[MOAB-dev] r1286 - MOAB/trunk
    kraftche at mcs.anl.gov
    Tue Sep 25 11:56:03 CDT 2007
Author: kraftche
Date: 2007-09-25 11:56:03 -0500 (Tue, 25 Sep 2007)
New Revision: 1286
Removed:
   MOAB/trunk/MBFileReadTool.cpp
   MOAB/trunk/MBFileReadTool.hpp
   MOAB/trunk/README.RefCount
   MOAB/trunk/RangeMap.hpp
   MOAB/trunk/RangeMapTest.cpp
Modified:
   MOAB/trunk/AEntityFactory.cpp
   MOAB/trunk/AEntityFactory.hpp
   MOAB/trunk/EntitySequence.cpp
   MOAB/trunk/EntitySequence.hpp
   MOAB/trunk/EntitySequenceManager.hpp
   MOAB/trunk/HigherOrderFactory.cpp
   MOAB/trunk/MBCore.cpp
   MOAB/trunk/MBCore.hpp
   MOAB/trunk/MBMeshSet.cpp
   MOAB/trunk/MBMeshSet.hpp
   MOAB/trunk/MBReadUtil.cpp
   MOAB/trunk/MBReadUtil.hpp
   MOAB/trunk/MBReadUtilIface.hpp
   MOAB/trunk/MBTest.cpp
   MOAB/trunk/Makefile.am
   MOAB/trunk/MeshSetSequence.cpp
   MOAB/trunk/MeshSetSequence.hpp
   MOAB/trunk/PolyEntitySequence.cpp
   MOAB/trunk/ReadGmsh.cpp
   MOAB/trunk/ReadHDF5.cpp
   MOAB/trunk/ReadNCDF.cpp
   MOAB/trunk/ReadSTL.cpp
   MOAB/trunk/ReadVtk.cpp
   MOAB/trunk/TagServer.cpp
   MOAB/trunk/TagServer.hpp
   MOAB/trunk/configure.in
Log:
back out changes from trunk that should have been checked into branckes
Modified: MOAB/trunk/AEntityFactory.cpp
--- MOAB/trunk/AEntityFactory.cpp	2007-09-25 16:45:54 UTC (rev 1285)
+++ MOAB/trunk/AEntityFactory.cpp	2007-09-25 16:56:03 UTC (rev 1286)
@@ -17,7 +17,7 @@
 #include "AEntityFactory.hpp"
 #include "MBInternals.hpp"
-#include "MBCore.hpp"
+#include "MBInterface.hpp"
 #include "MBRange.hpp"
 #include "MBError.hpp"
 #include "MBCN.hpp"
@@ -27,51 +27,9 @@
 #include <algorithm>
 #include <set>
-#ifdef MOAB_WITH_REFCOUNT
-MBErrorCode AEntityFactory::decrement_reference_count( const MBEntityHandle* arr, size_t len )
-  { return thisMB->decrement_reference_count( arr, len ); }
-MBErrorCode AEntityFactory::increment_reference_count( const MBEntityHandle* arr, size_t len )
-  { return thisMB->increment_reference_count( arr, len ); }
-MBErrorCode AEntityFactory::decrement_referenced_entities( MBEntityHandle h )
-  const MBEntityHandle* adj;
-  int num_adj;
-  MBErrorCode rval = get_adjacencies( h, adj, num_adj );
-  if (MB_SUCCESS != rval || num_adj == 0)
-    return rval;
-  MBEntityType type = TYPE_FROM_HANDLE(h);
-  if (type == MBVERTEX)
-    return MB_SUCCESS;
-  --type;
-  int junk;
-  const MBEntityHandle* end
-    = std::lower_bound( adj, adj+num_adj, CREATE_HANDLE( type, 0, junk ) );
-  return decrement_reference_count( adj, end - adj );
-MBErrorCode AEntityFactory::increment_referenced_entities( MBEntityHandle h )
-  int num_adj;
-    return rval;
-  --type;
-  int junk;
-  return increment_reference_count( adj, end - adj );
-#endif
-AEntityFactory::AEntityFactory(MBCore *mdb)
+AEntityFactory::AEntityFactory(MBInterface *mdb)
 : mDensePageGroup(sizeof(void*), 0)
   assert(NULL != mdb);
@@ -427,10 +385,10 @@
       // need to make a new adjacency list first
     adj_list_ptr = new MBAdjacencyVector();
     result = mDensePageGroup.set_data(from_ent, &adj_list_ptr);
     if (MB_SUCCESS != result) return result;
     // get an iterator to the right spot in this sorted vector
   MBAdjacencyVector::iterator adj_iter;
   if (!adj_list_ptr->empty())
@@ -441,19 +399,10 @@
     if ( adj_iter == adj_list_ptr->end() || to_ent != *adj_iter )
       adj_list_ptr->insert(adj_iter, to_ent);
-      if (TYPE_FROM_HANDLE(from_ent) > TYPE_FROM_HANDLE(to_ent))
-        increment_reference_count( to_ent );
-#endif
-  else {
+  else
     adj_list_ptr->push_back(to_ent);
-#endif
     // if both_ways is true, recursively call this function
   if (true == both_ways && to_type != MBVERTEX)
@@ -464,8 +413,7 @@
 //! remove an adjacency from from the base_entity.
 MBErrorCode AEntityFactory::remove_adjacency(MBEntityHandle base_entity,
-                              MBEntityHandle adj_to_remove,
-                              bool update_reference_count)
+                              MBEntityHandle adj_to_remove)
   MBErrorCode result;
@@ -487,30 +435,20 @@
   // remove the specified entity from the adjacency list and truncate
   // the list to the new length
-  std::vector<MBEntityHandle>::iterator iter
-    = std::lower_bound( adj_list->begin(), adj_list->end(), adj_to_remove );
-  if (iter == adj_list->end() || *iter != adj_to_remove)
-    return MB_FAILURE;
+  adj_list->erase(std::remove(adj_list->begin(), adj_list->end(), adj_to_remove),
+                  adj_list->end());
-  adj_list->erase( iter );
-  if (update_reference_count &&
-      TYPE_FROM_HANDLE(base_entity) > TYPE_FROM_HANDLE(adj_to_remove))
-    decrement_reference_count( adj_to_remove );
-#endif
   // reset the adjacency data list
   //result = thisMB->tag_set_data(adj_tag, base_entity, &adj_list);
   //if (result != MB_SUCCESS)
     //return result;
+  return result;
 //! remove all adjacencies from from the base_entity.
 MBErrorCode AEntityFactory::remove_all_adjacencies(MBEntityHandle base_entity,
-                                                   const bool delete_adj_list,
-                                                   bool update_reference_counts)
+                                                   const bool delete_adj_list)
   MBErrorCode result;
@@ -524,7 +462,7 @@
     if (MB_SUCCESS != result && MB_MULTIPLE_ENTITIES_FOUND != result) continue;
     for (MBRange::iterator rit = ents.begin(); rit != ents.end(); rit++) {
       if (explicitly_adjacent(*rit, base_entity))
-        remove_adjacency(*rit, base_entity, update_reference_counts);
+        remove_adjacency(*rit, base_entity);
Modified: MOAB/trunk/AEntityFactory.hpp
--- MOAB/trunk/AEntityFactory.hpp	2007-09-25 16:45:54 UTC (rev 1285)
+++ MOAB/trunk/AEntityFactory.hpp	2007-09-25 16:56:03 UTC (rev 1286)
@@ -26,15 +26,13 @@
 typedef std::vector<MBEntityHandle> MBAdjacencyVector;
-class MBCore;
 //! class AEntityFactory
 public:
   //! require an MBInterface object in order to access tags on that interface
-  AEntityFactory(MBCore *mdb);
+  AEntityFactory(MBInterface *mdb);
   //! destructor
   ~AEntityFactory();
@@ -49,13 +47,11 @@
   MBErrorCode remove_adjacency(MBEntityHandle base_entity,
-                                MBEntityHandle adjacency_to_remove,
-                                bool update_reference_count = true);
+                                MBEntityHandle adjacency_to_remove);
   MBErrorCode remove_all_adjacencies(MBEntityHandle base_entity,
-                                     const bool delete_adj_list = false,
-                                     bool update_reference_counts = true);
+                                     const bool delete_adj_list = false);
 //! get the elements contained by source_entity, of
 //! type target_type, passing back in target_entities; if create_if_missing
@@ -144,23 +140,13 @@
                               unsigned long& total_entity_storage,
                               unsigned long& total_amortized_storage );
-  MBErrorCode decrement_reference_count( const MBEntityHandle* arr, size_t len );
-  MBErrorCode increment_reference_count( const MBEntityHandle* arr, size_t len );
-  MBErrorCode decrement_reference_count( MBEntityHandle ent )
-    { return decrement_reference_count( &ent, 1 ); }
-  MBErrorCode increment_reference_count( MBEntityHandle ent )
-    { return increment_reference_count( &ent, 1 ); }
-  MBErrorCode decrement_referenced_entities( MBEntityHandle h );
-  MBErrorCode increment_referenced_entities( MBEntityHandle h );
-#endif
 private:
   //! private constructor to prevent the construction of a default one
   AEntityFactory();
   //! interface associated with this tool
-  MBCore *thisMB;
+  MBInterface *thisMB;
   //! adjacencies collection
   DensePageGroup mDensePageGroup;
@@ -217,7 +203,7 @@
 inline MBErrorCode AEntityFactory::notify_delete_entity(MBEntityHandle entity)
   // remove any references to this entity from other entities
-  return remove_all_adjacencies(entity, true, false);
+  return remove_all_adjacencies(entity, true);
Modified: MOAB/trunk/EntitySequence.cpp
--- MOAB/trunk/EntitySequence.cpp	2007-09-25 16:45:54 UTC (rev 1285)
+++ MOAB/trunk/EntitySequence.cpp	2007-09-25 16:56:03 UTC (rev 1286)
@@ -37,9 +37,6 @@
 MBEntitySequence::MBEntitySequence(EntitySequenceManager* seq_manager,
   MBEntityHandle start_handle, MBEntityID num_entities )
   : mSequenceManager(seq_manager)
-#ifdef MOAB_WTIH_REFCOUNT
-  , mRefCount( num_entities, 0 )
-#endif
   assert(MB_START_ID <= ID_FROM_HANDLE(start_handle));
   assert(TYPE_FROM_HANDLE(start_handle) < MBMAXTYPE);
@@ -78,13 +75,7 @@
   mCoords[1] = new double[num_entities];
   mCoords[2] = new double[num_entities];
-  mRefCount.clear();
-  mRefCount.resize( num_entities, all_handles_used ? 1 : 0 );
-#else
   mFreeEntities.clear();
-#endif
   if(all_handles_used)
     mNumEntities = num_entities;
@@ -93,9 +84,7 @@
   else
     seq_manager->notify_not_full(this);
-#ifndef MOAB_WITH_REFCOUNT
     mFreeEntities.resize(mNumAllocated, true);
-#endif
     mNumEntities = 0;
     mFirstFreeIndex = 0;
     for(MBEntityID i=0; i<num_entities; i++)
@@ -122,11 +111,7 @@
     return 0;
   MBEntityHandle new_handle = mStartEntityHandle + mFirstFreeIndex;
-  mRefCount[mFirstFreeIndex] = 1;
-#else
   mFreeEntities[mFirstFreeIndex] = false;
-#endif
   mFirstFreeIndex = reinterpret_cast<MBEntityID&>(mCoords[0][mFirstFreeIndex]);
@@ -134,10 +119,8 @@
   if(mNumEntities == mNumAllocated) {
     mSequenceManager->notify_full(this);
     std::vector<bool> empty;
     mFreeEntities.swap(empty);
-#endif
   if( mLastDeletedIndex == (MBEntityID)( new_handle - mStartEntityHandle ))
@@ -152,21 +135,12 @@
   if(!is_valid_entity(handle))
     return;
-  if (get_reference_count(handle) != 1) // only referenced by this sequence
-    return;
-  decrement_reference_count(handle);
-#endif
     mSequenceManager->notify_not_full(this);
     mFreeEntities.resize( mNumAllocated, false );
-#endif
   mFreeEntities[handle - mStartEntityHandle] = true;
-#endif
   MBEntityID prev_free_handle = -1;
   const MBEntityID handle_index = handle - mStartEntityHandle;
@@ -232,22 +206,13 @@
                                            unsigned long& allocated) const
   unsigned long per_ent = get_memory_use((MBEntityHandle)0);
-  allocated = sizeof(*this) + per_ent*number_allocated();
-  allocated += mRefCount.capacity() * sizeof(int);
-#else
-  allocated += mFreeEntities.capacity()/8;
-#endif
+  allocated = sizeof(*this) + mFreeEntities.capacity()/8 + per_ent*number_allocated();
   used = per_ent * number_entities();
 unsigned long VertexEntitySequence::get_memory_use( MBEntityHandle ) const
-  return 3 * sizeof(double) + sizeof(unsigned);
-#else
   return 3 * sizeof(double);
-#endif
 MBEntityID ElementEntitySequence::get_next_free_index( MBEntityID prev_free_index ) const
@@ -281,13 +246,7 @@
   seq_manager->entity_sequence_created(this);
-#else
-#endif
@@ -296,9 +255,7 @@
   else
     mFreeEntities.resize( mNumAllocated, true );
-#endif
     mNumEntities = 0;
     if (nodes_per_element)
@@ -326,11 +283,7 @@
   if(mFirstFreeIndex == -1)
     return 0;
-#else
-#endif
   mFirstFreeIndex = reinterpret_cast<MBEntityID&>(mElements[mFirstFreeIndex*mNodesPerElement]);
@@ -340,9 +293,7 @@
-#endif
@@ -356,22 +307,12 @@
     return;
-    return;
-#endif
-#endif
   mFreeEntities[handle-mStartEntityHandle] = true;
-#endif
   MBEntityID prev_free_index = -1;
@@ -438,7 +379,7 @@
   assert(get_end_handle() >= split_location);
   // make a new sequence
-  const bool all_used = (mNumEntities == mNumAllocated);
+  const bool all_used = mFreeEntities.empty();
   ElementEntitySequence* seq = new ElementEntitySequence( mSequenceManager, split_location,
       get_end_handle() - split_location + 1 , mNodesPerElement, all_used);
   new_sequence = seq;
@@ -464,15 +405,6 @@
     assert( seq->mNumEntities == seq->mNumAllocated );
     return MB_SUCCESS;
-  const MBEntityHandle count = split_location - get_start_handle();
-  seq->mRefCount = mRefCount;
-  mRefCount.resize( count );
-  seq->mRefCount.erase( seq->mRefCount.begin(), seq->mRefCount.begin() + count );
-  std::vector<unsigned>(mRefCount).swap(mRefCount);
-  std::vector<unsigned>(seq->mRefCount).swap(seq->mRefCount);
-#else
   //copy free handles over too
   std::copy(mFreeEntities.begin()+(split_location-mStartEntityHandle),
@@ -481,26 +413,21 @@
   // shrink capacity to what we need
   mFreeEntities.resize(mNumAllocated);
   std::vector<bool>(mFreeEntities).swap(mFreeEntities);
-#endif
   // need to recompute : mNumEntities, mFirstFreeIndex for both sequences
   mNumEntities = 0;
   mFirstFreeIndex = -1;
-  std::vector<unsigned>::reverse_iterator iter = mRefCount.rbegin();
-  std::vector<unsigned>::reverse_iterator end_iter = mRefCount.rend();
-#else
   std::vector<bool>::reverse_iterator iter = mFreeEntities.rbegin();
   std::vector<bool>::reverse_iterator end_iter = mFreeEntities.rend();
-#endif
-  MBEntityID index = mNumAllocated - 1;
+  MBEntityID index = mFreeEntities.size() - 1;
   MBEntityID last_index = -1;
   for(; iter != end_iter; )
-    if(*iter)
+    if(*iter == true)
       reinterpret_cast<MBEntityID&>(mElements[index*mNodesPerElement]) = last_index;
       last_index = index;
@@ -517,10 +444,8 @@
     mFreeEntities.swap( empty );
-#endif
   else
@@ -529,20 +454,14 @@
   seq->mNumEntities = 0;
   seq->mFirstFreeIndex = -1;
-  iter = seq->mRefCount.rbegin();
-  end_iter = seq->mRefCount.rend();
