[MOAB-dev] r1494 - MOAB/trunk/refiner
pebay at mcs.anl.gov
Thu Dec 27 17:05:55 CST 2007
Author: pebay
Date: 2007-12-27 17:05:55 -0600 (Thu, 27 Dec 2007)
New Revision: 1494
Modified:
MOAB/trunk/refiner/MBSimplexTemplateRefiner.cpp
MOAB/trunk/refiner/MBSimplexTemplateRefiner.hpp
Log:
ENH: refiner checkpoint: 3-d refiner implemented
Modified: MOAB/trunk/refiner/MBSimplexTemplateRefiner.cpp
--- MOAB/trunk/refiner/MBSimplexTemplateRefiner.cpp 2007-12-27 21:26:15 UTC (rev 1493)
+++ MOAB/trunk/refiner/MBSimplexTemplateRefiner.cpp 2007-12-27 23:05:55 UTC (rev 1494)
@@ -6,6 +6,14 @@
#include <iostream>
#include <stack>
+#ifdef MB_DEBUG_TESSELLATOR
+# define MB_TESSELLATOR_INCR_CASE_COUNT(cs) this->case_counts[cs]++
+# define MB_TESSELLATOR_INCR_SUBCASE_COUNT(cs,sc) this->subcase_counts[cs][sc]++
+#else // MB_DEBUG_TESSELLATOR
+#endif // MB_DEBUG_TESSELLATOR
/// Construct a template refiner.
MBSimplexTemplateRefiner::MBSimplexTemplateRefiner( MBInterface* mesh )
: MBEntityRefiner( mesh )
@@ -273,10 +281,10 @@
/**\brief Refine a tetrahedron.
bool MBSimplexTemplateRefiner::refine_3_simplex( int max_depth,
- const double* v0, const void* t0,
- const double* v1, const void* t1,
- const double* v2, const void* t2,
- const double* v3, const void* t3 )
+ double* v0, void* t0,
+ double* v1, void* t1,
+ double* v2, void* t2,
+ double* v3, void* t3 )
bool edge_code = false;
@@ -294,16 +302,6 @@
void* midpt4t;
void* midpt5t;
- double* facept0c;
- double* facept1c;
- double* facept2c;
- double* facept3c;
- void* facept0t;
- void* facept1t;
- void* facept2t;
- void* facept3t;
if ( max_depth-- > 0 )
midpt0c = this->heap_coord_storage();
@@ -389,18 +387,36 @@
return false;
- const double* vertex_coords[10] = { v0, v1, v2, v3,
- midpt0c, midpt1c, midpt2c,
- midpt3c, midpt4c, midpt5c };
- const void* vertex_tags[10] = { t0, t1, t2, t3,
- midpt0t, midpt1t, midpt2t,
- midpt3t, midpt4t, midpt5t };
+ double* facept0c;
+ double* facept1c;
+ double* facept2c;
+ double* facept3c;
+ facept0c = this->heap_coord_storage();
+ facept1c = this->heap_coord_storage();
+ facept2c = this->heap_coord_storage();
+ facept3c = this->heap_coord_storage();
+ double* vertex_coords[14] = { v0, v1, v2, v3,
+ midpt0c, midpt1c, midpt2c,
+ midpt3c, midpt4c, midpt5c,
+ facept0c, facept1c, facept2c, facept3c };
+ void* facept0t;
+ void* facept1t;
+ void* facept2t;
+ void* facept3t;
+ facept0t = this->heap_tag_storage();
+ facept1t = this->heap_tag_storage();
+ facept2t = this->heap_tag_storage();
+ facept3t = this->heap_tag_storage();
+ void* vertex_tags[14] = { t0, t1, t2, t3,
+ midpt0t, midpt1t, midpt2t,
+ midpt3t, midpt4t, midpt5t,
+ facept0t, facept1t, facept2t, facept3t };
// Generate tetrahedra that are compatible except when edge
// lengths are equal on indeterminately subdivided faces.
- const double* permuted_coords[14];
- const void* permuted_tags[14];
+ double* permuted_coords[14];
+ void* permuted_tags[14];
double permlen[6]; // permuted edge lengths
int C = MBSimplexTemplateRefiner::template_index[edge_code][0];
int P = MBSimplexTemplateRefiner::template_index[edge_code][1];
@@ -412,32 +428,994 @@
permuted_tags[i] = vertex_tags[MBSimplexTemplateRefiner::permutations_from_index[P][i]];
- for ( int i = 4 ; i < 10; ++ i )
+ for ( int i = 4 ; i < 10; ++ i )
+ // permute edges too
+ permuted_coords[i] = vertex_coords[MBSimplexTemplateRefiner::permutations_from_index[P][i]];
+ permuted_tags[i] = vertex_tags[MBSimplexTemplateRefiner::permutations_from_index[P][i]];
+ permlen[i-4] = edge_length2[MBSimplexTemplateRefiner::permutations_from_index[P][i] - 4];
+ // Add our local (heap) storage for face point coordinates to the list.
