[MOAB-dev] r1763 - in MOAB/trunk/tools: iMesh iMesh/SIDL/mserver mbperf
tautges at mcs.anl.gov
Mon Apr 14 17:33:55 CDT 2008
Author: tautges
Date: 2008-04-14 17:33:54 -0500 (Mon, 14 Apr 2008)
New Revision: 1763
Added:
MOAB/trunk/tools/iMesh/SIDL/mserver/iMesh_Factory_Impl.cc
MOAB/trunk/tools/mbperf/mbperf_SIDL.cpp
MOAB/trunk/tools/mbperf/mbperf_iMesh.cpp
Modified:
MOAB/trunk/tools/iMesh/iMesh_MOAB.cpp
MOAB/trunk/tools/mbperf/Makefile.am
Log:
Adding SIDL- and iMesh-based perf tests to tools/mbperf, and providing a factory implementation for SIDL iMesh.
Added: MOAB/trunk/tools/iMesh/SIDL/mserver/iMesh_Factory_Impl.cc
--- MOAB/trunk/tools/iMesh/SIDL/mserver/iMesh_Factory_Impl.cc (rev 0)
+++ MOAB/trunk/tools/iMesh/SIDL/mserver/iMesh_Factory_Impl.cc 2008-04-14 22:33:54 UTC (rev 1763)
@@ -0,0 +1,71 @@
+// File: iMesh_Factory_Impl.cc
+// Symbol: iMesh.Factory-v0.7
+// Symbol Type: class
+// Babel Version: 0.10.12
+// sidl Created: 20080414 17:40:04 GMT
+// Generated: 20080414 17:40:09 GMT
+// Description: Server-side implementation for iMesh.Factory
+// WARNING: Automatically generated; only changes within splicers preserved
+// babel-version = 0.10.12
+// source-line = 296
+// source-url = file:/home/tautges/MOAB/tools/iMesh/SIDL/iMesh.sidl
+#include "iMesh_Factory_Impl.hh"
+// DO-NOT-DELETE splicer.begin(iMesh.Factory._includes)
+// Insert-Code-Here {iMesh.Factory._includes} (additional includes or code)
+#include "iMesh_SIDL.hh"
+// DO-NOT-DELETE splicer.end(iMesh.Factory._includes)
+// user-defined constructor.
+void iMesh::Factory_impl::_ctor() {
+ // DO-NOT-DELETE splicer.begin(iMesh.Factory._ctor)
+ // Insert-Code-Here {iMesh.Factory._ctor} (constructor)
+ // DO-NOT-DELETE splicer.end(iMesh.Factory._ctor)
+// user-defined destructor.
+void iMesh::Factory_impl::_dtor() {
+ // DO-NOT-DELETE splicer.begin(iMesh.Factory._dtor)
+ // Insert-Code-Here {iMesh.Factory._dtor} (destructor)
+ // DO-NOT-DELETE splicer.end(iMesh.Factory._dtor)
+// static class initializer.
+void iMesh::Factory_impl::_load() {
+ // DO-NOT-DELETE splicer.begin(iMesh.Factory._load)
+ // Insert-Code-Here {iMesh.Factory._load} (class initialization)
+ // DO-NOT-DELETE splicer.end(iMesh.Factory._load)
+// user-defined static methods:
+ * Method: newMesh[]
+void
+iMesh::Factory_impl::newMesh (
+ /* in */ const ::std::string& option,
+ /* out */ ::iMesh::Mesh& new_mesh )
+throw (
+ ::iBase::Error
+ // DO-NOT-DELETE splicer.begin(iMesh.Factory.newMesh)
+ // Insert-Code-Here {iMesh.Factory.newMesh} (newMesh method)
+ try {
+ new_mesh = iMesh_SIDL::MeshSidl::_create();
+ } catch (iBase::Error err) {
+ throw err;
+ // DO-NOT-DELETE splicer.end(iMesh.Factory.newMesh)
+// user-defined non-static methods: (none)
+// DO-NOT-DELETE splicer.begin(iMesh.Factory._misc)
+// Insert-Code-Here {iMesh.Factory._misc} (miscellaneous code)
+// DO-NOT-DELETE splicer.end(iMesh.Factory._misc)
Modified: MOAB/trunk/tools/iMesh/iMesh_MOAB.cpp
--- MOAB/trunk/tools/iMesh/iMesh_MOAB.cpp 2008-04-14 18:18:46 UTC (rev 1762)
+++ MOAB/trunk/tools/iMesh/iMesh_MOAB.cpp 2008-04-14 22:33:54 UTC (rev 1763)
@@ -17,7 +17,7 @@
private:
bool haveDeletedEntities;
public:
- MBiMesh(int proc_rank = 0, int proc_size = 0)
+ MBiMesh(int proc_rank = 0, int proc_size = 1)
: MBCore(proc_rank, proc_size), haveDeletedEntities(false)
Modified: MOAB/trunk/tools/mbperf/Makefile.am
--- MOAB/trunk/tools/mbperf/Makefile.am 2008-04-14 18:18:46 UTC (rev 1762)
+++ MOAB/trunk/tools/mbperf/Makefile.am 2008-04-14 22:33:54 UTC (rev 1763)
@@ -6,3 +6,18 @@
mbperf_SOURCES = mbperf.cpp
LDADD = $(top_builddir)/libMOAB.la
mbperf_DEPENDENCIES = $(top_builddir)/libMOAB.la
+if USE_BABEL
+ INCLUDES += -I$(top_srcdir)/tools/iMesh/SIDL/mserver
+ bin_PROGRAMS += mbperf_SIDL
+ mbperf_SIDL_SOURCES = mbperf_SIDL.cpp
+ LDADD += $(top_builddir)/tools/iMesh/SIDL/mserver/libiMeshserver.la
+endif
+if ENABLE_imesh
+ bin_PROGRAMS += mbperf_iMesh
+ LDADD += $(top_builddir)/tools/iMesh/libiMesh.la
+ mbperf_iMesh_SOURCES = mbperf_iMesh.cpp
+endif
Added: MOAB/trunk/tools/mbperf/mbperf_SIDL.cpp
--- MOAB/trunk/tools/mbperf/mbperf_SIDL.cpp (rev 0)
+++ MOAB/trunk/tools/mbperf/mbperf_SIDL.cpp 2008-04-14 22:33:54 UTC (rev 1763)
@@ -0,0 +1,675 @@
+ * MOAB, a Mesh-Oriented datABase, is a software component for creating,
+ * storing and accessing finite element mesh data.
