[MOAB-dev] r1285 - MOAB/trunk
kraftche at mcs.anl.gov
Tue Sep 25 11:45:54 CDT 2007
Author: kraftche
Date: 2007-09-25 11:45:54 -0500 (Tue, 25 Sep 2007)
New Revision: 1285
Added:
MOAB/trunk/MBFileReadTool.cpp
MOAB/trunk/MBFileReadTool.hpp
MOAB/trunk/RangeMap.hpp
MOAB/trunk/RangeMapTest.cpp
Modified:
MOAB/trunk/Makefile.am
Log:
RangeMap and MBFileReadTool
Added: MOAB/trunk/MBFileReadTool.cpp
--- MOAB/trunk/MBFileReadTool.cpp (rev 0)
+++ MOAB/trunk/MBFileReadTool.cpp 2007-09-25 16:45:54 UTC (rev 1285)
@@ -0,0 +1,324 @@
+ * MOAB, a Mesh-Oriented datABase, is a software component for creating,
+ * storing and accessing finite element mesh data.
+ * Copyright 2004 Sandia Corporation. Under the terms of Contract
+ * DE-AC04-94AL85000 with Sandia Coroporation, the U.S. Government
+ * retains certain rights in this software.
+ * This library is free software; you can redistribute it and/or
+ * modify it under the terms of the GNU Lesser General Public
+ * License as published by the Free Software Foundation; either
+ * version 2.1 of the License, or (at your option) any later version.
+/**\file MBFileReadTool.cpp
+ *\author Jason Kraftcheck <kraftche at cae.wisc.edu>
+ *\date 2007-08-21
+#include "MBFileReadTool.hpp"
+MBFileReadToolBase( MBCore* moab )
+ : mMOAB( moab ), fileSet( 0 ),
+ parallelRank( moab->proc_config().rank() )
+void MBFileReadToolBase::report_error( std::string err )
+ mMOAB->get_error_handler()->set_last_error( err );
+void MBFileReadToolBase::report_error( const char* fmt, ... )
+ va_list args;
+ va_start(args, fmt);
+ mMOAB->get_error_handler()->set_last_error( fmt, args );
+ va_end( args );
+MBErrorCode MBFileReadToolBase::delete_all_entities()
+ MBErrorCode rval;
+ MBRange list;
+ if (fileSet == 0) // all entities already deleted
+ return MB_SUCCESS;
+ rval = moab()->get_entities_by_handle( fileSet, list );
+ if (MB_SUCCESS != rval)
+ return rval;
+ list.insert( fileSet );
+ rval = moab()->delete_entities( list );
+ return rval;
+ fileSet = 0;
+MBErrorCode MBFileReadToolBase::delete_non_tagged_entities(
+ const char* tagname,
+ const int* tag_values,
+ int num_tag_values )
+ MBErrorCode rval;
+ // no entities?
+ if (fileSet == 0) {
+ report_error( "No entities with tag \"%s\" in file.\n", tagname );
+ return MB_FAILURE;
+ // get tag
+ MBTag tag;
+ rval = moab()->tag_get_handle( tagname, tag );
+ if (MB_SUCCESS != rval) {
+ report_error( "Tag not found: \"%s\"\n", tagname );
+ return rval;
+ // check type of tag data
+ MBDataType type;
+ int size = 0;
+ moab()->tag_get_size( tag, size );
+ moab()->tag_get_type( tag, type );
+ if (size != sizeof(int) || (type != MB_TYPE_INTEGER && type != MB_TYPE_OPAQUE)) {
+ report_error( "Invalid type for tag \"%s\"\n", tagname );
+ return MB_TYPE_OUT_OF_RANGE;
+ // construct argument arrays
+ std::vector<MBTag> taghandles( num_tag_values ? num_tag_values : 1, tag );
+ std::vector<const void*> tagvals( num_tag_values );
+ for (int i = 0; i < num_tag_values; ++i)
+ tagvals[i] = tag_values + i;
+ // get entity sets with specified tag
+ MBRange sets;
+ rval = moab()->get_entities_by_type_and_tag( fileSet,
+ MBENTITYSET,
+ &taghandles[0],
+ num_tag_values ? &tagvals[0] : 0,
+ taghandles.size(),
+ sets,
+ MBInterface::UNION );
+ // get closure of entity sets
+ MBRange entities, temp;
+ MBRange::iterator iter;
+ // recursively descend all containd and child entity sets
+ std::set<MBEntityHandle> visited;
+ std::vector<MBEntityHandle> children;
+ while (!sets.empty()) {
+ MBEntityHandle entset = sets.pop_front();
+ if (!visited.insert(entset).first)
+ continue;
+ entities.insert( entset );
+ temp.clear();
+ moab()->get_entities_by_handle( entset, temp );
+ iter = temp.lower_bound( MBENTITYSET );
+ entities.merge( temp.begin(), iter );
+ std::copy( iter, temp.end(), mb_range_inserter( sets ) );
+ children.clear();
+ rval = moab()->get_child_meshsets( entset, children );
+ return rval;
+ std::copy( children.begin(), children.end(), mb_range_inserter( sets ) );
+ // get faces for all polyhedra
+ const MBEntityHandle* conn;
+ int len;
+ iter = entities.lower_bound( MBPOLYHEDRON );
+ for (; iter != entities.end() && TYPE_FROM_HANDLE(*iter) < MBENTITYSET; ++iter) {
+ rval = moab()->get_connectivity( *iter, conn, len );
+ return rval;
+ std::copy( conn, conn+len, mb_range_inserter( entities ) );
+ // get vertices for all elements
+ iter = entities.lower_bound( MBEDGE );
+ for (; iter != entities.end() && TYPE_FROM_HANDLE(*iter) < MBPOLYHEDRON; ++iter) {
+ return rval;
+ // We now have the list of entities to keep.
