[MOAB-dev] r1493 - MOAB/trunk/refiner
    pebay at mcs.anl.gov
    Thu Dec 27 15:26:15 CST 2007
Author: pebay
Date: 2007-12-27 15:26:15 -0600 (Thu, 27 Dec 2007)
New Revision: 1493
Modified:
   MOAB/trunk/refiner/MBEdgeSizeEvaluator.cpp
   MOAB/trunk/refiner/MBEdgeSizeEvaluator.hpp
   MOAB/trunk/refiner/MBRefiner.cpp
   MOAB/trunk/refiner/MBSimplexTemplateRefiner.cpp
   MOAB/trunk/refiner/MBSimplexTemplateRefiner.hpp
Log:
ENH: refiner checkpoint -- 0, 1, and 2 d cases done, 3 d case
     infrastructure done.
Modified: MOAB/trunk/refiner/MBEdgeSizeEvaluator.cpp
--- MOAB/trunk/refiner/MBEdgeSizeEvaluator.cpp	2007-12-27 19:42:29 UTC (rev 1492)
+++ MOAB/trunk/refiner/MBEdgeSizeEvaluator.cpp	2007-12-27 21:26:15 UTC (rev 1493)
@@ -92,8 +92,9 @@
   * @param[in] c1 Pointer to endpoint 1 coordinates. The parametric coordinates (3) are followed by world coordinates (3).
   * @param[in] t1 Pointer to endpoint 1 tag values.
-void MBEdgeSizeEvaluator::evaluate_tags_at_midpoint(
-  const double* c0, const void* t0, double* cm, void* tm, const double* c1, const void* t1 ) const
+void MBEdgeSizeEvaluator::evaluate_tags_at_midpoint( const double* c0, const void* t0,
+                                                     const double* cm, void* tm,
+                                                     const double* c1, const void* t1 ) const
Modified: MOAB/trunk/refiner/MBEdgeSizeEvaluator.hpp
--- MOAB/trunk/refiner/MBEdgeSizeEvaluator.hpp	2007-12-27 19:42:29 UTC (rev 1492)
+++ MOAB/trunk/refiner/MBEdgeSizeEvaluator.hpp	2007-12-27 21:26:15 UTC (rev 1493)
@@ -48,7 +48,7 @@
   int get_vertex_tag_size() { return this->vertexSize; }
   void evaluate_tags_at_midpoint(
-    double* cm, void* tm,
     const double* c1, const void* t1 ) const;
 protected:
Modified: MOAB/trunk/refiner/MBRefiner.cpp
--- MOAB/trunk/refiner/MBRefiner.cpp	2007-12-27 19:42:29 UTC (rev 1492)
+++ MOAB/trunk/refiner/MBRefiner.cpp	2007-12-27 21:26:15 UTC (rev 1493)
@@ -1510,10 +1510,10 @@
       outputPerm.push( MBRefiner::PermutationsFromIndex[0] );
       outputSign.push( 1 );
       VTK_TESSELLATOR_INCR_SUBCASE_COUNT(10,0);
         int alternates[] = { 1336, 1353, 1370, -1 };
         outputTets.push( MBRefiner::TetrahedralDecompositions + this->BestTets( alternates, permuted, 0, 1 ) );
       VTK_TESSELLATOR_INCR_SUBCASE_COUNT(10,1);
@@ -1571,689 +1571,3 @@
- * The array below is indexed by the edge code for a tetrahedron.
- * Looking up a row with a tet's edge code will return C and P.
- * C is a configuration number and P is a permutation index.
- * C is based on the case number from Ruprecht and
- * Müller's (1998) paper on adaptive tetrahedra. (The case
- * numbers are shown to the left of the row in the column
- * labeled case. The only difference is that we introduce
- * a case 3d which is part of case 3c in the paper.)
- * P is an index into the MBRefiner::PermutationsFromIndex array below,
- * and is used to transform the current tetrahedron into
- * the canonical configuration associated with C.
- * The 6-digit binary number to the left (which is shown in
- * the horribly UNconventional LSB->MSB order) is the edge
- * code for the row. The 6 digits correspond to the 6 edges
- * of the tetrahedron; a '0' implies no subdivision while
- * a '1' implies subdivision should occur. The ordering of
- * the bits is
- * Edge 0-1, Edge 1-2, Edge 2-0, Edge 0-3, Edge 1-3, Edge 2-3,
- * where the numbers are vertices of the tetrahedron 0-1-2-3.
- * Note that Tet 0-1-2-3 must be positive (i.e., the plane
- * specified by Triangle 0-1-2 must have a normal pointing
- * towards vertex 3, and Triangle 0-1-2's normal must be
- * calculated using the cross-product (Edge 0-1) x (Edge 0-2)).
- * References:
- * (Ruprect and Müller, 1998) A Scheme for Edge-based Adaptive
- *   Tetrahedron Subdivision, Mathematical Visualization (eds.
- *   Hege and Polthier), pp. 61--70. Springer-Verlag. 1998.