+ * Copyright 2004 Sandia Corporation. Under the terms of Contract
+ * DE-AC04-94AL85000 with Sandia Coroporation, the U.S. Government
+ * retains certain rights in this software.
+ * This library is free software; you can redistribute it and/or
+ * modify it under the terms of the GNU Lesser General Public
+ * License as published by the Free Software Foundation; either
+ * version 2.1 of the License, or (at your option) any later version.
+/** iMesh Mesh Interface brick mesh performance test
+ * This program tests iMesh mesh interface functions used to create a square structured
+ * mesh. Boilerplate taken from iMesh mesh interface test in MOAB and performance test in MOAB
+// Different platforms follow different conventions for usage
+#ifndef NT
+#include <sys/resource.h>
+#endif
+#ifdef SOLARIS
+extern "C" int getrusage(int, struct rusage *);
+#ifndef RUSAGE_SELF
+#include </usr/ucbinclude/sys/rusage.h>
+#endif
+#endif
+#include <stdlib.h>
+#include <stdio.h>
+#include <iostream>
+#include <assert.h>
+#include "iBase.hh"
+#include "iMesh.hh"
+#define CAST_INTERFACE(var_in, var_out, iface) \
+ iBase::iface var_out; \
+ try {var_out = var_in;}\
+ catch(iBase::Error) {\
+ cerr << "Error: current interface doesn't support iface." << endl; \
+ return;}
+#define CAST_MINTERFACE(var_in, var_out, iface) \
+ iMesh::iface var_out; \
+ return;}
+// needed to get the proper size for handles
+typedef void * Entity_Handle;
+using namespace std;
+#define ARRAY_PTR(array, type) reinterpret_cast<type*>(array._get_ior()->d_firstElement)
+#define HANDLE_ARRAY_PTR(array) reinterpret_cast<Entity_Handle*>(array._get_ior()->d_firstElement)
+#define ARRAY_SIZE(array) (array._is_nil() ? 0 : array.upper(0) - array.lower(0) + 1)
+#define CHECK_SIZE(array, size) \
+ if (array._is_nil() || ARRAY_SIZE(array) == 0) array = array.create1d(size); \
+ else if (ARRAY_SIZE(array) < size) { \
+ cerr << "Array passed in is non-zero but too short." << endl; \
+ assert(false); }
+double LENGTH = 1.0;
+// forward declare some functions
+void query_vert_to_elem(iMesh::Mesh &mesh);
+void query_elem_to_vert(iMesh::Mesh &mesh);
+void print_time(const bool print_em, double &tot_time, double &utime, double &stime);
+void build_connect(const int nelem, const int vstart, int *&connect);
+void testB(iMesh::Mesh &mesh,
+ const int nelem, sidl::array<double> &coords,
+ const int *connect);
+void testC(iMesh::Mesh &mesh, const int nelem, sidl::array<double> &coords);
+void compute_edge(double *start, const int nelem, const double xint,
+ const int stride);
+void compute_face(double *a, const int nelem, const double xint,
+ const int stride1, const int stride2);
+void build_coords(const int nelem, sidl::array<double> &coords);
+int main( int argc, char *argv[] )
+ int nelem = 20;
+ if (argc < 3) {
+ std::cout << "Usage: " << argv[0] << " <ints_per_side> <A|B|C>" << std::endl;
+ return 1;
+ char which_test = '\0';
+ sscanf(argv[1], "%d", &nelem);
+ sscanf(argv[2], "%c", &which_test);
+ if (which_test != 'B' && which_test != 'C') {
+ std::cout << "Must indicate B or C for test." << std::endl;
+ return 1;
+ std::cout << "number of elements: " << nelem << "; test "
+ << which_test << std::endl;
+ // pre-build the coords array
+ sidl::array<double> coords;
+ build_coords(nelem, coords);
+ assert(NULL != coords);
+ int *connect = NULL;
+ build_connect(nelem, 1, connect);
+ // create an implementation
+ iMesh::Mesh mesh;
+ try {
+ iMesh::Factory::newMesh("", mesh);
+ std::cerr << "Trouble creating imesh instance." << std::endl;
+ return 1;
+ switch (which_test) {
+ case 'B':
+ // test B: create mesh using bulk interface
+ testB(mesh, nelem, coords, connect);