-  index = seq->mRefCount.size() - 1;
-#else
   iter = seq->mFreeEntities.rbegin();
   end_iter = seq->mFreeEntities.rend();
   index = seq->mFreeEntities.size() - 1;
-#endif
   last_index = -1;
-    if(*iter)
+    if(*iter == true)
       reinterpret_cast<MBEntityID&>(seq->mElements[index*mNodesPerElement]) = last_index;
       last_index = index;
@@ -559,10 +478,8 @@
   if(seq->mNumEntities == seq->mNumAllocated) {
     mSequenceManager->notify_full(seq);
     seq->mFreeEntities.swap( empty );
-#endif
   else
     mSequenceManager->notify_not_full(seq);
@@ -573,15 +490,10 @@
 MBErrorCode ElementEntitySequence::convert_realloc(bool& mid_edge_nodes,
-    bool& mid_face_nodes, bool& mid_volume_nodes, MBCore* MB
-    , MBTag delete_mark_bit
-#endif
+    bool& mid_face_nodes, bool& mid_volume_nodes, MBCore* MB,
+    MBTag delete_mark_bit )
-  MBRange dead_nodes;
-#endif
   MBEntityType this_type = get_type();
   // figure out how many nodes per element we'll end up with
@@ -634,22 +546,13 @@
     old_end_handle = mElements + mNodesPerElement*mNumAllocated;
     old_iter = mElements + MBCN::VerticesPerEntity(this_type);
     std::set<MBEntityHandle> nodes_processed;
-#endif
     for(; old_iter < old_end_handle; )
       //tag each node-to-delete with parent element entity handle and number
       //of elements it is found on
       for(int i=0; i<number_to_delete; i++)
-        if (old_iter[i]) {
-          MB->decrement_reference_count( old_iter[i] );
-          if (MB->get_reference_count( old_iter[i] ) == 1)
-            dead_nodes.insert( old_iter[i] );
-#else
         //see if node has been processed yet
         if( old_iter[i] && nodes_processed.insert(old_iter[i]).second )
@@ -662,7 +565,6 @@
             MB->tag_set_data(delete_mark_bit, &(old_iter[i]), 1, &bit);
-#endif
       old_iter += mNodesPerElement;
@@ -696,22 +598,13 @@
     if(has_mid_edge_nodes())
       old_iter+=MBCN::mConnectivityMap[this_type][0].num_sub_elements;
-#endif
-#else
@@ -724,7 +617,6 @@
-#endif
@@ -761,20 +653,12 @@
-      if (*old_iter) {
-        MB->sequence_manager()->decrement_reference_count( *old_iter );
-        if (MB->get_reference_count( *old_iter ) == 1)
-          dead_nodes.insert( *old_iter );
-#else
       if( *old_iter != 0 && tag_for_deletion( old_iter - mElements, MB ) )
         //tag node as deletable
         unsigned char bit = 0x1;
         MB->tag_set_data(delete_mark_bit, &(*old_iter), 1, &bit);
-#endif
@@ -793,12 +677,8 @@
   mElements = new_array;
   mNodesPerElement = new_nodes_per_element;
-  return MB->delete_entities( dead_nodes );
-#else
   return MB_SUCCESS;
-#endif
 bool ElementEntitySequence::has_mid_edge_nodes() const
@@ -917,37 +797,11 @@
-  allocated += mRefCount.capacity() * sizeof(unsigned);
-#else
-#endif
 unsigned long ElementEntitySequence::get_memory_use( MBEntityHandle ) const
-  return sizeof(MBEntityHandle) * nodes_per_element() + sizeof(unsigned);
-#else
   return sizeof(MBEntityHandle) * nodes_per_element();
-#endif
-void ElementEntitySequence::decrement_all_referenced_entities( MBEntityHandle entity, AEntityFactory* f)
-  const MBEntityHandle* conn;
-  int len;
-  if (MB_SUCCESS == get_connectivity( entity, conn, len ))
-    f->decrement_reference_count( conn, len );
-void ElementEntitySequence::increment_all_referenced_entities( MBEntityHandle entity, AEntityFactory* f)
-  int len;
-    f->increment_reference_count( conn, len );
-#endif
Modified: MOAB/trunk/EntitySequence.hpp
--- MOAB/trunk/EntitySequence.hpp	2007-09-25 16:45:54 UTC (rev 1285)
+++ MOAB/trunk/EntitySequence.hpp	2007-09-25 16:56:03 UTC (rev 1286)
@@ -42,7 +42,6 @@
 class EntitySequenceManager;
 class MBCore;
-class AEntityFactory;
 class MBEntitySequence
@@ -102,18 +101,6 @@
                                unsigned long& allocated ) const = 0;
   virtual unsigned long get_memory_use( MBEntityHandle handle ) const = 0;
-  unsigned increment_reference_count( MBEntityHandle entity )
-    { return ++mRefCount[entity-get_start_handle()]; }
-  unsigned decrement_reference_count( MBEntityHandle entity )
-    { return --mRefCount[entity-get_start_handle()]; }
-  unsigned get_reference_count( MBEntityHandle entity) const
-    { return mRefCount[entity-get_start_handle()]; }
-  virtual void decrement_all_referenced_entities( MBEntityHandle entity, AEntityFactory* ) = 0;
-  virtual void increment_all_referenced_entities( MBEntityHandle entity, AEntityFactory* ) = 0;
-#endif
 protected:
   EntitySequenceManager* mSequenceManager;
@@ -135,11 +122,8 @@
   MBEntityID            mLastDeletedIndex;
   //! a list of whether entities are free or not
-  std::vector<unsigned> mRefCount;
-#else
   std::vector<bool>     mFreeEntities;
-#endif
@@ -178,11 +162,6 @@
   virtual void get_memory_use( unsigned long& used, unsigned long& allocated ) const;
   virtual unsigned long get_memory_use( MBEntityHandle handle ) const;
-  virtual void decrement_all_referenced_entities( MBEntityHandle , AEntityFactory* ) {}
-  virtual void increment_all_referenced_entities( MBEntityHandle , AEntityFactory* ) {}
-#endif
 private:
   // coordinate arrays x,y,z
@@ -228,11 +207,7 @@
   // reallocated the sequence to hold extra/less nodes, pass in what you want, and will return whether it needed
   // reallocate space for those nodes
   virtual MBErrorCode convert_realloc(bool& mid_edge_nodes, bool& mid_face_nodes, bool& mid_volume_nodes,
-      MBCore* MB
-      , MBTag bit_delete_mark
-#endif
+      MBCore* MB, MBTag bit_delete_mark );
   virtual bool has_mid_edge_nodes() const;
   virtual bool has_mid_face_nodes() const;
@@ -241,10 +216,6 @@
-  virtual void decrement_all_referenced_entities( MBEntityHandle entity, AEntityFactory* f);
-  virtual void increment_all_referenced_entities( MBEntityHandle entity, AEntityFactory* f);
-#endif
 protected:
   unsigned short mNodesPerElement;
@@ -261,11 +232,7 @@
 inline bool MBEntitySequence::is_valid_entity(MBEntityHandle entity) const
-  return 0 != get_reference_count(entity);
-#else
   return mFreeEntities.empty() || !mFreeEntities[entity-mStartEntityHandle];
-#endif
Modified: MOAB/trunk/EntitySequenceManager.hpp
--- MOAB/trunk/EntitySequenceManager.hpp	2007-09-25 16:45:54 UTC (rev 1285)
+++ MOAB/trunk/EntitySequenceManager.hpp	2007-09-25 16:56:03 UTC (rev 1286)
@@ -43,9 +43,9 @@
 #include "MBForward.hpp"
 #include "MBProcConfig.hpp"
-#include "EntitySequence.hpp"
 #include <map>
+class MBEntitySequence;
 class HomCoord;
 //! class for managing entity sequences
@@ -137,12 +137,6 @@
                               unsigned long& total_amortized_storage ) const;
-  inline unsigned increment_reference_count( MBEntityHandle handle );
-  inline unsigned decrement_reference_count( MBEntityHandle handle );
-  inline unsigned get_reference_count( MBEntityHandle handle ) const;
-#endif
 private:
   //! creates an entity sequence with a start handle and number of entities
@@ -180,24 +174,6 @@
   const MBProcConfig procInfo;
-unsigned EntitySequenceManager::increment_reference_count( MBEntityHandle handle )
-  MBEntitySequence* seq;
-  return MB_SUCCESS == find( handle, seq ) ? seq->increment_reference_count(handle) : 0;
-unsigned EntitySequenceManager::decrement_reference_count( MBEntityHandle handle )
-  return MB_SUCCESS == find( handle, seq ) ? seq->decrement_reference_count(handle) : 0;
-unsigned EntitySequenceManager::get_reference_count( MBEntityHandle handle ) const
-  return MB_SUCCESS == find( handle, seq ) ? seq->get_reference_count(handle) : 0;
 #endif
-#endif
Modified: MOAB/trunk/HigherOrderFactory.cpp
--- MOAB/trunk/HigherOrderFactory.cpp	2007-09-25 16:45:54 UTC (rev 1285)
+++ MOAB/trunk/HigherOrderFactory.cpp	2007-09-25 16:56:03 UTC (rev 1286)
@@ -234,10 +234,6 @@
   if(this_type == MBTRI || this_type == MBQUAD)
     temp_mid_volume = false;
-  seq->convert_realloc(temp_mid_edge, temp_mid_face, temp_mid_volume, mMB);
-#else
   MBTag deletable_nodes;
   mMB->tag_create("", 1, MB_TAG_BIT, deletable_nodes, NULL);
@@ -266,7 +262,6 @@
   mMB->tag_delete(deletable_nodes);
-#endif
   // create mid edge nodes if necessary
   if(temp_mid_edge)
@@ -332,9 +327,6 @@
     // create a new vertex at the centroid
     mMB->create_vertex(sum_coords, element[new_node_index]);
-    mMB->increment_reference_count( element[new_node_index] );
-#endif
     if(mHONodeAddedRemoved)
       mHONodeAddedRemoved->node_added(element[new_node_index], curr_handle);
@@ -421,9 +413,6 @@
         mMB->create_vertex(sum_coords, element[i+num_edges+num_vertices]);
-      mMB->increment_reference_count( element[i+num_edges+num_vertices] );
-#endif
         mHONodeAddedRemoved->node_added(element[i+num_edges+num_vertices], curr_handle);
@@ -509,9 +498,6 @@
         mMB->create_vertex(sum_coords, element[i+num_vertices]);
-      mMB->increment_reference_count( element[i+num_vertices] );
-#endif
         mHONodeAddedRemoved->node_added(element[i+num_vertices], curr_handle);
Modified: MOAB/trunk/MBCore.cpp
--- MOAB/trunk/MBCore.cpp	2007-09-25 16:45:54 UTC (rev 1285)
+++ MOAB/trunk/MBCore.cpp	2007-09-25 16:56:03 UTC (rev 1286)
@@ -950,23 +950,13 @@
   aEntityFactory->notify_change_connectivity(
     entity_handle, old_conn, connect, num_connect);
-  decrement_reference_count( old_conn, num_connect );
-#endif
   status = static_cast<ElementEntitySequence*>(seq)->set_connectivity(entity_handle,
-  if (status != MB_SUCCESS) {
+  if (status != MB_SUCCESS)
       entity_handle, connect, old_conn, num_connect);
-    increment_reference_count( old_conn, num_connect );
-  else {
-    increment_reference_count( connect, num_connect );
-#endif
   return status;
@@ -1397,86 +1387,22 @@
                                     const int num_entities,
                                     const void *tag_data)
-  MBErrorCode rval;
-  std::vector<MBEntityHandle> old_data;
-  std::vector<MBEntityHandle> unique_handles;
-  const TagInfo* tag_info = tagServer->get_tag_info( tag_handle );
-  if(!tag_info)
-    return MB_TAG_NOT_FOUND;
-  int count;
-#endif
+  if (NULL == entity_handles && 0 == num_entities)
+    return tagServer->set_mesh_data(tag_handle, tag_data);
-  if (NULL == entity_handles && 0 == num_entities) {
-    if (tag_info->get_data_type() == MB_TYPE_HANDLE) {
-      count = tag_info->get_size() / sizeof(MBEntityHandle);
-      old_data.resize( count );
-      rval = tagServer->get_mesh_data( tag_handle, &old_data[0] );
-      if (MB_SUCCESS == rval) {
-        rval = decrement_reference_count( &old_data[0], count );
-        if (MB_SUCCESS != rval)
-          return rval;
-      else
-        old_data.clear();
-#endif
-    rval = tagServer->set_mesh_data(tag_handle, tag_data);
-  else {
   //verify handles
-    const MBEntityHandle* iter;
-    const MBEntityHandle* end = entity_handles + num_entities;
-    for(iter = entity_handles; iter != end; ++iter)
-      if (TYPE_FROM_HANDLE(*iter) == MBENTITYSET) continue;
-      else if(sequenceManager->find(*iter, seq) != MB_SUCCESS)
-        return MB_ENTITY_NOT_FOUND;
+  MBEntitySequence* seq;
+  const MBEntityHandle* iter;
+  const MBEntityHandle* end = entity_handles + num_entities;
+  for(iter = entity_handles; iter != end; ++iter)
+    if (TYPE_FROM_HANDLE(*iter) == MBENTITYSET) continue;
-      unique_handles.resize( num_entities );
-      std::copy( entity_handles, entity_handles+num_entities, unique_handles.begin() );
-      std::sort( unique_handles.begin(), unique_handles.end() );
-      unique_handles.erase( std::unique( unique_handles.begin(), unique_handles.end() ), unique_handles.end() );
-      count = tag_info->get_size() * unique_handles.size() / sizeof(MBEntityHandle);
-          return rval;
-      else
-        old_data.clear();
-#endif
-    rval = tagServer->set_data(tag_handle, entity_handles, num_entities, tag_data);
+    else if(sequenceManager->find(*iter, seq) != MB_SUCCESS)
+      return MB_ENTITY_NOT_FOUND;
-      if (unique_handles.size()) {
-        tag_server()->get_data( tag_handle, &unique_handles[0], unique_handles.size(), &old_data[0] );
-        rval = increment_reference_count( &old_data[0], count );
-      else {
-        rval = increment_reference_count( (const MBEntityHandle*)tag_data, count );
-    else if (!old_data.empty())
-      increment_reference_count( &old_data[0], count );
-#endif
-  return rval;
+  return tagServer->set_data(tag_handle, entity_handles, num_entities, tag_data);
 //! set the data  for given EntityHandles and MBTag
@@ -1497,39 +1423,7 @@
       return result;
-  if(!tag_info)
-  int count;
-    count = tag_info->get_size() * entity_handles.size() / sizeof(MBEntityHandle);
-    result = tagServer->get_data( tag_handle, entity_handles, &old_data[0] );
-    if (MB_SUCCESS != result)
-      old_data.clear();
-    else {
-      result = decrement_reference_count( &old_data[0], count );
-        return result;
-#endif
-  result = tagServer->set_data(tag_handle, entity_handles, tag_data);
-    if (MB_SUCCESS == result)
-      result = increment_reference_count( (const MBEntityHandle*)tag_data, count );
-#endif
-  return result;
+  return tagServer->set_data(tag_handle, entity_handles, tag_data);
 //! adds a sparse tag for this specific EntityHandle/tag_name combination
@@ -1551,17 +1445,6 @@
                                 const void* def_val,
                                 bool use_existing )
-    // don't allow a non-zero default value for handle-type tags
-    // if reference counting is enabled.