-int MBRefiner::EdgeCodesToCaseCodesPlusPermutation[64][2] =
-  /*      code case      C    P */
-  /* 000000  0  0  */ {  0,   0 },
-  /* 100000  1  1  */ {  1,   0 },
-  /* 010000  2  1  */ {  1,   1 },
-  /* 110000  3  2a */ {  2,   0 },
-  /* 001000  4  1  */ {  1,   2 },
-  /* 101000  5  2a */ {  2,   2 },
-  /* 011000  6  2a */ {  2,   1 },
-  /* 111000  7  3b */ {  5,  11 },
-  /* 000100  8  1  */ {  1,  10 },
-  /* 100100  9  2a */ {  2,   5 },
-  /* 010100 10  2b */ {  3,   1 },
-  /* 110100 11  3c */ {  6,   0 },
-  /* 001100 12  2a */ {  2,  10 },
-  /* 101100 13  3a */ {  4,   0 },
-  /* 011100 14  3d */ {  7,   2 },
-  /* 111100 15  4a */ {  8,   6 },
-  /* 000010 16  1  */ {  1,   6 },
-  /* 100010 17  2a */ {  2,   4 },
-  /* 010010 18  2a */ {  2,   8 },
-  /* 110010 19  3a */ {  4,   1 },
-  /* 001010 20  2b */ {  3,   2 },
-  /* 101010 21  3d */ {  7,   0 },
-  /* 011010 22  3c */ {  6,   1 },
-  /* 111010 23  4a */ {  8,   9 },
-  /* 000110 24  2a */ {  2,   3 },
-  /* 100110 25  3b */ {  5,   0 },
-  /* 010110 26  3d */ {  7,   4 },
-  /* 110110 27  4a */ {  8,  11 },
-  /* 001110 28  3c */ {  6,  10 },
-  /* 101110 29  4a */ {  8,   7 },
-  /* 011110 30  4b */ {  9,   0 },
-  /* 111110 31  5  */ { 10,   7 },
-  /* 000001 32  1  */ {  1,   7 },
-  /* 100001 33  2b */ {  3,   0 },
-  /* 010001 34  2a */ {  2,   7 },
-  /* 110001 35  3d */ {  7,   1 },
-  /* 001001 36  2a */ {  2,  11 },
-  /* 101001 37  3c */ {  6,   2 },
-  /* 011001 38  3a */ {  4,   2 },
-  /* 111001 39  4a */ {  8,   3 },
-  /* 000101 40  2a */ {  2,   9 },
-  /* 100101 41  3d */ {  7,  10 },
-  /* 010101 42  3c */ {  6,   7 },
-  /* 110101 43  4b */ {  9,   2 },
-  /* 001101 44  3b */ {  5,   7 },
-  /* 101101 45  4a */ {  8,   8 },
-  /* 011101 46  4a */ {  8,   4 },
-  /* 111101 47  5  */ { 10,   6 },
-  /* 000011 48  2a */ {  2,   6 },
-  /* 100011 49  3c */ {  6,   4 },
-  /* 010011 50  3b */ {  5,   1 },
-  /* 110011 51  4a */ {  8,  10 },
-  /* 001011 52  3d */ {  7,   7 },
-  /* 101011 53  4b */ {  9,   1 },
-  /* 011011 54  4a */ {  8,   5 },
-  /* 111011 55  5  */ { 10,  10 },
-  /* 000111 56  3a */ {  4,  10 },
-  /* 100111 57  4a */ {  8,   1 },
-  /* 010111 58  4a */ {  8,   2 },
-  /* 110111 59  5  */ { 10,   2 },
-  /* 001111 60  4a */ {  8,   0 },
-  /* 101111 61  5  */ { 10,   1 },
-  /* 011111 62  5  */ { 10,   0 },
-  /* 111111 63  6  */ { 11,   0 },
-/* Does this mean anything? If so, then you are either
- * superstitious or much more clever than I (or both?).
-/* permutation index, P:  0  1  2  3  4  5  6  7  8  9 10 11 */
-/* number of references: 12  9  9  3  4  2  5  6  2  3  7  2 */
- * The array below is a list of all the _positive_
- * permutations of Tetrahedron 0-1-2-3. Given a
- * permutation index, it returns a row of 14 values:
- * these are the vertex numbers of the permuted
- * tetrahedron. The first 4 values are the permuted
- * corner indices, the next 6 values are the
- * permuted edge midpoint indices, and the final
- * entries reference mid-face points inserted
- * to maintain a compatible tetrahedralization.
- * There are 24 entries, 6 for each of the 4 faces of
- * the tetrahedron.