+ break;
+ case 'C':
+ // test C: create mesh using individual interface
+ testC(mesh, nelem, coords);
+ break;
+ return 0;
+ double utime, stime, ttime0, ttime1, ttime2, ttime3;
+ print_time(false, ttime0, utime, stime);
+ int num_verts = (nelem + 1)*(nelem + 1)*(nelem + 1);
+ int num_elems = nelem*nelem*nelem;
+ // create vertices as a block
+ CAST_MINTERFACE(mesh, mesh_arrmod, ArrMod);
+ sidl::array<Entity_Handle> sidl_vertices, dum_handles;
+ CHECK_SIZE(dum_handles, num_verts);
+ int sidl_vertices_size;
+ try {
+ mesh_arrmod.createVtxArr(num_verts, iBase::StorageOrder_BLOCKED,
+ coords, 3*num_verts,
+ sidl_vertices, sidl_vertices_size);
+ cerr << "Couldn't create vertices in bulk call" << endl;
+ return;
+ // need to explicitly fill connectivity array, since we don't know
+ // the format of entity handles
+ sidl::array<Entity_Handle> sidl_connect;
+ int sidl_connect_size = 8 * num_elems;
+ CHECK_SIZE(sidl_connect, 8*num_elems);
+ Entity_Handle *sidl_connect_ptr = HANDLE_ARRAY_PTR(sidl_connect);
+ Entity_Handle *sidl_vertices_ptr = HANDLE_ARRAY_PTR(sidl_vertices);
+ for (int i = 0; i < sidl_connect_size; i++) {
+ // use connect[i]-1 because we used starting vertex index (vstart) of 1
+ assert(connect[i]-1 < num_verts);
+ sidl_connect_ptr[i] = sidl_vertices_ptr[connect[i]-1];
+ // create the entities
+ sidl::array<Entity_Handle> new_hexes;
+ int new_hexes_size;
+ sidl::array<iBase::CreationStatus> status;
+ int status_size;
+ try {
+ mesh_arrmod.createEntArr(iMesh::EntityTopology_HEXAHEDRON, sidl_connect,
+ sidl_connect_size, new_hexes, new_hexes_size,
+ status, status_size);
+ cerr << "Couldn't create hex elements in bulk call" << endl;
+ return;
+ print_time(false, ttime1, utime, stime);
+ // query the mesh 2 ways
+ query_elem_to_vert(mesh);
+ print_time(false, ttime2, utime, stime);
+ query_vert_to_elem(mesh);
+ print_time(false, ttime3, utime, stime);
+ std::cout << "iMesh/MOAB ucd blocked: nelem, construct, e_to_v query, v_to_e query = "
+ << nelem << ", "
+ << ttime1-ttime0 << ", "
+ << ttime2-ttime1 << ", "
+ << ttime3-ttime2 << " seconds"
+ << std::endl;
+ const int nelem, sidl::array<double> &coords)
+ // need some dimensions
+ int numv = nelem + 1;
+ int numv_sq = numv*numv;
+ int num_verts = numv*numv*numv;
+#define VINDEX(i,j,k) (i + (j*numv) + (k*numv_sq))
+ // array to hold vertices created individually
+ sidl::array<Entity_Handle> sidl_vertices;
+ int sidl_vertices_size = num_verts;
+ CHECK_SIZE(sidl_vertices, num_verts);
+ // temporary array to hold vertex positions for single vertex
+ sidl::array<double> tmp_coords;
+ int tmp_coords_size = 3;
+ CHECK_SIZE(tmp_coords, 3);
+ double *dum_coords = ARRAY_PTR(tmp_coords, double);
+ // get direct pointer to coordinate array
+ double *coords_ptr = ARRAY_PTR(coords, double);
+ for (int i = 0; i < num_verts; i++) {
+ // temporary array to hold (single) vertices
+ sidl::array<Entity_Handle> tmp_vertices;
+ int tmp_vertices_size = 0;
+ // create the vertex
+ dum_coords[0] = coords_ptr[i];
+ dum_coords[1] = coords_ptr[num_verts+i];
+ dum_coords[2] = coords_ptr[2*num_verts+i];
+ try {
+ mesh_arrmod.createVtxArr(1, iBase::StorageOrder_BLOCKED,
+ tmp_coords, tmp_coords_size,
+ tmp_vertices, tmp_vertices_size);
+ cerr << "Couldn't create vertex in individual call" << endl;
+ return;
+ // assign into permanent vertex array
+ sidl_vertices.set(i, tmp_vertices.get(0));
+ // get vertex array pointer for reading into tmp_conn
+ Entity_Handle *tmp_sidl_vertices = HANDLE_ARRAY_PTR(sidl_vertices);
+ for (int i=0; i < nelem; i++) {
+ for (int j=0; j < nelem; j++) {
+ for (int k=0; k < nelem; k++) {
+ sidl::array<Entity_Handle> tmp_conn;
