[MOAB-dev] r1370 - MOAB/trunk/test/perf
kraftche at mcs.anl.gov kraftche at mcs.anl.gov
Fri Nov 9 09:53:18 CST 2007
Author: kraftche
Date: 2007-11-09 09:53:17 -0600 (Fri, 09 Nov 2007)
New Revision: 1370
Modified:
   MOAB/trunk/test/perf/seqperf.cpp
Log:
fix typo in output
Modified: MOAB/trunk/test/perf/seqperf.cpp
--- MOAB/trunk/test/perf/seqperf.cpp	2007-11-08 22:18:47 UTC (rev 1369)
+++ MOAB/trunk/test/perf/seqperf.cpp	2007-11-09 15:53:17 UTC (rev 1370)
@@ -236,9 +236,9 @@
             << get_number_sequences(MBHEX) << " element sequences." << std::endl;
 #endif
-  TIME_QRY( "  Quering vertex coordinates", query_verts[order], percent );
-  TIME_QRY( "  Quering element connectivity", query_elems[order], percent );
-  TIME_QRY( "  Quering element coordinates", query_elem_verts[order], percent );
+  TIME_QRY( "  Querying vertex coordinates", query_verts[order], percent );
+  TIME_QRY( "  Querying element connectivity", query_elems[order], percent );
+  TIME_QRY( "  Querying element coordinates", query_elem_verts[order], percent );
   TIME_DEL( "  Re-creating vertices", create_missing_vertices, percent );
   TIME_DEL( "  Re-creating elements", create_missing_elements, percent );
