[MOAB-dev] r1384 - MOAB/trunk
kraftche at mcs.anl.gov
Tue Nov 13 16:03:42 CST 2007
Author: kraftche
Date: 2007-11-13 16:03:42 -0600 (Tue, 13 Nov 2007)
New Revision: 1384
Modified:
MOAB/trunk/MBTest.cpp
Log:
check return value of MBCore::merge_entities when in mb_merge_test
Modified: MOAB/trunk/MBTest.cpp
--- MOAB/trunk/MBTest.cpp 2007-11-13 19:12:25 UTC (rev 1383)
+++ MOAB/trunk/MBTest.cpp 2007-11-13 22:03:42 UTC (rev 1384)
@@ -3854,9 +3854,11 @@
result = find_coincident_nodes(MB,nodes, coin_nodes);
cout <<"coin_nodes.size() = "<<coin_nodes.size() <<"\n";
std::vector< std::pair<MBEntityHandle, MBEntityHandle> >::iterator n_iter;
- for (n_iter=coin_nodes.begin(); n_iter != coin_nodes.end(); n_iter++)
- MB->merge_entities((*n_iter).first, (*n_iter).second, false, true);
+ for (n_iter=coin_nodes.begin(); n_iter != coin_nodes.end(); n_iter++) {
+ result = MB->merge_entities((*n_iter).first, (*n_iter).second, false, true);
+ if (MB_SUCCESS != result)
+ return result;
/* std::vector<std::pair<MBEntityHandle, MBEntityHandle> > coin_faces;
int nodes_per_elt = 4;
result = find_coincident_elements(forward_lower, nodes_per_elt, coin_faces);
