[MOAB-dev] r1341 - in MOAB/trunk: . tools/dagmc
tautges at mcs.anl.gov
Thu Oct 25 07:35:09 CDT 2007
Author: tautges
Date: 2007-10-25 07:35:08 -0500 (Thu, 25 Oct 2007)
New Revision: 1341
Modified:
MOAB/trunk/Tqdcfr.cpp
MOAB/trunk/tools/dagmc/DagMC.cpp
MOAB/trunk/tools/dagmc/DagMC.hpp
MOAB/trunk/tools/dagmc/pt_vol_test.cc
MOAB/trunk/tools/dagmc/test_geom.cc
Log:
Fixing DagMC so it builds again (but make check still fails there).
Fixing a 64 bit issue in Tqdcfr, where it was assuming sizeof(int) == sizeof(MBEntityHandle).
tqdcfr part of make check works on 64 bit machines now.
Modified: MOAB/trunk/Tqdcfr.cpp
--- MOAB/trunk/Tqdcfr.cpp 2007-10-25 12:33:33 UTC (rev 1340)
+++ MOAB/trunk/Tqdcfr.cpp 2007-10-25 12:35:08 UTC (rev 1341)
@@ -1095,24 +1095,32 @@
// now do something with them...
- // get the connectivity array
+ // get the connectivity array; be careful, the connectivity is stored
+ // in the file as ints, while the connect array is handles, which may
+ // be long; this will lead to problems on 64-bit machines
int total_conn = num_elem * nodes_per_elem;
- assert(sizeof(MBEntityHandle) == sizeof(int));
- FREADIA(total_conn, reinterpret_cast<int*>(conn));
+ int *tmp_conn = reinterpret_cast<int*>(conn);
+ if (sizeof(MBEntityHandle) != sizeof(int))
+ tmp_conn = new int[total_conn];
+ FREADIA(total_conn, tmp_conn);
// post-process connectivity into handles
MBEntityHandle new_handle, dum_handle;
int dum_err;
for (i = 0; i < total_conn; i++) {
if (NULL == cubMOABVertexMap)
- new_handle = CREATE_HANDLE(MBVERTEX, currNodeIdOffset+conn[i], dum_err);
- else new_handle = (*cubMOABVertexMap)[conn[i]];
+ new_handle = CREATE_HANDLE(MBVERTEX, currNodeIdOffset+tmp_conn[i], dum_err);
+ else new_handle = (*cubMOABVertexMap)[tmp_conn[i]];
assert(MB_SUCCESS ==
mdbImpl->handle_from_id(MBVERTEX, mdbImpl->id_from_handle(new_handle),
dum_handle));
conn[i] = new_handle;
+ delete [] tmp_conn;
// add these elements into the entity's set
MBRange dum_range(start_handle, start_handle+num_elem-1);
result = mdbImpl->add_entities(entity->setHandle, dum_range);
Modified: MOAB/trunk/tools/dagmc/DagMC.cpp
--- MOAB/trunk/tools/dagmc/DagMC.cpp 2007-10-25 12:33:33 UTC (rev 1340)
+++ MOAB/trunk/tools/dagmc/DagMC.cpp 2007-10-25 12:35:08 UTC (rev 1341)
@@ -1422,8 +1422,8 @@
setOffset = (*surfs.begin() < *vols.begin() ? *surfs.begin() : *vols.begin());
setOffset = (impl_compl_handle < setOffset ? impl_compl_handle : setOffset);
// max
- unsigned int tmp_offset = (surfs.back() > vols.back() ?
- surfs.back() : vols.back());
+ MBEntityHandle tmp_offset = (surfs.back() > vols.back() ?
+ surfs.back() : vols.back());
tmp_offset = (impl_compl_handle > tmp_offset ?
impl_compl_handle : tmp_offset);
// set size
Modified: MOAB/trunk/tools/dagmc/DagMC.hpp
--- MOAB/trunk/tools/dagmc/DagMC.hpp 2007-10-25 12:33:33 UTC (rev 1340)
+++ MOAB/trunk/tools/dagmc/DagMC.hpp 2007-10-25 12:35:08 UTC (rev 1341)
@@ -48,7 +48,8 @@
// Return values: {0 : outside, 1: inside, -1: on boundary}
MBErrorCode point_in_volume( MBEntityHandle volume,
double x, double y, double z,
- int& result );
+ int& result,
+ double u, double v, double w);
// Find the distance to the nearest surface
MBErrorCode closest_to_location( MBEntityHandle volume,
@@ -156,6 +157,11 @@
std::vector<MBEntityHandle> &surfaces,
double &len);
+ MBErrorCode boundary_case( MBEntityHandle volume, int& result,
+ double u, double v, double w,
+ MBEntityHandle facet,
+ MBEntityHandle surface);
private:
bool have_obb_tree();
Modified: MOAB/trunk/tools/dagmc/pt_vol_test.cc
--- MOAB/trunk/tools/dagmc/pt_vol_test.cc 2007-10-25 12:33:33 UTC (rev 1340)
+++ MOAB/trunk/tools/dagmc/pt_vol_test.cc 2007-10-25 12:35:08 UTC (rev 1341)
@@ -18,7 +18,8 @@
MBEntityHandle vol = dagmc.entity_by_id(3,volID);
- rval = dagmc.point_in_volume( vol, xxx, yyy, zzz, inside);
+ double u, v, w;
+ rval = dagmc.point_in_volume( vol, xxx, yyy, zzz, inside, u, v, w);
CHKERR;
return MB_SUCCESS;
Modified: MOAB/trunk/tools/dagmc/test_geom.cc
--- MOAB/trunk/tools/dagmc/test_geom.cc 2007-10-25 12:33:33 UTC (rev 1340)
+++ MOAB/trunk/tools/dagmc/test_geom.cc 2007-10-25 12:35:08 UTC (rev 1341)
@@ -446,12 +446,12 @@
for (int i = 0; i < num_test; ++i) {
int result;
+ double u, v, w;
tests[i].coords[0],
tests[i].coords[1],
tests[i].coords[2],
- result );
+ result, u, v, w);
CHKERR;
if (result != tests[i].result) {
std::cerr << "ERROR testing point_in_volume[" << i << "]:" << std::endl