+ // Get the list of entities to remove.
+ MBRange all, dead;
+ moab()->get_entities_by_handle( fileSet, all );
+ dead = all.subtract( entities );
+ // Destroy the entities
+ rval = moab()->remove_entities( fileSet, dead );
+ return rval;
+ rval = moab()->delete_entities( dead );
+ return rval;
+MBErrorCode MBFileReadToolBase::create_sequence( MBEntityID start_id,
+ MBEntityID count,
+ MBEntityID type,
+ MBEntityID conn_len,
+ const int* proc_id,
+ MBEntitySequence*& seq )
+ MBErrorCode rval;
+ // if we haven't created a set for all file entities yet,
+ // do it now
+ if (!fileSet) {
+ rval = moab()->create_meshset( MESHSET_SET, fileSet );
+ fileSet =0;
+ return rval;
+ const int proc = proc_id ? *proc_id : parallel_rank();
+ MBEntitySequence* seq = 0;
+ rval = mMOAB->sequence_manager()->create_entity_sequence(
+ type,
+ count,
+ conn_len,
+ start_id,
+ proc,
+ start_handle,
+ seq );
+ return rval;
+ MBRange new_handles( seq->get_start_handle(), seq->get_end_handle() );
+ assert( new_handles.size() == count );
+ rval = moab()->add_entites( fileSet, new_handles );
+ delete seq;
+ return rval;
+MBErrorCode MBFileReadToolBase::get_node_arrays(
+ MBEntityID preferred_start_id,
+ MBEntityID count,
+ MBEntityHandle& start_handle,
+ double *& x, double *& y, double *& z,
+ const int* proc_id )
+ MBErrorCode rval = create_sequence( preferred_start_id,
+ count,
+ MBVERTEX,
+ 0,
+ proc_id,
+ seq );
+ return rval;
+ VertexEntitySequence* vseq = static_cast<VertexEntitySequence*>(seq);
+ vseq->get_coordinate_arrays( x, y, z );
+ start_handle = seq->get_start_handle();
+MBErrorCode MBFileReadToolBase::create_element_array(
+ MBEntityID count,
+ MBEntityType type,
+ MBEntityID conn_length,
+ MBEntityHandle*& conn_array,
+ int** last_index_array = 0,
+ // caller needs last_index_array for poly-type elements
+ if (type == POLYGON || type == POLYHEDRON) {
+ if (!last_index_array)
+ // no last_index_array for other element types
+ else if (last_index_array)
+ *last_index_array = 0;
+ count,
+ type,
+ conn_length,
+ proc_id,
+ seq );
+ return rval;
+ PolyEntitySequence* pseq = static_cast<PolyEntitySequence*>(seq);
+ pseq->get_connectivity_array( conn_array );
+ pseq->get_index_array( *last_index_array );
+ else {
+ ElementEntitySequence* eseq = static_cast<ElementEntitySequence*>(seq);
+ eseq->get_connectivity_array( conn_array );
+MBErrorCode MBFileReadToolBase::create_meshset_block( MBEntityID start_id,
+ MBEntityID count,
+ unsigned flags,
+ std::vector<unsigned> flag_array( count, flags );
+ return create_meshset_block( start_id, count, start_handle, &flag_array[0], proc_id );
+ MBEntityID count,
+ const unsigned* flags,
+ MBErrorCode rval;
+ MBEntitySequence* seq;
+ rval = mMOAB->sequence_manager()->create_meshset_sequence( count,
+ start_id,
+ proc,
+ flags,
+ seq );
+ return rval;
+MBErrorCode MBFileReadToolBase::set_tag_data( MBTag tag,
+ MBEntityHandle beg,
+ MBEntityHandle num,
+ const void* data )
+ if (num == 0)
+ MBRange range( beg, beg + num - 1 );
+ return moab()->tag_set_data( tag, range, data );
Added: MOAB/trunk/MBFileReadTool.hpp
--- MOAB/trunk/MBFileReadTool.hpp (rev 0)
+++ MOAB/trunk/MBFileReadTool.hpp 2007-09-25 16:45:54 UTC (rev 1285)
@@ -0,0 +1,909 @@
+/**\file MBFileReadTool.hpp
+ *\date 2007-04-25
+#ifndef MB_FILE_READ_TOOL_HPP
+#define MB_FILE_READ_TOOL_HPP
+#include "RangeMap.hpp"
+#include <iosfwd>
+class MBCore;
+class MBError;
+/**\brief Non-template portions of MBFileReadTool */
+class MBFileReadToolBase {
+public:
+ MBFileReadToolBase( MBCore* moab );
+ /**\brief Set last error message */
+ void report_error( std::string error );
+ void report_error( const char* error, ... )
+#ifdef __GNUC__
+ __attribute__((format(printf,2,3)))
+#endif
+ inline MBInterface* moab() const
+ { return mMOAB; }
+ inline unsigned parallel_rank() const
+ { return parallelRank; }
+ /**\brief delete all read entities
+ * Delete all entities created through the methods
+ * provided by this class.