+ permuted_coords[10] = facept0c;
+ permuted_coords[11] = facept1c;
+ permuted_coords[12] = facept2c;
+ permuted_coords[13] = facept3c;
+ permuted_tags[10] = facept0t;
+ permuted_tags[11] = facept1t;
+ permuted_tags[12] = facept2t;
+ permuted_tags[13] = facept3t;
+ int comparison_bits;
+ std::stack<int*> output_tets;
+ std::stack<int*> output_perm;
+ std::stack<int> output_sign;
+ // cout << "Case " << C << " Permutation " << P << endl;
+ // 2. Generate tetrahedra based on the configuration.
+ // Note that case 0 is handled above (edgeCode == 0).
+ switch ( C )
+ case 1: // Ruprecht-Müller Case 1
+ MB_TESSELLATOR_INCR_CASE_COUNT(0);
+ output_tets.push( MBSimplexTemplateRefiner::templates + 0 );
+ output_perm.push( MBSimplexTemplateRefiner::permutations_from_index[0] );
+ output_sign.push( 1 );
+ MB_TESSELLATOR_INCR_SUBCASE_COUNT(0,0);
+ break;
+ case 2: // Ruprecht-Müller Case 2a
+ comparison_bits =
+ (permlen[0] <= permlen[1] ? 1 : 0) | (permlen[0] >= permlen[1] ? 2 : 0) |
+ 0;
+ if ( (comparison_bits & 3) == 3 )
+ // Compute face point
+ for ( int i = 0; i < 6; ++ i )
+ permuted_coords[10][i] = (permuted_coords[0][i] + permuted_coords[2][i]) * .375 + permuted_coords[1][i] * .25;
+ MB_TESSELLATOR_INCR_CASE_COUNT(1);
+ output_tets.push( MBSimplexTemplateRefiner::templates + 9 );
+ MB_TESSELLATOR_INCR_SUBCASE_COUNT(1,0);
+ switch ( comparison_bits )
+ case 2: // 0>1
+ output_tets.push( MBSimplexTemplateRefiner::templates + 14 );
+ MB_TESSELLATOR_INCR_SUBCASE_COUNT(1,1);
+ break;
+ case 1: // 1>0
+ output_perm.push( MBSimplexTemplateRefiner::permutations_from_index[13] );
+ output_sign.push( -1 );
+ MB_TESSELLATOR_INCR_SUBCASE_COUNT(1,2);
+ break;
+ case 3: // 0=1
+ output_tets.push( MBSimplexTemplateRefiner::templates + 23 );
+ MB_TESSELLATOR_INCR_SUBCASE_COUNT(1,3);
+ break;
+ break;
+ case 3: // Ruprecht-Müller Case 2b
+ MB_TESSELLATOR_INCR_CASE_COUNT(2);
+ output_tets.push( MBSimplexTemplateRefiner::templates + 40 );
+ MB_TESSELLATOR_INCR_SUBCASE_COUNT(2,0);
+ break;
+ case 4: // Ruprecht-Müller Case 3a
+ comparison_bits =
+ (permlen[0] <= permlen[3] ? 1 : 0) | (permlen[0] >= permlen[3] ? 2 : 0) |
+ (permlen[2] <= permlen[3] ? 4 : 0) | (permlen[2] >= permlen[3] ? 8 : 0) |
+ (permlen[0] <= permlen[2] ? 16 : 0) | (permlen[0] >= permlen[2] ? 32 : 0) |
+ 0;
+ permuted_coords[11][i] = (permuted_coords[1][i] + permuted_coords[3][i]) * .375 + permuted_coords[0][i] * .25;
+ if ( (comparison_bits & 12) == 12 )
+ permuted_coords[13][i] = (permuted_coords[2][i] + permuted_coords[3][i]) * .375 + permuted_coords[0][i] * .25;
+ if ( (comparison_bits & 48) == 48 )
+ permuted_coords[10][i] = (permuted_coords[1][i] + permuted_coords[2][i]) * .375 + permuted_coords[0][i] * .25;
+ MB_TESSELLATOR_INCR_CASE_COUNT(3);
+ output_tets.push( MBSimplexTemplateRefiner::templates + 57 );