+ int tmp_conn_size = 8;
+ CHECK_SIZE(tmp_conn, 8);
+ int vijk = VINDEX(i,j,k);
+ tmp_conn.set(0, tmp_sidl_vertices[vijk]);
+ tmp_conn.set(1, tmp_sidl_vertices[vijk+1]);
+ tmp_conn.set(2, tmp_sidl_vertices[vijk+1+numv]);
+ tmp_conn.set(3, tmp_sidl_vertices[vijk+numv]);
+ tmp_conn.set(4, tmp_sidl_vertices[vijk+numv*numv]);
+ tmp_conn.set(5, tmp_sidl_vertices[vijk+1+numv*numv]);
+ tmp_conn.set(6, tmp_sidl_vertices[vijk+1+numv+numv*numv]);
+ tmp_conn.set(7, tmp_sidl_vertices[vijk+numv+numv*numv]);
+ // create the entity
+ sidl::array<Entity_Handle> new_hex;
+ int new_hex_size = 0;
+ int status_size = 0;
+ try {
+ tmp_conn, tmp_conn_size,
+ new_hex, new_hex_size,
+ cerr << "Couldn't create hex element in individual call" << endl;
+ return;
+ std::cout << "TSTT/MOAB ucd indiv: nelem, construct, e_to_v query, v_to_e query = "
+ << nelem << ", "
+ << std::endl;
+ sidl::array<Entity_Handle> all_hexes;
+ int all_hexes_size;
+ CAST_MINTERFACE(mesh, mesh_ent, Entity);
+ // get all the hex elements
+ try {
+ mesh.getEntities(0, iBase::EntityType_REGION, iMesh::EntityTopology_HEXAHEDRON,
+ all_hexes, all_hexes_size);
+ cerr << "Couldn't get all hex elements in query_mesh" << endl;
+ return;
+ try {
+ // set up some tmp arrays and array ptrs
+ Entity_Handle *all_hexes_ptr = HANDLE_ARRAY_PTR(all_hexes);
+ // now loop over elements
+ for (int i = 0; i < all_hexes_size; i++) {
+ sidl::array<int> dum_offsets;
+ sidl::array<Entity_Handle> dum_connect;
+ int dum_connect_size = 0;
+ // get the connectivity of this element; will allocate space on 1st iteration,
+ // but will have correct size on subsequent ones
+ mesh_ent.getEntAdj(all_hexes_ptr[i], iBase::EntityType_VERTEX,
+ dum_connect, dum_connect_size);
+ // get vertex coordinates; ; will allocate space on 1st iteration,
+ sidl::array<double> dum_coords;
+ int dum_coords_size = 0;
+ iBase::StorageOrder order = iBase::StorageOrder_UNDETERMINED;
+ mesh.getVtxArrCoords(dum_connect, dum_connect_size, order,
+ dum_coords, dum_coords_size);
+ assert(24 == dum_coords_size && ARRAY_SIZE(dum_coords) == 24);
+ double *dum_coords_ptr = ARRAY_PTR(dum_coords, double);
+ double centroid[3] = {0.0, 0.0, 0.0};
+ if (order == iBase::StorageOrder_BLOCKED) {
+ for (int j = 0; j < 8; j++) {
+ centroid[0] += dum_coords_ptr[j];
+ centroid[1] += dum_coords_ptr[8+j];
+ centroid[2] += dum_coords_ptr[16+j];
+ centroid[0] += dum_coords.get(j);
+ centroid[1] += dum_coords.get(8+j);
+ centroid[2] += dum_coords.get(16+j);
+ else {
+ centroid[0] += dum_coords_ptr[3*j];
+ centroid[1] += dum_coords_ptr[3*j+1];
+ centroid[2] += dum_coords_ptr[3*j+2];
+ cerr << "Problem getting connectivity or vertex coords." << endl;
+ return;
+ sidl::array<Entity_Handle> all_verts;
+ int all_verts_size;
+ // get all the vertices elements
+ try {
+ mesh.getEntities(0, iBase::EntityType_VERTEX,
+ iMesh::EntityTopology_POINT, all_verts, all_verts_size);
+ cerr << "Couldn't get all vertices in query_vert_to_elem" << endl;
+ return;
+ try {
+ Entity_Handle *all_verts_ptr = HANDLE_ARRAY_PTR(all_verts);
+ // now loop over vertices
+ for (int i = 0; i < all_verts_size; i++) {
+ sidl::array<Entity_Handle> dum_hexes;
+ int dum_hexes_size;
+ // get the connectivity of this element; will have to allocate space on every
+ // iteration, since size can vary
+ mesh_ent.getEntAdj(all_verts_ptr[i], iBase::EntityType_REGION,
+ dum_hexes, dum_hexes_size);
+ return;
+ struct rusage r_usage;
+ getrusage(RUSAGE_SELF, &r_usage);
+ utime = (double)r_usage.ru_utime.tv_sec +
+ ((double)r_usage.ru_utime.tv_usec/1.e6);
+ stime = (double)r_usage.ru_stime.tv_sec +
+ ((double)r_usage.ru_stime.tv_usec/1.e6);
+ tot_time = utime + stime;
