[MOAB-dev] r1289 - in MOAB/branches: . range_map
    kraftche at mcs.anl.gov
    Tue Sep 25 12:34:22 CDT 2007
Author: kraftche
Date: 2007-09-25 12:34:22 -0500 (Tue, 25 Sep 2007)
New Revision: 1289
Added:
   MOAB/branches/range_map/
   MOAB/branches/range_map/MBFileReadTool.cpp
   MOAB/branches/range_map/MBFileReadTool.hpp
   MOAB/branches/range_map/RangeMap.hpp
   MOAB/branches/range_map/RangeMapTest.cpp
Modified:
   MOAB/branches/range_map/Makefile.am
Log:
Branch for RangeMap class and new file read utility using RangeMap
Copied: MOAB/branches/range_map (from rev 1288, MOAB/trunk)
Added: MOAB/branches/range_map/MBFileReadTool.cpp
--- MOAB/branches/range_map/MBFileReadTool.cpp	                        (rev 0)
+++ MOAB/branches/range_map/MBFileReadTool.cpp	2007-09-25 17:34:22 UTC (rev 1289)
@@ -0,0 +1,330 @@
+ * MOAB, a Mesh-Oriented datABase, is a software component for creating,
+ * storing and accessing finite element mesh data.
+ * Copyright 2004 Sandia Corporation.  Under the terms of Contract
+ * DE-AC04-94AL85000 with Sandia Coroporation, the U.S. Government
+ * retains certain rights in this software.
+ * This library is free software; you can redistribute it and/or
+ * modify it under the terms of the GNU Lesser General Public
+ * License as published by the Free Software Foundation; either
+ * version 2.1 of the License, or (at your option) any later version.
+/**\file MBFileReadTool.cpp
+ *\author Jason Kraftcheck <kraftche at cae.wisc.edu>
+ *\date 2007-08-21
+#include "MBFileReadTool.hpp"
+#include "MBError.hpp"
+#include <set>
+#include "MBInternals.hpp"
+#include "EntitySequence.hpp"
+#include "PolyEntitySequence.hpp"
+#include "EntitySequenceManager.hpp"
+MBFileReadToolBase::MBFileReadToolBase( MBCore* moab )
+  : mMOAB( moab ), fileSet( 0 ),
+    parallelRank( moab->proc_config().rank() )
+void MBFileReadToolBase::report_error( std::string err )
+  mMOAB->get_error_handler()->set_last_error( err );
+void MBFileReadToolBase::report_error( const char* fmt, ... )
+  va_list args;
+  va_start(args, fmt);
+  mMOAB->get_error_handler()->set_last_error( fmt, args );
+  va_end( args );
+MBErrorCode MBFileReadToolBase::delete_all_entities()
+  MBErrorCode rval;
+  MBRange list;
+  if (fileSet == 0)  // all entities already deleted
+    return MB_SUCCESS;
+  rval = moab()->get_entities_by_handle( fileSet, list );
+  if (MB_SUCCESS != rval)
+    return rval;
+  list.insert( fileSet );
+  rval = moab()->delete_entities( list );
+    return rval;
+  fileSet = 0;
+MBErrorCode MBFileReadToolBase::delete_non_tagged_entities(
+                                              const char* tagname,
+                                              const int* tag_values,
+                                              int num_tag_values )
+  MBErrorCode rval;
+    // no entities?
+  if (fileSet == 0) {
+    report_error( "No entities with tag \"%s\" in file.\n", tagname );
+    return MB_FAILURE;
+    // get tag
+  MBTag tag;
+  rval = moab()->tag_get_handle( tagname, tag );
+  if (MB_SUCCESS != rval) {
+    report_error( "Tag not found: \"%s\"\n", tagname );
+    return rval;
+    // check type of tag data
+  MBDataType type;
+  int size = 0;
+  moab()->tag_get_size( tag, size );
+  moab()->tag_get_data_type( tag, type );
+  if (size != sizeof(int) || (type != MB_TYPE_INTEGER && type != MB_TYPE_OPAQUE)) {
+    report_error( "Invalid type for tag \"%s\"\n", tagname );
+    return MB_TYPE_OUT_OF_RANGE;
+    // construct argument arrays
+  std::vector<MBTag> taghandles( num_tag_values ? num_tag_values : 1, tag );
+  std::vector<const void*> tagvals( num_tag_values );
+  for (int i = 0; i < num_tag_values; ++i)
+    tagvals[i] = tag_values + i;
+    // get entity sets with specified tag
+  MBRange sets;
+  rval = moab()->get_entities_by_type_and_tag( fileSet,
+                                               MBENTITYSET,
+                                               &taghandles[0],
+                                               num_tag_values ? &tagvals[0] : 0,
+                                               taghandles.size(),
+                                               sets,
+                                               MBInterface::UNION );
+    // get closure of entity sets
+  MBRange entities, temp;
+  MBRange::iterator iter;
+    // recursively descend all containd and child entity sets
+  std::set<MBEntityHandle> visited;
+  std::vector<MBEntityHandle> children;
+  while (!sets.empty()) {
+    MBEntityHandle entset = sets.pop_front();
+    if (!(visited.insert(entset).second))
+      continue;
+    entities.insert( entset );
+    temp.clear();
+    moab()->get_entities_by_handle( entset, temp );
+    iter = temp.lower_bound( MBENTITYSET );
+    entities.merge( temp.begin(), iter );
+    std::copy( iter, temp.end(), mb_range_inserter( sets ) );
+    children.clear();
+    rval = moab()->get_child_meshsets( entset, children );
+      return rval;
+    std::copy( children.begin(), children.end(), mb_range_inserter( sets ) );
+    // get faces for all polyhedra
+  const MBEntityHandle* conn;
+  int len;
+  iter = entities.lower_bound( MBPOLYHEDRON );
+  for (; iter != entities.end() && TYPE_FROM_HANDLE(*iter) < MBENTITYSET; ++iter) {
+    rval = moab()->get_connectivity( *iter, conn, len );
+      return rval;
+    std::copy( conn, conn+len, mb_range_inserter( entities ) );
+    // get vertices for all elements
+  iter = entities.lower_bound( MBEDGE );
+  for (; iter != entities.end() && TYPE_FROM_HANDLE(*iter) < MBPOLYHEDRON; ++iter) {
+      return rval;
+    // We now have the list of entities to keep.