+ MBErrorCode delete_all_entities();
+ /**\brief Get entity set containing all read entities
+ * Get a new entity set containing all the entities
+ * allocated via methods of this object.
+ inline MBEntityHandle get_file_set() const
+ { return fileSet; }
+ /**\brief Delete entities with specified tag
+ * Delete all entities read from file that do not have
+ * the specified tag or tag values.
+ *\param tagname The name of the tag -- must have single integer value
+ *\param tag_values If not null, a list of integer tag values
+ *\param num_tag_values The length of tag_values
+ MBErrorCode delete_non_tagged_entities( const char* tagname,
+ const int* tag_values = 0,
+ int num_tag_values = 0 );
+protected:
+ /**\brief Allocate vertex sequence
+ * Allocate a vertex sequence and update any bookkeeping in
+ * this object.
+ *\param preferred_start_id First MBEntityID, if available
+ *\param count Number of vertices to allocate
+ *\param start_handle Output: first vertex handle
+ *\param x Output: MOAB internal storage for vertex X-coordinates.
+ *\param y Output: MOAB internal storage for vertex Y-coordinates.
+ *\param z Output: MOAB internal storage for vertex Z-coordinates.
+ *\param proc_id NULL or requested parallel processor ID
+ MBErrorCode get_node_arrays( MBEntityID preferred_start_id,
+ MBEntityID count,
+ const int* proc_id );
+ /**\brief Allocate element sequence
+ * Allocate a element sequence and update any bookkeeping in
+ * this object.
+ *\param count Number of elements to allocate
+ *\param type Element type
+ *\param conn_length Vertices per element, zero for MBPOLYGON and MBPOLYHEDRON
+ *\param conn_array Output: MOAB internal storage for element connectivity
+ *\param last_index_array Cannot be NULL for MBPOLYGON or MBPOLYHEDRON. Must
+ * be NULL for other types. Output: Pointer to MOAB
+ * internal storage of last index in connectivity
+ * array for each element.
+ MBErrorCode get_element_array( MBEntityID preferred_start_id,
+ MBEntityID count,
+ /**\brief Allocate a meshset sequence
+ * Allocate a meshset sequence and update any bookkeeping in
+ * this object.
+ *\param count Number of entity sets to allocate
+ *\param start_handle Output: first entity set handle
+ *\param flags entity set creation flags (one val for all entity sets)
+ MBErrorCode create_meshset_block( MBEntityID preferred_start_id,
+ MBEntityID count,
+ MBEntityHandle& start_handle_out,
+ unsigned flags,
+ * this object.
+ *\param flags entity set creation flags (one val per entity sets)
+ MBEntityID count,
+ /**\brief Set tag data for a block of entity handles. */
+ MBErrorCode set_tag_data( MBTag tag,
+ MBEntityHandle count,
+ const void* data );
+private:
+ MBErrorCode create_sequence( MBEntityID start_id,
+ MBEntityID count,
+ MBEntityID type,
+ MBEntitySequence*& seq );
+ MBCore* mMOAB;
+ MBEntityHandle fileSet;
+ unsigned parallelRank;
+/**\brief Helper class for file readers.
+ * This class provides methods for creation of entities
+ * in MOAB and maintains a map from file IDs to MBEntityHandles.
+ * All methods accept values as file IDs and map them to MBEntityHandles
+ * internally.
+ * The type of a file ID is a template parameter, allowing a
+ * particular reader to work directly with the identifier/index
+ * type used by an underlying IO library.
+template <typename FileIDType>
+class MBFileReadTool : public MBFileReadToolBase
+public:
+ /**\brief Create reader tool
+ *\param vertex_unique_ids File ID space for vertices is separate from
+ * other entities. If this value is true, then
+ * the file may contain both a vertex with ID 1
+ * and an element with the same ID value of 1.
+ *\param element_type_unique_ids File ID space is separate for different
+ * element types. If this value is true, then
+ * the file may contain an edge and a
+ * triangle element that have the same ID.
+ *\param set_unique_ids File ID space for entity sets is separate from
+ * other entities.
+ inline
+ MBFileReadTool( MBCore* moab_instance,
+ bool vertex_unique_ids,
+ bool element_type_unique_ids,
+ bool set_unique_ids );
+ /**\brief Allocate a block of nodes.
+ * Allocate a block of nodes and return pointers to MOAB's internal
+ * storage of the vertex coordinaets for those nodes, such that the
+ * file reader may read the coordinate values directly into the
+ * vertex storage allocated by this method.
+ *\param start_id The file ID (or index) of the first vertex. The
+ * allocated vertices will be assigned file IDs in
+ * the range [start_id,start_id+count).
+ *\param count Number of vertices to allocate.
+ *\param x_array_out Output: location at which to write X-coordinates.
+ *\param y_array_out Output: location at which to write Y-coordinates.
+ *\param z_array_out Output: location at which to write Z-coordinates.
+ *\param proc_id For parallel, ID of processor to associate with entities.
+ * If null, current processor rank is assumed.
