[MOAB-dev] MOAB check for *AMD64* failed.
Nightly Test kraftche at cae.wisc.edu
Tue Apr 15 01:01:09 CDT 2008
../../../src/tools/mbperf/mbperf_SIDL.cpp:29:20: error: iBase.hh: No such file or directory
../../../src/tools/mbperf/mbperf_SIDL.cpp:30:20: error: iMesh.hh: No such file or directory
../../../src/tools/mbperf/mbperf_SIDL.cpp:64: error: variable or field ‘query_vert_to_elem’ declared void
../../../src/tools/mbperf/mbperf_SIDL.cpp:64: error: ‘iMesh’ has not been declared
../../../src/tools/mbperf/mbperf_SIDL.cpp:64: error: ‘mesh’ was not declared in this scope
../../../src/tools/mbperf/mbperf_SIDL.cpp:65: error: variable or field ‘query_elem_to_vert’ declared void
../../../src/tools/mbperf/mbperf_SIDL.cpp:65: error: ‘iMesh’ has not been declared
../../../src/tools/mbperf/mbperf_SIDL.cpp:65: error: ‘mesh’ was not declared in this scope
../../../src/tools/mbperf/mbperf_SIDL.cpp:71: error: variable or field ‘testB’ declared void
../../../src/tools/mbperf/mbperf_SIDL.cpp:71: error: ‘iMesh’ has not been declared
../../../src/tools/mbperf/mbperf_SIDL.cpp:71: error: ‘mesh’ was not declared in this scope
../../../src/tools/mbperf/mbperf_SIDL.cpp:72: error: expected primary-expression before ‘const’
../../../src/tools/mbperf/mbperf_SIDL.cpp:72: error: ‘sidl’ has not been declared
../../../src/tools/mbperf/mbperf_SIDL.cpp:72: error: expected primary-expression before ‘double’
../../../src/tools/mbperf/mbperf_SIDL.cpp:73: error: expected primary-expression before ‘const’
../../../src/tools/mbperf/mbperf_SIDL.cpp:73: error: initializer expression list treated as compound expression
../../../src/tools/mbperf/mbperf_SIDL.cpp:74: error: variable or field ‘testC’ declared void
../../../src/tools/mbperf/mbperf_SIDL.cpp:74: error: ‘iMesh’ has not been declared
../../../src/tools/mbperf/mbperf_SIDL.cpp:74: error: ‘mesh’ was not declared in this scope
../../../src/tools/mbperf/mbperf_SIDL.cpp:74: error: expected primary-expression before ‘const’
../../../src/tools/mbperf/mbperf_SIDL.cpp:74: error: ‘sidl’ has not been declared
../../../src/tools/mbperf/mbperf_SIDL.cpp:74: error: expected primary-expression before ‘double’
../../../src/tools/mbperf/mbperf_SIDL.cpp:74: error: initializer expression list treated as compound expression
../../../src/tools/mbperf/mbperf_SIDL.cpp:79: error: ‘sidl’ has not been declared
../../../src/tools/mbperf/mbperf_SIDL.cpp:79: error: expected ‘,’ or ‘...’ before ‘<’ token
../../../src/tools/mbperf/mbperf_SIDL.cpp: In function ‘int main(int, char**)’:
../../../src/tools/mbperf/mbperf_SIDL.cpp:104: error: ‘sidl’ has not been declared
../../../src/tools/mbperf/mbperf_SIDL.cpp:104: error: expected primary-expression before ‘double’
../../../src/tools/mbperf/mbperf_SIDL.cpp:104: error: expected `;' before ‘double’
../../../src/tools/mbperf/mbperf_SIDL.cpp:105: error: ‘coords’ was not declared in this scope
../../../src/tools/mbperf/mbperf_SIDL.cpp:112: error: ‘iMesh’ has not been declared
../../../src/tools/mbperf/mbperf_SIDL.cpp:112: error: expected `;' before ‘mesh’
../../../src/tools/mbperf/mbperf_SIDL.cpp:114: error: ‘iMesh’ has not been declared
../../../src/tools/mbperf/mbperf_SIDL.cpp:114: error: ‘mesh’ was not declared in this scope
../../../src/tools/mbperf/mbperf_SIDL.cpp:115: error: expected type-specifier before ‘iBase’
../../../src/tools/mbperf/mbperf_SIDL.cpp:115: error: expected `)' before ‘::’ token
../../../src/tools/mbperf/mbperf_SIDL.cpp:115: error: expected `{' before ‘::’ token