+    // Get the list of entities to remove.
+  MBRange all, dead;
+  moab()->get_entities_by_handle( fileSet, all );
+  dead = all.subtract( entities );
+    // Destroy the entities
+  rval = moab()->remove_entities( fileSet, dead );
+    return rval;
+  rval = moab()->delete_entities( dead );
+    return rval;
+MBErrorCode MBFileReadToolBase::create_sequence( MBEntityID start_id,
+                                                 MBEntityID count,
+                                                 MBEntityType type,
+                                                 MBEntityID conn_len,
+                                                 const int* proc_id,
+                                                 MBEntitySequence*& seq )
+  MBErrorCode rval;
+    // if we haven't created a set for all file entities yet,
+    // do it now
+  if (!fileSet) {
+    rval = moab()->create_meshset( MESHSET_SET, fileSet );
+      fileSet =0;
+      return rval;
+  MBEntityHandle start_handle;
+  const int proc = proc_id ? *proc_id : parallel_rank();
+  rval = mMOAB->sequence_manager()->create_entity_sequence(
+                                                    type,
+                                                    count,
+                                                    conn_len,
+                                                    start_id,
+                                                    proc,
+                                                    start_handle,
+                                                    seq );
+    return rval;
+  MBRange new_handles( seq->get_start_handle(), seq->get_end_handle() );
+  assert( new_handles.size() == (size_t)count );
+  rval = moab()->add_entities( fileSet, new_handles );
+    delete seq;
+    return rval;
+MBErrorCode MBFileReadToolBase::create_node_arrays(
+                               MBEntityID preferred_start_id,
+                               MBEntityID count,
+                               MBEntityHandle& start_handle,
+                               double *& x, double *& y, double *& z,
+                               const int* proc_id )
+  MBEntitySequence* seq = 0;
+  MBErrorCode rval = create_sequence( preferred_start_id,
+                                      count,
+                                      MBVERTEX,
+                                      0,
+                                      proc_id,
+                                      seq );
+    return rval;
+  VertexEntitySequence* vseq = static_cast<VertexEntitySequence*>(seq);
+  vseq->get_coordinate_arrays( x, y, z );
+  start_handle = seq->get_start_handle();
+MBErrorCode MBFileReadToolBase::create_element_array(
+                                              MBEntityID count,
+                                              MBEntityID conn_length,
+                                              MBEntityHandle*& conn_array,
+                                              int** last_index_array,
+    // caller needs last_index_array for poly-type elements
+  if (type == MBPOLYGON || type == MBPOLYHEDRON) {
+    if (!last_index_array)
+    // no last_index_array for other element types
+  else if (last_index_array)
+    *last_index_array = 0;
+                                      count,
+                                      type,
+                                      conn_length,
+                                      proc_id,
+                                      seq );
+    return rval;
+    PolyEntitySequence* pseq = static_cast<PolyEntitySequence*>(seq);
+    pseq->get_connectivity_array( conn_array );
+    pseq->get_index_array( *last_index_array );
+  else {
+    ElementEntitySequence* eseq = static_cast<ElementEntitySequence*>(seq);
+    eseq->get_connectivity_array( conn_array );
+MBErrorCode MBFileReadToolBase::create_meshset_block( MBEntityID start_id,
+                                                      MBEntityID count,
+                                                      unsigned flags,
+  std::vector<unsigned> flag_array( count, flags );
+  return create_meshset_block( start_id, count, start_handle, &flag_array[0], proc_id );
+                                                      MBEntityID count,
+                                                      const unsigned* flags,
+  MBErrorCode rval;
+  MBEntitySequence* seq;
+  rval = mMOAB->sequence_manager()->create_meshset_sequence( count,
+                                                             start_id,
+                                                             proc,
+                                                             flags,
+                                                             seq );
+    return rval;
+MBErrorCode MBFileReadToolBase::set_tag_data( MBTag tag,
+                                              MBEntityHandle beg,
+                                              MBEntityHandle num,
+                                              const void* data )
+  if (num == 0)
+  MBRange range( beg, beg + num - 1 );
+  return moab()->tag_set_data( tag, range, data );
Added: MOAB/branches/range_map/MBFileReadTool.hpp
--- MOAB/branches/range_map/MBFileReadTool.hpp	                        (rev 0)
+++ MOAB/branches/range_map/MBFileReadTool.hpp	2007-09-25 17:34:22 UTC (rev 1289)
@@ -0,0 +1,914 @@
+/**\file MBFileReadTool.hpp
+ *\date 2007-04-25
+#ifndef MB_FILE_READ_TOOL_HPP
+#define MB_FILE_READ_TOOL_HPP
+#include "RangeMap.hpp"
+#include "MBCore.hpp"
+#include <iosfwd>
+class MBError;
+class MBEntitySequence;
+/**\brief Non-template portions of MBFileReadTool */
+class MBFileReadToolBase {
+public:
+  MBFileReadToolBase( MBCore* moab );
+  /**\brief Set last error message */
+  void report_error( std::string error );
+  void report_error( const char* error, ... )
+#ifdef __GNUC__
+  __attribute__((format(printf,2,3)))
+#endif
+  inline MBInterface* moab() const
+    { return mMOAB; }
+  inline unsigned parallel_rank() const
+    { return parallelRank; }
+  /**\brief delete all read entities
+   * Delete all entities created through the methods
+   * provided by this class.
