[MOAB-dev] r1290 - in MOAB/trunk: . tools/mbperf tools/spheredecomp tools/surfplot
kraftche at mcs.anl.gov
Tue Sep 25 14:41:38 CDT 2007
Author: kraftche
Date: 2007-09-25 14:41:38 -0500 (Tue, 25 Sep 2007)
New Revision: 1290
Modified:
MOAB/trunk/configure.in
MOAB/trunk/tools/mbperf/mbperf.cpp
MOAB/trunk/tools/spheredecomp/SphereDecomp.cpp
MOAB/trunk/tools/surfplot/Makefile.am
MOAB/trunk/tools/surfplot/surfplot.cpp
Log:
o fix tool build errors resulting from API changes
o fix out-of-tree build of surfplot tool.
o default to building all tools that don't have external dependencies
(everything except mbchaco, mbzoltan, and qvdual)
Modified: MOAB/trunk/configure.in
--- MOAB/trunk/configure.in 2007-09-25 17:34:22 UTC (rev 1289)
+++ MOAB/trunk/configure.in 2007-09-25 19:41:38 UTC (rev 1290)
@@ -190,18 +190,18 @@
AC_HELP_STRING([--disable-tools],[Disable all tools by default])],
[ENABLE_TOOLS=$enableval],[ENABLE_TOOLS=] )
# Individual tools
-MB_OPTIONAL_TOOL([mbconvert], [yes])
-MB_OPTIONAL_TOOL([hexmodops], [no] )
-MB_OPTIONAL_TOOL([mbchaco], [no] )
-MB_OPTIONAL_TOOL([mbperf], [no] )
-MB_OPTIONAL_TOOL([qvdual], [no] )
-MB_OPTIONAL_TOOL([mbsize], [no] )
-MB_OPTIONAL_TOOL([mbskin], [no] )
-MB_OPTIONAL_TOOL([mbtagprop], [no] )
-MB_OPTIONAL_TOOL([spheredecomp], [no] )
-MB_OPTIONAL_TOOL([mbsurfplot], [no] )
-MB_OPTIONAL_TOOL([mbzoltan], [no] )
-MB_OPTIONAL_TOOL([dagmc], [no] )
+MB_OPTIONAL_TOOL([mbconvert], [yes])
+MB_OPTIONAL_TOOL([hexmodops], [yes])
+MB_OPTIONAL_TOOL([mbchaco], [no] )
+MB_OPTIONAL_TOOL([mbperf], [yes])
+MB_OPTIONAL_TOOL([qvdual], [no] )
+MB_OPTIONAL_TOOL([mbsize], [yes])
+MB_OPTIONAL_TOOL([mbskin], [yes])
+MB_OPTIONAL_TOOL([mbtagprop], [yes])
+MB_OPTIONAL_TOOL([spheredecomp], [yes])
+MB_OPTIONAL_TOOL([mbsurfplot], [yes])
+MB_OPTIONAL_TOOL([mbzoltan], [no] )
+MB_OPTIONAL_TOOL([dagmc], [yes])
Modified: MOAB/trunk/tools/mbperf/mbperf.cpp
--- MOAB/trunk/tools/mbperf/mbperf.cpp 2007-09-25 17:34:22 UTC (rev 1289)
+++ MOAB/trunk/tools/mbperf/mbperf.cpp 2007-09-25 19:41:38 UTC (rev 1290)
@@ -525,7 +525,7 @@
// create a sequence to hold the node coordinates
// get the current number of entities and start at the next slot
std::vector<double*> coord_arrays;
- MBErrorCode result = readMeshIface->get_node_arrays(3, num_verts, 1, vstart, coord_arrays);
+ MBErrorCode result = readMeshIface->get_node_arrays(3, num_verts, 1, 0, vstart, coord_arrays);
assert(MB_SUCCESS == result && 1 == vstart &&
coord_arrays[0] && coord_arrays[1] && coord_arrays[2]);
// memcpy the coordinate data into place
@@ -534,7 +534,7 @@
memcpy(coord_arrays[2], &coords[2*num_verts], sizeof(double)*num_verts);
MBEntityHandle *conn = 0;
- result = readMeshIface->get_element_array(num_elems, 8, MBHEX, 1, estart, conn);
+ result = readMeshIface->get_element_array(num_elems, 8, MBHEX, 1, 0, estart, conn);
assert(MB_SUCCESS == result);
memcpy(conn, connect, num_elems*8*sizeof(MBEntityHandle));
result = readMeshIface->update_adjacencies(estart, num_elems, 8, conn);
Modified: MOAB/trunk/tools/spheredecomp/SphereDecomp.cpp
--- MOAB/trunk/tools/spheredecomp/SphereDecomp.cpp 2007-09-25 17:34:22 UTC (rev 1289)
+++ MOAB/trunk/tools/spheredecomp/SphereDecomp.cpp 2007-09-25 19:41:38 UTC (rev 1290)
@@ -431,8 +431,11 @@
result = mbImpl->get_connectivity(&this_ent, 1, this_conn); RR;
// get relative orientation
+ std::vector<int> conn_tet_indices(this_conn.size());
+ for (size_t i = 0; i < this_conn.size(); ++i)
+ conn_tet_indices[i] = std::find(tet_conn, tet_conn+4, this_conn[i]) - tet_conn;
int sense, side_no, offset;
- int success = MBCN::SideNumber(tet_conn, MBTET, &this_conn[0],
+ int success = MBCN::SideNumber(MBTET, &conn_tet_indices[0],
this_conn.size(), dim, side_no, sense, offset);
if (-1 == success) return MB_FAILURE;
Modified: MOAB/trunk/tools/surfplot/Makefile.am
--- MOAB/trunk/tools/surfplot/Makefile.am 2007-09-25 17:34:22 UTC (rev 1289)
+++ MOAB/trunk/tools/surfplot/Makefile.am 2007-09-25 19:41:38 UTC (rev 1290)
@@ -1,6 +1,6 @@
AUTOMAKE_OPTIONS = foreign
DEFS = $(DEFINES)
-INCLUDES += -I$(top_builddir) -I$(top_builddir)
+INCLUDES += -I$(top_srcdir) -I$(top_builddir)
bin_PROGRAMS = mbsurfplot
mbsurfplot_SOURCES = surfplot.cpp
LDADD = $(top_builddir)/libMOAB.la
Modified: MOAB/trunk/tools/surfplot/surfplot.cpp
--- MOAB/trunk/tools/surfplot/surfplot.cpp 2007-09-25 17:34:22 UTC (rev 1289)
+++ MOAB/trunk/tools/surfplot/surfplot.cpp 2007-09-25 19:41:38 UTC (rev 1290)
@@ -4,6 +4,7 @@
#include <iostream>
#include <fstream>
#include <limits>
+#include <math.h>
/* Exit values */
#define USAGE_ERROR 1