-  if (data == MB_TYPE_HANDLE && def_val) {
-    const MBEntityHandle* handles = (const MBEntityHandle*)def_val;
-    for (size_t i = 0; i < size / sizeof(MBEntityHandle); ++i)
-      if (handles[i])
-#endif
   MBErrorCode rval = tagServer->add_tag( name, size, storage, data, handle, def_val );
     // If it is okay to use an existing tag of the same name, check that it
@@ -1601,32 +1484,11 @@
     return MB_FAILURE;
   MBErrorCode status = MB_SUCCESS, temp_status;
-  if(!tag_info)
-    old_data.resize( tag_info->get_size()/sizeof(MBEntityHandle) );
-#endif
   for (int i = 0; i < num_handles; i++) {
-    if (0 == entity_handles[i]) {
-      if (tag_info->get_data_type() == MB_TYPE_HANDLE &&
-          MB_SUCCESS == tagServer->get_mesh_data( tag_handle, &old_data[0] ))
-        decrement_reference_count( &old_data[0], old_data.size() );
-#endif
+    if (0 == entity_handles[i])
       temp_status = tagServer->remove_mesh_data(tag_handle);
-    else {
-          MB_SUCCESS == tagServer->get_data( tag_handle, entity_handles+i, 1, &old_data[0] ))
-#endif
+    else
       temp_status = tagServer->remove_data(tag_handle, entity_handles[i]);
     if (temp_status != MB_SUCCESS) status = temp_status;
@@ -1640,22 +1502,8 @@
   if (PROP_FROM_TAG_HANDLE(tag_handle) == MB_TAG_DENSE)
     return MB_FAILURE;
-  if(!tag_info)
-#endif
   for (MBRange::const_iterator it = entity_handles.begin(); it != entity_handles.end(); it++) {
-        MB_SUCCESS == tagServer->get_data( tag_handle, &*it, 1, &old_data[0] ))
-#endif
     temp_status = tagServer->remove_data(tag_handle, *it);
@@ -1666,21 +1514,6 @@
 //! removes the tag from MB
 MBErrorCode  MBCore::tag_delete(MBTag tag_handle)
-  if(!tag_info)
-    std::vector<MBEntityHandle> tag_data;
-    for (MBEntityType t = MBVERTEX; t <= MBENTITYSET; ++t) {
-      MBRange entities;
-      tagServer->get_entities( tag_handle, t, entities );
-      tag_data.resize( entities.size() );
-      tagServer->get_data( tag_handle, entities, &tag_data[0] );
-      decrement_reference_count( &tag_data[0], tag_data.size() );
-#endif
   return tag_server()->remove_tag(tag_handle);
@@ -1916,82 +1749,50 @@
-MBErrorCode MBCore::delete_entity( MBEntityHandle handle )
-  MBErrorCode result;
-    // tell AEntityFactory that this element is going away
-  result = aEntityFactory->notify_delete_entity(handle);
-    return result;
-    // reset and/or clean out data associated with this entity handle
-  result = tagServer->reset_data(handle);
-    return result;
-  if (TYPE_FROM_HANDLE(handle) == MBENTITYSET) {
-    if (MBMeshSet* ptr = get_mesh_set( sequence_manager(), handle )) {
-      int j, count;
-      const MBEntityHandle* rel;
-      ptr->clear( handle, a_entity_factory() );
-      rel = ptr->get_parents( count );
-      for (j = 0; j < count; ++j)
-        remove_child_meshset( rel[j], handle );
-      rel = ptr->get_children( count );
-        remove_parent_meshset( rel[j],handle );
-    // now delete the entity
-  result = sequence_manager()->delete_entity(handle);
-    return result;
 //! deletes an entity vector
 MBErrorCode MBCore::delete_entities(const MBEntityHandle *entities,
                                       const int num_entities)
-  // If reference counting is enabled, make sure all entities
-  // are unreferenced, assuming all other entities in the list
-  // are also deleted.
-  std::vector<MBTag> handle_tags;
-  tag_server()->get_tags( MB_TYPE_HANDLE, handle_tags );
-  int ii, jj;
-    // before deleting each entity, decrement the reference count on
-    // everything that entity references.
-  for (ii = 0; ii < num_entities; ++ii)
-    if (MB_SUCCESS != decrement_all_referenced_entities( entities[ii], handle_tags ))
-      break;
-    // make sure everything that is to be deleted has a reference count
-    // of 1 (only referenced by the containing sequence).
-  if (ii == num_entities)
-    for (jj = 0; jj < num_entities; ++jj)
-      if (get_reference_count( entities[jj] ) != 1)
-        break;
-    // if we can't delete the entities, but the reference counts back
-    // to what they were before and return failure.
-  if (ii < num_entities || jj < num_entities) {
-    while (ii > 0)
-      increment_all_referenced_entities( entities[--ii], handle_tags );
-#endif
   MBErrorCode result = MB_SUCCESS, temp_result;
   for (int i = 0; i < num_entities; i++) {
-    temp_result = delete_entity( entities[i] );
-    if (MB_SUCCESS != temp_result)
+      // tell AEntityFactory that this element is going away
+    temp_result = aEntityFactory->notify_delete_entity(entities[i]);
+    if (MB_SUCCESS != temp_result) {
       result = temp_result;
+      continue;
+      // reset and/or clean out data associated with this entity handle
+    temp_result = tagServer->reset_data(entities[i]);
+      result = temp_result;
+      continue;
+    if (TYPE_FROM_HANDLE(entities[i]) == MBENTITYSET) {
+      if (MBMeshSet* ptr = get_mesh_set( sequence_manager(), entities[i] )) {
+        int j, count;
+        const MBEntityHandle* rel;
+        ptr->clear( entities[i], a_entity_factory() );
+        rel = ptr->get_parents( count );
+        for (j = 0; j < count; ++j)
+          remove_child_meshset( rel[j], entities[i] );
+        rel = ptr->get_children( count );
+          remove_parent_meshset( rel[j], entities[i] );
+      // now delete the entity
+    temp_result = sequence_manager()->delete_entity(entities[i]);
+      continue;
   return result;
@@ -1999,36 +1800,9 @@
 //! deletes an entity range
 MBErrorCode MBCore::delete_entities(const MBRange &range)
-  MBRange::const_iterator ii, jj;
-  for (ii = range.begin(); ii != range.end(); ++ii)
-    if (MB_SUCCESS != decrement_all_referenced_entities( *ii, handle_tags ))
-      break;
-  if (ii == range.end())
-    for (jj = range.begin(); jj != range.end(); ++jj)
-      if (get_reference_count( *jj ) != 1)
-        break;
-  if (ii != range.end() || jj != range.end()) {
-    while (ii != range.begin())
-      increment_all_referenced_entities( *--ii, handle_tags );
-#endif
   MBErrorCode result = MB_SUCCESS, rval;
   for (MBRange::iterator i = range.begin(); i != range.end(); ++i)
-    if (MB_SUCCESS != (rval = delete_entity( *i )))
+    if (MB_SUCCESS != (rval = delete_entities( &*i, 1)))
       result = rval;
   return rval;
@@ -2592,7 +2366,13 @@
 MBErrorCode MBCore::add_parent_meshset( MBEntityHandle meshset,
                                         const MBEntityHandle parent_meshset)
-  return add_parent_meshsets( meshset, &parent_meshset, 1 );
+  MBMeshSet* set_ptr = get_mesh_set( sequence_manager(), meshset );
+  MBMeshSet* parent_ptr = get_mesh_set( sequence_manager(), parent_meshset );
+  if (!set_ptr || !parent_ptr)
+  set_ptr->add_parent( parent_meshset );
+  return MB_SUCCESS;
 MBErrorCode MBCore::add_parent_meshsets( MBEntityHandle meshset,
@@ -2607,21 +2387,21 @@
     if (!get_mesh_set( sequence_manager(), parents[i] ))
   for (int i = 0; i < count; ++i)
-    if (set_ptr->add_parent( parents[i] ))
-      increment_reference_count( parents + i, 1 );
-#else
-  for (int i = 0; i < count; ++i)
     set_ptr->add_parent( parents[i] );
-#endif
   return MB_SUCCESS;
 MBErrorCode MBCore::add_child_meshset(MBEntityHandle meshset,
                                         const MBEntityHandle child_meshset)
-  return add_child_meshsets( meshset, &child_meshset, 1 );
+  MBMeshSet* child_ptr = get_mesh_set( sequence_manager(), child_meshset );
+  if (!set_ptr || !child_ptr)
+  set_ptr->add_child( child_meshset );
 MBErrorCode MBCore::add_child_meshsets( MBEntityHandle meshset,
@@ -2636,14 +2416,8 @@
     if (!get_mesh_set( sequence_manager(), children[i] ))
-    if (set_ptr->add_child( children[i] ))
-      increment_reference_count( children+i, 1 );
-#else
     set_ptr->add_child( children[i] );
-#endif
   return MB_SUCCESS;
@@ -2655,16 +2429,9 @@
   MBMeshSet* child_ptr = get_mesh_set( sequence_manager(), child );
   if (!parent_ptr || !child_ptr)
-  if (parent_ptr->add_child( child ))
-    increment_reference_count( &child, 1 );
-  if (child_ptr->add_parent( parent ))
-    increment_reference_count( &parent, 1 );
-#else
   parent_ptr->add_child( child );
   child_ptr->add_parent( parent );
-#endif
   return MB_SUCCESS;
@@ -2676,15 +2443,8 @@
-  if (parent_ptr->remove_child( child ))
-    decrement_reference_count( &child, 1 );
-  if (child_ptr->remove_parent( parent ))
-    decrement_reference_count( &parent, 1 );
-#else
   parent_ptr->remove_child( child );
   child_ptr->remove_parent( parent );
-#endif
   return MB_SUCCESS;
@@ -2695,12 +2455,7 @@
   if (!set_ptr)
-  if (set_ptr->remove_parent( parent_meshset ))
-    decrement_reference_count( &parent_meshset, 1 );
-#else
   set_ptr->remove_parent( parent_meshset );
-#endif
   return MB_SUCCESS;
@@ -2710,12 +2465,7 @@
   if (!set_ptr)
-  if (set_ptr->remove_child( child_meshset ))
-    decrement_reference_count( &child_meshset, 1 );
-#else
   set_ptr->remove_child( child_meshset );
-#endif
   return MB_SUCCESS;
@@ -3147,265 +2897,3 @@
                          tag_array,         num_tags,
                          tag_storage,       amortized_tag_storage );
-MBErrorCode MBCore::increment_reference_count( const MBEntityHandle* array, size_t count )
-  MBErrorCode result = MB_SUCCESS, tmp;
-  for (size_t i = 0; i < count; ++i) {
-    tmp = sequence_manager()->find( array[i], seq );
-    if (MB_SUCCESS != tmp)
-      result = tmp;
-    else if (!seq->is_valid_entity(array[i]))
-      result = MB_ENTITY_NOT_FOUND;
-    else
-      seq->increment_reference_count( array[i] );
-  return result;
-MBErrorCode MBCore::decrement_reference_count( const MBEntityHandle* array, size_t count )
-      result = tmp;
-    else
-      seq->decrement_reference_count( array[i] );
-  return result;
-unsigned MBCore::get_reference_count( MBEntityHandle handle )
-  MBErrorCode rval = sequence_manager()->find( handle, seq );
-  return MB_SUCCESS == rval ? seq->get_reference_count(handle) : 0;
-MBErrorCode MBCore::decrement_all_referenced_entities( MBEntityHandle handle,
-                                   const std::vector<MBTag>& handle_tags )
-    return rval;
-  seq->decrement_all_referenced_entities( handle, a_entity_factory() );
-  rval = a_entity_factory()->decrement_referenced_entities( handle );
-  if (MB_SUCCESS != rval) {
-    seq->increment_all_referenced_entities( handle, a_entity_factory() );
-    return rval;
-  for (std::vector<MBTag>::const_iterator i = handle_tags.begin();
-       i != handle_tags.end(); ++i) {
-    int size;
-    tag_get_size( *i, size );
-    size /= sizeof(MBEntityHandle);
-    tag_data.resize( size );
-    rval = tag_server()->get_data( *i, &handle, 1, &tag_data[0] );
-      decrement_reference_count( &tag_data[0], size );
-MBErrorCode MBCore::increment_all_referenced_entities( MBEntityHandle handle,
-    return rval;
-  rval = a_entity_factory()->increment_referenced_entities( handle );
-    return rval;
-    int size;
-      increment_reference_count( &tag_data[0], size );
-#else
-MBErrorCode MBCore::increment_reference_count( const MBEntityHandle* , size_t  )
-  abort();
-MBErrorCode MBCore::decrement_reference_count( const MBEntityHandle* , size_t  )
-  abort();
-unsigned MBCore::get_reference_count( MBEntityHandle  )
-  abort();
-  return (unsigned)-1;
-MBErrorCode MBCore::decrement_all_referenced_entities( MBEntityHandle,
-                                   const std::vector<MBTag>&  )
-  abort();
-MBErrorCode MBCore::increment_all_referenced_entities( MBEntityHandle ,
-  abort();
-#endif
-MBErrorCode MBCore::find_all_referencing_entities( MBEntityHandle entity,
-                                                   MBRange& results )
-  MBErrorCode rval;
-  MBRange entities;
-    // if entity is a vertex, check all connectivity lists
-  if (TYPE_FROM_HANDLE(entity) == MBVERTEX) {
-    for (MBEntityType t = MBEDGE; t < MBENTITYSET; ++t) {
-      if (t == MBPOLYHEDRON)
-        continue;
-      entities.clear();
-      rval = get_entities_by_type( 0, t, entities );
-        return rval;
-      for (MBRange::iterator i = entities.begin(); i != entities.end(); ++i) {
-        int len;
-        rval = get_connectivity( *i, conn, len );
-          return rval;
-        if (std::find( conn, conn+len, entity ) - conn < len)
-          results.insert( *i );
-    // if entity type is a face, check polyhedron connectivity
-  if (MBCN::Dimension( TYPE_FROM_HANDLE(entity) ) == 2) {
-    entities.clear();
-    rval = get_entities_by_type( 0, MBPOLYHEDRON, entities );
-      return rval;
-      int len;
-        return rval;
-    // check all adjacnecy data
-  entities.clear();
-  rval = get_entities_by_handle( 0, entities );
-    return rval;
-    int len;
-    rval = a_entity_factory()->get_adjacencies( *i, adj, len );
-      return rval;
-    if (std::find( adj, adj+len, entity ) - adj < len)
-    // check set contents
-  entities.clear();
-  rval = get_entities_by_type( 0, MBENTITYSET, entities );
-    return rval;
-    MBRange contents;
-    rval = get_entities_by_handle( *i, contents );
-    if (contents.find( entity ) != contents.end())
-    // if entity is a set, check set parent/child links
-  if (TYPE_FROM_HANDLE(entity) == MBENTITYSET) {
-      MBRange parents, children;
-      rval = get_parent_meshsets( *i, parents );
-        return rval;
-      rval = get_child_meshsets( *i, children );
-        return rval;
-      if (parents.find(entity) != parents.end() || children.find(entity) != children.end())
-    // check all handle tags
-  std::vector<MBTag> tags;
-  rval = tag_server()->get_tags( MB_TYPE_HANDLE, tags );
-  while (!tags.empty()) {
-    MBTag tag = tags.back();
-    tags.pop_back();
-    int size;
-    rval = tag_get_size( tag, size );
-      return rval;
-    std::vector<MBEntityHandle> tag_values(size/sizeof(MBEntityHandle));;
-      entities.clear();
-      rval = get_entities_by_type_and_tag( 0, t, &tag, 0, 1, entities );
-        return rval;
-        rval = tag_get_data( tag, &*i, 1, &tag_values[0] );
-          return rval;
-        if (std::find(tag_values.begin(), tag_values.end(), entity) != tag_values.end())
Modified: MOAB/trunk/MBCore.hpp
--- MOAB/trunk/MBCore.hpp	2007-09-25 16:45:54 UTC (rev 1285)
+++ MOAB/trunk/MBCore.hpp	2007-09-25 16:56:03 UTC (rev 1286)
@@ -950,17 +950,6 @@
   virtual const MBProcConfig& proc_config() const
     { return procInfo; }
-  MBErrorCode increment_reference_count( MBEntityHandle h )
-    { return increment_reference_count( &h, 1 ); }
-  MBErrorCode decrement_reference_count( MBEntityHandle h )
-    { return decrement_reference_count( &h, 1 ); }
-  MBErrorCode increment_reference_count( const MBEntityHandle* handles, size_t size );
-  MBErrorCode decrement_reference_count( const MBEntityHandle* handles, size_t size );
-  unsigned get_reference_count( MBEntityHandle handle );
-  MBErrorCode decrement_all_referenced_entities( MBEntityHandle handle, const std::vector<MBTag>& handle_tags );
-  MBErrorCode increment_all_referenced_entities( MBEntityHandle handle, const std::vector<MBTag>& handle_tags );
-  MBErrorCode find_all_referencing_entities( MBEntityHandle entity, MBRange& results );
 private:
   void estimated_memory_use_internal( const MBRange* ents,
@@ -975,8 +964,6 @@
                             unsigned long* tag_storage,
                             unsigned long* amortized_tag_storage );
-  MBErrorCode delete_entity( MBEntityHandle handle );
     //! database init and de-init routines
Deleted: MOAB/trunk/MBFileReadTool.cpp
--- MOAB/trunk/MBFileReadTool.cpp	2007-09-25 16:45:54 UTC (rev 1285)
+++ MOAB/trunk/MBFileReadTool.cpp	2007-09-25 16:56:03 UTC (rev 1286)
@@ -1,324 +0,0 @@
- * MOAB, a Mesh-Oriented datABase, is a software component for creating,
- * storing and accessing finite element mesh data.