+  MBErrorCode delete_all_entities();
+  /**\brief Get entity set containing all read entities
+   * Get a new entity set containing all the entities
+   * allocated via methods of this object.
+  inline MBEntityHandle get_file_set() const
+    { return fileSet; }
+  /**\brief Delete entities with specified tag
+   * Delete all entities read from file that do not have
+   * the specified tag or tag values.
+   *\param tagname  The name of the tag -- must have single integer value
+   *\param tag_values If not null, a list of integer tag values
+   *\param num_tag_values The length of tag_values
+  MBErrorCode delete_non_tagged_entities( const char* tagname,
+                                          const int* tag_values = 0,
+                                          int num_tag_values = 0 );
+protected:
+  /**\brief Allocate vertex sequence
+   * Allocate a vertex sequence and update any bookkeeping in
+   * this object.
+   *\param preferred_start_id First MBEntityID, if available
+   *\param count              Number of vertices to allocate
+   *\param start_handle       Output: first vertex handle
+   *\param x                  Output: MOAB internal storage for vertex X-coordinates.
+   *\param y                  Output: MOAB internal storage for vertex Y-coordinates.
+   *\param z                  Output: MOAB internal storage for vertex Z-coordinates.
+   *\param proc_id            NULL or requested parallel processor ID
+  MBErrorCode create_node_arrays( MBEntityID preferred_start_id,
+                                  MBEntityID count,
+                                  const int* proc_id );
+  /**\brief Allocate element sequence
+   * Allocate a element sequence and update any bookkeeping in
+   * this object.
+   *\param count              Number of elements to allocate
+   *\param type               Element type
+   *\param conn_length        Vertices per element, zero for MBPOLYGON and MBPOLYHEDRON
+   *\param conn_array         Output: MOAB internal storage for element connectivity
+   *\param last_index_array   Cannot be NULL for MBPOLYGON or MBPOLYHEDRON.  Must
+   *                          be NULL for other types.  Output: Pointer to MOAB
+   *                          internal storage of last index in connectivity
+   *                          array for each element.
+  MBErrorCode create_element_array( MBEntityID preferred_start_id,
+                                    MBEntityID count,
+                                    int** last_index_array = 0,
+                                    const int* proc_id = 0);
+  /**\brief Allocate a meshset sequence
+   * Allocate a meshset sequence and update any bookkeeping in
+   * this object.
+   *\param count              Number of entity sets to allocate
+   *\param start_handle       Output: first entity set handle
+   *\param flags              entity set creation flags (one val for all entity sets)
+  MBErrorCode create_meshset_block( MBEntityID preferred_start_id,
+                                    MBEntityID count,
+                                    MBEntityHandle& start_handle_out,
+                                    unsigned flags,
+   * this object.
+   *\param flags              entity set creation flags (one val per entity sets)
+                                    MBEntityID count,
+  /**\brief Set tag data for a block of entity handles. */
+  MBErrorCode set_tag_data( MBTag tag,
+                            MBEntityHandle count,
+                            const void* data );
+private:
+  MBErrorCode create_sequence( MBEntityID start_id,
+                               MBEntityID count,
+                               MBEntitySequence*& seq );
+  MBCore* mMOAB;
+  MBEntityHandle fileSet;
+  unsigned parallelRank;
+/**\brief Helper class for file readers.
+ * This class provides methods for creation of entities
+ * in MOAB and maintains a map from file IDs to MBEntityHandles.
+ * All methods accept values as file IDs and map them to MBEntityHandles
+ * internally.
+ * The type of a file ID is a template parameter, allowing a
+ * particular reader to work directly with the identifier/index
+ * type used by an underlying IO library.
+template <typename FileIDType>
+class MBFileReadTool : public MBFileReadToolBase
+public:
+  /**\brief Create reader tool
+   *\param vertex_unique_ids File ID space for vertices is separate from
+   *                         other entities.  If this value is true, then
+   *                         the file may contain both a vertex with ID 1
+   *                         and an element with the same ID value of 1.
+   *\param element_type_unique_ids File ID space is separate for different
+   *                         element types.  If this value is true, then
+   *                         the file may contain an edge and a
+   *                         triangle element that have the same ID.
+   *\param set_unique_ids File ID space for entity sets is separate from
+   *                         other entities.
+  inline
+  MBFileReadTool( MBCore* moab_instance,
+                  bool vertex_unique_ids,
+                  bool element_type_unique_ids,
+                  bool set_unique_ids );
+  /**\brief Allocate a block of nodes.
+   * Allocate a block of nodes and return pointers to MOAB's internal
+   * storage of the vertex coordinaets for those nodes, such that the
+   * file reader may read the coordinate values directly into the
+   * vertex storage allocated by this method.
+   *\param start_id  The file ID (or index) of the first vertex.  The
+   *                 allocated vertices will be assigned file IDs in
+   *                 the range [start_id,start_id+count).