+ if (print_em)
+ std::cout << "User, system, total time = " << utime << ", " << stime
+ << ", " << tot_time << std::endl;
+#ifndef LINUX
+ std::cout << "Max resident set size = " << r_usage.ru_maxrss*4096 << " bytes" << std::endl;
+ std::cout << "Int resident set size = " << r_usage.ru_idrss << std::endl;
+#else
+ system("ps o args,drs,rss | grep perf | grep -v grep"); // RedHat 9.0 doesnt fill in actual memory data
+#endif
+ const int stride)
+ for (int i = 1; i < nelem; i++) {
+ start[i*stride] = start[0]+i*xint;
+ start[nelem+1+i*stride] = start[nelem+1]+i*xint;
+ start[2*(nelem+1)+i*stride] = start[2*(nelem+1)]+i*xint;
+ // 2D TFI on a face starting at a, with strides stride1 in ada and stride2 in tse
+ for (int j = 1; j < nelem; j++) {
+ double tse = j * xint;
+ double ada = i * xint;
+ a[i*stride1+j*stride2] = (1.0 - ada)*a[i*stride1]
+ + ada*a[i*stride1+nelem*stride2]
+ + (1.0 - tse)*a[j*stride2]
+ + tse*a[j*stride2+nelem*stride1]
+ - (1.0 - tse)*(1.0 - ada)*a[0]
+ - (1.0 - tse)*ada*a[nelem*stride1]
+ - tse*(1.0 - ada)*a[nelem*stride2]
+ - tse*ada*a[nelem*(stride1+stride2)];
+ a[nelem+1+i*stride1+j*stride2] = (1.0 - ada)*a[nelem+1+i*stride1]
+ + ada*a[nelem+1+i*stride1+nelem*stride2]
+ + (1.0 - tse)*a[nelem+1+j*stride2]
+ + tse*a[nelem+1+j*stride2+nelem*stride1]
+ - (1.0 - tse)*(1.0 - ada)*a[nelem+1+0]
+ - (1.0 - tse)*ada*a[nelem+1+nelem*stride1]
+ - tse*(1.0 - ada)*a[nelem+1+nelem*stride2]
+ - tse*ada*a[nelem+1+nelem*(stride1+stride2)];
+ a[2*(nelem+1)+i*stride1+j*stride2] = (1.0 - ada)*a[2*(nelem+1)+i*stride1]
+ + ada*a[2*(nelem+1)+i*stride1+nelem*stride2]
+ + (1.0 - tse)*a[2*(nelem+1)+j*stride2]
+ + tse*a[2*(nelem+1)+j*stride2+nelem*stride1]
+ - (1.0 - tse)*(1.0 - ada)*a[2*(nelem+1)+0]
+ - (1.0 - tse)*ada*a[2*(nelem+1)+nelem*stride1]
+ - tse*(1.0 - ada)*a[2*(nelem+1)+nelem*stride2]
+ - tse*ada*a[2*(nelem+1)+nelem*(stride1+stride2)];
+ double ttime0, ttime1, utime1, stime1;
+ print_time(false, ttime0, utime1, stime1);
+ // allocate the memory
+ int numv = nelem+1;
+ int tot_numv = numv*numv*numv;
+ CHECK_SIZE(coords, 3*tot_numv);
+// use FORTRAN-like indexing
+ int idx;
+ double scale1, scale2, scale3;
+ // use these to prevent optimization on 1-scale, etc (real map wouldn't have
+ // all these equal)
+ scale1 = LENGTH/nelem;
+ scale2 = LENGTH/nelem;
+ scale3 = LENGTH/nelem;
+#ifdef REALTFI
+ // use a real TFI xform to compute coordinates
+ // initialize positions of 8 corners
+ coords_ptr[VINDEX(0,0,0)] = coords_ptr[VINDEX(0,0,0)+nelem+1] = coords_ptr[VINDEX(0,0,0)+2*(nelem+1)] = 0.0;
+ coords_ptr[VINDEX(0,nelem,0)] = coords_ptr[VINDEX(0,nelem,0)+2*(nelem+1)] = 0.0; coords_ptr[VINDEX(0,nelem,0)+nelem+1] = LENGTH;
+ coords_ptr[VINDEX(0,0,nelem)] = coords_ptr[VINDEX(0,0,nelem)+nelem+1] = 0.0; coords_ptr[VINDEX(0,0,nelem)+2*(nelem+1)] = LENGTH;
+ coords_ptr[VINDEX(0,nelem,nelem)] = 0.0; coords_ptr[VINDEX(0,nelem,nelem)+nelem+1] = coords_ptr[VINDEX(0,nelem,nelem)+2*(nelem+1)] = LENGTH;
+ coords_ptr[VINDEX(nelem,0,0)] = LENGTH; coords_ptr[VINDEX(nelem,0,0)+nelem+1] = coords_ptr[VINDEX(nelem,0,0)+2*(nelem+1)] = 0.0;
+ coords_ptr[VINDEX(nelem,0,nelem)] = coords_ptr[VINDEX(nelem,0,nelem)+2*(nelem+1)] = LENGTH; coords_ptr[VINDEX(nelem,0,nelem)+nelem+1] = 0.0;
+ coords_ptr[VINDEX(nelem,nelem,0)] = coords_ptr[VINDEX(nelem,nelem,0)+nelem+1] = LENGTH; coords_ptr[VINDEX(nelem,nelem,0)+2*(nelem+1)] = 0.0;
+ coords_ptr[VINDEX(nelem,nelem,nelem)] = coords_ptr[VINDEX(nelem,nelem,nelem)+nelem+1] = coords_ptr[VINDEX(nelem,nelem,nelem)+2*(nelem+1)] = LENGTH;
+ // compute edges
+ // i (stride=1)
+ compute_edge(&coords_ptr[VINDEX(0,0,0)], nelem, scale1, 1);
+ compute_edge(&coords_ptr[VINDEX(0,nelem,0)], nelem, scale1, 1);