-vtkIdType MBRefiner::PermutationsFromIndex[24][14] =
-  /* corners      midpoints          face points   */
-  /* POSITIVE ARRANGEMENTS                         */
-  { 0, 1, 2, 3,   4, 5, 6, 7, 8, 9,  10, 11, 12, 13 }, /* Face 0-1-2 */
-  { 1, 2, 0, 3,   5, 6, 4, 8, 9, 7,  10, 12, 13, 11 },
-  { 2, 0, 1, 3,   6, 4, 5, 9, 7, 8,  10, 13, 11, 12 },
-  { 0, 3, 1, 2,   7, 8, 4, 6, 9, 5,  11, 13, 12, 10 }, /* Face 0-3-1 */
-  { 3, 1, 0, 2,   8, 4, 7, 9, 5, 6,  11, 12, 10, 13 },
-  { 1, 0, 3, 2,   4, 7, 8, 5, 6, 9,  11, 10, 13, 12 },
-  { 1, 3, 2, 0,   8, 9, 5, 4, 7, 6,  12, 11, 13, 10 }, /* Face 1-3-2 */
-  { 3, 2, 1, 0,   9, 5, 8, 7, 6, 4,  12, 13, 10, 11 },
-  { 2, 1, 3, 0,   5, 8, 9, 6, 4, 7,  12, 10, 11, 13 },
-  { 2, 3, 0, 1,   9, 7, 6, 5, 8, 4,  13, 12, 11, 10 }, /* Face 2-3-0 */
-  { 3, 0, 2, 1,   7, 6, 9, 8, 4, 5,  13, 11, 10, 12 },
-  { 0, 2, 3, 1,   6, 9, 7, 4, 5, 8,  13, 10, 12, 11 },
-  /* NEGATIVE ARRANGEMENTS                         */
-  { 0, 2, 1, 3,   6, 5, 4, 7, 9, 8,  10, 13, 12, 11 }, /* Face 0-1-2 */
-  { 2, 1, 0, 3,   5, 4, 6, 9, 8, 7,  10, 12, 11, 13 },
-  { 1, 0, 2, 3,   4, 6, 5, 8, 7, 9,  10, 11, 13, 12 },
-  { 0, 1, 3, 2,   4, 8, 7, 6, 5, 9,  11, 10, 12, 13 }, /* Face 0-3-1 */
-  { 1, 3, 0, 2,   8, 7, 4, 5, 9, 6,  11, 12, 13, 10 },
-  { 3, 0, 1, 2,   7, 4, 8, 9, 6, 5,  11, 13, 10, 12 },
-  { 1, 2, 3, 0,   5, 9, 8, 4, 6, 7,  12, 10, 13, 11 }, /* Face 1-3-2 */
-  { 2, 3, 1, 0,   9, 8, 5, 6, 7, 4,  12, 13, 11, 10 },
-  { 3, 1, 2, 0,   8, 5, 9, 7, 4, 6,  12, 11, 10, 13 },
-  { 2, 0, 3, 1,   6, 7, 9, 5, 4, 8,  13, 10, 11, 12 }, /* Face 2-3-0 */
-  { 0, 3, 2, 1,   7, 9, 6, 4, 8, 5,  13, 11, 12, 10 },
-  { 3, 2, 0, 1,   9, 6, 7, 8, 5, 4,  13, 12, 10, 11 }
- * Below is a list of output tetrahedra. The array is
- * generated by TessellatorGenerator.py
- * which also generates the code that references it.
- * Each set of tetrahedra begins with a single integer
- * that is the number of tetrahedra for that particular
- * case. It is followed by 5 integers for each output
- * tetrahedron; the first four numbers on each row are
- * indices of the output tetrahedron. The final number
- * is a bit vector specifying which edges of the
- * tetrahedron are internal to the parent tetrahedron
- * being decomposed.
- * Multiple lists of output tetrahedra may be
- * combined to create the tessellation of a single
- * input tetrahedron.
