[MOAB-dev] r1415 - MOAB/trunk
dcthomp at mcs.anl.gov dcthomp at mcs.anl.gov
Tue Nov 20 02:55:48 CST 2007
Author: dcthomp
Date: 2007-11-20 02:55:48 -0600 (Tue, 20 Nov 2007)
New Revision: 1415
Added:
   MOAB/trunk/MBEdgeSizeSimpleImplicit.cpp
   MOAB/trunk/MBEdgeSizeSimpleImplicit.hpp
   MOAB/trunk/test_mesh_refiner.cpp
Modified:
   MOAB/trunk/CMakeLists.txt
Log:
ENH: A concrete subclass of MBEdgeSizeEvaluator and a test for it
     that will eventually test all of the refinement code, hence
     the grandiose name.
Modified: MOAB/trunk/CMakeLists.txt
--- MOAB/trunk/CMakeLists.txt	2007-11-20 02:39:32 UTC (rev 1414)
+++ MOAB/trunk/CMakeLists.txt	2007-11-20 08:55:48 UTC (rev 1415)
@@ -121,6 +121,7 @@
     MBMatrix3.cpp
     MBCore.cpp
     MBEdgeSizeEvaluator.cpp
+    MBEdgeSizeSimpleImplicit.cpp
     MBFactory.cpp
     MBGeomUtil.cpp
     MBMeshSet.cpp
@@ -316,4 +317,10 @@
   target_link_libraries( tqdcfr MOAB )
   add_test( TestTQDCFR ${EXECUTABLE_OUTPUT_PATH}/tqdcfr )
+  add_executable( test_mesh_refiner test_mesh_refiner.cpp )
+  set_source_files_properties( test_mesh_refiner.cpp
+    COMPILE_FLAGS "-DTEST ${MOAB_DEFINES}" )
+  target_link_libraries( test_mesh_refiner MOAB )
+  add_test( TestMeshRefiner ${EXECUTABLE_OUTPUT_PATH}/test_mesh_refiner )
Added: MOAB/trunk/MBEdgeSizeSimpleImplicit.cpp
--- MOAB/trunk/MBEdgeSizeSimpleImplicit.cpp	                        (rev 0)
+++ MOAB/trunk/MBEdgeSizeSimpleImplicit.cpp	2007-11-20 08:55:48 UTC (rev 1415)
@@ -0,0 +1,78 @@
+#include "MBEdgeSizeSimpleImplicit.hpp"
+MBEdgeSizeSimpleImplicit::MBEdgeSizeSimpleImplicit( MBInterface* parentMesh )
+  : MBEdgeSizeEvaluator( parentMesh )
+  int i;
+  // Default to the plane: x = 0.
+  this->coeffC = 0.;
+  for ( i = 0; i < 3; ++i )
+    this->coeffB[i] = this->coeffA[i] = this->coeffA[i+3] = 0.;
+  this->coeffB[0] = 1.;
+  // Default to a scaling ratio of 1.
+  this->ratio = 1.;
+MBEdgeSizeSimpleImplicit::~MBEdgeSizeSimpleImplicit()
+bool MBEdgeSizeSimpleImplicit::evaluate_edge(
+  const double* p0, const void* t0,
+  double* p1, void* t1,
+  const double* p2, const void* t2 )
+  double L2 = 0.;
+  double delta;
+  int i;
+    delta = p2[i+3] - p0[i+3];
+    L2 += delta * delta;
+  // parametric coords in p1[{0,1,2}]
+  double x = p1[3];
+  double y = p1[4];
+  double z = p1[5];
+  double F2 =
+    this->coeffA[0] * x * x + 2. * this->coeffA[1] * x * y + 2. * this->coeffA[2] * x * z +
+    this->coeffA[3] * y * y + 2. * this->coeffA[4] * y * z +
+    this->coeffA[5] * z * z +
+    this->coeffB[0] * x + this->coeffB[1] * y + this->coeffB[2] * z +
+    this->coeffC;
+  F2 = F2 * F2; // square it
+  double r2 = this->ratio * this->ratio;
+  if ( 4. * F2 / L2 < r2 )
+    return true; // Midpoint is close to surface => split edge
+  return false; // Don't split edge
+void MBEdgeSizeSimpleImplicit::set_implicit_function( double* coeffs )
+  int i;
+    this->coeffA[i  ] = coeffs[i];
+    this->coeffA[i+3] = coeffs[i + 3];
+    this->coeffB[i  ] = coeffs[i + 6];
+  this->coeffC = coeffs[9];
+void MBEdgeSizeSimpleImplicit::get_implicit_function( double*& coeffs )
+  int i;
+    coeffs[i] = this->coeffA[i  ];
+    coeffs[i + 3] = this->coeffA[i+3];
+    coeffs[i + 6] = this->coeffB[i  ];
+  coeffs[9] = this->coeffC;
Added: MOAB/trunk/MBEdgeSizeSimpleImplicit.hpp
--- MOAB/trunk/MBEdgeSizeSimpleImplicit.hpp	                        (rev 0)
+++ MOAB/trunk/MBEdgeSizeSimpleImplicit.hpp	2007-11-20 08:55:48 UTC (rev 1415)
@@ -0,0 +1,67 @@
+ * MOAB, a Mesh-Oriented datABase, is a software component for creating,
+ * storing and accessing finite element mesh data.
