[MOAB-dev] r2037 - MOAB/trunk
kraftche at mcs.anl.gov
Tue Aug 12 10:56:29 CDT 2008
Author: kraftche
Date: 2008-08-12 10:56:29 -0500 (Tue, 12 Aug 2008)
New Revision: 2037
Modified:
MOAB/trunk/MBRange.cpp
MOAB/trunk/MBRange.hpp
Log:
Fixes to MBRange::subset_by_type:
o fix mismatched argument type between header (MBEntityType) and
source (const MBEntityType).
o function should be const, as it doesn't modify the object it is
called on.
o use 'equal_range' rather than 'lower_bound' and 'upper_bound' so
the range is searched once rather than twice.
Modified: MOAB/trunk/MBRange.cpp
--- MOAB/trunk/MBRange.cpp 2008-08-05 17:52:08 UTC (rev 2036)
+++ MOAB/trunk/MBRange.cpp 2008-08-12 15:56:29 UTC (rev 2037)
@@ -850,10 +850,11 @@
//! return a subset of this range, by type
-MBRange MBRange::subset_by_type(const MBEntityType t)
+MBRange MBRange::subset_by_type(MBEntityType t) const
MBRange result;
- result.merge( lower_bound(t), upper_bound(t) );
+ std::pair<const_iterator, const_iterator> iters = equal_range(t);
+ result.merge( iters.first, iters.second );
return result;
Modified: MOAB/trunk/MBRange.hpp
--- MOAB/trunk/MBRange.hpp 2008-08-05 17:52:08 UTC (rev 2036)
+++ MOAB/trunk/MBRange.hpp 2008-08-12 15:56:29 UTC (rev 2037)
@@ -316,7 +316,7 @@
void sanity_check() const;
- MBRange subset_by_type(MBEntityType t);
+ MBRange subset_by_type(MBEntityType t) const;
struct PairNode : public std::pair<MBEntityHandle,MBEntityHandle>