+ compute_edge(&coords_ptr[VINDEX(0,0,nelem)], nelem, scale1, 1);
+ compute_edge(&coords_ptr[VINDEX(0,nelem,nelem)], nelem, scale1, 1);
+ // j (stride=numv)
+ compute_edge(&coords_ptr[VINDEX(0,0,0)], nelem, scale1, numv);
+ compute_edge(&coords_ptr[VINDEX(nelem,0,0)], nelem, scale1, numv);
+ compute_edge(&coords_ptr[VINDEX(0,0,nelem)], nelem, scale1, numv);
+ compute_edge(&coords_ptr[VINDEX(nelem,0,nelem)], nelem, scale1, numv);
+ // k (stride=numv^2)
+ compute_edge(&coords_ptr[VINDEX(0,0,0)], nelem, scale1, numv_sq);
+ compute_edge(&coords_ptr[VINDEX(nelem,0,0)], nelem, scale1, numv_sq);
+ compute_edge(&coords_ptr[VINDEX(0,nelem,0)], nelem, scale1, numv_sq);
+ compute_edge(&coords_ptr[VINDEX(nelem,nelem,0)], nelem, scale1, numv_sq);
+ // compute faces
+ // i=0, nelem
+ compute_face(&coords_ptr[VINDEX(0,0,0)], nelem, scale1, numv, numv_sq);
+ compute_face(&coords_ptr[VINDEX(nelem,0,0)], nelem, scale1, numv, numv_sq);
+ // j=0, nelem
+ compute_face(&coords_ptr[VINDEX(0,0,0)], nelem, scale1, 1, numv_sq);
+ compute_face(&coords_ptr[VINDEX(0,nelem,0)], nelem, scale1, 1, numv_sq);
+ // k=0, nelem
+ compute_face(&coords_ptr[VINDEX(0,0,0)], nelem, scale1, 1, numv);
+ compute_face(&coords_ptr[VINDEX(0,0,nelem)], nelem, scale1, 1, numv);
+ // initialize corner indices
+ int i000 = VINDEX(0,0,0);
+ int ia00 = VINDEX(nelem,0,0);
+ int i0t0 = VINDEX(0,nelem,0);
+ int iat0 = VINDEX(nelem,nelem,0);
+ int i00g = VINDEX(0,0,nelem);
+ int ia0g = VINDEX(nelem,0,nelem);
+ int i0tg = VINDEX(0,nelem,nelem);
+ int iatg = VINDEX(nelem,nelem,nelem);
+ double cX, cY, cZ;
+ int adaInts = nelem;
+ int tseInts = nelem;
+ int gammaInts = nelem;
+ for (int i=1; i < nelem; i++) {
+ for (int j=1; j < nelem; j++) {
+ for (int k=1; k < nelem; k++) {
+ idx = VINDEX(i,j,k);
+ double tse = i*scale1;
+ double ada = j*scale2;
+ double gamma = k*scale3;
+ double tm1 = 1.0 - tse;
+ double am1 = 1.0 - ada;
+ double gm1 = 1.0 - gamma;
+ cX = gm1 * (am1*(tm1*coords_ptr[i000] + tse*coords_ptr[i0t0]) +
+ ada*(tm1*coords_ptr[ia00] + tse*coords_ptr[iat0])) +
+ gamma * (am1*(tm1*coords_ptr[i00g] + tse*coords_ptr[i0tg]) +
+ ada*(tm1*coords_ptr[ia0g] + tse*coords_ptr[iatg]));
+ cY = gm1 * (am1*(tm1*coords_ptr[i000] + tse*coords_ptr[i0t0]) +
+ cZ = gm1 * (am1*(tm1*coords_ptr[i000] + tse*coords_ptr[i0t0]) +
+ double *ai0k = &coords_ptr[VINDEX(k,0,i)];
+ double *aiak = &coords_ptr[VINDEX(k,adaInts,i)];
+ double *a0jk = &coords_ptr[VINDEX(k,j,0)];
+ double *atjk = &coords_ptr[VINDEX(k,j,tseInts)];
+ double *aij0 = &coords_ptr[VINDEX(0,j,i)];
+ double *aijg = &coords_ptr[VINDEX(gammaInts,j,i)];
+ coords_ptr[VINDEX(i,j,k)] = ( am1*ai0k[0]
+ + ada*aiak[0]
+ + tm1*a0jk[0]
+ + tse*atjk[0]
+ + gm1*aij0[0]
+ + gamma*aijg[0] )/2.0 - cX/2.0;
+ coords_ptr[nelem+1+VINDEX(i,j,k)] = ( am1*ai0k[nelem+1]
+ + ada*aiak[nelem+1]
+ + tm1*a0jk[nelem+1]
+ + tse*atjk[nelem+1]
+ + gm1*aij0[nelem+1]
+ + gamma*aijg[nelem+1] )/2.0 - cY/2.0;
+ coords_ptr[2*(nelem+1)+VINDEX(i,j,k)] = ( am1*ai0k[2*(nelem+1)]
+ + ada*aiak[2*(nelem+1)]
+ + tm1*a0jk[2*(nelem+1)]
+ + tse*atjk[2*(nelem+1)]
+ + gm1*aij0[2*(nelem+1)]
+ + gamma*aijg[2*(nelem+1)] )/2.0 - cZ/2.0;
+#else
+ for (int i=0; i < numv; i++) {
+ for (int j=0; j < numv; j++) {
+ for (int k=0; k < numv; k++) {
+ // blocked coordinate ordering
+ coords_ptr[idx] = i*scale1;
+ coords_ptr[tot_numv+idx] = j*scale2;
+ coords_ptr[2*tot_numv+idx] = k*scale3;
+#endif
+ print_time(false, ttime1, utime1, stime1);
+ std::cout << "TSTT/MOAB: TFI time = " << ttime1-ttime0 << " sec"
+ << std::endl;
+ int nume_tot = nelem*nelem*nelem;
+ connect = new int[8*nume_tot];
+ int vijk;
+ int idx = 0;
+ vijk = vstart+VINDEX(i,j,k);