+ * Copyright 2004 Sandia Corporation.  Under the terms of Contract
+ * DE-AC04-94AL85000 with Sandia Coroporation, the U.S. Government
+ * retains certain rights in this software.
+ * This library is free software; you can redistribute it and/or
+ * modify it under the terms of the GNU Lesser General Public
+ * License as published by the Free Software Foundation; either
+ * version 2.1 of the License, or (at your option) any later version.
+/** \class MBEdgeSizeSimpleImplicit
+  * This is an simple example edge evaluator tha subdivides edges based
+  * on their midpoint's distance to a simple, fixed-form implicit surface
+  * written as \f$ x^T A x + B x + C \f$ where \f$x\f$ is a column vector of
+  * holding the edge midpoint coordinates, \f$A\f$ is a symmetric 3x3 matrix,
+  * \f$B\f$ is a 1x3 row vector, and \f$C\f$ is a scalar.
+  * Whenever the implicit function divided by half of the edge length is smaller than
+  * some minimum ratio (which defaults to 1), the edge is marked for subdivision.
+  * \author David Thompson
+  * \date 19 November 2007
+#ifndef MB_EDGESIZESIMPLEIMPLICIT_H
+#define MB_EDGESIZESIMPLEIMPLICIT_H
+#include "MBEdgeSizeEvaluator.hpp"
+class MB_DLL_EXPORT MBEdgeSizeSimpleImplicit : public MBEdgeSizeEvaluator
+public:
+  /// Construct an evaluator.
+  MBEdgeSizeSimpleImplicit( MBInterface* parentMesh );
+  /// Destruction is virtual so subclasses may clean up after refinement.
+  virtual ~MBEdgeSizeSimpleImplicit();
+  /** \brief Given an edge of length L, true when edge midpoint is within $\alpha^2$ of $\left(\frac{2f(x,y,z)}{L}\right)^2$.
+  virtual bool evaluate_edge(
+    const double* p2, const void* t2 );
+  /// Set the 9 coefficients of the implicit function. The vector contains the entries of A, followed by B, followed by C.
+  virtual void set_implicit_function( double* coeffs );
+  /// Get the 9 coefficients of the implicit function. The vector contains the entries of A, followed by B, followed by C.
+  void get_implicit_function( double*& coeffs );
+  /// Set the threshold ratio of function value to half-edge length that triggers subdivision.
+  virtual void set_ratio( double r ) { this->ratio = r; }
+  /// Get the threshold ratio of function value to half-edge length that triggers subdivision.
+  double get_ratio() { return this->ratio; }
+protected:
+  double coeffA[6];
+  double coeffB[3];
+  double coeffC;
+  double ratio;
+#endif // MB_EDGESIZESIMPLEIMPLICIT_H
Added: MOAB/trunk/test_mesh_refiner.cpp
--- MOAB/trunk/test_mesh_refiner.cpp	                        (rev 0)
+++ MOAB/trunk/test_mesh_refiner.cpp	2007-11-20 08:55:48 UTC (rev 1415)
@@ -0,0 +1,30 @@
+#include "MBCore.hpp"
+#include "MBInterface.hpp"
+int TestMeshRefiner( int argc, char* argv[] )
+  MBInterface* iface = new MBCore;
+  MBEdgeSizeSimpleImplicit eval( iface );
+  double p0[6] = { 0.1, 0.0, 0.0,  0.1, 0.0, 0.0 };
+  double p1[6] = { 0.6, 0.0, 0.0,  0.6, 0.0, 0.0 };
+  double p2[6] = { 1.1, 0.0, 0.0,  1.1, 0.0, 0.0 };
+  if ( eval.evaluate_edge( p0, 0, p1, 0, p2, 0 ) )
+    return 1;
+  eval.set_ratio( 2. );
+  if ( ! eval.evaluate_edge( p0, 0, p1, 0, p2, 0 ) )
+    return 1;
+  delete iface;
+  return 0;
+int main( int argc, char* argv[] )
+  return TestMeshRefiner( argc, argv );