../../../src/tools/mbperf/mbperf_SIDL.cpp:115: error: ‘::Error’ has not been declared
../../../src/tools/mbperf/mbperf_SIDL.cpp:115: error: expected `;' before ‘err’
../../../src/tools/mbperf/mbperf_SIDL.cpp:125: error: ‘mesh’ was not declared in this scope
../../../src/tools/mbperf/mbperf_SIDL.cpp:125: error: ‘testB’ cannot be used as a function
../../../src/tools/mbperf/mbperf_SIDL.cpp:130: error: ‘testC’ cannot be used as a function
../../../src/tools/mbperf/mbperf_SIDL.cpp: At global scope:
../../../src/tools/mbperf/mbperf_SIDL.cpp:137: error: variable or field ‘testB’ declared void
../../../src/tools/mbperf/mbperf_SIDL.cpp:137: error: redefinition of ‘int testB’
../../../src/tools/mbperf/mbperf_SIDL.cpp:71: error: ‘int testB’ previously defined here
../../../src/tools/mbperf/mbperf_SIDL.cpp:137: error: ‘iMesh’ has not been declared
../../../src/tools/mbperf/mbperf_SIDL.cpp:137: error: ‘mesh’ was not declared in this scope
../../../src/tools/mbperf/mbperf_SIDL.cpp:138: error: expected primary-expression before ‘const’
../../../src/tools/mbperf/mbperf_SIDL.cpp:138: error: ‘sidl’ has not been declared
../../../src/tools/mbperf/mbperf_SIDL.cpp:138: error: expected primary-expression before ‘double’
../../../src/tools/mbperf/mbperf_SIDL.cpp:139: error: expected primary-expression before ‘const’
../../../src/tools/mbperf/mbperf_SIDL.cpp:215: error: variable or field ‘testC’ declared void
../../../src/tools/mbperf/mbperf_SIDL.cpp:215: error: redefinition of ‘int testC’
../../../src/tools/mbperf/mbperf_SIDL.cpp:74: error: ‘int testC’ previously defined here
../../../src/tools/mbperf/mbperf_SIDL.cpp:215: error: ‘iMesh’ has not been declared
../../../src/tools/mbperf/mbperf_SIDL.cpp:215: error: ‘mesh’ was not declared in this scope
../../../src/tools/mbperf/mbperf_SIDL.cpp:216: error: expected primary-expression before ‘const’
../../../src/tools/mbperf/mbperf_SIDL.cpp:216: error: ‘sidl’ has not been declared
../../../src/tools/mbperf/mbperf_SIDL.cpp:216: error: expected primary-expression before ‘double’
../../../src/tools/mbperf/mbperf_SIDL.cpp:330: error: variable or field ‘query_elem_to_vert’ declared void
../../../src/tools/mbperf/mbperf_SIDL.cpp:330: error: redefinition of ‘int query_elem_to_vert’
../../../src/tools/mbperf/mbperf_SIDL.cpp:65: error: ‘int query_elem_to_vert’ previously defined here
../../../src/tools/mbperf/mbperf_SIDL.cpp:330: error: ‘iMesh’ has not been declared
../../../src/tools/mbperf/mbperf_SIDL.cpp:330: error: ‘mesh’ was not declared in this scope
../../../src/tools/mbperf/mbperf_SIDL.cpp:396: error: variable or field ‘query_vert_to_elem’ declared void
../../../src/tools/mbperf/mbperf_SIDL.cpp:396: error: redefinition of ‘int query_vert_to_elem’
../../../src/tools/mbperf/mbperf_SIDL.cpp:64: error: ‘int query_vert_to_elem’ previously defined here
../../../src/tools/mbperf/mbperf_SIDL.cpp:396: error: ‘iMesh’ has not been declared
../../../src/tools/mbperf/mbperf_SIDL.cpp:396: error: ‘mesh’ was not declared in this scope
../../../src/tools/mbperf/mbperf_SIDL.cpp:541: error: ‘sidl’ has not been declared
../../../src/tools/mbperf/mbperf_SIDL.cpp:541: error: expected ‘,’ or ‘...’ before ‘<’ token
../../../src/tools/mbperf/mbperf_SIDL.cpp: In function ‘void build_coords(int, int)’:
../../../src/tools/mbperf/mbperf_SIDL.cpp:551: error: ‘coords’ was not declared in this scope
../../../src/tools/mbperf/mbperf_SIDL.cpp:552: error: ‘coords’ was not declared in this scope
make[3]: *** [mbperf_SIDL.o] Error 1
make[3]: *** Waiting for unfinished jobs....