+ connect[idx++] = vijk;
+ connect[idx++] = vijk+1;
+ connect[idx++] = vijk+1+numv;
+ connect[idx++] = vijk+numv;
+ connect[idx++] = vijk+numv*numv;
+ connect[idx++] = vijk+1+numv*numv;
+ connect[idx++] = vijk+1+numv+numv*numv;
+ connect[idx++] = vijk+numv+numv*numv;
+ assert(i <= numv*numv*numv);
Added: MOAB/trunk/tools/mbperf/mbperf_iMesh.cpp
--- MOAB/trunk/tools/mbperf/mbperf_iMesh.cpp (rev 0)
+++ MOAB/trunk/tools/mbperf/mbperf_iMesh.cpp 2008-04-14 22:33:54 UTC (rev 1763)
@@ -0,0 +1,576 @@
+ * mesh. Boilerplate taken from tstt mesh interface test in MOAB and performance test in MOAB
+#ifndef NT
+#endif
+#ifdef SOLARIS
+#endif
+#endif
+#include <stdio.h>
+#include "iMesh.h"
+void query_elem_to_vert(iMesh_Instance mesh);
+void query_vert_to_elem(iMesh_Instance mesh);
+void testB(iMesh_Instance mesh, const int nelem, const double *coords, const int *connect);
+void testC(iMesh_Instance mesh, const int nelem, const double *coords);
+void build_coords(const int nelem, double *&coords);
+ int nelem = 20;
+ if (argc < 3) {
+ return 1;
+ return 1;
+ // initialize the data in native format
+ double ttime0, utime1, stime1, ttime1;
+ double *coords;
+ iMesh_Instance mesh;
+ int result;
+ iMesh_newMesh(NULL, &mesh, &result, 0);
+ if (iBase_SUCCESS != result) {
+ cerr << "Couldn't create mesh instance." << endl;
+ return 1;
+ case 'B':
+ break;
+ case 'C':
+ break;
+ return 0;
+ const int nelem, const double *coords,
+ // create vertices as a block; initialize to NULL so allocation is done in interface
+ iBase_EntityHandle *vertices = NULL;
+ int vertices_allocated = 0, vertices_size;
+ int result;
+ iMesh_createVtxArr(mesh, num_verts, iBase_BLOCKED,
+ &vertices, &vertices_allocated, &vertices_size, &result);
+ return;
+ int nconnect = 8 * num_elems;
+ iBase_EntityHandle *sidl_connect = (iBase_EntityHandle*) malloc(nconnect*sizeof(iBase_EntityHandle));
+ for (int i = 0; i < nconnect; i++) {
+ sidl_connect[i] = vertices[connect[i]-1];
+ iBase_EntityHandle *new_hexes = NULL;
+ int new_hexes_allocated = 0, new_hexes_size;
+ int *status = NULL;
+ int status_allocated = 0, status_size;
+ iMesh_createEntArr(mesh, iMesh_HEXAHEDRON, sidl_connect, nconnect,
+ &new_hexes, &new_hexes_allocated, &new_hexes_size,
+ &status, &status_allocated, &status_size, &result);
+ return;
+ std::cout << "iMeshb/MOAB ucd blocked: nelem, construct, e_to_v query, v_to_e query = "
+ << nelem << ", "
+ << std::endl;
+ iBase_EntityHandle *sidl_vertices = (iBase_EntityHandle*) malloc(num_verts*sizeof(iBase_EntityHandle));
+ int result;
+ iMesh_createVtx(mesh, coords[3*i], coords[3*i+1], coords[3*i+2],
+ sidl_vertices+i, &result);
+ return;
+ iBase_EntityHandle tmp_conn[8], new_hex;
+ tmp_conn[0] = sidl_vertices[vijk];
+ tmp_conn[1] = sidl_vertices[vijk+1];
+ tmp_conn[2] = sidl_vertices[vijk+1+numv];
+ tmp_conn[3] = sidl_vertices[vijk+numv];
+ tmp_conn[4] = sidl_vertices[vijk+numv*numv];
+ tmp_conn[5] = sidl_vertices[vijk+1+numv*numv];
+ tmp_conn[6] = sidl_vertices[vijk+1+numv+numv*numv];
+ tmp_conn[7] = sidl_vertices[vijk+numv+numv*numv];
+ int status;
+ iMesh_createEnt(mesh, iMesh_HEXAHEDRON, tmp_conn, 8,
+ &new_hex, &status, &result);
+ return;
+ std::cout << "iMeshb/MOAB ucd indiv: nelem, construct, e_to_v query, v_to_e query = "
+ << nelem << ", "
+ << std::endl;
+ iBase_EntityHandle *all_hexes = NULL;
+ int all_hexes_size, all_hexes_allocated = 0;
+ int success;
+ iMesh_getEntities(mesh, 0, iBase_REGION,
+ iMesh_HEXAHEDRON,
+ &all_hexes, &all_hexes_allocated,
+ &all_hexes_size, &success);
+ if (iBase_SUCCESS != success) {
+ return;
+ iBase_EntityHandle *dum_connect = NULL;
+ int dum_connect_allocated = 0, dum_connect_size;
