[MOAB-dev] MOAB check for *AMD64-32* failed.
Nightly Test
kraftche at cae.wisc.edu
Tue Apr 15 01:01:19 CDT 2008
make[3]: *** No rule to make target `../../tools/iMesh/SIDL/mserver/libiMeshserver.la', needed by `mbperf_SIDL'. Stop.
make[3]: *** Waiting for unfinished jobs....
../../../src/tools/mbperf/mbperf_SIDL.cpp:29:20: error: iBase.hh: No such file or directory
../../../src/tools/mbperf/mbperf_SIDL.cpp:30:20: error: iMesh.hh: No such file or directory
../../../src/tools/mbperf/mbperf_SIDL.cpp:64: error: variable or field âquery_vert_to_elemâ declared void
../../../src/tools/mbperf/mbperf_SIDL.cpp:64: error: âiMeshâ has not been declared
../../../src/tools/mbperf/mbperf_SIDL.cpp:64: error: âmeshâ was not declared in this scope
../../../src/tools/mbperf/mbperf_SIDL.cpp:65: error: variable or field âquery_elem_to_vertâ declared void
../../../src/tools/mbperf/mbperf_SIDL.cpp:65: error: âiMeshâ has not been declared
../../../src/tools/mbperf/mbperf_SIDL.cpp:65: error: âmeshâ was not declared in this scope
../../../src/tools/mbperf/mbperf_SIDL.cpp:71: error: variable or field âtestBâ declared void
../../../src/tools/mbperf/mbperf_SIDL.cpp:71: error: âiMeshâ has not been declared
../../../src/tools/mbperf/mbperf_SIDL.cpp:71: error: âmeshâ was not declared in this scope
../../../src/tools/mbperf/mbperf_SIDL.cpp:72: error: expected primary-expression before âconstâ
../../../src/tools/mbperf/mbperf_SIDL.cpp:72: error: âsidlâ has not been declared
../../../src/tools/mbperf/mbperf_SIDL.cpp:72: error: expected primary-expression before âdoubleâ
../../../src/tools/mbperf/mbperf_SIDL.cpp:73: error: expected primary-expression before âconstâ
../../../src/tools/mbperf/mbperf_SIDL.cpp:73: error: initializer expression list treated as compound expression
../../../src/tools/mbperf/mbperf_SIDL.cpp:74: error: variable or field âtestCâ declared void
../../../src/tools/mbperf/mbperf_SIDL.cpp:74: error: âiMeshâ has not been declared
../../../src/tools/mbperf/mbperf_SIDL.cpp:74: error: âmeshâ was not declared in this scope
../../../src/tools/mbperf/mbperf_SIDL.cpp:74: error: expected primary-expression before âconstâ
../../../src/tools/mbperf/mbperf_SIDL.cpp:74: error: âsidlâ has not been declared
../../../src/tools/mbperf/mbperf_SIDL.cpp:74: error: expected primary-expression before âdoubleâ
../../../src/tools/mbperf/mbperf_SIDL.cpp:74: error: initializer expression list treated as compound expression
../../../src/tools/mbperf/mbperf_SIDL.cpp:79: error: âsidlâ has not been declared
../../../src/tools/mbperf/mbperf_SIDL.cpp:79: error: expected â,â or â...â before â<â token
../../../src/tools/mbperf/mbperf_SIDL.cpp: In function âint main(int, char**)â:
../../../src/tools/mbperf/mbperf_SIDL.cpp:104: error: âsidlâ has not been declared
../../../src/tools/mbperf/mbperf_SIDL.cpp:104: error: expected primary-expression before âdoubleâ
../../../src/tools/mbperf/mbperf_SIDL.cpp:104: error: expected `;' before âdoubleâ
../../../src/tools/mbperf/mbperf_SIDL.cpp:105: error: âcoordsâ was not declared in this scope
../../../src/tools/mbperf/mbperf_SIDL.cpp:112: error: âiMeshâ has not been declared
../../../src/tools/mbperf/mbperf_SIDL.cpp:112: error: expected `;' before âmeshâ
../../../src/tools/mbperf/mbperf_SIDL.cpp:114: error: âiMeshâ has not been declared
../../../src/tools/mbperf/mbperf_SIDL.cpp:114: error: âmeshâ was not declared in this scope
../../../src/tools/mbperf/mbperf_SIDL.cpp:115: error: expected type-specifier before âiBaseâ
../../../src/tools/mbperf/mbperf_SIDL.cpp:115: error: expected `)' before â::â token
../../../src/tools/mbperf/mbperf_SIDL.cpp:115: error: expected `{' before â::â token
../../../src/tools/mbperf/mbperf_SIDL.cpp:115: error: â::Errorâ has not been declared