make[2]: *** [all-recursive] Error 1
make[1]: *** [all-recursive] Error 1
make: *** [all] Error 2
or /opt/babel-0.10.10-64-c2/bin/babel... yes
configure: creating ./config.status
C:   cc  -g
C++: c++  -Wall -pipe -g
 /bin/sh ./config.status
config.status: creating Makefile
config.status: creating moab.make
config.status: creating testdir.h
config.status: creating parallel/Makefile
config.status: creating mhdf/Makefile
config.status: creating test/Makefile
config.status: creating test/h5file/Makefile
config.status: creating test/dual/Makefile
config.status: creating test/obb/Makefile
config.status: creating test/perf/Makefile
config.status: creating tools/Makefile
config.status: creating tools/converter/Makefile
config.status: creating tools/hexmodops/Makefile
config.status: creating tools/iMesh/Makefile
config.status: creating tools/iMesh/iMesh-Defs.inc
config.status: creating tools/iMesh/SIDL/iMesh-SIDL-Defs.inc
config.status: creating tools/iMesh/SIDL/Makefile
config.status: creating tools/iMesh/SIDL/common.make
config.status: creating tools/mbperf/Makefile
config.status: creating tools/mbchaco/Makefile
config.status: creating tools/mbzoltan/Config.moab
config.status: creating tools/mbzoltan/Makefile
config.status: creating tools/qvdual/Makefile
config.status: creating tools/size/Makefile
config.status: creating tools/skin/Makefile
config.status: creating tools/tagprop/Makefile
config.status: creating tools/spheredecomp/Makefile
config.status: creating tools/surfplot/Makefile
config.status: creating tools/dagmc/Makefile
config.status: creating tools/dagmc/dagmc.make
config.status: creating doc/Makefile
config.status: creating doxygen/Makefile
config.status: creating config.h
config.status: config.h is unchanged
config.status: creating MBVersion.h
config.status: MBVersion.h is unchanged
config.status: creating MBEntityHandle.h
config.status: MBEntityHandle.h is unchanged
config.status: creating tools/iMesh/iBase_FCDefs.h
config.status: tools/iMesh/iBase_FCDefs.h is unchanged
config.status: executing depfiles commands
make  all-recursive
make[1]: Entering directory `/home/jason/moab/test/AMD64'
Making all in mhdf
make[2]: Entering directory `/home/jason/moab/test/AMD64/mhdf'
make[2]: Nothing to be done for `all'.
make[2]: Leaving directory `/home/jason/moab/test/AMD64/mhdf'
Making all in .
make[2]: Entering directory `/home/jason/moab/test/AMD64'
make[2]: Leaving directory `/home/jason/moab/test/AMD64'
Making all in test
make[2]: Entering directory `/home/jason/moab/test/AMD64/test'
Making all in dual
make[3]: Entering directory `/home/jason/moab/test/AMD64/test/dual'
make[3]: Nothing to be done for `all'.
make[3]: Leaving directory `/home/jason/moab/test/AMD64/test/dual'
Making all in h5file
make[3]: Entering directory `/home/jason/moab/test/AMD64/test/h5file'
make[3]: Leaving directory `/home/jason/moab/test/AMD64/test/h5file'
Making all in obb
make[3]: Entering directory `/home/jason/moab/test/AMD64/test/obb'
make[3]: Leaving directory `/home/jason/moab/test/AMD64/test/obb'
Making all in perf
make[3]: Entering directory `/home/jason/moab/test/AMD64/test/perf'
make[3]: Leaving directory `/home/jason/moab/test/AMD64/test/perf'
make[3]: Entering directory `/home/jason/moab/test/AMD64/test'
make[3]: Nothing to be done for `all-am'.
make[3]: Leaving directory `/home/jason/moab/test/AMD64/test'
make[2]: Leaving directory `/home/jason/moab/test/AMD64/test'
Making all in tools
make[2]: Entering directory `/home/jason/moab/test/AMD64/tools'
Making all in converter
make[3]: Entering directory `/home/jason/moab/test/AMD64/tools/converter'
make[3]: Leaving directory `/home/jason/moab/test/AMD64/tools/converter'
Making all in hexmodops
make[3]: Entering directory `/home/jason/moab/test/AMD64/tools/hexmodops'
make[3]: Leaving directory `/home/jason/moab/test/AMD64/tools/hexmodops'
Making all in mbperf
make[3]: Entering directory `/home/jason/moab/test/AMD64/tools/mbperf'
if c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I../../../src/tools/mbperf -I../.. -I../.. -I../.. -I../../tools/iMesh -I../../../src -I../.. -I../../../src/tools/iMesh/SIDL/mserver -I../../../src/tools/iMesh/    -Wall -pipe -g -MT mbperf_SIDL.o -MD -MP -MF ".deps/mbperf_SIDL.Tpo" -c -o mbperf_SIDL.o ../../../src/tools/mbperf/mbperf_SIDL.cpp; \
	then mv -f ".deps/mbperf_SIDL.Tpo" ".deps/mbperf_SIDL.Po"; else rm -f ".deps/mbperf_SIDL.Tpo"; exit 1; fi
if c++ -DTEMPLATE_SPECIALIZATION -DHDF5_FILE -DNETCDF_FILE -DNETCDF_FILE -DIS_BUILDING_MB -I. -I../../../src/tools/mbperf -I../.. -I../.. -I../.. -I../../tools/iMesh -I../../../src -I../.. -I../../../src/tools/iMesh/SIDL/mserver -I../../../src/tools/iMesh/    -Wall -pipe -g -MT mbperf_iMesh.o -MD -MP -MF ".deps/mbperf_iMesh.Tpo" -c -o mbperf_iMesh.o ../../../src/tools/mbperf/mbperf_iMesh.cpp; \
	then mv -f ".deps/mbperf_iMesh.Tpo" ".deps/mbperf_iMesh.Po"; else rm -f ".deps/mbperf_iMesh.Tpo"; exit 1; fi
make[3]: Leaving directory `/home/jason/moab/test/AMD64/tools/mbperf'
make[2]: Leaving directory `/home/jason/moab/test/AMD64/tools'
make[1]: Leaving directory `/home/jason/moab/test/AMD64'