+ MB_TESSELLATOR_INCR_SUBCASE_COUNT(3,0);
+ case 42: // 0>2>3<0
+ output_tets.push( MBSimplexTemplateRefiner::templates + 62 );
+ MB_TESSELLATOR_INCR_SUBCASE_COUNT(3,1);
+ break;
+ case 25: // 2>3>0<2
+ output_perm.push( MBSimplexTemplateRefiner::permutations_from_index[11] );
+ MB_TESSELLATOR_INCR_SUBCASE_COUNT(3,2);
+ break;
+ case 37: // 3>0>2<3
+ output_perm.push( MBSimplexTemplateRefiner::permutations_from_index[3] );
+ MB_TESSELLATOR_INCR_SUBCASE_COUNT(3,3);
+ break;
+ case 21: // 3>2>0<3
+ output_perm.push( MBSimplexTemplateRefiner::permutations_from_index[22] );
+ MB_TESSELLATOR_INCR_SUBCASE_COUNT(3,4);
+ break;
+ case 26: // 2>0>3<2
+ output_perm.push( MBSimplexTemplateRefiner::permutations_from_index[12] );
+ MB_TESSELLATOR_INCR_SUBCASE_COUNT(3,5);
+ break;
+ case 38: // 0>3>2<0
+ output_perm.push( MBSimplexTemplateRefiner::permutations_from_index[15] );
+ MB_TESSELLATOR_INCR_SUBCASE_COUNT(3,6);
+ break;
+ case 58: // 0=2>3<0
+ output_tets.push( MBSimplexTemplateRefiner::templates + 75 );
+ MB_TESSELLATOR_INCR_SUBCASE_COUNT(3,7);
+ break;
+ case 29: // 2=3>0<2
+ MB_TESSELLATOR_INCR_SUBCASE_COUNT(3,8);
+ break;
+ case 39: // 0=3>2<0
+ MB_TESSELLATOR_INCR_SUBCASE_COUNT(3,9);
+ break;
+ case 53: // 3>0=2<3
+ output_tets.push( MBSimplexTemplateRefiner::templates + 96 );
+ MB_TESSELLATOR_INCR_SUBCASE_COUNT(3,10);
+ break;
+ case 46: // 0>2=3<0
+ MB_TESSELLATOR_INCR_SUBCASE_COUNT(3,11);
+ break;
+ case 27: // 2>0=3<2
+ MB_TESSELLATOR_INCR_SUBCASE_COUNT(3,12);
+ break;
+ case 63: // 0=2=3=0
+ output_tets.push( MBSimplexTemplateRefiner::templates + 117 );
+ MB_TESSELLATOR_INCR_SUBCASE_COUNT(3,13);
+ break;
+ break;
+ case 5: // Ruprecht-Müller Case 3b
+ MB_TESSELLATOR_INCR_CASE_COUNT(4);
+ output_tets.push( MBSimplexTemplateRefiner::templates + 162 );
+ MB_TESSELLATOR_INCR_SUBCASE_COUNT(4,0);
+ break;
+ case 6: // Ruprecht-Müller Case 3c
+ comparison_bits =
+ (permlen[0] <= permlen[3] ? 4 : 0) | (permlen[0] >= permlen[3] ? 8 : 0) |
+ 0;
+ MB_TESSELLATOR_INCR_CASE_COUNT(5);
+ case 10: // 0>1,0>3
+ output_tets.push( MBSimplexTemplateRefiner::templates + 179 );
+ MB_TESSELLATOR_INCR_SUBCASE_COUNT(5,0);
+ break;
+ case 5: // 1>0,3>0
+ output_tets.push( MBSimplexTemplateRefiner::templates + 200 );
+ MB_TESSELLATOR_INCR_SUBCASE_COUNT(5,1);
+ break;
+ case 6: // 0>1,3>0
+ output_tets.push( MBSimplexTemplateRefiner::templates + 221 );
+ MB_TESSELLATOR_INCR_SUBCASE_COUNT(5,2);
+ break;
+ case 9: // 1>0,0>3
+ output_tets.push( MBSimplexTemplateRefiner::templates + 242 );
+ MB_TESSELLATOR_INCR_SUBCASE_COUNT(5,3);
+ break;
+ case 11: // 0=1,0>3
+ output_tets.push( MBSimplexTemplateRefiner::templates + 263 );
+ MB_TESSELLATOR_INCR_SUBCASE_COUNT(5,4);
+ break;
+ case 14: // 0=3,0>1
+ output_perm.push( MBSimplexTemplateRefiner::permutations_from_index[5] );