-vtkIdType MBRefiner::TetrahedralDecompositions[] =
-// case 1_0
-   2,
-   0,  4,  2,  3,
-   4,  1,  2,  3,
-// case 2a_0
-   1,
-   3,  4,  5,  1,
-// case 2a, 0>1
-   2,
-   0,  4,  2,  3,
-   4,  5,  2,  3,
-// case 2a, 0=1
-   4,
-  10,  3,  0,  4,
-  10,  3,  4,  5,
-  10,  3,  5,  2,
-  10,  3,  2,  0,
-// case 2b_0
-   4,
-   0,  4,  9,  3,
-   4,  1,  9,  3,
-   0,  4,  2,  9,
-   4,  1,  2,  9,
-// case 3a_0
-   1,
-   4,  7,  6,  0,
-// case 3a, 0>2>3<0
-   3,
-   1,  3,  2,  4,
-   4,  6,  3,  2,
-   4,  6,  7,  3,
-// case 3a, 0=2>3<0
-   5,
-   4,  6,  7,  3,
-  10,  1,  2,  3,
-  10,  2,  6,  3,
-  10,  6,  4,  3,
-  10,  4,  1,  3,
-// case 3a, 3>0=2<3
-   5,
-   1,  3,  2,  7,
-  10,  1,  2,  7,
-  10,  2,  6,  7,
-  10,  6,  4,  7,
-  10,  4,  1,  7,
-// case 3a, 0=2=3=0
-  11,
-   2,  6, 10, 13,
-   3,  7, 13, 11,
-   4,  1, 10, 11,
-  11,  6, 10,  4,
-  11,  6, 13, 10,
-  11,  6,  7, 13,
-  11,  6,  4,  7,
-   2, 10, 11, 13,
-   1, 10, 11,  2,
-   2, 11,  3, 13,
-   3,  2,  1, 11,
-// case 3b_0
-   4,
-   0,  7,  4,  2,
-   4,  7,  8,  2,
-   4,  8,  1,  2,
-   7,  3,  8,  2,
-// case 3c, 0>1,0>3
-   5,
-   4,  2,  7,  5,
-   4,  2,  0,  7,
-   4,  3,  1,  5,
-   4,  3,  5,  7,
-   3,  5,  7,  2,
-// case 3c, 1>0,3>0
-   5,
-   0,  5,  2,  7,
-   0,  5,  7,  4,
-   7,  1,  4,  5,
-   7,  1,  5,  3,
-   3,  5,  7,  2,
-// case 3c, 0>1,3>0
-   5,
-   4,  2,  7,  5,
-   4,  2,  0,  7,
-   7,  1,  4,  5,
-   7,  1,  5,  3,
-   3,  5,  7,  2,
-// case 3c, 1>0,0>3
-   5,
-   0,  5,  2,  7,
-   0,  5,  7,  4,
-   4,  3,  1,  5,
-   4,  3,  5,  7,
-   3,  5,  7,  2,
-// case 3c, 0=1,0>3
-   7,
-   4,  1,  5,  3,
-  10,  0,  4,  7,
-  10,  2,  0,  7,
-  10,  7,  4,  3,
-  10,  2,  7,  3,
-  10,  5,  2,  3,
-  10,  4,  5,  3,
-// case 3c, 3>0,0=1
-   7,
-   7,  1,  5,  3,
-   7,  5,  2,  3,
-  10,  0,  4,  7,
-  10,  2,  0,  7,
-  10,  5,  2,  7,
-  10,  4,  5,  7,
-   1,  5,  4,  7,
-// case 3c, 0=1,0=3
-  10,
-   4,  1,  5, 11,
-  11,  1,  5,  3,
-  10,  0,  4,  7,
-  10,  2,  0,  7,
-  10,  5,  2,  3,
-  10,  2,  7,  3,
-  10,  7,  4, 11,
-  10,  7, 11,  3,
-  10,  4,  5, 11,
-  10, 11,  5,  3,
-// case 3d, 0>4,0>2
-   5,
-   4,  3,  6,  0,
-   4,  3,  8,  6,
-   4,  2,  8,  1,
-   4,  2,  6,  8,
-   2,  3,  6,  8,
-// case 3d, 4>0,2>0
-   5,
-   8,  0,  6,  4,
-   8,  0,  3,  6,
-   6,  1,  8,  4,
-   6,  1,  2,  8,
-   2,  3,  6,  8,
-// case 3d, 0>4,2>0
-   5,
-   4,  3,  6,  0,
-   4,  3,  8,  6,
-   6,  1,  8,  4,
-   6,  1,  2,  8,
-   2,  3,  6,  8,
-// case 3d, 4>0,0>2
-   5,
-   8,  0,  6,  4,
-   8,  0,  3,  6,
-   4,  2,  8,  1,
-   4,  2,  6,  8,
-   2,  3,  6,  8,
-// case 3d, 0=4,0>2
-   7,
-   4,  1,  2,  8,
-  11,  4,  0,  6,
-  11,  0,  3,  6,
-  11,  2,  4,  6,
-  11,  3,  2,  6,
-  11,  3,  8,  2,
-  11,  8,  4,  2,
-// case 3d, 2>0,0=4
-   7,
-   6,  2,  8,  1,
-   6,  8,  2,  3,
-  11,  4,  0,  6,
