[MOAB-dev] r1764 - MOAB/trunk/tools/mbperf
tautges at mcs.anl.gov
Mon Apr 14 19:29:40 CDT 2008
Author: tautges
Date: 2008-04-14 19:29:40 -0500 (Mon, 14 Apr 2008)
New Revision: 1764
Modified:
MOAB/trunk/tools/mbperf/mbperf_SIDL.cpp
MOAB/trunk/tools/mbperf/mbperf_iMesh.cpp
Log:
Adding memory usage tracking into these tests.
Also found & fixed a fairly major error, involving freeing memory; could degrade timing results for C-based imesh test.
Modified: MOAB/trunk/tools/mbperf/mbperf_SIDL.cpp
--- MOAB/trunk/tools/mbperf/mbperf_SIDL.cpp 2008-04-14 22:33:54 UTC (rev 1763)
+++ MOAB/trunk/tools/mbperf/mbperf_SIDL.cpp 2008-04-15 00:29:40 UTC (rev 1764)
@@ -1,18 +1,3 @@
- * MOAB, a Mesh-Oriented datABase, is a software component for creating,
- * storing and accessing finite element mesh data.
- * Copyright 2004 Sandia Corporation. Under the terms of Contract
- * DE-AC04-94AL85000 with Sandia Coroporation, the U.S. Government
- * retains certain rights in this software.
- * This library is free software; you can redistribute it and/or
- * modify it under the terms of the GNU Lesser General Public
- * License as published by the Free Software Foundation; either
- * version 2.1 of the License, or (at your option) any later version.
/** iMesh Mesh Interface brick mesh performance test
* This program tests iMesh mesh interface functions used to create a square structured
@@ -34,6 +19,11 @@
#include <stdlib.h>
#include <stdio.h>
#include <iostream>
+#include <time.h>
+#include <unistd.h>
+#include <sys/types.h>
+#include <sys/stat.h>
+#include <fcntl.h>
#include <assert.h>
#include "iBase.hh"
@@ -73,8 +63,11 @@
// forward declare some functions
void query_vert_to_elem(iMesh::Mesh &mesh);
void query_elem_to_vert(iMesh::Mesh &mesh);
-void print_time(const bool print_em, double &tot_time, double &utime, double &stime);
+void print_time(const bool print_em, double &tot_time, double &utime, double &stime,
+ double &mem);
void build_connect(const int nelem, const int vstart, int *&connect);
+void get_time_mem(double &tot_time, double &user_time,
+ double &sys_time, double &tot_mem);
void testB(iMesh::Mesh &mesh,
const int nelem, sidl::array<double> &coords,
const int *connect);
@@ -145,9 +138,11 @@
const int *connect)
- double utime, stime, ttime0, ttime1, ttime2, ttime3;
+ double utime, stime, ttime0, ttime1, ttime2, ttime3, mem;
- print_time(false, ttime0, utime, stime);
+ print_time(false, ttime0, utime, stime, mem);
+ std::cout << "Ready to read model into MOAB; memory = " << mem/1.0e6 << " MB." << std::endl;
int num_verts = (nelem + 1)*(nelem + 1)*(nelem + 1);
int num_elems = nelem*nelem*nelem;
@@ -195,16 +190,19 @@
return;
- print_time(false, ttime1, utime, stime);
+ print_time(false, ttime1, utime, stime, mem);
+ std::cout << "Read model into MOAB; memory = " << mem/1.0e6 << " MB." << std::endl;
// query the mesh 2 ways
query_elem_to_vert(mesh);
- print_time(false, ttime2, utime, stime);
+ print_time(false, ttime2, utime, stime, mem);
+ std::cout << "After E-v query; memory = " << mem/1.0e6 << " MB." << std::endl;
query_vert_to_elem(mesh);
- print_time(false, ttime3, utime, stime);
+ print_time(false, ttime3, utime, stime, mem);
+ std::cout << "After v-E query; memory = " << mem/1.0e6 << " MB." << std::endl;