+ inline
+ MBErrorCode create_nodes( FileIDType start_id,
+ FileIDType count,
+ double *& x_array_out,
+ double *& y_array_out,
+ double *& z_array_out,
+ const int* proc_id = 0 );
+ /**\brief Create a block of elements.
+ * Create mesh elements.
+ *\param type The element type.
+ *\param connectivity_length Nodes per element. Zero for MBPOLY* types.
+ *\param interleaved_connectivity Element connectivity list, specified
+ * as vertex IDs as assigned by the create_nodes method
+ * of this class (face IDs if type == POLYHEDRON).
+ *\param poly_end_indices For MBPOLYGON and MBPOLYHEDRON types, the
+ * *last* index in interleaved_connectivity for each element.
+ inline
+ MBErrorCode create_elements( FileIDType start_id,
+ FileIDType count,
+ FileIDType connectivity_length,
+ const FileIDType* interleaved_connectivity,
+ const FileIDType* poly_end_indices = 0,
+ /**\brief Specifiy explicit adjacencies
+ * Create explicit adjacencies between entities.
+ *\param from_id Source entity for adjacency
+ *\param to_ids Target entities for adjacencies
+ *\param to_count Length of to_ids
+ *\param from_type Type of source entity. The caller
+ * must specify this value if it cannot
+ * be inferred from the source entity ID
+ * (see constructor arguments.)
+ *\param to_type Type of target entities. The caller
+ * be inferred from the target entity IDs
+ inline
+ MBErrorCode add_adjacencies( FileIDType from_id,
+ const FileIDType* to_ids,
+ FileIDType to_count,
+ MBEntityType from_type = MBMAXTYPE,
+ MBEntityType to_type = MBMAXTYPE );
+ /**\brief Create tag for storing entity handles.
+ *\param name Tag name
+ *\param num_handles Number of handles in each tag value. If
+ * this value is greater than one, then each
+ * entity has an array of handles for this tag.
+ *\param storage_type Tag storage type.
+ *\param handle_out Output: tag handle
+ *\param mesh_value Global, or mesh value for tag.
+ *\param default_value Default value for tag.
+ *\param null_id If non-null, the value pointed to by this
+ * argument is treated as special: a "NULL" file ID.
+ inline
+ MBErrorCode create_entity_handle_tag( const char* name,
+ unsigned num_handles,
+ MBTagType storage_type,
+ MBTag& handle_out,
+ const FileIDType* mesh_value = 0,
+ const FileIDType* default_value = 0,
+ const FileIDType* null_id = 0 );
+ /**\brief Set tag data for a block of entities
+ * Set tag data for non-handle type tags. This method will
+ * fail if the tag has a data type MB_TAG_HANDLE.
+ *\param handle Tag handle
+ *\param start_id File ID of first entity
+ *\param id_count Number of entities.
+ *\param tag_data Tag values
+ *\param type The type of the entities for which the tag
+ * data is being set. The caller must specify
+ * this if it cannot be inferred from the file
+ * IDs (see constructor arguments).
+ inline
+ MBErrorCode set_tag_data( MBTag handle,
+ FileIDType start_id,
+ FileIDType id_count,
+ const void* tag_data,
+ MBEntityType type = MBMAXTYPE );
+ /**\brief Set tag data for entity handle tag for a block of entities
+ * This method will fail for any tag that does not have a data type
+ * of MB_TYPE_HANDLE.
+ *\param tag_data Tag values as file IDs
+ *\param entity_type The type of the entities for which the tag
+ *\param value_type The type of the entities in the tag values.
+ * The caller must specify
+ inline
+ const FileIDType* id_array,
+ const FileIDType* tag_data,
+ MBEntityType entity_type = MBMAXTYPE,
+ MBEntityType value_type = MBMAXTYPE,
+ /**\brief Create a block of entity sets
+ * Create count entity sets with consecutive file IDs, beginning
+ * with the specified start_id.
+ *\param start_id File ID for first entity set
+ *\param options Set creation flags for each entity set.
+ inline
+ MBErrorCode create_meshsets( FileIDType start_id,
+ MBEntityId count,
+ const unsigned* options,
+ inline
+ FileIDType count,
+ unsigned options,
+ /**\brief Specify set contents for a block of entity sets
+ *\param start_id File id of first entity set
+ *\param concatenated_content_lists The concatenation of the list of set
+ * contents.
+ *\param end_indices For each entity set, the index of the last entry
+ * for that set in concatenated_content_lists
+ *\param type The type of the entities in concatenated_content_list.
+ * The caller must specify this value if it cannot be
+ * inferred from the file IDs (see constructor args.)
+ inline
+ MBErrorCode add_meshset_contents( FileIDType start_id,
+ FileIDType count,
+ const FileIDType* concatenated_content_lists,
+ const FileIDType* end_indices ,
+ * Specify contents for a block of entity sets, where the set
+ * contents are specified as ranges of file IDs.
+ *\param concatenated_range_list The concatenation of the list of set
+ * contents. The contents for each set are specified
+ * as pairs of file IDS, where each pair corresponds
+ * to the first and last file ID of a range of entities.
+ * To specify a single entity, both values in the range
+ * pair should be the same.
+ * for that set in concatenated_range_list
+ *\param type The type of the entities in concatenated_range_list.