-  11,  0,  3,  6,
-   8, 11,  3,  6,
-   8,  4, 11,  6,
-   1,  6,  4,  8,
-// case 3d, 0=4,0=2
-  10,
-   4,  1, 10,  8,
-  10,  2,  8,  1,
-  11,  4,  0,  6,
-  11,  0,  3,  6,
-  11,  3,  8,  2,
-  11,  3,  2,  6,
-  11, 10,  4,  6,
-  11, 10,  6,  2,
-   8,  4, 11, 10,
-  11, 10,  2,  8,
-// case 4a_0
-   2,
-   7,  8,  9,  3,
-   7,  9,  8,  6,
-// case 4a, 5>4>3
-   4,
-   8,  0,  6,  1,
-   8,  0,  7,  6,
-   9,  1,  6,  2,
-   9,  1,  8,  6,
-// case 4a, 3<4>5
-   4,
-   8,  0,  6,  1,
-   8,  0,  7,  6,
-   8,  2,  6,  9,
-   8,  2,  1,  6,
-// case 4a, 3>4<5
-   4,
-   6,  9,  8,  1,
-   6,  9,  1,  2,
-   6,  7,  0,  1,
-   6,  7,  1,  8,
-// case 4a, 3=4>5
-   6,
-   6,  7,  0, 11,
-   6,  0,  1, 11,
-   6,  7, 11,  8,
-   6, 11,  1,  8,
-   1,  2,  6,  8,
-   2,  6,  8,  9,
-// case 4a, 5>4,3=4
-   6,
-   6,  7,  0, 11,
-   6,  0,  1, 11,
-   6,  7, 11,  8,
-   6, 11,  1,  8,
-   1,  2,  6,  9,
-   1,  6,  8,  9,
-// case 4a, 3=4=5
-   8,
-   6,  7,  0, 11,
-   6,  0,  1, 11,
-   6,  7, 11,  8,
-   6, 11,  1,  8,
-   6,  1,  2, 12,
-   6,  2,  9, 12,
-   6,  9,  8, 12,
-   6,  8,  1, 12,
-// case 4b, 2>1,3>2,4>3,4>1
-   6,
-   6,  8,  1,  5,
-   6,  8,  0,  1,
-   6,  8,  7,  0,
-   6,  8,  2,  7,
-   7,  8,  2,  3,
-   6,  8,  5,  2,
-// case 4b, 2>1,3>2,3>4,4>1
-   6,
-   6,  8,  1,  5,
-   6,  8,  7,  1,
-   6,  7,  0,  1,
-   8,  7,  3,  2,
-   6,  8,  5,  2,
-   6,  8,  2,  7,
-// case 4b, 2>1,3>2,3>4,4>1, a
-   6,
-   7,  8,  1,  5,
-   6,  5,  7,  1,
-   6,  7,  0,  1,
-   8,  7,  3,  2,
-   7,  8,  5,  2,
-   6,  5,  2,  7,
-// case 4b, 2>1,2>3,4>3,4>1
-   6,
-   6,  8,  5,  2,
-   6,  8,  2,  3,
-   6,  8,  3,  7,
-   6,  8,  7,  0,
-   6,  8,  0,  1,
-   6,  8,  1,  5,
-// case 4b, 1=2,3>2,3>4,4>1
-   9,
-  10,  6,  0,  7,
-  10,  1,  5,  8,
-  10,  0,  1,  7,
-  10,  7,  1,  8,
-   6,  7, 10,  8,
-   6, 10,  5,  8,
-   6,  2,  7,  8,
-   6,  5,  2,  8,
-   7,  8,  2,  3,
-// case 4b, 1=2,2>3,4>3,1>4
-   9,
-  10,  6,  0,  7,
-  10,  1,  5,  8,
-  10,  0,  1,  8,
-  10,  7,  0,  8,
-   6,  7, 10,  8,
-   6, 10,  5,  8,
-   6,  3,  7,  8,
-   6,  5,  3,  8,
-   6,  5,  2,  3,
-// case 4b, 1=2,2>3,4>3,4>1
-   9,
-  10,  6,  0,  7,
-  10,  1,  5,  8,
-  10,  0,  1,  8,
-  10,  7,  0,  8,
-   6,  7, 10,  8,
-   6, 10,  5,  8,
-   6,  3,  7,  8,
-   6,  5,  2,  8,
-   6,  2,  3,  8,
-// case 4b, 1=2,3>2,3=4,4>1
-  11,
-  10,  6,  0,  7,
-  10,  1,  5,  8,
-  10,  0,  1, 11,
-  10, 11,  1,  8,
-  10,  0, 11,  7,
-  10,  7, 11,  8,
-   6,  7, 10,  8,
-   6, 10,  5,  8,
-   6,  2,  7,  8,
-   6,  5,  2,  8,
-   7,  8,  2,  3,
-// case 4b, 4>1=2=3,4>3
-  12,
-  10,  6,  0,  7,
-  10,  1,  5,  8,
-  10,  0,  1,  8,
-  10,  7,  0,  8,
-  13,  6,  2,  5,
-  13,  3,  7,  8,
-  13,  2,  3,  8,
-  13,  2,  8,  5,
-   6,  7, 10,  8,
-   6, 10,  5,  8,
-   6, 13,  7,  8,
-   6,  5, 13,  8,
-// case 4b, 1=2=3>4,1>4
-  12,