../../../src/tools/mbperf/mbperf_SIDL.cpp:115: error: expected `;' before âerrâ
../../../src/tools/mbperf/mbperf_SIDL.cpp:125: error: âmeshâ was not declared in this scope
../../../src/tools/mbperf/mbperf_SIDL.cpp:125: error: âtestBâ cannot be used as a function
../../../src/tools/mbperf/mbperf_SIDL.cpp:130: error: âtestCâ cannot be used as a function
../../../src/tools/mbperf/mbperf_SIDL.cpp: At global scope:
../../../src/tools/mbperf/mbperf_SIDL.cpp:137: error: variable or field âtestBâ declared void
../../../src/tools/mbperf/mbperf_SIDL.cpp:137: error: redefinition of âint testBâ
../../../src/tools/mbperf/mbperf_SIDL.cpp:71: error: âint testBâ previously defined here
../../../src/tools/mbperf/mbperf_SIDL.cpp:137: error: âiMeshâ has not been declared
../../../src/tools/mbperf/mbperf_SIDL.cpp:137: error: âmeshâ was not declared in this scope
../../../src/tools/mbperf/mbperf_SIDL.cpp:138: error: expected primary-expression before âconstâ
../../../src/tools/mbperf/mbperf_SIDL.cpp:138: error: âsidlâ has not been declared
../../../src/tools/mbperf/mbperf_SIDL.cpp:138: error: expected primary-expression before âdoubleâ
../../../src/tools/mbperf/mbperf_SIDL.cpp:139: error: expected primary-expression before âconstâ
../../../src/tools/mbperf/mbperf_SIDL.cpp:215: error: variable or field âtestCâ declared void
../../../src/tools/mbperf/mbperf_SIDL.cpp:215: error: redefinition of âint testCâ
../../../src/tools/mbperf/mbperf_SIDL.cpp:74: error: âint testCâ previously defined here
../../../src/tools/mbperf/mbperf_SIDL.cpp:215: error: âiMeshâ has not been declared
../../../src/tools/mbperf/mbperf_SIDL.cpp:215: error: âmeshâ was not declared in this scope
../../../src/tools/mbperf/mbperf_SIDL.cpp:216: error: expected primary-expression before âconstâ
../../../src/tools/mbperf/mbperf_SIDL.cpp:216: error: âsidlâ has not been declared
../../../src/tools/mbperf/mbperf_SIDL.cpp:216: error: expected primary-expression before âdoubleâ
../../../src/tools/mbperf/mbperf_SIDL.cpp:330: error: variable or field âquery_elem_to_vertâ declared void
../../../src/tools/mbperf/mbperf_SIDL.cpp:330: error: redefinition of âint query_elem_to_vertâ
../../../src/tools/mbperf/mbperf_SIDL.cpp:65: error: âint query_elem_to_vertâ previously defined here
../../../src/tools/mbperf/mbperf_SIDL.cpp:330: error: âiMeshâ has not been declared
../../../src/tools/mbperf/mbperf_SIDL.cpp:330: error: âmeshâ was not declared in this scope
../../../src/tools/mbperf/mbperf_SIDL.cpp:396: error: variable or field âquery_vert_to_elemâ declared void
../../../src/tools/mbperf/mbperf_SIDL.cpp:396: error: redefinition of âint query_vert_to_elemâ
../../../src/tools/mbperf/mbperf_SIDL.cpp:64: error: âint query_vert_to_elemâ previously defined here
../../../src/tools/mbperf/mbperf_SIDL.cpp:396: error: âiMeshâ has not been declared
../../../src/tools/mbperf/mbperf_SIDL.cpp:396: error: âmeshâ was not declared in this scope
../../../src/tools/mbperf/mbperf_SIDL.cpp:541: error: âsidlâ has not been declared
../../../src/tools/mbperf/mbperf_SIDL.cpp:541: error: expected â,â or â...â before â<â token
../../../src/tools/mbperf/mbperf_SIDL.cpp: In function âvoid build_coords(int, int)â:
../../../src/tools/mbperf/mbperf_SIDL.cpp:551: error: âcoordsâ was not declared in this scope
../../../src/tools/mbperf/mbperf_SIDL.cpp:552: error: âcoordsâ was not declared in this scope
make[3]: *** [mbperf_SIDL.o] Error 1
make[2]: *** [all-recursive] Error 1
make[1]: *** [all-recursive] Error 1
make: *** [all] Error 2
s/Makefile
config.status: creating tools/converter/Makefile
config.status: creating tools/hexmodops/Makefile
config.status: creating tools/iMesh/Makefile
config.status: creating tools/iMesh/iMesh-Defs.inc
config.status: creating tools/iMesh/SIDL/iMesh-SIDL-Defs.inc