+   *\param count     Number of vertices to allocate.
+   *\param x_array_out  Output: location at which to write X-coordinates.
+   *\param y_array_out  Output: location at which to write Y-coordinates.
+   *\param z_array_out  Output: location at which to write Z-coordinates.
+   *\param proc_id   For parallel, ID of processor to associate with entities.
+   *                 If null, current processor rank is assumed.
+  inline
+  MBErrorCode create_nodes( FileIDType start_id,
+                            FileIDType count,
+                            double *& x_array_out,
+                            double *& y_array_out,
+                            double *& z_array_out,
+                            const int* proc_id = 0 );
+  /**\brief Create a block of elements.
+   * Create mesh elements.
+   *\param type      The element type.
+   *\param connectivity_length Nodes per element.  Zero for MBPOLY* types.
+   *\param interleaved_connectivity Element connectivity list, specified
+   *                 as vertex IDs as assigned by the create_nodes method
+   *                 of this class (face IDs if type == POLYHEDRON).
+   *\param poly_end_indices For MBPOLYGON and MBPOLYHEDRON types, the
+   *                 *last* index in interleaved_connectivity for each element.
+  inline
+  MBErrorCode create_elements( FileIDType start_id,
+                               FileIDType count,
+                               FileIDType connectivity_length,
+                               const FileIDType* interleaved_connectivity,
+                               const FileIDType* poly_end_indices = 0,
+  /**\brief Specifiy explicit adjacencies
+   * Create explicit adjacencies between entities.
+   *\param from_id   Source entity for adjacency
+   *\param to_ids    Target entities for adjacencies
+   *\param to_count  Length of to_ids
+   *\param from_type Type of source entity.  The caller
+   *                 must specify this value if it cannot
+   *                 be inferred from the source entity ID
+   *                 (see constructor arguments.)
+   *\param to_type   Type of target entities.  The caller
+   *                 be inferred from the target entity IDs
+  inline
+  MBErrorCode add_adjacencies( FileIDType from_id,
+                               const FileIDType* to_ids,
+                               FileIDType to_count,
+                               MBEntityType from_type = MBMAXTYPE,
+                               MBEntityType to_type = MBMAXTYPE );
+  /**\brief Create tag for storing entity handles.
+   *\param name         Tag name
+   *\param num_handles  Number of handles in each tag value.  If
+   *                    this value is greater than one, then each
+   *                    entity has an array of handles for this tag.
+   *\param storage_type Tag storage type.
+   *\param handle_out   Output: tag handle
+   *\param mesh_value   Global, or mesh value for tag.
+   *\param default_value Default value for tag.
+   *\param null_id      If non-null, the value pointed to by this
+   *                    argument is treated as special: a "NULL" file ID.
+  inline
+  MBErrorCode create_entity_handle_tag( const char* name,
+                                        unsigned num_handles,
+                                        MBTagType storage_type,
+                                        MBTag& handle_out,
+                                        const FileIDType* mesh_value = 0,
+                                        const FileIDType* default_value = 0,
+                                        const FileIDType* null_id = 0 );
+  /**\brief Set tag data for a block of entities
+   * Set tag data for non-handle type tags.  This method will
+   * fail if the tag has a data type MB_TAG_HANDLE.
+   *\param handle       Tag handle
+   *\param start_id     File ID of first entity
+   *\param id_count     Number of entities.
+   *\param tag_data     Tag values
+   *\param entity_type  The type of the entities for which the tag
+   *                    data is being set.  The caller must specify
+   *                    this if it cannot be inferred from the file
+   *                    IDs (see constructor arguments).
+   *\param value_type   The type of the entities in the tag values.
+   *                    The caller must specify
+  inline
+  MBErrorCode set_tag_data( MBTag handle,
+                            FileIDType start_id,
+                            FileIDType id_count,
+                            const void* tag_data,
+                            MBEntityType entity_type = MBMAXTYPE,
+                            MBEntityType val_type = MBMAXTYPE );
+  /**\brief Set tag data for entity handle tag for a block of entities
+   * This method will fail for any tag that does not have a data type
+   * of MB_TYPE_HANDLE.
+   *\param tag_data     Tag values as file IDs
+  inline
+                            const FileIDType* id_array,
+                            const FileIDType* tag_data,
+                            MBEntityType value_type = MBMAXTYPE,
+  /**\brief Create a block of entity sets
+   * Create count entity sets with consecutive file IDs, beginning
+   * with the specified start_id.
+   *\param start_id   File ID for first entity set
+   *\param options    Set creation flags for each entity set.
+  inline
+  MBErrorCode create_meshsets( FileIDType start_id,
+                               MBEntityID count,
+                               const unsigned* options,
+  inline
+                               FileIDType count,
+                               unsigned options,
+  /**\brief Specify set contents for a block of entity sets
+   *\param start_id  File id of first entity set
+   *\param concatenated_content_lists The concatenation of the list of set
+   *                 contents.
+   *\param end_indices For each entity set, the index of the last entry
+   *                 for that set in concatenated_content_lists
+   *\param type      The type of the entities in concatenated_content_list.
+   *                 The caller must specify this value if it cannot be
+   *                 inferred from the file IDs (see constructor args.)
+  inline
+  MBErrorCode add_meshset_contents( FileIDType start_id,
+                                    FileIDType count,
+                                    const FileIDType* concatenated_content_lists,
+                                    const FileIDType* end_indices ,
+                                    MBEntityType type = MBMAXTYPE );
+   * Specify contents for a block of entity sets, where the set
+   * contents are specified as ranges of file IDs.