-  10,  6,  0,  7,
-  10,  1,  5,  8,
-  10,  0,  1,  7,
-  10,  7,  1,  8,
-  13,  6,  2,  5,
-  13,  3,  7,  8,
-  13,  2,  3,  5,
-  13,  3,  8,  5,
-   6,  7, 10,  8,
-   6, 10,  5,  8,
-   6, 13,  7,  8,
-   6,  5, 13,  8,
-// case 4b, 1=2=3=4=1
-  16,
-  10,  6,  0,  7,
-  10,  1,  5,  8,
-  10,  0,  1, 11,
-  10, 11,  1,  8,
-  10,  0, 11,  7,
-  10,  7, 11,  8,
-  13,  6,  2,  5,
-  13,  3,  7,  8,
-  13,  2,  3, 12,
-  13,  2, 12,  5,
-  13, 12,  3,  8,
-  13, 12,  5,  8,
-   6,  7, 10,  8,
-   6, 10,  5,  8,
-   6,  5, 13,  8,
-   6, 13,  7,  8,
-// case 5_0
-   2,
-   7,  8,  9,  3,
-   6,  5,  2,  9,
-// case 5, 1>2,3>4
-   5,
-   5,  7,  1,  8,
-   5,  7,  0,  1,
-   5,  7,  6,  0,
-   5,  7,  9,  6,
-   5,  7,  8,  9,
-// case 5, 1>2,4>3
-   5,
-   0,  5,  6,  7,
-   0,  5,  7,  8,
-   0,  5,  8,  1,
-   5,  7,  9,  6,
-   5,  7,  8,  9,
-// case 5, 1>2,4>3, a
-   5,
-   0,  5,  6,  8,
-   0,  6,  7,  8,
-   0,  5,  8,  1,
-   5,  8,  9,  6,
-   6,  7,  8,  9,
-// case 5, 1=2,3>4
-   8,
-  10,  6,  0,  7,
-  10,  1,  5,  8,
-  10,  0,  1,  7,
-  10,  7,  1,  8,
-  10,  8,  5,  9,
-  10,  6,  7,  9,
-  10,  7,  8,  9,
-  10,  5,  6,  9,
-// case 5, 1=2,3>4, a
-   8,
-  10,  6,  0,  7,
-  10,  1,  5,  8,
-  10,  0,  1,  7,
-  10,  7,  1,  8,
-   7,  8,  5,  9,
-  10,  6,  7,  5,
-  10,  7,  8,  5,
-   5,  9,  6,  7,
-// case 5, 1=2,3>4, b
-   8,
-  10,  6,  0,  7,
-  10,  1,  5,  8,
-  10,  0,  1,  7,
-  10,  7,  1,  8,
-   6,  8,  5,  9,
-  10,  6,  7,  8,
-  10,  6,  8,  5,
-   8,  9,  6,  7,
-// case 5, 1=2,3=4
-  10,
-  10,  6,  0,  7,
-  10,  1,  5,  8,
-  10,  0,  1, 11,
-  10, 11,  1,  8,
-  10,  0, 11,  7,
-  10,  7, 11,  8,
-  10,  8,  5,  9,
-  10,  6,  7,  9,
-  10,  7,  8,  9,
-  10,  5,  6,  9,
-// case 6_0
-   4,
-   7,  8,  9,  3,
-   6,  5,  2,  9,
-   4,  1,  5,  8,
-   0,  4,  6,  7,
-// case 6_1
-   4,
-   6,  4,  5,  8,
-   6,  5,  9,  8,
-   6,  9,  7,  8,
-   6,  7,  4,  8,
-// case 6_1, a
-   4,
-   5,  8,  9,  7,
-   5,  9,  6,  7,
-   5,  6,  4,  7,
-   5,  4,  8,  7,
-// case 6_1, b
-   4,
-   4,  5,  6,  9,
-   4,  6,  7,  9,
-   4,  7,  8,  9,
-   4,  8,  5,  9,
Modified: MOAB/trunk/refiner/MBSimplexTemplateRefiner.cpp
--- MOAB/trunk/refiner/MBSimplexTemplateRefiner.cpp	2007-12-27 19:42:29 UTC (rev 1492)
+++ MOAB/trunk/refiner/MBSimplexTemplateRefiner.cpp	2007-12-27 21:26:15 UTC (rev 1493)
@@ -4,6 +4,7 @@
 #include "MBInterface.hpp"
 #include <iostream>
+#include <stack>
 /// Construct a template refiner.
 MBSimplexTemplateRefiner::MBSimplexTemplateRefiner( MBInterface* mesh )
@@ -59,7 +60,7 @@
       rval = false;
       break;
     case MBTET:
-      rval = this->refine_3_simplex();
+      rval = this->refine_3_simplex( 0, 0, 0, 0, 0, 0, 0, 0, 0 ); // FIXME
       break;
     case MBPYRAMID:
       std::cerr << "Pyramid schemes not handled yet\n";
@@ -271,8 +272,172 @@
 /**\brief Refine a tetrahedron.