+ inline
+ MBErrorCode add_meshset_range_contents( FileIDType start_id,
+ FileIDType count,
+ const FileIDType* concatenated_range_list,
+ const FileIDType* end_indices,
+ /**\brief Specify set children for a block of entity sets
+ *\param start_parent_id File id of first entity set
+ *\param parent_count Number of entity sets
+ *\param concatenated_children_lists The concatenation of the list of set
+ * children.
+ * for that set in concatenated_children_lists
+ *\param bidirectional If true, also create link from child up to parent.
+ * If false, links are single-directional.
+ inline
+ MBErrorcode add_meshset_children( FileIDType start_parent_id,
+ FileIDType parent_count,
+ const FileIDType* concatenated_children_lists,
+ const FileIDType* null_id,
+ bool bidirectional = true );
+ /**\brief Specify set parents for a block of entity sets
+ *\param start_child_id File id of first entity set
+ *\param child_count Number of entity sets
+ *\param concatenated_parents_lists The concatenation of the list of set
+ * parents.
+ * for that set in concatenated_parents_lists
+ inline
+ MBErrorcode add_meshset_parents( FileIDType start_child_id,
+ FileIDType child_count,
+ const FileIDType* concatenated_parents_lists,
+ const FileIDType* null_id );
+ /**\brief Get number of entities of each type */
+ inline void get_entity_counts( FileIDType counts[MBMAXTYPE] ) const;
+ /**\brief Convert from file IDs to MBEntityHandles
+ * Convert from file IDs to MBEntityHandles
+ *\param type The type of the entities, or MBMAXTYPE if
+ * the entity type can be inferred from the file ID.
+ * The type can be inferred if all arguments to the
+ * constructor that control the file ID space mapping
+ * are false. I.e. there is to potential ID conflict.
+ *\param ids The input array of IDs for which to get the
+ * corresponding MBEntityHandles.
+ *\param handles The array in which to store the result MBEntityHandles
+ *\param count The length of ids (and handles).
+ *\param null_id If this argument is not NULL, then the value it points
+ * to will be assumed to be a 'NULL' file ID value, such
+ * that any input FileIDType with this value will be
+ * assigned a zero (NULL) MBEntityHandle.
+ *\return true if success, false if failure.
+ inline bool ids_to_handles( MBEntityType type,
+ const FileIdType* ids,
+ MBEntityHandle* handles,
+ FileIDType count,
+private:
+ HandleRangeMap<FileIDType> typeMap[MBMAXTYPE+1];
+ const bool vertexUniqueIds, elemTypeUniqueIds, setUniqueIds;
+ std::vector<MBEntityHandle> handleArray;
+template <typename FileIDType> inline
+bool MBFileReadTool<FileIdType>::ids_to_handles( MBEntityType type,
+ FileIDType count,
+ bool ok = true;
+ const HandleRangeMap& map = typeMap[type];
+ for (FileIDType i = 0; i < count; ++i) {
+ handles[i] = map.find( ids[i] );
+ if (!handles[i] && (!null_id || *null_id != ids[i]))
+ ok = false;
+ return ok;
+MBFileReadTool<FileIdType>::MBFileReadTool( MBInterface* moab_iface,
+ : MBReaderUtilBase( moab_interface ),
+ vertexUniqueIds( vertex_unique_ids ),
+ elemTypeUniqueIds( element_type_unique_ids ),
+ setUniqueIds( set_unique_ids )
+MBErrorCode MBFileReadTool<FileIdType>::create_nodes( FileIDType start_id,
+ FileIDType count,
+ double *& x,
+ double *& y,
+ double *& z,
+ MBEntityHandle handle,
+ MBErrorCode rval = get_node_arrays( start+id, count, handle, x, y, z, proc_id );
+ return rval;
+ typeMap[MBVERTEX].insert( handle, count, start_id );
+ if (!vertexUniqueIds)
+ typeMap[MBMAXTYPE].insert( handle, count, start_id );
+MBErrorCode MBFileReadTool<FileIdType>::create_elements( FileIDType start_id,
+ FileIDType count,
+ FileIDType len,
+ const FileIDType* conn_ids,
+ const FileIDType* poly,
+ if (type == MBPOLYGON || type == MBPOLYHEDRON)
+ if (!poly || poly[count-1] != len)
+ int* index_array;
+ MBErrorCode rval;
+ MBEntityHandle handle, *conn;
+ rval = get_element_array( start_id, count, type, len, handle, conn, &index_array, proc_id );
+ return rval;
+ typeMap[type].insert( handle, count, start_id );
+ if (!elemTypeUniqueIds)
+ bool valid;
+ if (type != MBPOLYHEDRON)
+ valid = convert_ids_to_handles( MBVERTEX, conn_ids, conn, count );
+ else if (elemTypeUniqueIDs)
+ valid = convert_ids_to_handles( MBPOLYGON, conn_ids, conn, count );
+ else
+ valid = convert_ids_to_handles( MBMAXTYPE, conn_ids, conn, count );
+ index_array[i] = poly[i];