- * Copyright 2004 Sandia Corporation.  Under the terms of Contract
- * DE-AC04-94AL85000 with Sandia Coroporation, the U.S. Government
- * retains certain rights in this software.
- * This library is free software; you can redistribute it and/or
- * modify it under the terms of the GNU Lesser General Public
- * License as published by the Free Software Foundation; either
- * version 2.1 of the License, or (at your option) any later version.
-/**\file MBFileReadTool.cpp
- *\author Jason Kraftcheck <kraftche at cae.wisc.edu>
- *\date 2007-08-21
-#include "MBFileReadTool.hpp"
-MBFileReadToolBase( MBCore* moab )
-  : mMOAB( moab ), fileSet( 0 ),
-    parallelRank( moab->proc_config().rank() )
-void MBFileReadToolBase::report_error( std::string err )
-  mMOAB->get_error_handler()->set_last_error( err );
-void MBFileReadToolBase::report_error( const char* fmt, ... )
-  va_list args;
-  va_start(args, fmt);
-  mMOAB->get_error_handler()->set_last_error( fmt, args );
-  va_end( args );
-MBErrorCode MBFileReadToolBase::delete_all_entities()
-  MBErrorCode rval;
-  MBRange list;
-  if (fileSet == 0)  // all entities already deleted
-  rval = moab()->get_entities_by_handle( fileSet, list );
-    return rval;
-  list.insert( fileSet );
-  rval = moab()->delete_entities( list );
-    return rval;
-  fileSet = 0;
-MBErrorCode MBFileReadToolBase::delete_non_tagged_entities(
-                                              const char* tagname,
-                                              const int* tag_values,
-                                              int num_tag_values )
-  MBErrorCode rval;
-    // no entities?
-  if (fileSet == 0) {
-    report_error( "No entities with tag \"%s\" in file.\n", tagname );
-    // get tag
-  MBTag tag;
-  rval = moab()->tag_get_handle( tagname, tag );
-    report_error( "Tag not found: \"%s\"\n", tagname );
-    return rval;
-    // check type of tag data
-  MBDataType type;
-  int size = 0;
-  moab()->tag_get_size( tag, size );
-  moab()->tag_get_type( tag, type );
-  if (size != sizeof(int) || (type != MB_TYPE_INTEGER && type != MB_TYPE_OPAQUE)) {
-    report_error( "Invalid type for tag \"%s\"\n", tagname );
-    return MB_TYPE_OUT_OF_RANGE;
-    // construct argument arrays
-  std::vector<MBTag> taghandles( num_tag_values ? num_tag_values : 1, tag );
-  std::vector<const void*> tagvals( num_tag_values );
-  for (int i = 0; i < num_tag_values; ++i)
-    tagvals[i] = tag_values + i;
-    // get entity sets with specified tag
-  MBRange sets;
-  rval = moab()->get_entities_by_type_and_tag( fileSet,
-                                               MBENTITYSET,
-                                               &taghandles[0],
-                                               num_tag_values ? &tagvals[0] : 0,
-                                               taghandles.size(),
-                                               sets,
-                                               MBInterface::UNION );
-    // get closure of entity sets
-  MBRange entities, temp;
-  MBRange::iterator iter;
-    // recursively descend all containd and child entity sets
-  std::set<MBEntityHandle> visited;
-  std::vector<MBEntityHandle> children;
-  while (!sets.empty()) {
-    MBEntityHandle entset = sets.pop_front();
-    if (!visited.insert(entset).first)
-      continue;
-    entities.insert( entset );
-    temp.clear();
-    moab()->get_entities_by_handle( entset, temp );
-    iter = temp.lower_bound( MBENTITYSET );
-    entities.merge( temp.begin(), iter );
-    std::copy( iter, temp.end(), mb_range_inserter( sets ) );
-    children.clear();
-    rval = moab()->get_child_meshsets( entset, children );
-      return rval;
-    std::copy( children.begin(), children.end(), mb_range_inserter( sets ) );
-    // get faces for all polyhedra
-  int len;
-  iter = entities.lower_bound( MBPOLYHEDRON );
-  for (; iter != entities.end() && TYPE_FROM_HANDLE(*iter) < MBENTITYSET; ++iter) {
-    rval = moab()->get_connectivity( *iter, conn, len );
-      return rval;
-    std::copy( conn, conn+len, mb_range_inserter( entities ) );
-    // get vertices for all elements
-  iter = entities.lower_bound( MBEDGE );
-  for (; iter != entities.end() && TYPE_FROM_HANDLE(*iter) < MBPOLYHEDRON; ++iter) {
-      return rval;
-    // We now have the list of entities to keep.
-    // Get the list of entities to remove.
-  MBRange all, dead;
-  moab()->get_entities_by_handle( fileSet, all );
-  dead = all.subtract( entities );
-    // Destroy the entities
-  rval = moab()->remove_entities( fileSet, dead );
-    return rval;
-  rval = moab()->delete_entities( dead );
-    return rval;
-MBErrorCode MBFileReadToolBase::create_sequence( MBEntityID start_id,
-                                                 MBEntityID count,
-                                                 MBEntityID type,
-                                                 MBEntityID conn_len,
-                                                 const int* proc_id,
-                                                 MBEntitySequence*& seq )
-  MBErrorCode rval;
-    // if we haven't created a set for all file entities yet,
-    // do it now
-  if (!fileSet) {
-    rval = moab()->create_meshset( MESHSET_SET, fileSet );
-      fileSet =0;
-      return rval;
-  const int proc = proc_id ? *proc_id : parallel_rank();
-  MBEntitySequence* seq = 0;
-  rval = mMOAB->sequence_manager()->create_entity_sequence(
-                                                    type,
-                                                    count,
-                                                    conn_len,
-                                                    start_id,
-                                                    proc,
-                                                    start_handle,
-                                                    seq );
-    return rval;
-  MBRange new_handles( seq->get_start_handle(), seq->get_end_handle() );
-  assert( new_handles.size() == count );
-  rval = moab()->add_entites( fileSet, new_handles );
-    delete seq;
-    return rval;
-MBErrorCode MBFileReadToolBase::get_node_arrays(
-                               MBEntityID preferred_start_id,
-                               MBEntityID count,
-                               MBEntityHandle& start_handle,
-                               double *& x, double *& y, double *& z,
-                               const int* proc_id )
-  MBErrorCode rval = create_sequence( preferred_start_id,
-                                      count,
-                                      MBVERTEX,
-                                      0,
-                                      proc_id,
-                                      seq );
-    return rval;
-  VertexEntitySequence* vseq = static_cast<VertexEntitySequence*>(seq);
-  vseq->get_coordinate_arrays( x, y, z );
-  start_handle = seq->get_start_handle();
-MBErrorCode MBFileReadToolBase::create_element_array(
-                                              MBEntityID count,
-                                              MBEntityType type,
-                                              MBEntityID conn_length,
-                                              MBEntityHandle*& conn_array,
-                                              int** last_index_array = 0,
-    // caller needs last_index_array for poly-type elements
-  if (type == POLYGON || type == POLYHEDRON) {
-    if (!last_index_array)
-    // no last_index_array for other element types
-  else if (last_index_array)
-    *last_index_array = 0;
-                                      count,
-                                      type,
-                                      conn_length,
-                                      proc_id,
-                                      seq );
-    return rval;
-    PolyEntitySequence* pseq = static_cast<PolyEntitySequence*>(seq);
-    pseq->get_connectivity_array( conn_array );
-    pseq->get_index_array( *last_index_array );
-  else {
-    ElementEntitySequence* eseq = static_cast<ElementEntitySequence*>(seq);
-    eseq->get_connectivity_array( conn_array );
-MBErrorCode MBFileReadToolBase::create_meshset_block( MBEntityID start_id,
-                                                      MBEntityID count,
-                                                      unsigned flags,
-  std::vector<unsigned> flag_array( count, flags );
-  return create_meshset_block( start_id, count, start_handle, &flag_array[0], proc_id );
-                                                      MBEntityID count,
-                                                      const unsigned* flags,
-  MBErrorCode rval;
-  rval = mMOAB->sequence_manager()->create_meshset_sequence( count,
-                                                             start_id,
-                                                             proc,
-                                                             flags,
-                                                             seq );
-    return rval;
-MBErrorCode MBFileReadToolBase::set_tag_data( MBTag tag,
-                                              MBEntityHandle beg,
-                                              MBEntityHandle num,
-                                              const void* data )
-  if (num == 0)
-  MBRange range( beg, beg + num - 1 );
-  return moab()->tag_set_data( tag, range, data );
Deleted: MOAB/trunk/MBFileReadTool.hpp
--- MOAB/trunk/MBFileReadTool.hpp	2007-09-25 16:45:54 UTC (rev 1285)
+++ MOAB/trunk/MBFileReadTool.hpp	2007-09-25 16:56:03 UTC (rev 1286)
@@ -1,909 +0,0 @@
-/**\file MBFileReadTool.hpp
- *\date 2007-04-25
-#ifndef MB_FILE_READ_TOOL_HPP
-#define MB_FILE_READ_TOOL_HPP
-#include "RangeMap.hpp"
-#include <iosfwd>
-class MBCore;
-class MBError;
-/**\brief Non-template portions of MBFileReadTool */
-class MBFileReadToolBase {
-public:
-  MBFileReadToolBase( MBCore* moab );
-  /**\brief Set last error message */
-  void report_error( std::string error );
-  void report_error( const char* error, ... )
-#ifdef __GNUC__
-  __attribute__((format(printf,2,3)))
-#endif
-  inline MBInterface* moab() const
-    { return mMOAB; }
-  inline unsigned parallel_rank() const
-    { return parallelRank; }
-  /**\brief delete all read entities
-   * Delete all entities created through the methods
-   * provided by this class.
-  MBErrorCode delete_all_entities();
-  /**\brief Get entity set containing all read entities
-   * Get a new entity set containing all the entities
-   * allocated via methods of this object.
-  inline MBEntityHandle get_file_set() const
-    { return fileSet; }
-  /**\brief Delete entities with specified tag
-   * Delete all entities read from file that do not have
-   * the specified tag or tag values.
-   *\param tagname  The name of the tag -- must have single integer value
-   *\param tag_values If not null, a list of integer tag values
-   *\param num_tag_values The length of tag_values
-  MBErrorCode delete_non_tagged_entities( const char* tagname,
-                                          const int* tag_values = 0,
-                                          int num_tag_values = 0 );
-protected:
-  /**\brief Allocate vertex sequence
-   * Allocate a vertex sequence and update any bookkeeping in
-   * this object.
-   *\param preferred_start_id First MBEntityID, if available
-   *\param count              Number of vertices to allocate
-   *\param start_handle       Output: first vertex handle
-   *\param x                  Output: MOAB internal storage for vertex X-coordinates.
-   *\param y                  Output: MOAB internal storage for vertex Y-coordinates.
-   *\param z                  Output: MOAB internal storage for vertex Z-coordinates.
-   *\param proc_id            NULL or requested parallel processor ID
-  MBErrorCode get_node_arrays( MBEntityID preferred_start_id,
-                               MBEntityID count,
-                               const int* proc_id );
-  /**\brief Allocate element sequence
-   * Allocate a element sequence and update any bookkeeping in
-   * this object.
