[MOAB-dev] r1372 - MOAB/trunk/mhdf/include
kraftche at mcs.anl.gov
Fri Nov 9 15:23:28 CST 2007
Author: kraftche
Date: 2007-11-09 15:23:27 -0600 (Fri, 09 Nov 2007)
New Revision: 1372
Modified:
MOAB/trunk/mhdf/include/mhdf.h
Log:
fix incorrect (outdated) comment
Modified: MOAB/trunk/mhdf/include/mhdf.h
--- MOAB/trunk/mhdf/include/mhdf.h 2007-11-09 16:19:55 UTC (rev 1371)
+++ MOAB/trunk/mhdf/include/mhdf.h 2007-11-09 21:23:27 UTC (rev 1372)
@@ -982,9 +982,10 @@
* Meshset data is divided into three groups of data. The set-list/meta-information table,
* the set contents table and the set children table. Each is written and read independently.
- * The set list table contains one row for each set. Each row contains three values:
- * {content list end index, child list end index, flags}. The flags is a collection of bits with
- * values from \ref mhdf_set_flag . The all the flags except \ref mhdf_SET_RANGE_BIT are
+ * The set list table contains one row for each set. Each row contains four values:
+ * {content list end index, child list end index, parent list end index, and flags}. The flags
+ * value is a collection of bits with
+ * values defined in \ref mhdf_set_flag . The all the flags except \ref mhdf_SET_RANGE_BIT are
* saved properties of the mesh data and are not relevant to the actual file in any way. The
* \ref mhdf_SET_RANGE_BIT flag is a toggle for how the meshset contents (not children) are saved.
* It is an internal property of the file format and should not be passed on to the mesh database.