+ return valid ? MB_SUCCESS : MB_FAILURE;;
+MBErrorCode MBFileReadTool<FileIdType>::add_adjacencies( FileIDType from_id,
+ MBEntityType from_type,
+ MBEntityType to_type )
+ MBEntityHandle from_handle;
+ if (!convert_ids_to_handles( from_type, &from_id, &from_handle, 1 ))
+ handleArray.resize( to_count );
+ if (!convert_ids_to_handles( to_type, to_ids, &handleArray[0], to_count ))
+ return moab()->add_adjacencies( from_handle, &handleArray[0], to_count, false );
+MBErrorCode MBFileReadTool<FileIdType>::create_entity_handle_tag(
+ const char* name,
+ const FileIDType* mesh_value,
+ const FileIDType* default_value,
+ handleArray.resize( 2*num_handles );
+ MBEntityHandle *mesh_handles = 0, *default_handles = 0;
+ if (mesh_values) {
+ mesh_handles = &handleArray[0];
+ if (!ids_to_handles( MBMAXTYPE, mesh_value, mesh_handles, num_handles, null_id ))
+ if (default_value) {
+ default_handles = &handleArray[num_handles];
+ if (!ids_to_handles( MBMAXTYPE, default_value, default_handles, num_handles, null_id ))
+ MBErrorCode rval = moab()->tag_create( name,
+ num_handles * sizeof(MBEntityHandle),
+ storage_type,
+ MB_TYPE_HANDLE,
+ handle_out,
+ default_handles,
+ true );
+ return rval;
+ return tag_set_data( handle_out, 0, 0, mesh_handles );
+MBErrorCode MBFileReadTool<FileIdType>::set_tag_data( MBTag handle,
+ MBEntityType val_type )
+ MBErrorCode rval, result = MB_SUCCESS;
+ std::vector<MBEntityHandle> ranges, hdata;
+ if (!typeMap[type].find( start_id, id_count, ranges ))
+ MBDataType tag_type;
+ rval = moab()->tag_get_data_type( handle, tag_type );
+ return rval;
+ int tag_size;
+ rval = moab()->tag_get_size( handle, tag_size );
+ return rval;
+ if (MB_TYPE_HANDLE == tag_type)
+ const char* data = static_cast<const char*>(tag_data);
+ for (MBEntityID i = 0; i < ranges.size(); i += 2) {
+ MBEntityHandle start_handle = ranges[i];
+ MBEntityID count = ranges[i+1];
+ rval = set_tag_data( handle, start_handle, count, data );
+ result = rval;
+ data += (count + tag+size);
+ return result;
+ MBEntityType val_type,
+ MBErrorCode rval;
+ return rval;
+ if (tag_type != MB_TYPE_HANDLE)
+ int tag_size;
+ return rval;
+ tag_size /= sizeof(MBEntityHandle);
+ handleArray.resize( id_count * (tag_size + 1) );
+ if (!ids_to_handles( val_type,
+ tag_data,
+ &handlesArray[id_count],
+ null_id ))
+ tag_data = &handlesArray[id_count];
+ if (!ids_to_handles( type, id_array, &handlesArray[0], id_count ))
+ return moab()->tag_set_data( handle, &handlesArray[0], id_count, tag_data );
+MBErrorCode MBFileReadTool<FileIdType>::create_meshsets( FileIDType start_id,
+ MBEntityId count,
+ MBEntityHandle h;
+ MBErrorCode rval;
+ rval = craete_meshset_block( start_id, count, h, options, proc_id );
+ return rval;
+ typeMap[MBENTITYSET].insert( h, count, start_id );
+ if (!setUniqueIDs)
+ typeMap[MBMAXTYPE].insert( h, count, start_id );
+ FileIDType count,
+ unsigned options,
+ MBEntityHandle h;
+ MBErrorCode rval;
+ return rval;
+MBErrorCode MBFileReadTool<FileIdType>::add_meshset_contents(
+ FileIDType count,
+ const FileIDType* list,
+ MBEntityType type )
+ MBEntityHandle handle;
+ FileIDType id, prev = 0, n;
+ MBErrorCode result = MB_SUCCESS;
+ for (FileIDType i = 0; i < count; prev = end_indices[i++]) {
+ id = start_id + i;
+ if (!ids_to_handles( MBENTITYSET, &id, &handle, 1 )) {
+ result = MB_FAILURE;
+ continue;
+ n = end_indices[i] - prev;
+ handleArray.resize( n );
+ if (!ids_to_handles( type, list+prev, &handleArray[0], n))
+ else if (MB_SUCCESS != moab()->add_entities( handle, &handleArray[0], n ))
+ return result;
+MBErrorCode MBFileReadTool<FileIdType>::add_meshset_range_contents(
+ FileIDType count,
+ MBRange range;
+ MBRange::iterator h;
+ prev = end_indices[i];
+ continue;
+ range.clear();
+ h = range.begin();
+ for ( ; prev < end_indices[i]; prev += 2)
+ typeMap[type].find( list[i], list[i+i], range, h );
+ if (range.size() != count)
+ rval = moab()->add_entities( handle, range );
+ result = rval;
+ return result;
+MBErrorCode MBFileReadTool<FileIdType>::add_meshset_children(
+ FileIDType count,
+ const FileIDType* counts,
+ bool bidirectional )
+ continue;
+ if (!ids_to_handles( MBENTITYSET, list+prev, &handleArray[0], n))
+ else {
+ if (bidirectional) {
+ for (FileIDType i = 0; i < n; ++i)
+ if (MB_SUCCESS != moab()->add_parent_child( handle, handleArray[i] ))
+ else if (MB_SUCCESS != moab()->add_child_meshsets( handle, &handleArray[0], n ))