-   *\param count              Number of elements to allocate
-   *\param type               Element type
-   *\param conn_length        Vertices per element, zero for MBPOLYGON and MBPOLYHEDRON
-   *\param conn_array         Output: MOAB internal storage for element connectivity
-   *\param last_index_array   Cannot be NULL for MBPOLYGON or MBPOLYHEDRON.  Must
-   *                          be NULL for other types.  Output: Pointer to MOAB
-   *                          internal storage of last index in connectivity
-   *                          array for each element.
-  MBErrorCode get_element_array( MBEntityID preferred_start_id,
-                                 MBEntityID count,
-  /**\brief Allocate a meshset sequence
-   * Allocate a meshset sequence and update any bookkeeping in
-   * this object.
-   *\param count              Number of entity sets to allocate
-   *\param start_handle       Output: first entity set handle
-   *\param flags              entity set creation flags (one val for all entity sets)
-  MBErrorCode create_meshset_block( MBEntityID preferred_start_id,
-                                    MBEntityID count,
-                                    MBEntityHandle& start_handle_out,
-                                    unsigned flags,
-   * this object.
-   *\param flags              entity set creation flags (one val per entity sets)
-                                    MBEntityID count,
-  /**\brief Set tag data for a block of entity handles. */
-  MBErrorCode set_tag_data( MBTag tag,
-                            MBEntityHandle count,
-                            const void* data );
-private:
-  MBErrorCode create_sequence( MBEntityID start_id,
-                               MBEntityID count,
-                               MBEntityID type,
-                               MBEntitySequence*& seq );
-  MBCore* mMOAB;
-  MBEntityHandle fileSet;
-  unsigned parallelRank;
-/**\brief Helper class for file readers.
- * This class provides methods for creation of entities
- * in MOAB and maintains a map from file IDs to MBEntityHandles.
- * All methods accept values as file IDs and map them to MBEntityHandles
- * internally.
- * The type of a file ID is a template parameter, allowing a
- * particular reader to work directly with the identifier/index
- * type used by an underlying IO library.
-template <typename FileIDType>
-class MBFileReadTool : public MBFileReadToolBase
-public:
-  /**\brief Create reader tool
-   *\param vertex_unique_ids File ID space for vertices is separate from
-   *                         other entities.  If this value is true, then
-   *                         the file may contain both a vertex with ID 1
-   *                         and an element with the same ID value of 1.
-   *\param element_type_unique_ids File ID space is separate for different
-   *                         element types.  If this value is true, then
-   *                         the file may contain an edge and a
-   *                         triangle element that have the same ID.
-   *\param set_unique_ids File ID space for entity sets is separate from
-   *                         other entities.
-  inline
-  MBFileReadTool( MBCore* moab_instance,
-                  bool vertex_unique_ids,
-                  bool element_type_unique_ids,
-                  bool set_unique_ids );
-  /**\brief Allocate a block of nodes.
-   * Allocate a block of nodes and return pointers to MOAB's internal
-   * storage of the vertex coordinaets for those nodes, such that the
-   * file reader may read the coordinate values directly into the
-   * vertex storage allocated by this method.
-   *\param start_id  The file ID (or index) of the first vertex.  The
-   *                 allocated vertices will be assigned file IDs in
-   *                 the range [start_id,start_id+count).
-   *\param count     Number of vertices to allocate.
-   *\param x_array_out  Output: location at which to write X-coordinates.
-   *\param y_array_out  Output: location at which to write Y-coordinates.
-   *\param z_array_out  Output: location at which to write Z-coordinates.
-   *\param proc_id   For parallel, ID of processor to associate with entities.
-   *                 If null, current processor rank is assumed.
-  inline
-  MBErrorCode create_nodes( FileIDType start_id,
-                            FileIDType count,
-                            double *& x_array_out,
-                            double *& y_array_out,
-                            double *& z_array_out,
-                            const int* proc_id = 0 );
-  /**\brief Create a block of elements.
-   * Create mesh elements.
-   *\param type      The element type.
-   *\param connectivity_length Nodes per element.  Zero for MBPOLY* types.
-   *\param interleaved_connectivity Element connectivity list, specified
-   *                 as vertex IDs as assigned by the create_nodes method
-   *                 of this class (face IDs if type == POLYHEDRON).
-   *\param poly_end_indices For MBPOLYGON and MBPOLYHEDRON types, the
-   *                 *last* index in interleaved_connectivity for each element.
-  inline
-  MBErrorCode create_elements( FileIDType start_id,
-                               FileIDType count,
-                               FileIDType connectivity_length,
-                               const FileIDType* interleaved_connectivity,
-                               const FileIDType* poly_end_indices = 0,
-  /**\brief Specifiy explicit adjacencies
-   * Create explicit adjacencies between entities.
-   *\param from_id   Source entity for adjacency
-   *\param to_ids    Target entities for adjacencies
-   *\param to_count  Length of to_ids
-   *\param from_type Type of source entity.  The caller
-   *                 must specify this value if it cannot
-   *                 be inferred from the source entity ID
-   *                 (see constructor arguments.)
-   *\param to_type   Type of target entities.  The caller
-   *                 be inferred from the target entity IDs
-  inline
-  MBErrorCode add_adjacencies( FileIDType from_id,
-                               const FileIDType* to_ids,
-                               FileIDType to_count,
-                               MBEntityType from_type = MBMAXTYPE,
-                               MBEntityType to_type = MBMAXTYPE );
-  /**\brief Create tag for storing entity handles.
-   *\param name         Tag name
-   *\param num_handles  Number of handles in each tag value.  If
-   *                    this value is greater than one, then each
-   *                    entity has an array of handles for this tag.
-   *\param storage_type Tag storage type.
-   *\param handle_out   Output: tag handle
-   *\param mesh_value   Global, or mesh value for tag.
-   *\param default_value Default value for tag.
-   *\param null_id      If non-null, the value pointed to by this
-   *                    argument is treated as special: a "NULL" file ID.
-  inline
-  MBErrorCode create_entity_handle_tag( const char* name,
-                                        unsigned num_handles,
-                                        MBTagType storage_type,
-                                        MBTag& handle_out,
-                                        const FileIDType* mesh_value = 0,
-                                        const FileIDType* default_value = 0,
-                                        const FileIDType* null_id = 0 );
-  /**\brief Set tag data for a block of entities
-   * Set tag data for non-handle type tags.  This method will
-   * fail if the tag has a data type MB_TAG_HANDLE.
-   *\param handle       Tag handle
-   *\param start_id     File ID of first entity
-   *\param id_count     Number of entities.
-   *\param tag_data     Tag values
-   *\param type         The type of the entities for which the tag
-   *                    data is being set.  The caller must specify
-   *                    this if it cannot be inferred from the file
-   *                    IDs (see constructor arguments).
-  inline
-  MBErrorCode set_tag_data( MBTag handle,
-                            FileIDType start_id,
-                            FileIDType id_count,
-                            const void* tag_data,
-                            MBEntityType type = MBMAXTYPE );
-  /**\brief Set tag data for entity handle tag for a block of entities
-   * This method will fail for any tag that does not have a data type
-   * of MB_TYPE_HANDLE.
-   *\param tag_data     Tag values as file IDs
-   *\param entity_type  The type of the entities for which the tag
-   *\param value_type   The type of the entities in the tag values.
-   *                    The caller must specify
-  inline
-                            const FileIDType* id_array,
-                            const FileIDType* tag_data,
-                            MBEntityType entity_type = MBMAXTYPE,
-                            MBEntityType value_type = MBMAXTYPE,
-  /**\brief Create a block of entity sets
-   * Create count entity sets with consecutive file IDs, beginning
-   * with the specified start_id.
-   *\param start_id   File ID for first entity set
-   *\param options    Set creation flags for each entity set.
-  inline
-  MBErrorCode create_meshsets( FileIDType start_id,
-                               MBEntityId count,
-                               const unsigned* options,
-  inline
-                               FileIDType count,
-                               unsigned options,
-  /**\brief Specify set contents for a block of entity sets
-   *\param start_id  File id of first entity set
-   *\param concatenated_content_lists The concatenation of the list of set
-   *                 contents.
-   *\param end_indices For each entity set, the index of the last entry
-   *                 for that set in concatenated_content_lists
-   *\param type      The type of the entities in concatenated_content_list.
-   *                 The caller must specify this value if it cannot be
-   *                 inferred from the file IDs (see constructor args.)
-  inline
-  MBErrorCode add_meshset_contents( FileIDType start_id,
-                                    FileIDType count,
-                                    const FileIDType* concatenated_content_lists,
-                                    const FileIDType* end_indices ,
-   * Specify contents for a block of entity sets, where the set
-   * contents are specified as ranges of file IDs.
-   *\param concatenated_range_list The concatenation of the list of set
-   *                 contents.  The contents for each set are specified
-   *                 as pairs of file IDS, where each pair corresponds
-   *                 to the first and last file ID of a range of entities.
-   *                 To specify a single entity, both values in the range
-   *                 pair should be the same.
-   *                 for that set in concatenated_range_list
-   *\param type      The type of the entities in concatenated_range_list.
-  inline
-  MBErrorCode add_meshset_range_contents( FileIDType start_id,
-                                          FileIDType count,
-                                          const FileIDType* concatenated_range_list,
-                                          const FileIDType* end_indices,
-  /**\brief Specify set children for a block of entity sets
-   *\param start_parent_id  File id of first entity set
-   *\param parent_count     Number of entity sets
-   *\param concatenated_children_lists The concatenation of the list of set
-   *                        children.
-   *                        for that set in concatenated_children_lists
-   *\param bidirectional    If true, also create link from child up to parent.
-   *                        If false, links are single-directional.
-  inline
-  MBErrorcode add_meshset_children( FileIDType start_parent_id,
-                                    FileIDType parent_count,
-                                    const FileIDType* concatenated_children_lists,
-                                    const FileIDType* null_id,
-                                    bool bidirectional = true );
-  /**\brief Specify set parents for a block of entity sets
-   *\param start_child_id  File id of first entity set
-   *\param child_count     Number of entity sets
-   *\param concatenated_parents_lists The concatenation of the list of set
-   *                       parents.
-   *                       for that set in concatenated_parents_lists
-  inline
-  MBErrorcode add_meshset_parents(  FileIDType start_child_id,
-                                    FileIDType child_count,
-                                    const FileIDType* concatenated_parents_lists,
-                                    const FileIDType* null_id );
-  /**\brief Get number of entities of each type */
-  inline void get_entity_counts( FileIDType counts[MBMAXTYPE] ) const;
-  /**\brief Convert from file IDs to MBEntityHandles
-   * Convert from file IDs to MBEntityHandles
-   *\param type    The type of the entities, or MBMAXTYPE if
-   *               the entity type can be inferred from the file ID.
-   *               The type can be inferred if all arguments to the
-   *               constructor that control the file ID space mapping
-   *               are false.  I.e. there is to potential ID conflict.
-   *\param ids     The input array of IDs for which to get the
-   *               corresponding MBEntityHandles.
-   *\param handles The array in which to store the result MBEntityHandles
-   *\param count   The length of ids (and handles).
-   *\param null_id If this argument is not NULL, then the value it points
-   *               to will be assumed to be a 'NULL' file ID value, such
-   *               that any input FileIDType with this value will be
-   *               assigned a zero (NULL) MBEntityHandle.
-   *\return        true if success, false if failure.
