[MOAB-dev] r1339 - MOAB/trunk
dcthomp at mcs.anl.gov
Wed Oct 24 18:41:57 CDT 2007
Author: dcthomp
Date: 2007-10-24 18:41:57 -0500 (Wed, 24 Oct 2007)
New Revision: 1339
Modified:
MOAB/trunk/CMakeLists.txt
Log:
ENH: Add some more of the tests to the CMake build.
Modified: MOAB/trunk/CMakeLists.txt
--- MOAB/trunk/CMakeLists.txt 2007-10-24 22:56:13 UTC (rev 1338)
+++ MOAB/trunk/CMakeLists.txt 2007-10-24 23:41:57 UTC (rev 1339)
@@ -267,6 +267,31 @@
add_executable( moab_test MBTest.cpp )
target_link_libraries( moab_test MOAB )
- add_test( moab_test moab_test )
+ add_test( TestMOAB ${EXECUTABLE_OUTPUT_PATH}/moab_test -nostress )
# FIXME: moab_test depends on: test/mb_big_test.g test/cell1.gen test/cell2.gen
+ add_executable( internals_test internals_test.cpp )
+ set_source_files_properties( internals_test.cpp
+ COMPILE_FLAGS "-DIS_BUILDING_MB ${MOAB_DEFINES}" )
+ target_link_libraries( internals_test MOAB )
+ add_test( TestInternals ${EXECUTABLE_OUTPUT_PATH}/internals_test )
+ add_executable( homxform_test HomXform.cpp )
+ set_source_files_properties( HomXform.cpp
+ COMPILE_FLAGS "-DTEST ${MOAB_DEFINES}" )
+ target_link_libraries( homxform_test MOAB )
+ add_test( TestHomXform ${EXECUTABLE_OUTPUT_PATH}/homxform_test )
+ add_executable( scdseq_test scdseq_test.cpp )
+ set_source_files_properties( scdseq_test.cpp
+ target_link_libraries( scdseq_test MOAB )
+ add_test( TestSCDSeq ${EXECUTABLE_OUTPUT_PATH}/scdseq_test )
+ add_executable( tqdcfr Tqdcfr.cpp )
+ set_source_files_properties( Tqdcfr.cpp
+ COMPILE_FLAGS "-DTEST -DIS_BUILDING_MB ${MOAB_DEFINES}" )
+ target_link_libraries( tqdcfr MOAB )
+ add_test( TestTQDCFR ${EXECUTABLE_OUTPUT_PATH}/tqdcfr )
