[MOAB-dev] r1385 - in MOAB/trunk: . tools/dagmc
pebay at mcs.anl.gov pebay at mcs.anl.gov
Tue Nov 13 16:09:11 CST 2007
Author: pebay
Date: 2007-11-13 16:09:10 -0600 (Tue, 13 Nov 2007)
New Revision: 1385
Modified:
   MOAB/trunk/CMakeLists.txt
   MOAB/trunk/tools/dagmc/CMakeLists.txt
Log:
COMP: match changes in Makefile.am from rev. 1374.
Modified: MOAB/trunk/CMakeLists.txt
--- MOAB/trunk/CMakeLists.txt	2007-11-13 22:03:42 UTC (rev 1384)
+++ MOAB/trunk/CMakeLists.txt	2007-11-13 22:09:10 UTC (rev 1385)
@@ -102,7 +102,6 @@
     DenseTagCollections.cpp
     DualTool.cpp
     EntitySequence.cpp
-    EntitySequenceManager.cpp
     ExoIIUtil.cpp
     FileOptions.cpp
     FileTokenizer.cpp
@@ -133,15 +132,20 @@
     MBWriteUtil.cpp
     MeshSetSequence.cpp
     MeshTopoUtil.cpp
-    PolyEntitySequence.cpp
     ReadGmsh.cpp
     ReadSTL.cpp
     ReadVtk.cpp
-    ScdElementSeq.cpp
-    ScdVertexSeq.cpp
+    ScdElementData.cpp
+    ScdVertexData.cpp
+    SequenceData.cpp
+    SequenceManager.cpp
     SparseTagCollections.cpp
+    StructuredElementSeq.cpp
     TagServer.cpp
     Tqdcfr.cpp
+    TypeSequenceManager.cpp
+    UnstructuredElemSeq.cpp
+    VertexSequence.cpp
     VtkUtil.cpp
     WriteAns.cpp
     WriteGMV.cpp
@@ -270,6 +274,13 @@
   add_test( TestMOAB ${EXECUTABLE_OUTPUT_PATH}/moab_test -nostress )
   # FIXME: moab_test depends on: test/mb_big_test.g test/cell1.gen test/cell2.gen
+  add_executable( seq_man_test TestTypeSequenceManager.cpp )
+  target_link_libraries( seq_man_test MOAB )
+  set_source_files_properties( TestTypeSequenceManager.cpp
+    COMPILE_FLAGS "-DIS_BUILDING_MB ${MOAB_DEFINES}" )
+   add_test( TestTypeSequenceManager ${EXECUTABLE_OUTPUT_PATH}/seq_man_test )
+  # FIXME: moab_test depends on: test/mb_big_test.g test/cell1.gen test/cell2.gen
   add_executable( internals_test internals_test.cpp )
   set_source_files_properties( internals_test.cpp
Modified: MOAB/trunk/tools/dagmc/CMakeLists.txt
--- MOAB/trunk/tools/dagmc/CMakeLists.txt	2007-11-13 22:03:42 UTC (rev 1384)
+++ MOAB/trunk/tools/dagmc/CMakeLists.txt	2007-11-13 22:09:10 UTC (rev 1385)
@@ -32,7 +32,7 @@
   ${MOAB_DAGMC_LIB_SRCS}
 target_link_libraries( dagmc
-  moab
+  MOAB
 add_executable( test_geom
@@ -40,7 +40,7 @@
 target_link_libraries( test_geom
   dagmc
-  moab
+  MOAB
 if ( CGM_FOUND )