-  inline bool ids_to_handles( MBEntityType type,
-                              const FileIdType* ids,
-                              MBEntityHandle* handles,
-                              FileIDType count,
-private:
-  HandleRangeMap<FileIDType> typeMap[MBMAXTYPE+1];
-  const bool vertexUniqueIds, elemTypeUniqueIds, setUniqueIds;
-  std::vector<MBEntityHandle> handleArray;
-template <typename FileIDType> inline
-bool MBFileReadTool<FileIdType>::ids_to_handles( MBEntityType type,
-                                                 FileIDType count,
-  bool ok = true;
-  const HandleRangeMap& map = typeMap[type];
-  for (FileIDType i = 0; i < count; ++i) {
-    handles[i] = map.find( ids[i] );
-    if (!handles[i] && (!null_id || *null_id != ids[i]))
-      ok = false;
-  return ok;
-MBFileReadTool<FileIdType>::MBFileReadTool( MBInterface* moab_iface,
-  : MBReaderUtilBase( moab_interface ),
-    vertexUniqueIds( vertex_unique_ids ),
-    elemTypeUniqueIds( element_type_unique_ids ),
-    setUniqueIds( set_unique_ids )
-MBErrorCode MBFileReadTool<FileIdType>::create_nodes( FileIDType start_id,
-                                                      FileIDType count,
-                                                      double *& x,
-                                                      double *& y,
-                                                      double *& z,
-  MBEntityHandle handle,
-  MBErrorCode rval = get_node_arrays( start+id, count, handle, x, y, z, proc_id );
-    return rval;
-  typeMap[MBVERTEX].insert( handle, count, start_id );
-  if (!vertexUniqueIds)
-    typeMap[MBMAXTYPE].insert( handle, count, start_id );
-MBErrorCode MBFileReadTool<FileIdType>::create_elements( FileIDType start_id,
-                                                         FileIDType count,
-                                                         FileIDType len,
-                                                         const FileIDType* conn_ids,
-                                                         const FileIDType* poly,
-  if (type == MBPOLYGON || type == MBPOLYHEDRON)
-    if (!poly || poly[count-1] != len)
-  int* index_array;
-  MBErrorCode rval;
-  MBEntityHandle handle, *conn;
-  rval = get_element_array( start_id, count, type, len, handle, conn, &index_array, proc_id );
-    return rval;
-  typeMap[type].insert( handle, count, start_id );
-  if (!elemTypeUniqueIds)
-  bool valid;
-  if (type != MBPOLYHEDRON)
-    valid = convert_ids_to_handles( MBVERTEX, conn_ids, conn, count );
-  else if (elemTypeUniqueIDs)
-    valid = convert_ids_to_handles( MBPOLYGON, conn_ids, conn, count );
-  else
-    valid = convert_ids_to_handles( MBMAXTYPE, conn_ids, conn, count );
-      index_array[i] = poly[i];
-  return valid ? MB_SUCCESS : MB_FAILURE;;
-MBErrorCode MBFileReadTool<FileIdType>::add_adjacencies( FileIDType from_id,
-                                              MBEntityType from_type,
-                                              MBEntityType to_type )
-  MBEntityHandle from_handle;
-  if (!convert_ids_to_handles( from_type, &from_id, &from_handle, 1 ))
-  handleArray.resize( to_count );
-  if (!convert_ids_to_handles( to_type, to_ids, &handleArray[0], to_count ))
-  return moab()->add_adjacencies( from_handle, &handleArray[0], to_count, false );
-MBErrorCode MBFileReadTool<FileIdType>::create_entity_handle_tag(
-                                        const char* name,
-                                        const FileIDType* mesh_value,
-                                        const FileIDType* default_value,
-  handleArray.resize( 2*num_handles );
-  MBEntityHandle *mesh_handles = 0, *default_handles = 0;
-  if (mesh_values) {
-    mesh_handles = &handleArray[0];
-    if (!ids_to_handles( MBMAXTYPE, mesh_value, mesh_handles, num_handles, null_id ))
-  if (default_value) {
-    default_handles = &handleArray[num_handles];
-    if (!ids_to_handles( MBMAXTYPE, default_value, default_handles, num_handles, null_id ))
-  MBErrorCode rval =  moab()->tag_create( name,
-                             num_handles * sizeof(MBEntityHandle),
-                             storage_type,
-                             MB_TYPE_HANDLE,
-                             handle_out,
-                             default_handles,
-                             true );
-    return rval;
-  return tag_set_data( handle_out, 0, 0, mesh_handles );
-MBErrorCode MBFileReadTool<FileIdType>::set_tag_data( MBTag handle,
-                                                    MBEntityType val_type )
-  MBErrorCode rval, result = MB_SUCCESS;
-  std::vector<MBEntityHandle> ranges, hdata;
-  if (!typeMap[type].find( start_id, id_count, ranges ))
-  MBDataType tag_type;
-  rval = moab()->tag_get_data_type( handle, tag_type );
-    return rval;
-  int tag_size;
-  rval = moab()->tag_get_size( handle, tag_size );
-    return rval;
-  if (MB_TYPE_HANDLE == tag_type)
-  const char* data = static_cast<const char*>(tag_data);
-  for (MBEntityID i = 0; i < ranges.size(); i += 2) {
-    MBEntityHandle start_handle = ranges[i];
-    MBEntityID count = ranges[i+1];
-    rval = set_tag_data( handle, start_handle, count, data );
-      result = rval;
-    data += (count + tag+size);
-  return result;
-                                                    MBEntityType val_type,
-  MBErrorCode rval;
-    return rval;
-  if (tag_type != MB_TYPE_HANDLE)
-  int tag_size;
-    return rval;
-  tag_size /= sizeof(MBEntityHandle);
-  handleArray.resize( id_count * (tag_size + 1) );
-  if (!ids_to_handles( val_type,
-                       tag_data,
-                       &handlesArray[id_count],
-                       null_id ))
-  tag_data = &handlesArray[id_count];
-  if (!ids_to_handles( type, id_array, &handlesArray[0], id_count ))
-  return moab()->tag_set_data( handle, &handlesArray[0], id_count, tag_data );
-MBErrorCode MBFileReadTool<FileIdType>::create_meshsets( FileIDType start_id,
-                               MBEntityId count,
-  MBEntityHandle h;
-  MBErrorCode rval;
-  rval = craete_meshset_block( start_id, count, h, options, proc_id );
-    return rval;
-  typeMap[MBENTITYSET].insert( h, count, start_id );
-  if (!setUniqueIDs)
-    typeMap[MBMAXTYPE].insert( h, count, start_id );
-  return MB_SUCCESS;
-                               FileIDType count,
-                               unsigned options,
-  MBEntityHandle h;
-  MBErrorCode rval;
-    return rval;
-MBErrorCode MBFileReadTool<FileIdType>::add_meshset_contents(
-                                    FileIDType count,
-                                    const FileIDType* list,
-                                    MBEntityType type )
-  MBEntityHandle handle;
-  FileIDType id, prev = 0, n;
-  MBErrorCode result = MB_SUCCESS;
-  for (FileIDType i = 0; i < count; prev = end_indices[i++]) {
-    id = start_id + i;
-    if (!ids_to_handles( MBENTITYSET, &id, &handle, 1 )) {
-      result = MB_FAILURE;
-      continue;
-    n = end_indices[i] - prev;
-    handleArray.resize( n );
-    if (!ids_to_handles( type, list+prev, &handleArray[0], n))
-    else if (MB_SUCCESS != moab()->add_entities( handle, &handleArray[0], n ))
-  return result;
-MBErrorCode MBFileReadTool<FileIdType>::add_meshset_range_contents(
-                                          FileIDType count,
-  MBRange range;
-  MBRange::iterator h;
-      prev = end_indices[i];
-      continue;
-    range.clear();
-    h = range.begin();
-    for ( ; prev < end_indices[i]; prev += 2)
-      typeMap[type].find( list[i], list[i+i], range, h );
-    if (range.size() != count)
-    rval = moab()->add_entities( handle, range );
-      result = rval;
-  return result;
-MBErrorCode MBFileReadTool<FileIdType>::add_meshset_children(
-                                    FileIDType count,
-                                    const FileIDType* counts,
-                                    bool bidirectional )
-      continue;
-    if (!ids_to_handles( MBENTITYSET, list+prev, &handleArray[0], n))
-    else {
-      if (bidirectional) {
-        for (FileIDType i = 0; i < n; ++i)
-          if (MB_SUCCESS != moab()->add_parent_child( handle, handleArray[i] ))
-      else if (MB_SUCCESS != moab()->add_child_meshsets( handle, &handleArray[0], n ))
-  return result;
-MBErrorCode MBFileReadTool<FileIdType>::add_meshset_parents(
-                                    FileIDType count,
-                                    const FileIDType* counts )
-      continue;
-    else if (MB_SUCCESS != moab()->add_parent_meshsets( handle, &handleArray[0], n ))
-  return result;
-void MBFileReadTool<FileIdType>::get_entity_counts( FileIDType counts[MBMAXTYPE] ) const
-  for (MBEntityType t = MBVERTEX; t < MBMAXTYPE; ++i)
-    counts[t] = typeMap[t].size();
Modified: MOAB/trunk/MBMeshSet.cpp
--- MOAB/trunk/MBMeshSet.cpp	2007-09-25 16:45:54 UTC (rev 1285)
+++ MOAB/trunk/MBMeshSet.cpp	2007-09-25 16:56:03 UTC (rev 1286)
@@ -274,11 +274,6 @@
       mAdjFact->remove_adjacency(*iter, mEntityHandle);
-#ifdef MOAB_WITH_REFCOUNT
-  for (MBRange::iterator i = mRange.begin(); i != mRange.end(); ++i)
-    mAdjFact->decrement_reference_count( *i );
-#endif
   mRange.clear();
   return MB_SUCCESS;
@@ -291,17 +286,7 @@
   int i;
   for(i = 0; i < num_entities; i++)
     mRange.insert(entities[i]);
-#else
-    MBRange::iterator j = MBRange::lower_bound( mRange.begin(), mRange.end(), entities[i] );
-    if (j == mRange.end() || *j != entities[i]) {
-      mRange.insert( entities[i] );
-      mAdjFact->increment_reference_count( entities[i] );
-#endif
   if(tracking() && mAdjFact)
@@ -316,27 +301,8 @@
                                              MBEntityHandle mEntityHandle,
                                              AEntityFactory* mAdjFact )
-  if (entities.size() > mRange.size()) {
-    MBRange::const_iterator i;
-    for (i = mRange.begin(); i != mRange.end(); ++i)
-      mAdjFact->decrement_reference_count( * i );
-    mRange.merge( entities );
-      mAdjFact->increment_reference_count( * i );
-  else {
-    // do this in this way because we expect duplicate to be empty
-    MBRange duplicate = mRange.intersect( entities );
-    for (MBRange::const_iterator i = entities.begin(); i != entities.end(); ++i)
-      if (duplicate.find(*i) == duplicate.end())
-        mAdjFact->increment_reference_count( *i );
-     mRange.merge(entities);
-#else
-#endif
@@ -359,9 +325,6 @@
     if(found != mRange.end())
       mRange.erase(found);
-      mAdjFact->decrement_reference_count( *iter );
-#endif
@@ -382,9 +345,6 @@
-      mAdjFact->decrement_reference_count( entities[i] );
-#endif
         mAdjFact->remove_adjacency(entities[i], mEntityHandle);
@@ -408,12 +368,6 @@
-#endif
   MBRange other_range;
   meshset_2->get_entities(other_range);
@@ -430,11 +384,6 @@
     mRange.insert(*iter);
-#endif
   //track owner
@@ -468,10 +417,6 @@
 MBErrorCode MBMeshSet_Vector::clear( MBEntityHandle mEntityHandle,
                                      AEntityFactory* mAdjFact)
-  mAdjFact->decrement_reference_count( &mVector[0], mVector.size() );
-#endif
     for(std::vector<MBEntityHandle>::iterator iter = mVector.begin();
@@ -508,10 +453,6 @@
   mVector.resize(prev_size + num_entities);
   std::copy(entities, entities+num_entities, &mVector[prev_size]);
-  mAdjFact->increment_reference_count( entities, num_entities );
-#endif
     for(int i = 0; i < num_entities; i++)
@@ -530,11 +471,6 @@
   unsigned int prev_size = mVector.size();
   mVector.resize(prev_size + entities.size());
   std::copy(entities.begin(), entities.end(), &mVector[prev_size]);
-#endif
@@ -556,9 +492,6 @@
     if(entities.find(*iter) != entities.end())
-#endif
       iter = mVector.erase(iter);
@@ -582,9 +515,6 @@
     temp_iter = std::find( mVector.begin(), mVector.end(), entities[i]);
     if( temp_iter != mVector.end() )
-      mAdjFact->decrement_reference_count( *temp_iter );
-#endif
       mVector.erase(temp_iter);
@@ -607,10 +537,6 @@
-#endif
@@ -637,10 +563,6 @@
-  mAdjFact->increment_reference_count( &mVector[0], mVector.size() );
-#endif
   return MB_SUCCESS;
@@ -659,60 +581,3 @@
        + mVector.capacity()*sizeof(MBEntityHandle);
-void MBMeshSet::increment_all_referenced_entities( AEntityFactory* f )
-  int count;
-  const MBEntityHandle* array;
-  array = get_children(count);
-  f->increment_reference_count( array, count );
-  array = get_parents(count);
-  if (vector_based())
-    reinterpret_cast<MBMeshSet_Vector* >(this)->increment_all_referenced_entities( f );
-  else
-    reinterpret_cast<MBMeshSet_MBRange*>(this)->increment_all_referenced_entities( f );
-void MBMeshSet::decrement_all_referenced_entities( AEntityFactory* f )
-  int count;
-  f->decrement_reference_count( array, count );
-    reinterpret_cast<MBMeshSet_Vector* >(this)->decrement_all_referenced_entities( f );
-  else
-    reinterpret_cast<MBMeshSet_MBRange*>(this)->decrement_all_referenced_entities( f );
-void MBMeshSet_Vector::increment_all_referenced_entities( AEntityFactory* f )
-  f->increment_reference_count( &mVector[0], mVector.size() );
-void MBMeshSet_Vector::decrement_all_referenced_entities( AEntityFactory* f )
-  f->decrement_reference_count( &mVector[0], mVector.size() );
-void MBMeshSet_MBRange::increment_all_referenced_entities( AEntityFactory* f )
-  for (MBRange::const_iterator i = mRange.begin(); i != mRange.end(); ++i)
-    f->increment_reference_count( *i );
-void MBMeshSet_MBRange::decrement_all_referenced_entities( AEntityFactory* f )
-    f->decrement_reference_count( *i );
-#endif
Modified: MOAB/trunk/MBMeshSet.hpp
--- MOAB/trunk/MBMeshSet.hpp	2007-09-25 16:45:54 UTC (rev 1285)
+++ MOAB/trunk/MBMeshSet.hpp	2007-09-25 16:56:03 UTC (rev 1286)
@@ -208,11 +208,6 @@
   inline unsigned long get_memory_use() const;
-  void increment_all_referenced_entities( AEntityFactory* f );
-  void decrement_all_referenced_entities( AEntityFactory* f );
-#endif
 protected:
   unsigned long parent_child_memory_use() const;
@@ -313,7 +308,7 @@
   inline unsigned int num_entities_by_dimension(int dimesion) const; \
-  unsigned long get_memory_use() const;
+  unsigned long get_memory_use() const;
@@ -328,11 +323,6 @@
   MESH_SET_VIRTUAL_FUNCTIONS
-  void decrement_all_referenced_entities( AEntityFactory* f);
-  void increment_all_referenced_entities( AEntityFactory* f);
-#endif
 private:
   MBRange mRange;
@@ -349,11 +339,6 @@
-#endif
 private:
   static void vector_to_range( std::vector<MBEntityHandle>& vect, MBRange& range );
Modified: MOAB/trunk/MBReadUtil.cpp
--- MOAB/trunk/MBReadUtil.cpp	2007-09-25 16:45:54 UTC (rev 1285)
+++ MOAB/trunk/MBReadUtil.cpp	2007-09-25 16:56:03 UTC (rev 1286)
@@ -36,20 +36,6 @@
 unsigned  MBReadUtil::parallel_rank() const
   { return mMB->proc_config().rank(); }
-  /** Update reference counts for connectivity links.  Does nothing if
-   *  not compiled with reference counting enabled.