std::cout << "iMesh/MOAB ucd blocked: nelem, construct, e_to_v query, v_to_e query = "
<< nelem << ", "
@@ -217,8 +215,9 @@
void testC(iMesh::Mesh &mesh,
const int nelem, sidl::array<double> &coords)
+ std::cout << "Ready to read data into MOAB; memory = " << mem/1.0e6 << " MB." << std::endl;
CAST_MINTERFACE(mesh, mesh_arrmod, ArrMod);
@@ -306,16 +305,19 @@
+ std::cout << "Read data into MOAB; memory = " << mem/1.0e6 << " MB." << std::endl;
std::cout << "TSTT/MOAB ucd indiv: nelem, construct, e_to_v query, v_to_e query = "
<< nelem << ", "
@@ -426,26 +428,69 @@
+void print_time(const bool print_em, double &tot_time, double &utime, double &stime, double &mem)
- struct rusage r_usage;
- getrusage(RUSAGE_SELF, &r_usage);
- utime = (double)r_usage.ru_utime.tv_sec +
- ((double)r_usage.ru_utime.tv_usec/1.e6);
- stime = (double)r_usage.ru_stime.tv_sec +
- ((double)r_usage.ru_stime.tv_usec/1.e6);
- tot_time = utime + stime;
- if (print_em)
+ get_time_mem(tot_time, utime, stime, mem);
+ if (print_em) {
std::cout << "User, system, total time = " << utime << ", " << stime
<< ", " << tot_time << std::endl;
-#ifndef LINUX
- std::cout << "Max resident set size = " << r_usage.ru_maxrss*4096 << " bytes" << std::endl;
- std::cout << "Int resident set size = " << r_usage.ru_idrss << std::endl;
-#else
- system("ps o args,drs,rss | grep perf | grep -v grep"); // RedHat 9.0 doesnt fill in actual memory data
-#endif
+ std::cout << "Total memory = " << mem / 1.0e6 << " MB." << std::endl;
+ struct rusage r_usage;
+ getrusage(RUSAGE_SELF, &r_usage);
+ user_time = (double)r_usage.ru_utime.tv_sec +
+ ((double)r_usage.ru_utime.tv_usec/1.e6);
+ sys_time = (double)r_usage.ru_stime.tv_sec +
+ ((double)r_usage.ru_stime.tv_usec/1.e6);
+ tot_time = user_time + sys_time;
+ tot_mem = 0;
+ if (0 != r_usage.ru_maxrss) {
+ tot_mem = r_usage.ru_idrss;
+ else {
+ // this machine doesn't return rss - try going to /proc
+ // print the file name to open
+ char file_str[4096], dum_str[4096];
+ int file_ptr = -1, file_len;
+ file_ptr = open("/proc/self/stat", O_RDONLY);
+ file_len = read(file_ptr, file_str, sizeof(file_str)-1);
+ if (file_len == 0) return;
+ close(file_ptr);
+ file_str[file_len] = '\0';
+ // read the preceeding fields and the ones we really want...
+ int dum_int;
+ unsigned int dum_uint, vm_size, rss;
+ int num_fields = sscanf(file_str,
+ "%d " // pid
+ "%s " // comm
+ "%c " // state
+ "%d %d %d %d %d " // ppid, pgrp, session, tty, tpgid
+ "%u %u %u %u %u " // flags, minflt, cminflt, majflt, cmajflt
+ "%d %d %d %d %d %d " // utime, stime, cutime, cstime, counter, priority
+ "%u %u " // timeout, itrealvalue
+ "%d " // starttime
+ "%u %u", // vsize, rss
+ &dum_int,
+ dum_str,
+ dum_str,
+ &dum_int, &dum_int, &dum_int, &dum_int, &dum_int,
+ &dum_uint, &dum_uint, &dum_uint, &dum_uint, &dum_uint,
+ &dum_int, &dum_int, &dum_int, &dum_int, &dum_int, &dum_int,
+ &dum_int,
+ &vm_size, &rss);
+ if (num_fields == 24)
+ tot_mem = ((double)vm_size);
void compute_edge(double *start, const int nelem, const double xint,
const int stride)
@@ -495,8 +540,9 @@
void build_coords(const int nelem, sidl::array<double> &coords)
- double ttime0, ttime1, utime1, stime1;
- print_time(false, ttime0, utime1, stime1);