+   *\param concatenated_range_list The concatenation of the list of set
+   *                 contents.  The contents for each set are specified
+   *                 as pairs of file IDS, where each pair corresponds
+   *                 to the first and last file ID of a range of entities.
+   *                 To specify a single entity, both values in the range
+   *                 pair should be the same.
+   *                 for that set in concatenated_range_list
+   *\param type      The type of the entities in concatenated_range_list.
+  inline
+  MBErrorCode add_meshset_range_contents( FileIDType start_id,
+                                          FileIDType count,
+                                          const FileIDType* concatenated_range_list,
+                                          const FileIDType* end_indices,
+  /**\brief Specify set children for a block of entity sets
+   *\param start_parent_id  File id of first entity set
+   *\param parent_count     Number of entity sets
+   *\param concatenated_children_lists The concatenation of the list of set
+   *                        children.
+   *                        for that set in concatenated_children_lists
+   *\param bidirectional    If true, also create link from child up to parent.
+   *                        If false, links are single-directional.
+  inline
+  MBErrorCode add_meshset_children( FileIDType start_parent_id,
+                                    FileIDType parent_count,
+                                    const FileIDType* concatenated_children_lists,
+                                    bool bidirectional = true );
+  /**\brief Specify set parents for a block of entity sets
+   *\param start_child_id  File id of first entity set
+   *\param child_count     Number of entity sets
+   *\param concatenated_parents_lists The concatenation of the list of set
+   *                       parents.
+   *                       for that set in concatenated_parents_lists
+  inline
+  MBErrorCode add_meshset_parents(  FileIDType start_child_id,
+                                    FileIDType child_count,
+                                    const FileIDType* concatenated_parents_lists,
+                                    const FileIDType* end_indices );
+  /**\brief Get number of entities of each type */
+  inline void get_entity_counts( FileIDType counts[MBMAXTYPE] ) const;
+  /**\brief Convert from file IDs to MBEntityHandles
+   * Convert from file IDs to MBEntityHandles
+   *\param type    The type of the entities, or MBMAXTYPE if
+   *               the entity type can be inferred from the file ID.
+   *               The type can be inferred if all arguments to the
+   *               constructor that control the file ID space mapping
+   *               are false.  I.e. there is to potential ID conflict.
+   *\param ids     The input array of IDs for which to get the
+   *               corresponding MBEntityHandles.
+   *\param handles The array in which to store the result MBEntityHandles
+   *\param count   The length of ids (and handles).
+   *\param null_id If this argument is not NULL, then the value it points
+   *               to will be assumed to be a 'NULL' file ID value, such
+   *               that any input FileIDType with this value will be
+   *               assigned a zero (NULL) MBEntityHandle.
+   *\return        true if success, false if failure.
+  inline bool ids_to_handles( MBEntityType type,
+                              const FileIDType* ids,
+                              MBEntityHandle* handles,
+                              FileIDType count,
+private:
+  RangeMap<FileIDType,MBEntityHandle> typeMap[MBMAXTYPE+1];
+  const bool vertexUniqueIds, elemTypeUniqueIds, setUniqueIds;
+  std::vector<MBEntityHandle> handleArray;
+template <typename FileIDType> inline
+bool MBFileReadTool<FileIDType>::ids_to_handles( MBEntityType type,
+                                                 FileIDType count,
+                                                 const FileIDType* null_id  )
+  bool ok = true;
+  const RangeMap<FileIDType,MBEntityHandle>& map = typeMap[type];
+  for (FileIDType i = 0; i < count; ++i) {
+    handles[i] = map.find( ids[i] );
+    if (!handles[i] && (!null_id || *null_id != ids[i]))
+      ok = false;
+  return ok;
+MBFileReadTool<FileIDType>::MBFileReadTool( MBCore* moab_iface,
+  : MBFileReadToolBase( moab_iface ),
+    vertexUniqueIds( vertex_unique_ids ),
+    elemTypeUniqueIds( element_type_unique_ids ),
+    setUniqueIds( set_unique_ids )
+MBErrorCode MBFileReadTool<FileIDType>::create_nodes( FileIDType start_id,
+                                                      FileIDType count,
+                                                      double *& x,
+                                                      double *& y,
+                                                      double *& z,
+  MBEntityHandle handle;
+  MBErrorCode rval = create_node_arrays( start_id, count, handle, x, y, z, proc_id );
+    return rval;
+  typeMap[MBVERTEX].insert( handle, count, start_id );
+  if (!vertexUniqueIds)
+    typeMap[MBMAXTYPE].insert( handle, count, start_id );
+MBErrorCode MBFileReadTool<FileIDType>::create_elements( FileIDType start_id,
+                                                         FileIDType count,