-MBErrorCode MBReadUtil::increment_reference_count(
-                               const MBEntityHandle* ent_array,
-                               size_t num_ent )
-  return mMB->increment_reference_count( ent_array, num_ent );
-#else
-#endif
 MBErrorCode MBReadUtil::get_node_arrays(
     const int /*num_arrays*/,
Modified: MOAB/trunk/MBReadUtil.hpp
--- MOAB/trunk/MBReadUtil.hpp	2007-09-25 16:45:54 UTC (rev 1285)
+++ MOAB/trunk/MBReadUtil.hpp	2007-09-25 16:56:03 UTC (rev 1286)
@@ -88,12 +88,6 @@
       int*& last_index_array,
       MBEntityHandle*& connectivity_array
-  virtual MBErrorCode increment_reference_count( const MBEntityHandle* ent_array,
-                                                 size_t num_ent );
   MBErrorCode create_entity_sets(
     MBEntityID num_sets,
Modified: MOAB/trunk/MBReadUtilIface.hpp
--- MOAB/trunk/MBReadUtilIface.hpp	2007-09-25 16:45:54 UTC (rev 1285)
+++ MOAB/trunk/MBReadUtilIface.hpp	2007-09-25 16:56:03 UTC (rev 1286)
@@ -109,12 +109,6 @@
    ) = 0;
-                                                 size_t num_ent ) = 0;
   virtual MBErrorCode create_entity_sets(
     const unsigned* set_flags,
Modified: MOAB/trunk/MBTest.cpp
--- MOAB/trunk/MBTest.cpp	2007-09-25 16:45:54 UTC (rev 1285)
+++ MOAB/trunk/MBTest.cpp	2007-09-25 16:56:03 UTC (rev 1286)
@@ -1333,13 +1333,6 @@
       return rval;
-  MBCore* core = dynamic_cast<MBCore*>(MB);
-  for (int i = 0; i < num_sets; ++i)
-    if (core->get_reference_count(sets[i]) != 1)
-      return MB_FAILURE;
-#endif
     // test adding child meshsets
@@ -1369,7 +1362,7 @@
   if (!compare_lists( list, sets+1, 2 ))
     return MB_FAILURE;
     // try adding child again
-  rval = MB->add_child_meshset( sets[0], sets[2] );
+  rval = MB->add_child_meshset( sets[0], sets[1] );
   if (MB_SUCCESS != rval) return rval;
   list.clear();
   rval = MB->get_child_meshsets( sets[0], list );
@@ -1386,7 +1379,7 @@
   if (!compare_lists( list, sets+1, 3 ))
     return MB_FAILURE;
-  rval = MB->add_child_meshset( sets[0], sets[3] );
   list.clear();
@@ -1402,14 +1395,6 @@
   if (!compare_lists( list, sets+1, 4 ))
     return MB_FAILURE;
-  for (int i = 1; i < 5; ++i)
-    if (core->get_reference_count(sets[i]) != 2)
-#endif
     // make sure range query returns same result
   std::sort( list.begin(), list.end() );
@@ -1458,12 +1443,6 @@
   if (!list.empty())
     return MB_FAILURE;
-#endif
     // test adding parent meshsets
@@ -1493,7 +1472,7 @@
     return MB_FAILURE;
     // try adding parent again
-  rval = MB->add_parent_meshset( sets[0], sets[2] );
+  rval = MB->add_parent_meshset( sets[0], sets[1] );
   list.clear();
   rval = MB->get_parent_meshsets( sets[0], list );
@@ -1510,7 +1489,7 @@
     return MB_FAILURE;
-  rval = MB->add_parent_meshset( sets[0], sets[3] );
   list.clear();
@@ -1526,12 +1505,6 @@
     return MB_FAILURE;
-#endif
@@ -1579,12 +1552,6 @@
   if (!list.empty())
     return MB_FAILURE;
-#endif
     // setup tests of recursive child query
@@ -1615,13 +1582,6 @@
   rval = MB->add_child_meshset( sets[5], sets[7] );
-  unsigned expref1[num_sets] = { 1, 2, 2, 2, 3, 2, 3, 3, 1, 1 };
-    if (core->get_reference_count(sets[i]) != expref1[i])
-#endif
     // test query at depth of 1
   list.clear();
@@ -1702,13 +1662,7 @@
   for (int i = 0; i < 5; ++i)
     if (MB_SUCCESS != MB->num_child_meshsets(sets[i], &count) || count)
       return MB_FAILURE;
-#endif
     // setup tests of recursive parent query
     //          6       7
@@ -1737,12 +1691,6 @@
   rval = MB->add_parent_meshset( sets[5], sets[7] );
-#endif
   list.clear();
@@ -1823,25 +1771,13 @@
     if (MB_SUCCESS != MB->num_parent_meshsets(sets[i], &count) || count)
       return MB_FAILURE;
-#endif
     // test combined parent/child links
     // test creation
   rval = MB->add_parent_child( sets[9], sets[8] );
-  if (core->get_reference_count(sets[9]) != 2 ||
-      core->get_reference_count(sets[8]) != 2)
-#endif
   list.clear();
   rval = MB->get_child_meshsets( sets[9], list );
@@ -1854,7 +1790,6 @@
     return MB_FAILURE;
     // test deletion of parent/child
-#ifndef MOAB_WITH_REFCOUNT
   rval = MB->add_parent_child( sets[7], sets[9] );
   rval = MB->delete_entities( &sets[9], 1 );
@@ -1870,10 +1805,6 @@
     // clean up remaining sets
   return MB->delete_entities( sets, 9 );
-#else
-    // clean up remaining sets
-  return MB->delete_entities( sets, 10 );
-#endif
 MBErrorCode mb_mesh_sets_set_test( MBInterface* mb )
@@ -1996,19 +1927,6 @@
   if( hexes.size() + tets.size() != dim_3_range.size() )
     return MB_FAILURE;
-  if (core->get_reference_count( ms1 ) != 1)
-  if (core->get_reference_count( ms2 ) != 1)
-  if (core->get_reference_count( ms3 ) != 1)
-  std::vector<unsigned> hex_refs;
-  for (MBRange::iterator i = hexes.begin(); i != hexes.end(); ++i)
-    hex_refs.push_back( core->get_reference_count(*i) );
-#endif
     //put all hexes in ms1, ms2, ms3
   result = MB->add_entities(ms1, hexes); //add ents in a range
   if(result != MB_SUCCESS )
@@ -2024,19 +1942,6 @@
     return result;
-  std::vector<unsigned>::iterator j = hex_refs.begin();
-  for (MBRange::iterator i = hexes.begin(); i != hexes.end(); ++i, ++j)
-    if (core->get_reference_count(*i) != 3+*j)
-#endif
     //put all tets in ms1, ms2
   if(MB->add_entities(ms1, &tets[0], tets.size()) != MB_SUCCESS )  //add ents in a vector
     return MB_FAILURE;                             //to ordered meshset
@@ -2164,21 +2069,15 @@
   MB->get_number_entities_by_handle(ms2, num_before);
   vec_iter = tets.begin();
   result = MB->delete_entities( &(*vec_iter), 1);
-  if (result == MB_SUCCESS)
-#else
     return result;
-#endif
   int num_after = 0;
   MB->get_number_entities_by_handle(ms2, num_after);
   if( num_before != num_after + 1)
     return MB_FAILURE;
-#endif
   return MB_SUCCESS;
@@ -3088,7 +2987,6 @@
   entities.clear();
   MB->get_entities_by_type(0, MBVERTEX, entities);
   unsigned int original_num_nodes = entities.size();
   entities.clear();
   MB->get_entities_by_type(0, MBHEX, entities);
@@ -3107,7 +3005,6 @@
   entities.clear();
     // make sure the higher order nodes really were deleted
   if(entities.size() != original_num_nodes)
     return MB_FAILURE;
@@ -3224,38 +3121,17 @@
-  MBEntityHandle file_set;
   file_name = TestDir + "/mbtest1.g";
-  error = MB->load_file(file_name.c_str(), file_set);
+  error = MB->load_mesh(file_name.c_str(), NULL, 0);
   if (error != MB_SUCCESS)
     return error;
-  error = MB->delete_entities( &file_set, 1 );
-  if (MB_SUCCESS != error)
-    return error;
     // delete all MBTRI's
-  MBRange tri_sets;
-  MBTag matset_tag;
-  if (MB_SUCCESS == MB->tag_get_handle( MATERIAL_SET_TAG_NAME, matset_tag )) {
-    error = MB->get_entities_by_type_and_tag( 0, MBENTITYSET, &matset_tag, 0, 1, tri_sets, MBInterface::UNION );
-      return error;
-//MBRange users2;
-//error = dynamic_cast<MBCore*>(MB)->find_all_referencing_entities( tri_sets.front(), users2 );
-//assert(MB_SUCCESS == error);
-//users2.print();
-    error = MB->delete_entities( tri_sets );
-      return error;
   entities.clear();
   error = MB->get_entities_by_type(0, MBTRI, entities);
     return error;
-//MBRange users;
-//error = dynamic_cast<MBCore*>(MB)->find_all_referencing_entities( entities.front(), users );
-//users.print();
   error = MB->delete_entities(entities);
     return error;
Modified: MOAB/trunk/Makefile.am
--- MOAB/trunk/Makefile.am	2007-09-25 16:45:54 UTC (rev 1285)
+++ MOAB/trunk/Makefile.am	2007-09-25 16:56:03 UTC (rev 1286)
@@ -29,8 +29,7 @@
 check_PROGRAMS = $(TESTS) \
 		 kd_tree_tool \
-		 kd_tree_time \
-		 range_map_test
+		 kd_tree_time
 #noinst_PROGRAMS = scdseq_timing
@@ -120,8 +119,6 @@
   MBMatrix3.hpp \
   MBCore.cpp \
   MBFactory.cpp \
-  MBFileReadTool.hpp \
   MBGeomUtil.cpp \
   MBInternals.hpp \
   MBMem.hpp \
@@ -146,7 +143,6 @@
   MeshTopoUtil.cpp \
   PolyEntitySequence.cpp \
   PolyEntitySequence.hpp \
-  RangeMap.hpp \
   ReadGmsh.cpp \
   ReadGmsh.hpp \
   ReadParallel.hpp \
@@ -305,8 +301,6 @@
 file_options_test_SOURCES = FileOptions.cpp
 file_options_test_CPPFLAGS = -DTEST
-range_map_test_sources = RangeMapTest.cpp RangeMap.hpp
 # Other files to clean up (e.g. output from tests)
 MOSTLYCLEANFILES = dumped_acis.sat
Modified: MOAB/trunk/MeshSetSequence.cpp
--- MOAB/trunk/MeshSetSequence.cpp	2007-09-25 16:45:54 UTC (rev 1285)
+++ MOAB/trunk/MeshSetSequence.cpp	2007-09-25 16:56:03 UTC (rev 1286)
@@ -49,13 +49,7 @@
     // allocate storage
   mSets = new unsigned char[SET_SIZE * num_entities];
-  mRefCount.clear();
-  mRefCount.resize( num_entities, flags ? 1 : 0 );
-#else
   mFreeEntities.clear();
-#endif
   if (flags) {
     mNumEntities = num_entities;
     mFirstFreeIndex = -1;
@@ -66,9 +60,7 @@
     man->notify_not_full( this );
     mNumEntities = 0;
     mFirstFreeIndex = 0;
     mFreeEntities.resize( mNumAllocated, true );
-#endif
     for (MBEntityID i = 0; i < num_entities; ++i)
       next_free(i) = i + 1;
     next_free(num_entities-1) = -1;
@@ -97,11 +89,7 @@
     return 0;
   const MBEntityID index = mFirstFreeIndex;
   mFreeEntities[index] = false;
-#else
-  mRefCount[index] = 1;
-#endif
   mFirstFreeIndex = next_free(index);
   if (mLastDeletedIndex == index)
     mLastDeletedIndex = -1;
@@ -110,10 +98,8 @@
   mNumEntities++;
   if (mNumEntities == mNumAllocated) {
     mSequenceManager->notify_full(this);
     std::vector<bool> empty;
     mFreeEntities.swap( empty);
-#endif
   return get_start_handle() + index;
@@ -124,12 +110,6 @@
   if (!is_valid_entity(handle))
     return;
   const MBEntityID index = handle - get_start_handle();
-  if (get_reference_count(handle) != 1)
-    return;
-  decrement_reference_count(handle);
-#endif
     // free any memory allocated by the MBMeshSet
   deallocate_set( index );
@@ -137,17 +117,12 @@
     // decerement count of valid entities
   if(mNumEntities == mNumAllocated) {
     mSequenceManager->notify_not_full(this);
     mFreeEntities.resize( mNumAllocated, false );
-#endif
   --mNumEntities;
     // mark this entity as invalid
   mFreeEntities[index] = true;
-#endif
     // Add this entity to the free list.
     // Free list is maintained in sorted order.
@@ -197,12 +172,7 @@
                                       unsigned long& allocated ) const
   used = 0;
-  allocated = sizeof(*this);
-  allocated += mRefCount.capacity() * sizeof(unsigned);
-#else
-  allocated += mFreeEntities.capacity()/8;
-#endif
+  allocated = sizeof(*this) + mFreeEntities.capacity()/8;
   allocated += mNumAllocated * SET_SIZE;
   for (MBEntityHandle h = get_start_handle(); h <= get_end_handle(); ++h) {
     if (is_valid_entity(h)) {
@@ -531,16 +501,3 @@
   number = children.size();
   return result;
-void MeshSetSequence::decrement_all_referenced_entities( MBEntityHandle handle, AEntityFactory* f)
-  if (is_valid_entity(handle))
-    get_set( handle )->decrement_all_referenced_entities( f );
-void MeshSetSequence::increment_all_referenced_entities( MBEntityHandle handle, AEntityFactory* f)
-    get_set( handle )->increment_all_referenced_entities( f );
-#endif
Modified: MOAB/trunk/MeshSetSequence.hpp
--- MOAB/trunk/MeshSetSequence.hpp	2007-09-25 16:45:54 UTC (rev 1285)
+++ MOAB/trunk/MeshSetSequence.hpp	2007-09-25 16:56:03 UTC (rev 1286)
@@ -64,10 +64,6 @@
   MBErrorCode num_parents ( MBEntityHandle of, int& number, int num_hops ) const;
   MBErrorCode num_children( MBEntityHandle of, int& number, int num_hops ) const;
-  virtual void decrement_all_referenced_entities( MBEntityHandle , AEntityFactory* );
-  virtual void increment_all_referenced_entities( MBEntityHandle , AEntityFactory* );
-#endif
 private:
   void initialize( EntitySequenceManager* seq_man,
Modified: MOAB/trunk/PolyEntitySequence.cpp
--- MOAB/trunk/PolyEntitySequence.cpp	2007-09-25 16:45:54 UTC (rev 1285)
+++ MOAB/trunk/PolyEntitySequence.cpp	2007-09-25 16:56:03 UTC (rev 1286)
@@ -140,17 +140,11 @@
   mNumEntities++;
     mFreeEntities.swap( empty );
-#endif
   mFreeEntities[handle - get_start_handle()] = false;
-#else
-  mRefCount[handle - get_start_handle()] = 1;
-#endif
     // put the connectivity on the end of that array
   polyConn.insert(polyConn.end(), conn, conn+num_conn);
@@ -188,12 +182,6 @@
     // add this handle to the dead list, and zero out its connectivity
   MBEntityID index = entity - mStartEntityHandle;
   if (!is_valid_entity(entity)) return;
-  if (get_reference_count(entity) != 1) // only referenced by this sequence
-    return;
-  decrement_reference_count(entity);
-#endif
   int start_index;
   if (0 == index) start_index = 0;
@@ -203,11 +191,9 @@
     // now add it to the dead list
   mDeadEntities.push_back(entity);
   if (mFreeEntities.empty())
-#endif
     // decrement number of entities
   mNumEntities--;
@@ -223,17 +209,11 @@
                                          unsigned long& allocated) const
+       + mFreeEntities.capacity() / 8
        + polyConn.capacity() * sizeof(MBEntityHandle)
        + mLastIndex.capacity() * sizeof(int)
        + mDeadEntities.capacity() * sizeof(MBEntityHandle)
-#else
-  allocated += mFreeEntities.capacity() / 8;
-#endif
   used = 0;
Deleted: MOAB/trunk/README.RefCount
--- MOAB/trunk/README.RefCount	2007-09-25 16:45:54 UTC (rev 1285)
+++ MOAB/trunk/README.RefCount	2007-09-25 16:56:03 UTC (rev 1286)
@@ -1,19 +0,0 @@
-This branch replaces the vector<bool> of valid/invalid flags in entity
-sequences with a vector<unsigned> of reference counts.  A value of zero
-for an entity signifies a hole in the sequence.  A valid entity has a
-reference count of at least 1, signifying that it is referenced by it's
-owning EntitySequence.
-This branch contains code to update reference counts for a) entities used in
-connectivity lists, b) entities contained in sets, c) sets referenced by
-parent/child links, d) downward adjacencies, and e) entities referenced in
-handle-type tag data.  Additionally, this branch contains enhancements to
-several existing algorithms that benefit from the reference count, including
-entity deletion, higher-order conversion, merging, etc.
-MBTest fails due to one or more bugs while deleting entity sets.  The high-level
-deletion code decrmenents reference counts for contained and parent/child
-entities.  However, as part of cleaning up adjacencies, updating bi-directional
-parent/child links, etc. the low-level deletion code clears the set contents,
-etc.  This results in the reference count to be decremented a *second* time.