+ MB_TESSELLATOR_INCR_SUBCASE_COUNT(5,5);
+ break;
+ case 7: // 3>0,0=1
+ output_tets.push( MBSimplexTemplateRefiner::templates + 292 );
+ MB_TESSELLATOR_INCR_SUBCASE_COUNT(5,6);
+ break;
+ case 13: // 1>0,0=3
+ MB_TESSELLATOR_INCR_SUBCASE_COUNT(5,7);
+ break;
+ case 15: // 0=1,0=3
+ output_tets.push( MBSimplexTemplateRefiner::templates + 321 );
+ MB_TESSELLATOR_INCR_SUBCASE_COUNT(5,8);
+ break;
+ break;
+ case 7: // Ruprecht-Müller Case 3d
+ comparison_bits =
+ (permlen[0] <= permlen[2] ? 1 : 0) | (permlen[0] >= permlen[2] ? 2 : 0) |
+ (permlen[0] <= permlen[4] ? 4 : 0) | (permlen[0] >= permlen[4] ? 8 : 0) |
+ 0;
+ permuted_coords[11][i] = (permuted_coords[0][i] + permuted_coords[3][i]) * .375 + permuted_coords[1][i] * .25;
+ MB_TESSELLATOR_INCR_CASE_COUNT(6);
+ case 10: // 0>4,0>2
+ output_tets.push( MBSimplexTemplateRefiner::templates + 362 );
+ MB_TESSELLATOR_INCR_SUBCASE_COUNT(6,0);
+ break;
+ case 5: // 4>0,2>0
+ output_tets.push( MBSimplexTemplateRefiner::templates + 383 );
+ MB_TESSELLATOR_INCR_SUBCASE_COUNT(6,1);
+ break;
+ case 9: // 0>4,2>0
+ output_tets.push( MBSimplexTemplateRefiner::templates + 404 );
+ MB_TESSELLATOR_INCR_SUBCASE_COUNT(6,2);
+ break;
+ case 6: // 4>0,0>2
+ output_tets.push( MBSimplexTemplateRefiner::templates + 425 );
+ MB_TESSELLATOR_INCR_SUBCASE_COUNT(6,3);
+ break;
+ case 14: // 0=4,0>2
+ output_tets.push( MBSimplexTemplateRefiner::templates + 446 );
+ MB_TESSELLATOR_INCR_SUBCASE_COUNT(6,4);
+ break;
+ case 11: // 0=2,0>4
+ MB_TESSELLATOR_INCR_SUBCASE_COUNT(6,5);
+ break;
+ case 13: // 2>0,0=4
+ output_tets.push( MBSimplexTemplateRefiner::templates + 475 );
+ MB_TESSELLATOR_INCR_SUBCASE_COUNT(6,6);
+ break;
+ case 7: // 4>0,0=2
+ MB_TESSELLATOR_INCR_SUBCASE_COUNT(6,7);
+ break;
+ case 15: // 0=4,0=2
+ output_tets.push( MBSimplexTemplateRefiner::templates + 504 );
+ MB_TESSELLATOR_INCR_SUBCASE_COUNT(6,8);
+ break;
+ break;
+ case 8: // Ruprecht-Müller Case 4a
+ comparison_bits =
+ (permlen[4] <= permlen[5] ? 1 : 0) | (permlen[4] >= permlen[5] ? 2 : 0) |
+ (permlen[3] <= permlen[4] ? 4 : 0) | (permlen[3] >= permlen[4] ? 8 : 0) |
+ 0;
+ permuted_coords[12][i] = (permuted_coords[1][i] + permuted_coords[2][i]) * .375 + permuted_coords[3][i] * .25;
+ permuted_coords[11][i] = (permuted_coords[0][i] + permuted_coords[1][i]) * .375 + permuted_coords[3][i] * .25;
+ MB_TESSELLATOR_INCR_CASE_COUNT(7);
+ output_tets.push( MBSimplexTemplateRefiner::templates + 545 );
+ MB_TESSELLATOR_INCR_SUBCASE_COUNT(7,0);
+ case 5: // 5>4>3
+ output_tets.push( MBSimplexTemplateRefiner::templates + 554 );
+ MB_TESSELLATOR_INCR_SUBCASE_COUNT(7,1);
+ break;
+ case 10: // 3>4>5
+ MB_TESSELLATOR_INCR_SUBCASE_COUNT(7,2);
+ break;
+ case 6: // 3<4>5
+ output_tets.push( MBSimplexTemplateRefiner::templates + 571 );
