[MOAB-dev] r1414 - MOAB/trunk
dcthomp at mcs.anl.gov dcthomp at mcs.anl.gov
Mon Nov 19 20:39:32 CST 2007
Author: dcthomp
Date: 2007-11-19 20:39:32 -0600 (Mon, 19 Nov 2007)
New Revision: 1414
Added:
   MOAB/trunk/MBEdgeSizeEvaluator.cpp
   MOAB/trunk/MBEdgeSizeEvaluator.hpp
Modified:
   MOAB/trunk/CMakeLists.txt
Log:
ENH: Some groundwork for mesh refinement.
Modified: MOAB/trunk/CMakeLists.txt
--- MOAB/trunk/CMakeLists.txt	2007-11-19 22:59:01 UTC (rev 1413)
+++ MOAB/trunk/CMakeLists.txt	2007-11-20 02:39:32 UTC (rev 1414)
@@ -120,6 +120,7 @@
     MBHandleUtils.cpp
     MBMatrix3.cpp
     MBCore.cpp
+    MBEdgeSizeEvaluator.cpp
     MBFactory.cpp
     MBGeomUtil.cpp
     MBMeshSet.cpp
Added: MOAB/trunk/MBEdgeSizeEvaluator.cpp
--- MOAB/trunk/MBEdgeSizeEvaluator.cpp	                        (rev 0)
+++ MOAB/trunk/MBEdgeSizeEvaluator.cpp	2007-11-20 02:39:32 UTC (rev 1414)
@@ -0,0 +1,50 @@
+#include "MBEdgeSizeEvaluator.hpp"
+#include "MBInterface.hpp"
+#include <assert.h>
+MBEdgeSizeEvaluator::MBEdgeSizeEvaluator( MBInterface* parentMesh )
+  assert( parentMesh );
+  this->mesh = parentMesh;
+  this->reset_vertex_tags();
+MBEdgeSizeEvaluator::~MBEdgeSizeEvaluator()
+void MBEdgeSizeEvaluator::reset_vertex_tags()
+  this->vertexSize = 0;
+  this->vertexTags.clear();
+int MBEdgeSizeEvaluator::add_vertex_tag( MBTag tag_handle )
+  int offset = this->vertexSize; // old size is offset of tag being added
+  int tagSize;
+  MBTagType tagType;
+  if ( this->mesh->tag_get_size( tag_handle, tagSize ) != MB_SUCCESS )
+    return -1;
+  if ( this->mesh->tag_get_type( tag_handle, tagType ) != MB_SUCCESS )
+    return -1;
+  if ( tagType == MB_TAG_BIT )
+    // Pad any bit tags to a size in full bytes.
+    tagSize = ( tagSize % 8 ? 1 : 0 ) + ( tagSize / 8 );
+  // Now pad so that the next tag will be word-aligned:
+  while ( tagSize % sizeof(int) )
+    ++tagSize;
+  this->vertexSize += tagSize;
+  this->vertexTags.push_back( std::pair< MBTag, int >( tag_handle, offset ) );
+  return offset;
Added: MOAB/trunk/MBEdgeSizeEvaluator.hpp
--- MOAB/trunk/MBEdgeSizeEvaluator.hpp	                        (rev 0)
+++ MOAB/trunk/MBEdgeSizeEvaluator.hpp	2007-11-20 02:39:32 UTC (rev 1414)
@@ -0,0 +1,79 @@
+ * MOAB, a Mesh-Oriented datABase, is a software component for creating,
+ * storing and accessing finite element mesh data.
+ * Copyright 2004 Sandia Corporation.  Under the terms of Contract
+ * DE-AC04-94AL85000 with Sandia Coroporation, the U.S. Government
+ * retains certain rights in this software.
+ * This library is free software; you can redistribute it and/or
+ * modify it under the terms of the GNU Lesser General Public
+ * License as published by the Free Software Foundation; either
+ * version 2.1 of the License, or (at your option) any later version.
+/** \class MBEdgeSizeEvaluator
+  * This is an abstract class that embodies the rule used during edge-based mesh
+  * refinement to decide whether an edge should be subdivided or not.
+  * Subclasses must implement the pure virtual evaluate_edge() function.
+  * \author David Thompson
+  * \date 19 November 2007
+#ifndef MB_EDGESIZEEVALUATOR_H
+#define MB_EDGESIZEEVALUATOR_H
+#include "MBTypes.h" // for MB_DLL_EXPORT
+#include <vector>
+class MBInterface;
+class MB_DLL_EXPORT MBEdgeSizeEvaluator
+public:
+  /// Construct an evaluator.
+  MBEdgeSizeEvaluator( MBInterface* parentMesh );
+  /// Destruction is virtual so subclasses may clean up after refinement.
+  virtual ~MBEdgeSizeEvaluator();
+  /** \brief Returns true if the edge \a p0 - \a p2 should be subdivided, false otherwise.
+    * The arguments \a p0, \a p1, and \a p2 are all pointers to arrays of 6 doubles each
+    * while the arguments \a t0, \a t1, and \a t2 are all pointers to arrays of tag data
+    * defined at the corresponding point. While the endpoints \a p0 and \a p2 are
+    * immutable, the mid-edge point coordinates \a p1 and tag data \a t1 may be altered by
+    * evaluate_edge(). Altered values will be ignored if evaluate_edge() returns false.
+    * Be careful to ensure that all calls to evaluate_edge() perform identical modifications
+    * given identical input values!
+    * A list of tags passed in \a t0, \a t1, and \a t2 is stored in the vertexTags member.
+    * The vertexSize member stores the total length of data associated with each pointer (in bytes).
+    * Subclasses may access vertexTags and vertexSize directly; the refiner uses public methods to
+    * populate vertexTags before evaluate_edge() is called.
+  virtual bool evaluate_edge(
+    const double* p0, const void* t0,
+    double* p1, void* t1,
+    const double* p2, const void* t2 ) = 0;
+  /// Clear the list of tag values that will appear past the vertex coordinates in \a p0, \a p1, and \a p2.
+  void reset_vertex_tags();
+  /** Add a tag to the list of tag values that will appear past the vertex coordinates.
+    * The return value is the offset into each vertex coordinate pointer (\a p0, \a p1, \a p2) where the
+    * tag value(s) will be stored.
+  int add_vertex_tag( MBTag tag_handle );
+  /// Return the number of bytes to allocate for tag data per point.
+  int get_vertex_tag_size() { return this->vertexSize; }
+protected:
+  std::vector< std::pair< MBTag, int > > vertexTags;
+  int vertexSize;
+  MBInterface* mesh;
+#endif // MB_EDGESIZEEVALUATOR_H