Deleted: MOAB/trunk/RangeMap.hpp
--- MOAB/trunk/RangeMap.hpp	2007-09-25 16:45:54 UTC (rev 1285)
+++ MOAB/trunk/RangeMap.hpp	2007-09-25 16:56:03 UTC (rev 1286)
@@ -1,199 +0,0 @@
-/**\file RangeMap.hpp
- *\author Jason Kraftcheck (kraftche at cae.wisc.edu)
- *\date 2007-04-25
-#ifndef RANGE_MAP_HPP
-#define RANGE_MAP_HPP
-#include <vector>
-#include <algorithm>
-/**\brief Map ranges of values
- * This class provides a map between ranges of values, such as
- * a map between file IDs and MBEntityHandles.  It is intended
- * for use in situations where there are relatively few insertions
- * of large contiguous ranges of values.
-template <typename KeyType, typename ValType, ValType NullVal = 0>
-class RangeMap
-public:
-  struct Range {
-    KeyType begin, count;
-    ValType value;
-    bool operator<( const Range& other ) const
-      { return begin + count <= other.begin; } // equal if overlapping!
-  typedef typename std::vector<Range> RangeList;
-  typedef typename RangeList::const_iterator iterator;
-  /**\brief Insert mapping between range of keys and range of values
-   * Insert mapping from [first_key, first_key+count) to [first_val, first_val+count)
-   * Input range of keys many not overlap any other input range.  If it does overlap
-   * an existing range, false is returned and the internal map is not changed.
-  inline iterator insert( KeyType first_key, ValType first_val, KeyType count );
-  /** Find the value corresponding to the specified key.  Returns NullVal if not found */
-  inline ValType find( KeyType key ) const;
-  /** Remove a block of values */
-  inline iterator erase( KeyType beg, KeyType count );
-  inline unsigned num_ranges() const { return data.size(); }
-  inline iterator begin() const { return data.begin(); }
-  inline iterator end() const { return data.end(); }
-  inline iterator lower_bound( KeyType key ) const
-      Range b = { key, 1, NullVal };
-      return std::lower_bound( begin(), end(), b );
-  inline iterator upper_bound( KeyType key ) const
-      return std::upper_bound( begin(), end(), b );
-  inline std::pair<iterator,iterator>
-    equal_range( KeyType key ) const
-      return std::equal_range( begin(), end(), b );
-  inline void clear() { data.clear(); }
-protected:
-  RangeList data;
-template <typename KeyType, typename ValType, ValType NullVal>
-inline typename RangeMap<KeyType,ValType,NullVal>::iterator
-RangeMap<KeyType,ValType,NullVal>::insert( KeyType first_key, ValType first_val, KeyType count )
-  Range block = { first_key, count, first_val };
-  typename RangeList::iterator i = std::lower_bound( data.begin(), data.end(), block );
-  if (i == data.end()) {
-    if (i != data.begin()) {
-      --i;
-      if (i->begin + i->count == first_key &&
-          i->value + i->count == first_val) {
-        i->count += count;
-        return i;
-    data.push_back( block );
-    return data.end() - 1;
-  if (i->begin < first_key + count)
-    return data.end();
-  if (i->begin == first_key + count &&
-      i->value == first_val + count) {
-    i->begin = first_key;
-    i->value = first_val;
-      count = i->count;
-      --i;
-        ++i;
-        i = data.erase(i);
-        --i;
-    return i;
-    --i;
-      return i;
-    ++i;
-  return data.insert( i, block );
-template <typename KeyType, typename ValType, ValType NullVal> inline
-ValType RangeMap<KeyType,ValType,NullVal>::find( KeyType key ) const
-  Range search = { key, 1, NullVal };
-  typename RangeList::const_iterator i = std::lower_bound( data.begin(), data.end(), search );
-  if (i == data.end() || i->begin > key)
-    return NullVal;
-  return i->value + key - i->begin;
-RangeMap<KeyType,ValType,NullVal>::erase( KeyType key, KeyType count )
-  typename RangeList::iterator i, j;
-  i = std::lower_bound( data.begin(), data.end(), search );
-    return i;
-  if (key > i->begin) {
-    KeyType offset = key - i->begin;
-      // special case - split existing entry
-    if((offset + count) < i->count) {
-      Range ins = { i->begin, offset, i->value };
-      offset += count;
-      i->begin += offset;
-      i->value += offset;
-      i->count -= offset;
-      return data.insert( i, ins ) + 1;
-      // otherwise remove the latter part of i
-    i->count = offset;
-    ++i;
-    // remove any entries entirely convered by the input range
-  for (j = i; j != data.end() && (j->begin + j->count) <= (key + count); ++j);
-  i = data.erase(i,j);
-    // remove beginning of last block
-  if (i != data.end() && (key + count) >= i->begin) {
-    KeyType offset = key + count - i->begin;
-  return i;
-#endif
Deleted: MOAB/trunk/RangeMapTest.cpp
--- MOAB/trunk/RangeMapTest.cpp	2007-09-25 16:45:54 UTC (rev 1285)
+++ MOAB/trunk/RangeMapTest.cpp	2007-09-25 16:56:03 UTC (rev 1286)
@@ -1,143 +0,0 @@
-#include <iostream>
-#include <iomanip>
-#include <stdio.h>
-#include <stdlib.h>
-RangeMap<long,long,0> mapInstance;
-bool insert( std::vector<long>& values );
-bool verify( std::vector<long>& values );
-bool print( std::vector<long>& values );
-bool clear( std::vector<long>& values );
-bool help();
-bool do_command( char* cmd )
-  std::vector<long> values;
-  char *ptr, *end;
-  const char space[] = " \t\r\n";
-  char c = cmd[0];
-  ++cmd;
-  for (ptr = strtok( cmd, space ); ptr; ptr = strtok( 0, space )) {
-    long val = strtol( ptr, &end, 0 );
-    if (*end) {
-      std::cerr << "Invalid integer value: " << ptr << std::endl;
-      return false;
-    values.push_back( val );
-  switch (c) {
-    case 'i': return insert( values );
-    case 'v': return verify( values );
-    case 'p': return print( values );
-    case 'c': return clear( values );
-    case 'h': return help( );
-    default:
-      std::cerr << "Unknown command: " << c << std::endl;
-      return false;
-  if (values.size() % 3) {
-    std::cerr << "Invalid arguments for insertion.  "
-                 "Insertion requires tuples of three values:  "
-                 "{start_key,start_val,count}" << std::endl;
-    return false;
-  for (unsigned i = 0; i < values.size(); i += 3)
-    if (mapInstance.end() == mapInstance.insert( values[i], values[i+1], values[i+2] ))
-      std::cout << "Insertion of {" << values[i] << ", "
-                                    << values[i+1] << ", "
-                                    << values[i+2] << "} FAILED" << std::endl;
-  return true;
-  if (values.size() % 2) {
-    std::cerr << "(c)lear command expects ranges of values (or no values)" << std::endl;
-    return false;
-  if(values.empty()) {
-    mapInstance.clear();
-    return true;
-  for (unsigned i = 0; i < values.size(); i += 2)
-    mapInstance.erase( values[i], values[i+1] );
-  return true;
-  const int W = 20;
-  if (values.empty()) {
-    std::cout  << std::setw(W) << "Start Key"
-               << std::setw(W) << "Start Val"
-               << std::setw(W) << "Count"
-               << std::endl;
-    RangeMap<long,long,0>::iterator i = mapInstance.begin();
-    for (; i != mapInstance.end(); ++i)
-      std::cout << std::setw(W) << i->begin
-                << std::setw(W) << i->value
-                << std::setw(W) << i->count
-                << std::endl;
-  else {
-    for (unsigned i = 0; i < values.size(); ++i)
-      std::cout << std::setw(W) << values[i] << "->"
-                << std::setw(W) << mapInstance.find(values[i]) << std::endl;
-  return true;
-    return false;
-  bool result = true;
-  std::vector<long>::iterator j = values.begin();
-    if (j == values.end() ||
-        i->begin != *j++ ||
-        i->value != *j++ ||
-        i->count != *j++)
-      result = false;
-  return result && j == values.end();
-bool help()
-  std::cout << "Commands: i p c v h" << std::endl
-            << " i - insert list of values " << std::endl
-            << " p - print entire map or lookup specified values" << std::endl
-            << " c - clear map" << std::endl
-            << " v - verify map contents" << std::endl
-            << " h - this help" << std::endl;
-  return true;
-int main() {
-  char buffer[1024];
-  bool exit_val = 0;
-  while (fgets(buffer, sizeof(buffer), stdin))
-    exit_val += !do_command(buffer);
-  return exit_val;
Modified: MOAB/trunk/ReadGmsh.cpp
--- MOAB/trunk/ReadGmsh.cpp	2007-09-25 16:45:54 UTC (rev 1285)
+++ MOAB/trunk/ReadGmsh.cpp	2007-09-25 16:56:03 UTC (rev 1286)
@@ -399,8 +399,6 @@
     memcpy( conn_array, &connectivity[0], connectivity.size() * sizeof(MBEntityHandle) );
-  readMeshIface->increment_reference_count( conn_array, num_elem * node_per_elem );
     // Store element IDs
   result = mdbImpl->tag_set_data( globalId, elements, &elem_ids[0] );
Modified: MOAB/trunk/ReadHDF5.cpp
--- MOAB/trunk/ReadHDF5.cpp	2007-09-25 16:45:54 UTC (rev 1285)
+++ MOAB/trunk/ReadHDF5.cpp	2007-09-25 16:56:03 UTC (rev 1286)
@@ -429,9 +429,7 @@
     return MB_FAILURE;
-  rval = convert_id_to_handle( nodeSet, array, (size_t)nodes_per_elem*count );
-  if (MB_SUCCESS == rval)
-    readUtil->increment_reference_count( array, (size_t)nodes_per_elem*count );
+  rval = convert_id_to_handle( nodeSet, array, (size_t)(nodes_per_elem*count) );
   return rval;
@@ -523,10 +521,7 @@
     return MB_FAILURE;
-  rval = convert_id_to_handle( conn_array, (size_t)data_len );
-    readUtil->increment_reference_count( conn_array, (size_t)data_len );
-  return rval;
+  return convert_id_to_handle( conn_array, (size_t)data_len );
 template <typename T>
Modified: MOAB/trunk/ReadNCDF.cpp
--- MOAB/trunk/ReadNCDF.cpp	2007-09-25 16:45:54 UTC (rev 1285)
+++ MOAB/trunk/ReadNCDF.cpp	2007-09-25 16:56:03 UTC (rev 1286)
@@ -905,7 +905,6 @@
       nodesInLoadedBlocks[tmp_ptr[i]] = 1;
       conn[i] = static_cast<MBEntityHandle>(tmp_ptr[i]) + vertexOffset;
-    readMeshIface->increment_reference_count( conn, number_nodes );
     readMeshIface->update_adjacencies((*this_it).startMBId, (*this_it).numElements,
                                       ExoIIUtil::VerticesPerElement[(*this_it).elemType], conn);
Modified: MOAB/trunk/ReadSTL.cpp
--- MOAB/trunk/ReadSTL.cpp	2007-09-25 16:45:54 UTC (rev 1285)
+++ MOAB/trunk/ReadSTL.cpp	2007-09-25 16:56:03 UTC (rev 1286)
@@ -218,8 +218,6 @@
     *connectivity = vertex_map[i->points[2]]; ++connectivity;
-  readMeshIface->increment_reference_count( connectivity, 3*triangles.size() );
   return MB_SUCCESS;
Modified: MOAB/trunk/ReadVtk.cpp
--- MOAB/trunk/ReadVtk.cpp	2007-09-25 16:45:54 UTC (rev 1285)
+++ MOAB/trunk/ReadVtk.cpp	2007-09-25 16:56:03 UTC (rev 1286)
@@ -573,8 +573,6 @@
-  readMeshIface->increment_reference_count( conn_array, size[1] - size[0] );
   return MB_SUCCESS;
@@ -659,11 +657,11 @@
     MBEntityHandle* conn_array;
     int* index_array = 0;
-    long conn_len = 0;
     if (type == MBPOLYGON)
         // Calculate total length of connectivity list
       std::vector<long>::iterator conn_iter2 = conn_iter;
+      long conn_len = 0;
       for (i = 0; i < num_elem; ++i)
         conn_len += *conn_iter2;
@@ -676,7 +674,6 @@
     else
-      conn_len = num_elem * num_vtx;
       result = allocate_elements( num_elem, num_vtx, type, start_handle,
                                   conn_array, elem_list );
@@ -735,10 +732,8 @@
       conn_array += num_vtx;
-    readMeshIface->increment_reference_count( conn_array, conn_len );
   return MB_SUCCESS;
@@ -798,8 +793,6 @@
           *conn_array = index + corners[j] + first_vtx;
-  readMeshIface->increment_reference_count( conn_array, vert_per_elem * num_elems );
   return MB_SUCCESS;
Modified: MOAB/trunk/TagServer.cpp
--- MOAB/trunk/TagServer.cpp	2007-09-25 16:45:54 UTC (rev 1285)
+++ MOAB/trunk/TagServer.cpp	2007-09-25 16:56:03 UTC (rev 1286)
@@ -591,16 +591,6 @@
   return MB_SUCCESS;
-MBErrorCode TagServer::get_tags(MBDataType type, std::vector<MBTag> &all_tags)
-  for (int i = 0; i < MB_TAG_LAST+1; ++i)
-    for (MBTagId j = 0; j < mTagTable[i].size(); ++j)
-      if (mTagTable[i][j].is_valid() && mTagTable[i][j].get_data_type() == type)
-        all_tags.push_back( TAG_HANDLE_FROM_ID( j + 1, (MBTagType)i ) );
 MBErrorCode TagServer::get_tags(const MBEntityHandle entity, std::vector<MBTag> &all_tags)
Modified: MOAB/trunk/TagServer.hpp
--- MOAB/trunk/TagServer.hpp	2007-09-25 16:45:54 UTC (rev 1285)
+++ MOAB/trunk/TagServer.hpp	2007-09-25 16:56:03 UTC (rev 1286)
@@ -255,9 +255,6 @@
   //! get all the tags which have been defined
   MBErrorCode get_tags(std::vector<MBTag> &all_tags);
-  //! get all tags that store a specified data type
-  MBErrorCode get_tags( MBDataType type, std::vector<MBTag>& tags );
     //! get the default value for a given tag
   MBErrorCode get_default_data(const MBTag tag_handle, void *data);
Modified: MOAB/trunk/configure.in
--- MOAB/trunk/configure.in	2007-09-25 16:45:54 UTC (rev 1285)
+++ MOAB/trunk/configure.in	2007-09-25 16:56:03 UTC (rev 1286)
@@ -47,16 +47,7 @@
 fi
 AC_DEFINE_UNQUOTED(MB_VERSION_STRING,"${VERSION_STRING}",[MOAB Version String])
-#                              Debugging Features
-AC_MSG_CHECKING([if reference counting is enabled])
-AC_ARG_ENABLE([refcounts],
-              [AC_HELP_STRING([enable-refcounts],[Enable reference counting])],
-              [DEFINES="$DEFINES -DMOAB_WITH_REFCOUNT"; AC_MSG_RESULT([yes])],
-              [AC_MSG_RESULT([no])])
 #                              Extract libtool config