+ MB_TESSELLATOR_INCR_SUBCASE_COUNT(7,3);
+ break;
+ case 9: // 3>4<5
+ output_tets.push( MBSimplexTemplateRefiner::templates + 588 );
+ MB_TESSELLATOR_INCR_SUBCASE_COUNT(7,4);
+ break;
+ case 14: // 3=4>5
+ output_tets.push( MBSimplexTemplateRefiner::templates + 605 );
+ MB_TESSELLATOR_INCR_SUBCASE_COUNT(7,5);
+ break;
+ case 7: // 4=5,4>3
+ MB_TESSELLATOR_INCR_SUBCASE_COUNT(7,6);
+ break;
+ case 13: // 5>4,3=4
+ output_tets.push( MBSimplexTemplateRefiner::templates + 630 );
+ MB_TESSELLATOR_INCR_SUBCASE_COUNT(7,7);
+ break;
+ case 11: // 3>4=5
+ MB_TESSELLATOR_INCR_SUBCASE_COUNT(7,8);
+ break;
+ case 15: // 3=4=5
+ output_tets.push( MBSimplexTemplateRefiner::templates + 655 );
+ MB_TESSELLATOR_INCR_SUBCASE_COUNT(7,9);
+ break;
+ break;
+ case 9: // Ruprecht-Müller Case 4b
+ comparison_bits =
+ (permlen[1] <= permlen[2] ? 1 : 0) | (permlen[1] >= permlen[2] ? 2 : 0) |
+ (permlen[3] <= permlen[4] ? 16 : 0) | (permlen[3] >= permlen[4] ? 32 : 0) |
+ (permlen[1] <= permlen[4] ? 64 : 0) | (permlen[1] >= permlen[4] ? 128 : 0) |
+ 0;
+ permuted_coords[10][i] = (permuted_coords[1][i] + permuted_coords[0][i]) * .375 + permuted_coords[2][i] * .25;
+ if ( (comparison_bits & 192) == 192 )
+ permuted_coords[12][i] = (permuted_coords[2][i] + permuted_coords[3][i]) * .375 + permuted_coords[1][i] * .25;
+ MB_TESSELLATOR_INCR_CASE_COUNT(8);
+ case 85: // 2>1,3>2,4>3,4>1
+ output_tets.push( MBSimplexTemplateRefiner::templates + 688 );
+ MB_TESSELLATOR_INCR_SUBCASE_COUNT(8,0);
+ break;
+ case 102: // 1>2,3>2,3>4,4>1
+ output_perm.push( MBSimplexTemplateRefiner::permutations_from_index[14] );
+ MB_TESSELLATOR_INCR_SUBCASE_COUNT(8,1);
+ break;
+ case 170: // 1>2,2>3,3>4,1>4
+ MB_TESSELLATOR_INCR_SUBCASE_COUNT(8,2);
+ break;
+ case 153: // 2>1,2>3,4>3,1>4
+ MB_TESSELLATOR_INCR_SUBCASE_COUNT(8,3);
+ break;
+ case 90: // 1>2,2>3,4>3,4>1
+ output_perm.push( MBSimplexTemplateRefiner::permutations_from_index[9] );
+ MB_TESSELLATOR_INCR_SUBCASE_COUNT(8,4);
+ break;
+ case 105: // 2>1,2>3,3>4,4>1
+ output_perm.push( MBSimplexTemplateRefiner::permutations_from_index[7] );
+ MB_TESSELLATOR_INCR_SUBCASE_COUNT(8,5);
+ break;
+ case 165: // 2>1,3>2,3>4,1>4
+ output_perm.push( MBSimplexTemplateRefiner::permutations_from_index[19] );
+ MB_TESSELLATOR_INCR_SUBCASE_COUNT(8,6);
+ break;
+ case 150: // 1>2,3>2,4>3,1>4
+ output_perm.push( MBSimplexTemplateRefiner::permutations_from_index[23] );
+ MB_TESSELLATOR_INCR_SUBCASE_COUNT(8,7);
+ break;
+ case 101: // 2>1,3>2,3>4,4>1
+ int alternates[] = { 713, 738, -1 };
+ output_tets.push( MBSimplexTemplateRefiner::templates + this->best_tets( alternates, permuted_coords, 0, 1 ) );
+ MB_TESSELLATOR_INCR_SUBCASE_COUNT(8,8);
+ break;
+ case 86: // 1>2,3>2,4>3,4>1
+ int alternates[] = {713, 738, -1 };
+ output_tets.push( MBSimplexTemplateRefiner::templates + this->best_tets( alternates, permuted_coords, 14, -1 ) );