+                                                         FileIDType len,
+                                                         const FileIDType* conn_ids,
+                                                         const FileIDType* poly,
+    if (!poly || poly[count-1] != len)
+  int* index_array;
+  MBErrorCode rval;
+  MBEntityHandle handle, *conn;
+  rval = create_element_array( start_id, count, type, len, handle, conn, &index_array, proc_id );
+    return rval;
+  typeMap[type].insert( handle, count, start_id );
+  if (!elemTypeUniqueIds)
+  bool valid;
+  if (type != MBPOLYHEDRON)
+    valid = convert_ids_to_handles( MBVERTEX, conn_ids, conn, count );
+  else if (elemTypeUniqueIds)
+    valid = convert_ids_to_handles( MBPOLYGON, conn_ids, conn, count );
+  else
+    valid = convert_ids_to_handles( MBMAXTYPE, conn_ids, conn, count );
+      index_array[i] = poly[i];
+  return valid ? MB_SUCCESS : MB_FAILURE;;
+MBErrorCode MBFileReadTool<FileIDType>::add_adjacencies( FileIDType from_id,
+                                              MBEntityType from_type,
+                                              MBEntityType to_type )
+  MBEntityHandle from_handle;
+  if (!convert_ids_to_handles( from_type, &from_id, &from_handle, 1 ))
+  handleArray.resize( to_count );
+  if (!convert_ids_to_handles( to_type, to_ids, &handleArray[0], to_count ))
+  return moab()->add_adjacencies( from_handle, &handleArray[0], to_count, false );
+MBErrorCode MBFileReadTool<FileIDType>::create_entity_handle_tag(
+                                        const char* name,
+                                        const FileIDType* mesh_value,
+                                        const FileIDType* default_value,
+  handleArray.resize( 2*num_handles );
+  MBEntityHandle *mesh_handles = 0, *default_handles = 0;
+  if (mesh_value) {
+    mesh_handles = &handleArray[0];
+    if (!ids_to_handles( MBMAXTYPE, mesh_value, mesh_handles, num_handles, null_id ))
+  if (default_value) {
+    default_handles = &handleArray[num_handles];
+    if (!ids_to_handles( MBMAXTYPE, default_value, default_handles, num_handles, null_id ))
+  MBErrorCode rval =  moab()->tag_create( name,
+                             num_handles * sizeof(MBEntityHandle),
+                             storage_type,
+                             MB_TYPE_HANDLE,
+                             handle_out,
+                             default_handles,
+                             true );
+    return rval;
+  return set_tag_data( handle_out, 0, 0, mesh_handles );
+MBErrorCode MBFileReadTool<FileIDType>::set_tag_data( MBTag handle,
+                                                    MBEntityType val_type )
+  MBErrorCode rval, result = MB_SUCCESS;
+  std::vector<MBEntityHandle> ranges, hdata;
+  if (!typeMap[type].find( start_id, id_count, ranges ))
+  MBDataType tag_type;
+  rval = moab()->tag_get_data_type( handle, tag_type );
+    return rval;
+  int tag_size;
+  rval = moab()->tag_get_size( handle, tag_size );
+    return rval;
+  if (MB_TYPE_HANDLE == tag_type)
+  const char* data = static_cast<const char*>(tag_data);
+  for (MBEntityID i = 0; i < ranges.size(); i += 2) {
+    MBEntityHandle start_handle = ranges[i];
+    MBEntityID count = ranges[i+1];
+    rval = set_tag_data( handle, start_handle, count, data );
+      result = rval;
+    data += (count + tag_size);
+  return result;
+                                                    MBEntityType val_type,
+  MBErrorCode rval;
+    return rval;
+  if (tag_type != MB_TYPE_HANDLE)
+  int tag_size;
+    return rval;
+  tag_size /= sizeof(MBEntityHandle);
+  handleArray.resize( id_count * (tag_size + 1) );
+  if (!ids_to_handles( val_type,
+                       tag_data,
+                       &handleArray[id_count],
+                       null_id ))
+  tag_data = &handleArray[id_count];
+  if (!ids_to_handles( type, id_array, &handleArray[0], id_count ))
+  return set_tag_data( handle, &handleArray[0], id_count, tag_data );
+MBErrorCode MBFileReadTool<FileIDType>::create_meshsets( FileIDType start_id,
+                               MBEntityID count,
+  MBEntityHandle h;
+  MBErrorCode rval;
+  rval = craete_meshset_block( start_id, count, h, options, proc_id );
+    return rval;
+  typeMap[MBENTITYSET].insert( h, count, start_id );
+  if (!setUniqueIds)
+    typeMap[MBMAXTYPE].insert( h, count, start_id );
+                               FileIDType count,
+                               unsigned options,
+  MBEntityHandle h;
+  MBErrorCode rval;
+    return rval;
+MBErrorCode MBFileReadTool<FileIDType>::add_meshset_contents(
+                                    FileIDType count,
+                                    const FileIDType* list,
+                                    MBEntityType type )
+  FileIDType id, prev = 0, n;
+  MBErrorCode result = MB_SUCCESS;
+  for (FileIDType i = 0; i < count; prev = end_indices[i++]) {
+    id = start_id + i;
+    if (!ids_to_handles( MBENTITYSET, &id, &handle, 1 )) {
+      result = MB_FAILURE;
+      continue;
+    n = end_indices[i] - prev;
+    handleArray.resize( n );
+    if (!ids_to_handles( type, list+prev, &handleArray[0], n))
+    else if (MB_SUCCESS != moab()->add_entities( handle, &handleArray[0], n ))
+  return result;