+ double *dum_coords = NULL;
+ int dum_coords_size, dum_coords_allocated = 0;
+ iMesh_getEntAdj(mesh, all_hexes[i], iBase_VERTEX,
+ &dum_connect, &dum_connect_allocated, &dum_connect_size,
+ &success);
+ if (iBase_SUCCESS == success) {
+ int order = iBase_UNDETERMINED;
+ iMesh_getVtxArrCoords(mesh, dum_connect, dum_connect_size,
+ &order,
+ &dum_coords, &dum_coords_allocated,
+ &dum_coords_size, &success);
+ if (order == iBase_BLOCKED) {
+ centroid[0] += dum_coords[j];
+ centroid[1] += dum_coords[8+j];
+ centroid[2] += dum_coords[16+j];
+ else {
+ centroid[0] += dum_coords[3*j];
+ centroid[1] += dum_coords[3*j+1];
+ centroid[2] += dum_coords[3*j+2];
+ return;
+ iBase_EntityHandle *all_verts = NULL;
+ int all_verts_allocated = 0, all_verts_size;
+ int success;
+ iMesh_getEntities(mesh, 0, iBase_VERTEX,
+ iMesh_POINT, &all_verts,
+ &all_verts_allocated, &all_verts_size, &success);
+ return;
+ iBase_EntityHandle *dum_hexes = NULL;
+ int dum_hexes_allocated = 0, dum_hexes_size;
+ iMesh_getEntAdj(mesh, all_verts[i], iBase_REGION,
+ &dum_hexes, &dum_hexes_allocated, &dum_hexes_size,
+ &success);
+ return;
+ if (print_em)
+#ifndef LINUX
+#else
+#endif
+ //delete [] hex_array;
+ const int stride)
+ coords = (double*) malloc(3*tot_numv*sizeof(double));
+ int idx;
+#ifdef REALTFI
+ // compute edges
+ // i (stride=1)
+ compute_edge(&coords[VINDEX(0,0,0)], nelem, scale1, 1);
+ compute_edge(&coords[VINDEX(0,nelem,0)], nelem, scale1, 1);
+ compute_edge(&coords[VINDEX(0,0,nelem)], nelem, scale1, 1);
+ compute_edge(&coords[VINDEX(0,nelem,nelem)], nelem, scale1, 1);
+ compute_edge(&coords[VINDEX(0,0,0)], nelem, scale1, numv);
+ compute_edge(&coords[VINDEX(nelem,0,0)], nelem, scale1, numv);
+ compute_edge(&coords[VINDEX(0,0,nelem)], nelem, scale1, numv);
+ compute_edge(&coords[VINDEX(nelem,0,nelem)], nelem, scale1, numv);
+ compute_edge(&coords[VINDEX(0,0,0)], nelem, scale1, numv_sq);
+ compute_edge(&coords[VINDEX(nelem,0,0)], nelem, scale1, numv_sq);
+ compute_edge(&coords[VINDEX(0,nelem,0)], nelem, scale1, numv_sq);
+ compute_edge(&coords[VINDEX(nelem,nelem,0)], nelem, scale1, numv_sq);
+ // compute faces
+ // i=0, nelem
+ compute_face(&coords[VINDEX(0,0,0)], nelem, scale1, numv, numv_sq);
+ compute_face(&coords[VINDEX(nelem,0,0)], nelem, scale1, numv, numv_sq);
+ // j=0, nelem
+ compute_face(&coords[VINDEX(0,0,0)], nelem, scale1, 1, numv_sq);
+ compute_face(&coords[VINDEX(0,nelem,0)], nelem, scale1, 1, numv_sq);
+ // k=0, nelem
+ compute_face(&coords[VINDEX(0,0,0)], nelem, scale1, 1, numv);
+ compute_face(&coords[VINDEX(0,0,nelem)], nelem, scale1, 1, numv);
+ cX = gm1 * (am1*(tm1*coords[i000] + tse*coords[i0t0]) +
+ ada*(tm1*coords[ia00] + tse*coords[iat0])) +
+ gamma * (am1*(tm1*coords[i00g] + tse*coords[i0tg]) +
+ ada*(tm1*coords[ia0g] + tse*coords[iatg]));
+ cY = gm1 * (am1*(tm1*coords[i000] + tse*coords[i0t0]) +
+ cZ = gm1 * (am1*(tm1*coords[i000] + tse*coords[i0t0]) +
+ double *ai0k = &coords[VINDEX(k,0,i)];
+ double *aiak = &coords[VINDEX(k,adaInts,i)];
+ double *a0jk = &coords[VINDEX(k,j,0)];
+ double *atjk = &coords[VINDEX(k,j,tseInts)];
+ double *aij0 = &coords[VINDEX(0,j,i)];
+ double *aijg = &coords[VINDEX(gammaInts,j,i)];
+ coords[VINDEX(i,j,k)] = ( am1*ai0k[0]
+ + ada*aiak[0]
+ + tm1*a0jk[0]
+ + tse*atjk[0]
+ + gm1*aij0[0]
+ coords[nelem+1+VINDEX(i,j,k)] = ( am1*ai0k[nelem+1]
+ coords[2*(nelem+1)+VINDEX(i,j,k)] = ( am1*ai0k[2*(nelem+1)]
+#else
+ coords[idx] = i*scale1;
+ coords[tot_numv+idx] = j*scale2;
+ coords[2*tot_numv+idx] = k*scale3;
+#endif
+ std::cout << "iMesh/MOAB: TFI time = " << ttime1-ttime0 << " sec"
+ << std::endl;
+ connect = (int*) malloc(8*nume_tot*sizeof(int));
+ int vijk;
+ int idx = 0;