+ MB_TESSELLATOR_INCR_SUBCASE_COUNT(8,9);
+ break;
+ case 154: // 1>2,2>3,4>3,1>4
+ output_tets.push( MBSimplexTemplateRefiner::templates + this->best_tets( alternates, permuted_coords, 5, 1 ) );
+ MB_TESSELLATOR_INCR_SUBCASE_COUNT(8,10);
+ break;
+ case 169: // 2>1,2>3,3>4,1>4
+ output_tets.push( MBSimplexTemplateRefiner::templates + this->best_tets( alternates, permuted_coords, 15, -1 ) );
+ MB_TESSELLATOR_INCR_SUBCASE_COUNT(8,11);
+ break;
+ case 89: // 2>1,2>3,4>3,4>1
+ output_tets.push( MBSimplexTemplateRefiner::templates + 763 );
+ MB_TESSELLATOR_INCR_SUBCASE_COUNT(8,12);
+ break;
+ case 166: // 1>2,3>2,3>4,1>4
+ MB_TESSELLATOR_INCR_SUBCASE_COUNT(8,13);
+ break;
+ case 103: // 1=2,3>2,3>4,4>1
+ output_tets.push( MBSimplexTemplateRefiner::templates + 788 );
+ MB_TESSELLATOR_INCR_SUBCASE_COUNT(8,14);
+ break;
+ case 87: // 1=2,3>2,4>3,4>1
+ MB_TESSELLATOR_INCR_SUBCASE_COUNT(8,15);
+ break;
+ case 185: // 2>1,2>3,3=4,1>4
+ MB_TESSELLATOR_INCR_SUBCASE_COUNT(8,16);
+ break;
+ case 186: // 1>2,2>3,3=4,1>4
+ MB_TESSELLATOR_INCR_SUBCASE_COUNT(8,17);
+ break;
+ case 158: // 1>2,2=3,4>3,1>4
+ MB_TESSELLATOR_INCR_SUBCASE_COUNT(8,18);
+ break;
+ case 229: // 2>1,3>2,3>4,1=4
+ MB_TESSELLATOR_INCR_SUBCASE_COUNT(8,19);
+ break;
+ case 233: // 2>1,2>3,3>4,1=4
+ MB_TESSELLATOR_INCR_SUBCASE_COUNT(8,20);
+ break;
+ case 94: // 1>2,2=3,4>3,4>1
+ MB_TESSELLATOR_INCR_SUBCASE_COUNT(8,21);
+ break;
+ case 155: // 1=2,2>3,4>3,1>4
+ output_tets.push( MBSimplexTemplateRefiner::templates + 825 );
+ MB_TESSELLATOR_INCR_SUBCASE_COUNT(8,22);
+ break;
+ case 171: // 1=2,2>3,3>4,1>4
+ MB_TESSELLATOR_INCR_SUBCASE_COUNT(8,23);
+ break;
+ case 118: // 1>2,3>2,3=4,4>1
+ MB_TESSELLATOR_INCR_SUBCASE_COUNT(8,24);
+ break;
+ case 117: // 2>1,3>2,3=4,4>1
+ MB_TESSELLATOR_INCR_SUBCASE_COUNT(8,25);
+ break;
+ case 109: // 2>1,2=3,3>4,4>1
+ MB_TESSELLATOR_INCR_SUBCASE_COUNT(8,26);
+ break;
+ case 218: // 1>2,2>3,4>3,1=4
+ MB_TESSELLATOR_INCR_SUBCASE_COUNT(8,27);
+ break;
+ case 214: // 1>2,3>2,4>3,1=4
+ MB_TESSELLATOR_INCR_SUBCASE_COUNT(8,28);
+ break;
+ case 173: // 2>1,2=3,3>4,1>4
+ MB_TESSELLATOR_INCR_SUBCASE_COUNT(8,29);
+ break;
+ case 91: // 1=2,2>3,4>3,4>1
+ output_tets.push( MBSimplexTemplateRefiner::templates + 862 );
+ MB_TESSELLATOR_INCR_SUBCASE_COUNT(8,30);
+ break;
+ case 167: // 1=2,3>2,3>4,1>4
+ MB_TESSELLATOR_INCR_SUBCASE_COUNT(8,31);
+ break;
+ case 182: // 1>2,3>2,3=4,1>4
+ MB_TESSELLATOR_INCR_SUBCASE_COUNT(8,32);
+ break;
+ case 121: // 2>1,2>3,3=4,4>1
+ MB_TESSELLATOR_INCR_SUBCASE_COUNT(8,33);
+ break;
+ case 93: // 2>1,2=3,4>3,4>1
+ MB_TESSELLATOR_INCR_SUBCASE_COUNT(8,34);
+ break;
+ case 217: // 2>1,2>3,4>3,1=4
+ MB_TESSELLATOR_INCR_SUBCASE_COUNT(8,35);
+ break;
+ case 230: // 1>2,3>2,3>4,1=4
