[MOAB-dev] Failed in step PARALLEL DELETE NONLOCAL
Tim Tautges
tautges at mcs.anl.gov
Tue Aug 26 12:55:25 CDT 2008
Could be, depending on what kind of decomposition is being requested. I
think by default it tries to use a material set decomposition, so if
there are fewer than 4 mat sets, it will fail.
- tim
de Almeida, Valmor F. wrote:
> Hello,
> Is this the normal output of
> -> mpirun -np 4 mbparallelcomm_test 0 3 parallel/ptest.cub
> When using moab rev 2047.
> Thanks,
> Valmor
> Broadcasting mesh.
> Reading file parallel/ptest.cub
> Broadcasting mesh.
> Checking global ids.
> Getting fileset entities.
> Broadcasting mesh.
> Bcast done; entities:
> Number of entities per type:
> Vertex: 75
> Edge: 146
> Tri: 0
> Quad: 80
> Polygon: 0
> Tet: 0
> Pyramid: 0
> Prism: 0
> Knife: 0
> Hex: 32
> Polyhedron: 0
> EntitySet: 76
> Deleting nonlocal entities.
> Vertex: 75
> Couldn't read mesh; error message:
> Number of procs greater than number of partitions.
> Edge: 146
> Tri: 0
> Quad: 80
> Polygon: 0
> Tet: 0
> Pyramid: 0
> Prism: 0
> Knife: 0
> Hex: 32
> Polyhedron: 0
> EntitySet: 76
> Couldn't read mesh; error message:Broadcasting mesh.
> Vertex: 75
> Edge: 146
> Tri: 0
> Quad: 80
> Polygon: 0
> Tet: 0
> Pyramid: 0
> Vertex: 75
> Edge: 146
> Tri: 0
> Quad: 80
> Polygon: 0
> Tet: 0
> Prism: 0
> Knife: 0
> Hex: 32
> Polyhedron: 0
> EntitySet: 76
> Pyramid: 0
> Prism: 0
> Knife: 0
> Hex: 32
> Polyhedron: 0
> EntitySet: 76
> Proc 2: Success.
> Proc 1: Success.
> Proc 3: Success.
> Proc 0: Success.
> Times: 0.0222449 0.0222418 -1.21972e+09 3.14295e-39 1.21972e+09
> (total/read/shared/report/delete)
steadfast, because he trusts in you." Isaiah 26:3
Tim Tautges Argonne National Laboratory
(tautges at mcs.anl.gov) (telecommuting from UW-Madison)
phone: (608) 263-8485 1500 Engineering Dr.
fax: (608) 263-4499 Madison, WI 53706