-bool MBSimplexTemplateRefiner::refine_3_simplex()
+bool MBSimplexTemplateRefiner::refine_3_simplex( int max_depth,
+                                                 const double* v0, const void* t0,
+                                                 const double* v1, const void* t1,
+                                                 const double* v2, const void* t2,
+                                                 const double* v3, const void* t3 )
+  bool edge_code = false;
+  double* midpt0c;
+  double* midpt1c;
+  double* midpt2c;
+  double* midpt3c;
+  double* midpt4c;
+  double* midpt5c;
+  void* midpt0t;
+  void* midpt1t;
+  void* midpt2t;
+  void* midpt3t;
+  void* midpt4t;
+  void* midpt5t;
+  double* facept0c;
+  double* facept1c;
+  double* facept2c;
+  double* facept3c;
+  void* facept0t;
+  void* facept1t;
+  void* facept2t;
+  void* facept3t;
+  if ( max_depth-- > 0 )
+    midpt0c = this->heap_coord_storage();
+    midpt1c = this->heap_coord_storage();
+    midpt2c = this->heap_coord_storage();
+    midpt3c = this->heap_coord_storage();
+    midpt4c = this->heap_coord_storage();
+    midpt5c = this->heap_coord_storage();
+    midpt0t = this->heap_tag_storage();
+    midpt1t = this->heap_tag_storage();
+    midpt2t = this->heap_tag_storage();
+    midpt3t = this->heap_tag_storage();
+    midpt4t = this->heap_tag_storage();
+    midpt5t = this->heap_tag_storage();
+    for ( int i = 0; i < 6; ++ i )
+      midpt0c[i] = ( v0[i] + v1[i] ) * .5;
+      midpt1c[i] = ( v1[i] + v2[i] ) * .5;
+      midpt2c[i] = ( v2[i] + v0[i] ) * .5;
+      midpt3c[i] = ( v0[i] + v3[i] ) * .5;
+      midpt4c[i] = ( v1[i] + v3[i] ) * .5;
+      midpt5c[i] = ( v2[i] + v3[i] ) * .5;
+    this->edge_size_evaluator->evaluate_tags_at_midpoint( v0, t0, midpt0c, midpt0t, v1, t1 );
+    this->edge_size_evaluator->evaluate_tags_at_midpoint( v1, t1, midpt1c, midpt1t, v2, t2 );
+    this->edge_size_evaluator->evaluate_tags_at_midpoint( v2, t2, midpt2c, midpt2t, v0, t0 );
+    this->edge_size_evaluator->evaluate_tags_at_midpoint( v0, t0, midpt3c, midpt3t, v3, t3 );
+    this->edge_size_evaluator->evaluate_tags_at_midpoint( v1, t1, midpt4c, midpt4t, v3, t3 );
+    this->edge_size_evaluator->evaluate_tags_at_midpoint( v2, t2, midpt5c, midpt5t, v3, t3 );
+    if ( this->edge_size_evaluator->evaluate_edge( v0, t0, midpt0c, midpt0t, v1, t1 ) )
+      edge_code |=  1;
+    if ( this->edge_size_evaluator->evaluate_edge( v1, t1, midpt1c, midpt1t, v2, t2 ) )
+      edge_code |=  2;
+    if ( this->edge_size_evaluator->evaluate_edge( v2, t2, midpt2c, midpt2t, v0, t0 ) )
+      edge_code |=  4;
+    if ( this->edge_size_evaluator->evaluate_edge( v0, t0, midpt3c, midpt3t, v3, t3 ) )
+      edge_code |=  8;
+    if ( this->edge_size_evaluator->evaluate_edge( v1, t1, midpt4c, midpt4t, v3, t3 ) )
+      edge_code |= 16;
+    if ( this->edge_size_evaluator->evaluate_edge( v2, t2, midpt5c, midpt5t, v3, t3 ) )
+      edge_code |= 32;
+  double edge_length2[6];
+  edge_length2[0]
+    = edge_length2[1]
+    = edge_length2[2]
+    = edge_length2[3]
+    = edge_length2[4]
+    = edge_length2[5]
+    = 0;
+  for ( int c = 0; c < 3; ++ c )
+    double tmp;
+    tmp = v1[c] - v0[c];
+    edge_length2[0] += tmp * tmp;
+    tmp = v2[c] - v1[c];
+    edge_length2[1] += tmp * tmp;
+    tmp = v2[c] - v0[c];
+    edge_length2[2] += tmp * tmp;
+    tmp = v3[c] - v0[c];
+    edge_length2[3] += tmp * tmp;
+    tmp = v3[c] - v1[c];
+    edge_length2[4] += tmp * tmp;
+    tmp = v3[c] - v2[c];
+    edge_length2[5] += tmp * tmp;
+  if ( ! edge_code )
+    // No edges to subdivide
+    (*this->output_functor)( v0, t0 );
+    (*this->output_functor)( v1, t1 );
+    (*this->output_functor)( v2, t2 );
+    (*this->output_functor)( v3, t3 );
+    (*this->output_functor)( MBTET );
+    return false;
+  const double* vertex_coords[10] = { v0, v1, v2, v3,
+                                      midpt0c, midpt1c, midpt2c,
+                                      midpt3c, midpt4c, midpt5c };
+  const void* vertex_tags[10] = { t0, t1, t2, t3,
+                                  midpt0t, midpt1t, midpt2t,
+                                  midpt3t, midpt4t, midpt5t };
+  // Generate tetrahedra that are compatible except when edge
+  // lengths are equal on indeterminately subdivided faces.