+ MB_TESSELLATOR_INCR_SUBCASE_COUNT(8,36);
+ break;
+ case 174: // 1>2,2=3,3>4,1>4
+ MB_TESSELLATOR_INCR_SUBCASE_COUNT(8,37);
+ break;
+ case 119: // 1=2,3>2,3=4,4>1
+ output_tets.push( MBSimplexTemplateRefiner::templates + 899 );
+ MB_TESSELLATOR_INCR_SUBCASE_COUNT(8,38);
+ break;
+ case 187: // 1=2>3=4,1>4
+ MB_TESSELLATOR_INCR_SUBCASE_COUNT(8,39);
+ break;
+ case 222: // 1>2,2=3,4>3,1=4
+ MB_TESSELLATOR_INCR_SUBCASE_COUNT(8,40);
+ break;
+ case 237: // 2>1,2=3,3>4,1=4
+ MB_TESSELLATOR_INCR_SUBCASE_COUNT(8,41);
+ break;
+ case 95: // 4>1=2=3,4>3
+ output_tets.push( MBSimplexTemplateRefiner::templates + 944 );
+ MB_TESSELLATOR_INCR_SUBCASE_COUNT(8,42);
+ break;
+ case 231: // 1=2,3>2,3>4,1=4
+ MB_TESSELLATOR_INCR_SUBCASE_COUNT(8,43);
+ break;
+ case 190: // 1>2=3=4,1>4
+ MB_TESSELLATOR_INCR_SUBCASE_COUNT(8,44);
+ break;
+ case 249: // 2>1,2>3,3=4,1=4
+ MB_TESSELLATOR_INCR_SUBCASE_COUNT(8,45);
+ break;
+ case 175: // 1=2=3>4,1>4
+ output_tets.push( MBSimplexTemplateRefiner::templates + 993 );
+ MB_TESSELLATOR_INCR_SUBCASE_COUNT(8,46);
+ break;
+ case 219: // 1=2>3,4>3,1=4
+ MB_TESSELLATOR_INCR_SUBCASE_COUNT(8,47);
+ break;
+ case 125: // 2>1,2=3=4>1
+ MB_TESSELLATOR_INCR_SUBCASE_COUNT(8,48);
+ break;
+ case 246: // 1>2,3>2,3=4=1
+ MB_TESSELLATOR_INCR_SUBCASE_COUNT(8,49);
+ break;
+ case 255: // 1=2=3=4=1
+ output_tets.push( MBSimplexTemplateRefiner::templates + 1042 );
+ MB_TESSELLATOR_INCR_SUBCASE_COUNT(8,50);
+ break;
+ break;
+ case 10: // Ruprecht-Müller Case 5
+ comparison_bits =
+ 0;
+ MB_TESSELLATOR_INCR_CASE_COUNT(9);
+ output_tets.push( MBSimplexTemplateRefiner::templates + 1107 );
+ MB_TESSELLATOR_INCR_SUBCASE_COUNT(9,0);
+ case 10: // 1>2,3>4
+ output_tets.push( MBSimplexTemplateRefiner::templates + 1116 );
+ MB_TESSELLATOR_INCR_SUBCASE_COUNT(9,1);
+ break;
+ case 5: // 2>1,4>3
+ MB_TESSELLATOR_INCR_SUBCASE_COUNT(9,2);
+ break;
+ case 6: // 1>2,4>3
+ int alternates[] = { 1137, 1158, -1 };
+ MB_TESSELLATOR_INCR_SUBCASE_COUNT(9,3);
+ break;
+ case 9: // 2>1,3>4
+ int alternates[] = {1137, 1158, -1 };
+ MB_TESSELLATOR_INCR_SUBCASE_COUNT(9,4);
+ break;
+ case 11: // 1=2,3>4
+ int alternates[] = { 1179, 1212, 1245, -1 };
+ MB_TESSELLATOR_INCR_SUBCASE_COUNT(9,5);
+ break;
+ case 7: // 1=2,4>3
+ int alternates[] = {1179, 1212, 1245, -1 };
+ MB_TESSELLATOR_INCR_SUBCASE_COUNT(9,6);
+ break;
+ case 14: // 3=4,1>2
+ MB_TESSELLATOR_INCR_SUBCASE_COUNT(9,7);
+ break;
+ case 13: // 3=4,2>1
+ MB_TESSELLATOR_INCR_SUBCASE_COUNT(9,8);
+ break;
+ case 15: // 1=2,3=4
+ output_tets.push( MBSimplexTemplateRefiner::templates + 1278 );
+ MB_TESSELLATOR_INCR_SUBCASE_COUNT(9,9);
+ break;
+ break;
+ case 11: // Ruprecht-Müller Case 6
+ MB_TESSELLATOR_INCR_CASE_COUNT(10);
+ output_tets.push( MBSimplexTemplateRefiner::templates + 1319 );
+ MB_TESSELLATOR_INCR_SUBCASE_COUNT(10,0);