config.status: creating tools/iMesh/SIDL/Makefile
config.status: creating tools/iMesh/SIDL/common.make
config.status: creating tools/mbperf/Makefile
config.status: creating tools/mbchaco/Makefile
config.status: creating tools/mbzoltan/Config.moab
config.status: creating tools/mbzoltan/Makefile
config.status: creating tools/qvdual/Makefile
config.status: creating tools/size/Makefile
config.status: creating tools/skin/Makefile
config.status: creating tools/tagprop/Makefile
config.status: creating tools/spheredecomp/Makefile
config.status: creating tools/surfplot/Makefile
config.status: creating tools/dagmc/Makefile
config.status: creating tools/dagmc/dagmc.make
config.status: creating doc/Makefile
config.status: creating doxygen/Makefile
config.status: creating config.h
config.status: config.h is unchanged
config.status: creating MBVersion.h
config.status: MBVersion.h is unchanged
config.status: creating MBEntityHandle.h
config.status: MBEntityHandle.h is unchanged
config.status: creating tools/iMesh/iBase_FCDefs.h
config.status: tools/iMesh/iBase_FCDefs.h is unchanged
config.status: executing depfiles commands
make all-recursive
make[1]: Entering directory `/home/jason/moab/test/AMD64-32'
Making all in mhdf
make[2]: Entering directory `/home/jason/moab/test/AMD64-32/mhdf'
make[2]: Nothing to be done for `all'.
make[2]: Leaving directory `/home/jason/moab/test/AMD64-32/mhdf'
Making all in .
make[2]: Entering directory `/home/jason/moab/test/AMD64-32'
make[2]: Leaving directory `/home/jason/moab/test/AMD64-32'
Making all in test
make[2]: Entering directory `/home/jason/moab/test/AMD64-32/test'
Making all in dual
make[3]: Entering directory `/home/jason/moab/test/AMD64-32/test/dual'
make[3]: Nothing to be done for `all'.
make[3]: Leaving directory `/home/jason/moab/test/AMD64-32/test/dual'
Making all in h5file
make[3]: Entering directory `/home/jason/moab/test/AMD64-32/test/h5file'
make[3]: Leaving directory `/home/jason/moab/test/AMD64-32/test/h5file'
Making all in obb
make[3]: Entering directory `/home/jason/moab/test/AMD64-32/test/obb'
make[3]: Leaving directory `/home/jason/moab/test/AMD64-32/test/obb'
Making all in perf
make[3]: Entering directory `/home/jason/moab/test/AMD64-32/test/perf'
make[3]: Leaving directory `/home/jason/moab/test/AMD64-32/test/perf'
make[3]: Entering directory `/home/jason/moab/test/AMD64-32/test'
make[3]: Nothing to be done for `all-am'.
make[3]: Leaving directory `/home/jason/moab/test/AMD64-32/test'
make[2]: Leaving directory `/home/jason/moab/test/AMD64-32/test'
Making all in tools
make[2]: Entering directory `/home/jason/moab/test/AMD64-32/tools'
Making all in converter
make[3]: Entering directory `/home/jason/moab/test/AMD64-32/tools/converter'
make[3]: Leaving directory `/home/jason/moab/test/AMD64-32/tools/converter'
Making all in hexmodops
make[3]: Entering directory `/home/jason/moab/test/AMD64-32/tools/hexmodops'
make[3]: Leaving directory `/home/jason/moab/test/AMD64-32/tools/hexmodops'
Making all in mbperf
make[3]: Entering directory `/home/jason/moab/test/AMD64-32/tools/mbperf'
if c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I../../../src/tools/mbperf -I../.. -I../.. -I../.. -I../../tools/iMesh -I../../../src -I../.. -I../../../src/tools/iMesh/SIDL/mserver -Wall -pipe -g -MT mbperf_SIDL.o -MD -MP -MF ".deps/mbperf_SIDL.Tpo" -c -o mbperf_SIDL.o ../../../src/tools/mbperf/mbperf_SIDL.cpp; \
then mv -f ".deps/mbperf_SIDL.Tpo" ".deps/mbperf_SIDL.Po"; else rm -f ".deps/mbperf_SIDL.Tpo"; exit 1; fi
make[3]: Leaving directory `/home/jason/moab/test/AMD64-32/tools/mbperf'
make[2]: Leaving directory `/home/jason/moab/test/AMD64-32/tools'
make[1]: Leaving directory `/home/jason/moab/test/AMD64-32'