+ double ttime0, ttime1, utime1, stime1, mem1;
+ print_time(false, ttime0, utime1, stime1, mem1);
+ std::cout << "Before TFI, total memory = " << mem1 / 1.0e6 << " MB." << std::endl;
// allocate the memory
int numv = nelem+1;
@@ -641,9 +687,9 @@
#endif
- print_time(false, ttime1, utime1, stime1);
- std::cout << "TSTT/MOAB: TFI time = " << ttime1-ttime0 << " sec"
- << std::endl;
+ print_time(false, ttime1, utime1, stime1, mem1);
+ std::cout << "MOAB: TFI time = " << ttime1-ttime0 << " sec, memory = "
+ << mem1/1.0e6 << " MB." << std::endl;
Modified: MOAB/trunk/tools/mbperf/mbperf_iMesh.cpp
--- MOAB/trunk/tools/mbperf/mbperf_iMesh.cpp 2008-04-14 22:33:54 UTC (rev 1763)
+++ MOAB/trunk/tools/mbperf/mbperf_iMesh.cpp 2008-04-15 00:29:40 UTC (rev 1764)
@@ -19,9 +19,13 @@
#include <stdlib.h>
#include <stdio.h>
#include <iostream>
+#include <time.h>
+#include <fcntl.h>
+#include <assert.h>
-#include <iostream>
-#include <assert.h>
#include "iMesh.h"
// needed to get the proper size for handles
@@ -33,8 +37,11 @@
void query_elem_to_vert(iMesh_Instance mesh);
void query_vert_to_elem(iMesh_Instance mesh);
+ double &mem);
void testB(iMesh_Instance mesh, const int nelem, const double *coords, const int *connect);
void testC(iMesh_Instance mesh, const int nelem, const double *coords);
@@ -68,7 +75,6 @@
// initialize the data in native format
// pre-build the coords array
- double ttime0, utime1, stime1, ttime1;
double *coords;
build_coords(nelem, coords);
assert(NULL != coords);
@@ -106,9 +112,10 @@
const int *connect)
@@ -149,16 +156,19 @@
return;
std::cout << "iMeshb/MOAB ucd blocked: nelem, construct, e_to_v query, v_to_e query = "
<< nelem << ", "
@@ -170,8 +180,9 @@
// need some dimensions
int numv = nelem + 1;
@@ -223,16 +234,19 @@
std::cout << "iMeshb/MOAB ucd indiv: nelem, construct, e_to_v query, v_to_e query = "
<< nelem << ", "
@@ -318,17 +332,20 @@
return;
- iBase_EntityHandle *dum_hexes = NULL;
- int dum_hexes_allocated = 0, dum_hexes_size;
// now loop over vertices
for (int i = 0; i < all_verts_size; i++) {
- // get the connectivity of this element; will have to allocate space on every
+ iBase_EntityHandle *dum_hexes = NULL;
+ int dum_hexes_allocated = 0, dum_hexes_size;
+ // get the connectivity of this element; will have to allocate space on every
// iteration, since size can vary
iMesh_getEntAdj(mesh, all_verts[i], iBase_REGION,
&dum_hexes, &dum_hexes_allocated, &dum_hexes_size,
&success);
+ free(dum_hexes);
if (iBase_SUCCESS != success) {
cerr << "Problem getting connectivity or vertex coords." << endl;
return;
@@ -336,27 +353,69 @@
- if (print_em)
+ if (print_em) {
-#ifndef LINUX
-#else
-#endif
- //delete [] hex_array;
+ tot_mem = 0;
+ else {
+ close(file_ptr);
+ int dum_int;
+ "%d " // pid
+ "%s " // comm
+ "%c " // state
+ &dum_int,
+ dum_str,
+ dum_str,
+ &dum_int,
+ &vm_size, &rss);
const int stride)
@@ -406,8 +465,8 @@
void build_coords(const int nelem, double *&coords)
+ double ttime0, ttime1, utime1, stime1, mem;
+ print_time(false, ttime0, utime1, stime1, mem);
int numv = nelem+1;
@@ -542,9 +601,9 @@
#endif
- std::cout << "iMesh/MOAB: TFI time = " << ttime1-ttime0 << " sec"
- << std::endl;
+ print_time(false, ttime1, utime1, stime1, mem);
+ << mem/1.0e6 << " MB." << std::endl;
