[MOAB-dev] BCAST_DELETE changes
Jason Kraftcheck kraftche at cae.wisc.edu
Mon Aug 11 21:04:54 CDT 2008
Tim wrote most of that code, so he is the obvious person to look over
these changes.  However, he will not be returning from vacation for a
couple of weeks.
- jason
David Thompson wrote:
> Hi all,
> I ran into an issue where using the parallel reader with an invalid
> filename in BCAST_DELETE mode would cause a hang. I have a patch
> (attached) that fixes the issue for me but want to make sure it doesn't
> cause trouble for anyone else before checking it in.
> The patch also deletes a bit of what appears to be dead code in
> resolve_shared_ents(). The code was apparently meant to detect the
> maximum that a global ID could be but the results of the MPI_AllReduce
> (which sums the number of entities across all processes) don't appear to
> be used anywhere.
> Any comments before I commit the change?
> 	Thanks,
> 	David