+ return result;
+MBErrorCode MBFileReadTool<FileIdType>::add_meshset_parents(
+ FileIDType count,
+ const FileIDType* counts )
+ continue;
+ else if (MB_SUCCESS != moab()->add_parent_meshsets( handle, &handleArray[0], n ))
+ return result;
+void MBFileReadTool<FileIdType>::get_entity_counts( FileIDType counts[MBMAXTYPE] ) const
+ for (MBEntityType t = MBVERTEX; t < MBMAXTYPE; ++i)
+ counts[t] = typeMap[t].size();
Modified: MOAB/trunk/Makefile.am
--- MOAB/trunk/Makefile.am 2007-09-25 16:45:14 UTC (rev 1284)
+++ MOAB/trunk/Makefile.am 2007-09-25 16:45:54 UTC (rev 1285)
@@ -29,7 +29,8 @@
check_PROGRAMS = $(TESTS) \
kd_tree_tool \
- kd_tree_time
+ kd_tree_time \
+ range_map_test
#noinst_PROGRAMS = scdseq_timing
@@ -119,6 +120,8 @@
MBMatrix3.hpp \
MBCore.cpp \
MBFactory.cpp \
+ MBFileReadTool.hpp \
MBGeomUtil.cpp \
MBInternals.hpp \
MBMem.hpp \
@@ -143,6 +146,7 @@
MeshTopoUtil.cpp \
PolyEntitySequence.cpp \
PolyEntitySequence.hpp \
+ RangeMap.hpp \
ReadGmsh.cpp \
ReadGmsh.hpp \
ReadParallel.hpp \
@@ -301,6 +305,8 @@
file_options_test_SOURCES = FileOptions.cpp
file_options_test_CPPFLAGS = -DTEST
+range_map_test_sources = RangeMapTest.cpp RangeMap.hpp
# Other files to clean up (e.g. output from tests)
MOSTLYCLEANFILES = dumped_acis.sat
Added: MOAB/trunk/RangeMap.hpp
--- MOAB/trunk/RangeMap.hpp (rev 0)
+++ MOAB/trunk/RangeMap.hpp 2007-09-25 16:45:54 UTC (rev 1285)
@@ -0,0 +1,199 @@
+/**\file RangeMap.hpp
+ *\author Jason Kraftcheck (kraftche at cae.wisc.edu)
+ *\date 2007-04-25
+#ifndef RANGE_MAP_HPP
+#define RANGE_MAP_HPP
+#include <vector>
+#include <algorithm>
+/**\brief Map ranges of values
+ * This class provides a map between ranges of values, such as
+ * a map between file IDs and MBEntityHandles. It is intended
+ * for use in situations where there are relatively few insertions
+ * of large contiguous ranges of values.
+template <typename KeyType, typename ValType, ValType NullVal = 0>
+class RangeMap
+public:
+ struct Range {
+ KeyType begin, count;
+ ValType value;
+ bool operator<( const Range& other ) const
+ { return begin + count <= other.begin; } // equal if overlapping!
+ typedef typename std::vector<Range> RangeList;
+ typedef typename RangeList::const_iterator iterator;
+ /**\brief Insert mapping between range of keys and range of values
+ * Insert mapping from [first_key, first_key+count) to [first_val, first_val+count)
+ * Input range of keys many not overlap any other input range. If it does overlap
+ * an existing range, false is returned and the internal map is not changed.
+ inline iterator insert( KeyType first_key, ValType first_val, KeyType count );
+ /** Find the value corresponding to the specified key. Returns NullVal if not found */
+ inline ValType find( KeyType key ) const;
+ /** Remove a block of values */
+ inline iterator erase( KeyType beg, KeyType count );
+ inline unsigned num_ranges() const { return data.size(); }
+ inline iterator begin() const { return data.begin(); }
+ inline iterator end() const { return data.end(); }
+ inline iterator lower_bound( KeyType key ) const
+ Range b = { key, 1, NullVal };
+ return std::lower_bound( begin(), end(), b );
+ inline iterator upper_bound( KeyType key ) const
+ return std::upper_bound( begin(), end(), b );
+ inline std::pair<iterator,iterator>
+ equal_range( KeyType key ) const
+ return std::equal_range( begin(), end(), b );
+ inline void clear() { data.clear(); }
+protected:
+ RangeList data;
+template <typename KeyType, typename ValType, ValType NullVal>
+inline typename RangeMap<KeyType,ValType,NullVal>::iterator
+RangeMap<KeyType,ValType,NullVal>::insert( KeyType first_key, ValType first_val, KeyType count )
+ Range block = { first_key, count, first_val };
+ typename RangeList::iterator i = std::lower_bound( data.begin(), data.end(), block );
+ if (i == data.end()) {
+ if (i != data.begin()) {
+ --i;
+ if (i->begin + i->count == first_key &&
+ i->value + i->count == first_val) {
+ i->count += count;
+ return i;
+ data.push_back( block );
+ return data.end() - 1;
+ if (i->begin < first_key + count)
+ return data.end();
+ if (i->begin == first_key + count &&
+ i->value == first_val + count) {
+ i->begin = first_key;
+ i->value = first_val;
+ count = i->count;
+ --i;
+ ++i;
+ i = data.erase(i);
+ --i;
+ return i;
+ --i;
+ return i;
+ ++i;
+ return data.insert( i, block );
