[MOAB-dev] MOAB question
shontz at cse.psu.edu
Tue Dec 2 23:53:39 CST 2008
Dear Jason,
You were right about this -- I saw the 4 vertices and had assumed they
were tets. But closer inspection shows they were quads. Your
postprocessing step (using mbconvert with the -3 option) worked. So now I
have the hex meshes with the corresponding boundary information I need.
Suzanne
> Suzanne Shontz wrote:
>> Jason & Tim,
>> Actually, on closer inspection of the resulting meshes, I see that
>> mbskin did *not* yield the desired result. mbconvert yielded hex meshes
>> (but without boundary information), whereas mbskin (when called as
>> indicated below) yielded the desired boundary information, but it
>> returned hybrid meshes with tet and hex elements. Any idea why this is
>> happening? The meshes are definitely hex meshes I'm trying to convert.
>> Any suggestions
>> would be appreciated.
> It definitely should not be creating any tetrahedral elements. If it
> is, that is certainly a bug. Are you sure that it is creating
> tetrahedral elements and not quadrilateral ones? The mbskin utility
> might be creating the quadrilateral elements that define the skin of the
> mesh. If that is the case, you can use mbconvert to remove those from
> the file:
> mbconvert -3 input.vtk output.vtk
> - jason