+MBErrorCode MBFileReadTool<FileIDType>::add_meshset_range_contents(
+                                          FileIDType count,
+  MBRange range;
+  MBRange::iterator h;
+      prev = end_indices[i];
+      continue;
+    range.clear();
+    h = range.begin();
+    for ( ; prev < end_indices[i]; prev += 2)
+      typeMap[type].find( list[i], list[i+i], range, h );
+    if (range.size() != count)
+    rval = moab()->add_entities( handle, range );
+      result = rval;
+  return result;
+MBErrorCode MBFileReadTool<FileIDType>::add_meshset_children(
+                                    FileIDType count,
+                                    bool bidirectional )
+      continue;
+    if (!ids_to_handles( MBENTITYSET, list+prev, &handleArray[0], n))
+    else {
+      if (bidirectional) {
+        for (FileIDType i = 0; i < n; ++i)
+          if (MB_SUCCESS != moab()->add_parent_child( handle, handleArray[i] ))
+      else if (MB_SUCCESS != moab()->add_child_meshsets( handle, &handleArray[0], n ))
+  return result;
+MBErrorCode MBFileReadTool<FileIDType>::add_meshset_parents(
+                                    FileIDType count,
+      continue;
+    else if (MB_SUCCESS != moab()->add_parent_meshsets( handle, &handleArray[0], n ))
+  return result;
+void MBFileReadTool<FileIDType>::get_entity_counts( FileIDType counts[MBMAXTYPE] ) const
+  for (MBEntityType t = MBVERTEX; t < MBMAXTYPE; ++t)
+    counts[t] = typeMap[t].size();
+#endif
Modified: MOAB/branches/range_map/Makefile.am
--- MOAB/trunk/Makefile.am	2007-09-25 17:01:01 UTC (rev 1288)
+++ MOAB/branches/range_map/Makefile.am	2007-09-25 17:34:22 UTC (rev 1289)
@@ -29,7 +29,8 @@
 check_PROGRAMS = $(TESTS) \
 		 kd_tree_tool \
-		 kd_tree_time
+		 kd_tree_time \
+		 range_map_test
 #noinst_PROGRAMS = scdseq_timing
@@ -119,6 +120,8 @@
   MBMatrix3.hpp \
   MBCore.cpp \
   MBFactory.cpp \
+  MBFileReadTool.cpp \
+  MBFileReadTool.hpp \
   MBGeomUtil.cpp \
   MBInternals.hpp \
   MBMem.hpp \
@@ -143,6 +146,7 @@
   MeshTopoUtil.cpp \
   PolyEntitySequence.cpp \
   PolyEntitySequence.hpp \
+  RangeMap.hpp \
   ReadGmsh.cpp \
   ReadGmsh.hpp \
   ReadParallel.hpp \
@@ -301,6 +305,8 @@
 file_options_test_SOURCES = FileOptions.cpp
 file_options_test_CPPFLAGS = -DTEST
+range_map_test_sources = RangeMapTest.cpp RangeMap.hpp
 # Other files to clean up (e.g. output from tests)
 MOSTLYCLEANFILES = dumped_acis.sat
Added: MOAB/branches/range_map/RangeMap.hpp
--- MOAB/branches/range_map/RangeMap.hpp	                        (rev 0)
+++ MOAB/branches/range_map/RangeMap.hpp	2007-09-25 17:34:22 UTC (rev 1289)
@@ -0,0 +1,199 @@
+/**\file RangeMap.hpp
+ *\author Jason Kraftcheck (kraftche at cae.wisc.edu)
+ *\date 2007-04-25
+#ifndef RANGE_MAP_HPP
+#define RANGE_MAP_HPP
+#include <vector>
+#include <algorithm>
+/**\brief Map ranges of values
+ * This class provides a map between ranges of values, such as
+ * a map between file IDs and MBEntityHandles.  It is intended
+ * for use in situations where there are relatively few insertions
+ * of large contiguous ranges of values.
+template <typename KeyType, typename ValType, ValType NullVal = 0>
+class RangeMap
+public:
+  struct Range {
+    KeyType begin, count;
+    ValType value;
+    bool operator<( const Range& other ) const
+      { return begin + count <= other.begin; } // equal if overlapping!
+  typedef typename std::vector<Range> RangeList;
+  typedef typename RangeList::const_iterator iterator;
+  /**\brief Insert mapping between range of keys and range of values
+   * Insert mapping from [first_key, first_key+count) to [first_val, first_val+count)
+   * Input range of keys many not overlap any other input range.  If it does overlap
+   * an existing range, false is returned and the internal map is not changed.
+  inline iterator insert( KeyType first_key, ValType first_val, KeyType count );
+  /** Find the value corresponding to the specified key.  Returns NullVal if not found */
+  inline ValType find( KeyType key ) const;
+  /** Remove a block of values */
+  inline iterator erase( KeyType beg, KeyType count );
+  inline unsigned num_ranges() const { return data.size(); }
+  inline iterator begin() const { return data.begin(); }
+  inline iterator end() const { return data.end(); }
+  inline iterator lower_bound( KeyType key ) const
+      Range b = { key, 1, NullVal };
+      return std::lower_bound( begin(), end(), b );
+  inline iterator upper_bound( KeyType key ) const
+      return std::upper_bound( begin(), end(), b );
+  inline std::pair<iterator,iterator>
+    equal_range( KeyType key ) const
+      return std::equal_range( begin(), end(), b );
+  inline void clear() { data.clear(); }
+protected:
+  RangeList data;
+template <typename KeyType, typename ValType, ValType NullVal>
+inline typename RangeMap<KeyType,ValType,NullVal>::iterator
+RangeMap<KeyType,ValType,NullVal>::insert( KeyType first_key, ValType first_val, KeyType count )
+  Range block = { first_key, count, first_val };
+  typename RangeList::iterator i = std::lower_bound( data.begin(), data.end(), block );
+  if (i == data.end()) {
+    if (i != data.begin()) {
+      --i;
+      if (i->begin + i->count == first_key &&
+          i->value + i->count == first_val) {
+        i->count += count;
+        return i;
+    data.push_back( block );
+    return data.end() - 1;