+template <typename KeyType, typename ValType, ValType NullVal> inline
+ValType RangeMap<KeyType,ValType,NullVal>::find( KeyType key ) const
+ Range search = { key, 1, NullVal };
+ typename RangeList::const_iterator i = std::lower_bound( data.begin(), data.end(), search );
+ if (i == data.end() || i->begin > key)
+ return NullVal;
+ return i->value + key - i->begin;
+RangeMap<KeyType,ValType,NullVal>::erase( KeyType key, KeyType count )
+ typename RangeList::iterator i, j;
+ i = std::lower_bound( data.begin(), data.end(), search );
+ return i;
+ if (key > i->begin) {
+ KeyType offset = key - i->begin;
+ // special case - split existing entry
+ if((offset + count) < i->count) {
+ Range ins = { i->begin, offset, i->value };
+ offset += count;
+ i->begin += offset;
+ i->value += offset;
+ i->count -= offset;
+ return data.insert( i, ins ) + 1;
+ // otherwise remove the latter part of i
+ i->count = offset;
+ ++i;
+ // remove any entries entirely convered by the input range
+ for (j = i; j != data.end() && (j->begin + j->count) <= (key + count); ++j);
+ i = data.erase(i,j);
+ // remove beginning of last block
+ if (i != data.end() && (key + count) >= i->begin) {
+ KeyType offset = key + count - i->begin;
+ return i;
+#endif
Added: MOAB/trunk/RangeMapTest.cpp
--- MOAB/trunk/RangeMapTest.cpp (rev 0)
+++ MOAB/trunk/RangeMapTest.cpp 2007-09-25 16:45:54 UTC (rev 1285)
@@ -0,0 +1,143 @@
+#include <iostream>
+#include <iomanip>
+#include <stdio.h>
+#include <stdlib.h>
+RangeMap<long,long,0> mapInstance;
+bool insert( std::vector<long>& values );
+bool verify( std::vector<long>& values );
+bool print( std::vector<long>& values );
+bool clear( std::vector<long>& values );
+bool help();
+bool do_command( char* cmd )
+ std::vector<long> values;
+ char *ptr, *end;
+ const char space[] = " \t\r\n";
+ char c = cmd[0];
+ ++cmd;
+ for (ptr = strtok( cmd, space ); ptr; ptr = strtok( 0, space )) {
+ long val = strtol( ptr, &end, 0 );
+ if (*end) {
+ std::cerr << "Invalid integer value: " << ptr << std::endl;
+ return false;
+ values.push_back( val );
+ switch (c) {
+ case 'i': return insert( values );
+ case 'v': return verify( values );
+ case 'p': return print( values );
+ case 'c': return clear( values );
+ case 'h': return help( );
+ default:
+ std::cerr << "Unknown command: " << c << std::endl;
+ return false;
+ if (values.size() % 3) {
+ std::cerr << "Invalid arguments for insertion. "
+ "Insertion requires tuples of three values: "
+ "{start_key,start_val,count}" << std::endl;
+ return false;
+ for (unsigned i = 0; i < values.size(); i += 3)
+ if (mapInstance.end() == mapInstance.insert( values[i], values[i+1], values[i+2] ))
+ std::cout << "Insertion of {" << values[i] << ", "
+ << values[i+1] << ", "
+ << values[i+2] << "} FAILED" << std::endl;
+ return true;
+ if (values.size() % 2) {
+ std::cerr << "(c)lear command expects ranges of values (or no values)" << std::endl;
+ return false;
+ if(values.empty()) {
+ mapInstance.clear();
+ return true;
+ for (unsigned i = 0; i < values.size(); i += 2)
+ mapInstance.erase( values[i], values[i+1] );
+ return true;
+ const int W = 20;
+ if (values.empty()) {
+ std::cout << std::setw(W) << "Start Key"
+ << std::setw(W) << "Start Val"
+ << std::setw(W) << "Count"
+ << std::endl;
+ RangeMap<long,long,0>::iterator i = mapInstance.begin();
+ for (; i != mapInstance.end(); ++i)
+ std::cout << std::setw(W) << i->begin
+ << std::setw(W) << i->value
+ << std::setw(W) << i->count
+ << std::endl;
+ else {
+ for (unsigned i = 0; i < values.size(); ++i)
+ std::cout << std::setw(W) << values[i] << "->"
+ << std::setw(W) << mapInstance.find(values[i]) << std::endl;
+ return true;
+ return false;
+ bool result = true;
+ std::vector<long>::iterator j = values.begin();
+ if (j == values.end() ||
+ i->begin != *j++ ||
+ i->value != *j++ ||
+ i->count != *j++)
+ result = false;
+ return result && j == values.end();
+bool help()
+ std::cout << "Commands: i p c v h" << std::endl
+ << " i - insert list of values " << std::endl
+ << " p - print entire map or lookup specified values" << std::endl
+ << " c - clear map" << std::endl
+ << " v - verify map contents" << std::endl
+ << " h - this help" << std::endl;
+ return true;
+int main() {
+ char buffer[1024];
+ bool exit_val = 0;
+ while (fgets(buffer, sizeof(buffer), stdin))
+ exit_val += !do_command(buffer);
+ return exit_val;