+ int alternates[] = { 1336, 1353, 1370, -1 };
+ MB_TESSELLATOR_INCR_SUBCASE_COUNT(10,1);
+ break;
+ int* tets;
+ int ntets;
+ int* perm;
+ int sgn;
+ if ( output_tets.empty() )
+ cout << "Argh! Case " << C << " Perm " << P << " has no output!" << endl;
+ while ( ! output_tets.empty() )
+ tets = output_tets.top();
+ ntets = *tets;
+ tets++;
+ perm = output_perm.top();
+ sgn = output_sign.top();
+ output_tets.pop();
+ output_perm.pop();
+ output_sign.pop();
+ int t;
+ if ( sgn > 0 )
- // permute edges too
- permuted_coords[i] = vertex_coords[MBSimplexTemplateRefiner::permutations_from_index[P][i]];
- permuted_tags[i] = vertex_tags[MBSimplexTemplateRefiner::permutations_from_index[P][i]];
- permlen[i-4] = edge_length2[MBSimplexTemplateRefiner::permutations_from_index[P][i] - 4];
+ for ( t = 0; t < ntets; ++t )
+ this->refine_3_simplex( max_depth,
+ permuted_coords[perm[tets[0]]],
+ permuted_tags[perm[tets[0]]],
+ permuted_coords[perm[tets[1]]],
+ permuted_tags[perm[tets[1]]],
+ permuted_coords[perm[tets[2]]],
+ permuted_tags[perm[tets[2]]],
+ permuted_coords[perm[tets[3]]],
+ permuted_tags[perm[tets[3]]] );
+ tets += 4;
- // Add our local (heap) storage for face point coordinates to the list.
- permuted_coords[10] = facept0c;
- permuted_coords[11] = facept1c;
- permuted_coords[12] = facept2c;
- permuted_coords[13] = facept3c;
- permuted_tags[10] = facept0t;
- permuted_tags[11] = facept1t;
- permuted_tags[12] = facept2t;
- permuted_tags[13] = facept3t;
+ else
+ // we have an inverted tet... reverse the first 2 vertices
+ // so the orientation is positive.
+ tets += 4;
- int comparison_bits;
- std::stack<int*> output_tets;
- std::stack<int*> output_perm;
- std::stack<int> output_sign;
- // cout << "Case " << C << " Permutation " << P << endl;
- // 2. Generate tetrahedra based on the configuration.
- // Note that case 0 is handled above (edgeCode == 0).
return true;
@@ -451,7 +1429,7 @@
double sq_mag_a = 0.;
double sq_mag_b = 0.;
- for (int i=0; i<3; i++)
+ for ( int i = 0; i < 3; ++ i )
double tmp;
tmp = a0[i] - a1[i];
Modified: MOAB/trunk/refiner/MBSimplexTemplateRefiner.hpp
--- MOAB/trunk/refiner/MBSimplexTemplateRefiner.hpp 2007-12-27 21:26:15 UTC (rev 1493)
+++ MOAB/trunk/refiner/MBSimplexTemplateRefiner.hpp 2007-12-27 23:05:55 UTC (rev 1494)
@@ -51,11 +51,13 @@
bool refine_2_simplex( int max_depth, int move,
const double* v0, const void* t0, const double* v1, const void* t1, const double* v2, const void* t2 );
bool refine_3_simplex( int max_depth,
- const double* v3, const void* t3 );
+ double* v3, void* t3 );
static bool compare_Hopf_cross_string_dist( const double* v00, const double* v01, const double* v10, const double* v11 );
+ int best_tets( int* alternates, double*[14], int, int ) { return alternates[0]; }
#endif // MB_SIMPLEXTEMPLATEREFINER_H
