools/dagmc/main.cc
> --- MOAB/trunk/tools/dagmc/main.cc 2008-12-03 17:19:10 UTC (rev 2301)
> +++ MOAB/trunk/tools/dagmc/main.cc 2008-12-03 17:29:55 UTC (rev 2302)
> @@ -10,6 +10,7 @@
> #define GF_IGES_FILE_TYPE "IGES"
> #define GF_ACIS_TXT_FILE_TYPE "ACIS_SAT"
> #define GF_ACIS_BIN_FILE_TYPE "ACIS_SAB"
> +#define GF_OCC_BREP_FILE_TYPE "BREP"
> /* Get the type of a file.
> Return value is one of the above constants
> @@ -22,6 +23,7 @@
> int is_iges_file( FILE* file );
> int is_acis_txt_file( FILE* file );
> int is_acis_bin_file( FILE* file );
> +int is_occ_brep_file( FILE* file );
> double parse_tol( char* argv[], int argc, int& i );
> void usage(char *name);
> @@ -113,7 +115,7 @@
> // Initialize CGM
> - InitCGMA::initialize_cgma("ACIS");
> + InitCGMA::initialize_cgma();
> if (actuate_attribs) {
> CGMApp::instance()->attrib_manager()->set_all_auto_read_flags( actuate_attribs );
> CGMApp::instance()->attrib_manager()->set_all_auto_actuate_flags( actuate_attribs );
> @@ -268,6 +270,7 @@
> static const char* IGES_NAME = GF_IGES_FILE_TYPE;
> static const char* SAT_NAME = GF_ACIS_TXT_FILE_TYPE;
> static const char* SAB_NAME = GF_ACIS_BIN_FILE_TYPE;
> + static const char* BREP_NAME = GF_OCC_BREP_FILE_TYPE;
> if (is_cubit_file(file))
> return CUBIT_NAME;
> @@ -279,6 +282,8 @@
> return SAB_NAME;
> else if (is_acis_txt_file(file))
> return SAT_NAME;
> + else if (is_occ_brep_file(file))
> + return BREP_NAME;
> else
> return 0;
> @@ -337,3 +342,11 @@
> return !strcmp( buffer, "ACIS" );
> + unsigned char buffer[6];
> + return !fseek(file, 0, SEEK_SET) &&
> + fread(buffer, 6, 1, file) &&
> + !memcmp(buffer, "DBRep_", 6);
steadfast, because he trusts in you." Isaiah 26:3
Tim Tautges Argonne National Laboratory
(tautges at mcs.anl.gov) (telecommuting from UW-Madison)
phone: (608) 263-8485 1500 Engineering Dr.
fax: (608) 263-4499 Madison, WI 53706
