[MOAB-dev] MBErrorCode Test Failed: MB_SUCCESS == rval
de Almeida, Valmor F. dealmeidav at ornl.gov
Mon Aug 25 21:02:52 CDT 2008
Hello,
I think the output below is not correct (moab rev 2047). Any help
appreciated.
Valmor
-> mpirun -np 2 parallel/pcomm_unit
Running test_pack_vertices ...
Running test_pack_elements ...
  at line 86 of 'pcomm_unit.cpp'
  Expected value: Success (0)
  Actual value:   Memory Alloc. Failed (3)
  test_pack_vertices: FAILED
Running test_pack_higher_order ...
Running test_pack_poly ...
Running test_pack_sets_simple ...
  test_pack_elements: FAILED
  test_pack_higher_order: FAILED
Running test_pack_set_contents ...
Running test_pack_sets_of_sets ...
  test_pack_poly: FAILED
Running test_pack_set_parent_child ...
Running test_pack_tag_data ...
  test_pack_sets_simple: FAILED
  test_pack_set_contents: FAILED
Running test_pack_variable_length_tag ...
Running test_pack_tag_handle_data ...
  test_pack_tag_data: FAILED
  test_pack_variable_length_tag: FAILED
  test_pack_tag_handle_data: FAILED