+  if (i->begin < first_key + count)
+    return data.end();
+  if (i->begin == first_key + count &&
+      i->value == first_val + count) {
+    i->begin = first_key;
+    i->value = first_val;
+      count = i->count;
+      --i;
+        ++i;
+        i = data.erase(i);
+        --i;
+    return i;
+    --i;
+      return i;
+    ++i;
+  return data.insert( i, block );
+template <typename KeyType, typename ValType, ValType NullVal> inline
+ValType RangeMap<KeyType,ValType,NullVal>::find( KeyType key ) const
+  Range search = { key, 1, NullVal };
+  typename RangeList::const_iterator i = std::lower_bound( data.begin(), data.end(), search );
+  if (i == data.end() || i->begin > key)
+    return NullVal;
+  return i->value + key - i->begin;
+RangeMap<KeyType,ValType,NullVal>::erase( KeyType key, KeyType count )
+  typename RangeList::iterator i, j;
+  i = std::lower_bound( data.begin(), data.end(), search );
+    return i;
+  if (key > i->begin) {
+    KeyType offset = key - i->begin;
+      // special case - split existing entry
+    if((offset + count) < i->count) {
+      Range ins = { i->begin, offset, i->value };
+      offset += count;
+      i->begin += offset;
+      i->value += offset;
+      i->count -= offset;
+      return data.insert( i, ins ) + 1;
+      // otherwise remove the latter part of i
+    i->count = offset;
+    ++i;
+    // remove any entries entirely convered by the input range
+  for (j = i; j != data.end() && (j->begin + j->count) <= (key + count); ++j);
+  i = data.erase(i,j);
+    // remove beginning of last block
+  if (i != data.end() && (key + count) >= i->begin) {
+    KeyType offset = key + count - i->begin;
+  return i;
+#endif
Added: MOAB/branches/range_map/RangeMapTest.cpp
--- MOAB/branches/range_map/RangeMapTest.cpp	                        (rev 0)
+++ MOAB/branches/range_map/RangeMapTest.cpp	2007-09-25 17:34:22 UTC (rev 1289)
@@ -0,0 +1,143 @@
+#include <iostream>
+#include <iomanip>
+#include <stdio.h>
+#include <stdlib.h>
+RangeMap<long,long,0> mapInstance;
+bool insert( std::vector<long>& values );
+bool verify( std::vector<long>& values );
+bool print( std::vector<long>& values );
+bool clear( std::vector<long>& values );
+bool help();
+bool do_command( char* cmd )
+  std::vector<long> values;
+  char *ptr, *end;
+  const char space[] = " \t\r\n";
+  char c = cmd[0];
+  ++cmd;
+  for (ptr = strtok( cmd, space ); ptr; ptr = strtok( 0, space )) {
+    long val = strtol( ptr, &end, 0 );
+    if (*end) {
+      std::cerr << "Invalid integer value: " << ptr << std::endl;
+      return false;
+    values.push_back( val );
+  switch (c) {
+    case 'i': return insert( values );
+    case 'v': return verify( values );
+    case 'p': return print( values );
+    case 'c': return clear( values );
+    case 'h': return help( );
+    default:
+      std::cerr << "Unknown command: " << c << std::endl;
+      return false;
+  if (values.size() % 3) {
+    std::cerr << "Invalid arguments for insertion.  "
+                 "Insertion requires tuples of three values:  "
+                 "{start_key,start_val,count}" << std::endl;
+    return false;
+  for (unsigned i = 0; i < values.size(); i += 3)
+    if (mapInstance.end() == mapInstance.insert( values[i], values[i+1], values[i+2] ))
+      std::cout << "Insertion of {" << values[i] << ", "
+                                    << values[i+1] << ", "
+                                    << values[i+2] << "} FAILED" << std::endl;
+  return true;
+  if (values.size() % 2) {
+    std::cerr << "(c)lear command expects ranges of values (or no values)" << std::endl;
+    return false;
+  if(values.empty()) {
+    mapInstance.clear();
+    return true;
+  for (unsigned i = 0; i < values.size(); i += 2)
+    mapInstance.erase( values[i], values[i+1] );
+  return true;
+  const int W = 20;
+  if (values.empty()) {
+    std::cout  << std::setw(W) << "Start Key"
+               << std::setw(W) << "Start Val"
+               << std::setw(W) << "Count"
+               << std::endl;
+    RangeMap<long,long,0>::iterator i = mapInstance.begin();
+    for (; i != mapInstance.end(); ++i)
+      std::cout << std::setw(W) << i->begin
+                << std::setw(W) << i->value
+                << std::setw(W) << i->count
+                << std::endl;
+  else {
+    for (unsigned i = 0; i < values.size(); ++i)
+      std::cout << std::setw(W) << values[i] << "->"
+                << std::setw(W) << mapInstance.find(values[i]) << std::endl;
+  return true;
+    return false;
+  bool result = true;
+  std::vector<long>::iterator j = values.begin();
+    if (j == values.end() ||
+        i->begin != *j++ ||
+        i->value != *j++ ||
+        i->count != *j++)
+      result = false;
+  return result && j == values.end();
+bool help()
+  std::cout << "Commands: i p c v h" << std::endl
+            << " i - insert list of values " << std::endl
+            << " p - print entire map or lookup specified values" << std::endl
+            << " c - clear map" << std::endl
+            << " v - verify map contents" << std::endl
+            << " h - this help" << std::endl;
+  return true;
+int main() {
+  char buffer[1024];
+  bool exit_val = 0;
+  while (fgets(buffer, sizeof(buffer), stdin))
+    exit_val += !do_command(buffer);
+  return exit_val;