+  const double* permuted_coords[14];
+  const void* permuted_tags[14];
+  double permlen[6]; // permuted edge lengths
+  int C = MBSimplexTemplateRefiner::template_index[edge_code][0];
+  int P = MBSimplexTemplateRefiner::template_index[edge_code][1];
+  // 1. Permute the tetrahedron into our canonical configuration
+  for ( int i = 0; i < 4; ++ i )
+    permuted_coords[i] = vertex_coords[MBSimplexTemplateRefiner::permutations_from_index[P][i]];
+    permuted_tags[i] = vertex_tags[MBSimplexTemplateRefiner::permutations_from_index[P][i]];
+    for ( int i = 4 ; i < 10; ++ i )
+      // permute edges too
+      permlen[i-4]  = edge_length2[MBSimplexTemplateRefiner::permutations_from_index[P][i] - 4];
+    // Add our local (heap) storage for face point coordinates to the list.
+    permuted_coords[10] = facept0c;
+    permuted_coords[11] = facept1c;
+    permuted_coords[12] = facept2c;
+    permuted_coords[13] = facept3c;
+    permuted_tags[10] = facept0t;
+    permuted_tags[11] = facept1t;
+    permuted_tags[12] = facept2t;
+    permuted_tags[13] = facept3t;
+    int comparison_bits;
+    std::stack<int*> output_tets;
+    std::stack<int*> output_perm;
+    std::stack<int>  output_sign;
+    // cout << "Case " << C << "  Permutation " << P << endl;
+    // 2. Generate tetrahedra based on the configuration.
+    //    Note that case 0 is handled above (edgeCode == 0).
   return true;
@@ -297,3 +462,689 @@
   return sq_mag_a < sq_mag_b;
+ * The array below is indexed by the edge code for a tetrahedron.
+ * Looking up a row with a tet's edge code will return C and P.
+ * C is a configuration number and P is a permutation index.
+ * C is based on the case number from Ruprecht and
+ * Müller's (1998) paper on adaptive tetrahedra. (The case
+ * numbers are shown to the left of the row in the column
+ * labeled case. The only difference is that we introduce
+ * a case 3d which is part of case 3c in the paper.)
+ * P is an index into the permutations_from_index array below,
+ * and is used to transform the current tetrahedron into
+ * the canonical configuration associated with C.
+ * The 6-digit binary number to the left (which is shown in
+ * the horribly UNconventional LSB->MSB order) is the edge
+ * code for the row. The 6 digits correspond to the 6 edges
+ * of the tetrahedron; a '0' implies no subdivision while
+ * a '1' implies subdivision should occur. The ordering of
+ * the bits is
+ * Edge 0-1, Edge 1-2, Edge 2-0, Edge 0-3, Edge 1-3, Edge 2-3,
+ * where the numbers are vertices of the tetrahedron 0-1-2-3.
+ * Note that Tet 0-1-2-3 must be positive (i.e., the plane
+ * specified by Triangle 0-1-2 must have a normal pointing
+ * towards vertex 3, and Triangle 0-1-2's normal must be
+ * calculated using the cross-product (Edge 0-1) x (Edge 0-2)).
+ * References:
+ * (Ruprect and Müller, 1998) A Scheme for Edge-based Adaptive
+ *   Tetrahedron Subdivision, Mathematical Visualization (eds.
+ *   Hege and Polthier), pp. 61--70. Springer-Verlag. 1998.
+int MBSimplexTemplateRefiner::template_index[64][2] =
+  /*      code case      C    P */
+  /* 000000  0  0  */ {  0,   0 },
+  /* 100000  1  1  */ {  1,   0 },
+  /* 010000  2  1  */ {  1,   1 },
+  /* 110000  3  2a */ {  2,   0 },
+  /* 001000  4  1  */ {  1,   2 },
+  /* 101000  5  2a */ {  2,   2 },
+  /* 011000  6  2a */ {  2,   1 },
+  /* 111000  7  3b */ {  5,  11 },
+  /* 000100  8  1  */ {  1,  10 },
+  /* 100100  9  2a */ {  2,   5 },
+  /* 010100 10  2b */ {  3,   1 },
+  /* 110100 11  3c */ {  6,   0 },
+  /* 001100 12  2a */ {  2,  10 },
+  /* 101100 13  3a */ {  4,   0 },
+  /* 011100 14  3d */ {  7,   2 },
+  /* 111100 15  4a */ {  8,   6 },
+  /* 000010 16  1  */ {  1,   6 },
+  /* 100010 17  2a */ {  2,   4 },
+  /* 010010 18  2a */ {  2,   8 },
+  /* 110010 19  3a */ {  4,   1 },
+  /* 001010 20  2b */ {  3,   2 },
+  /* 101010 21  3d */ {  7,   0 },
+  /* 011010 22  3c */ {  6,   1 },
+  /* 111010 23  4a */ {  8,   9 },
+  /* 000110 24  2a */ {  2,   3 },
+  /* 100110 25  3b */ {  5,   0 },
+  /* 010110 26  3d */ {  7,   4 },
+  /* 110110 27  4a */ {  8,  11 },
+  /* 001110 28  3c */ {  6,  10 },
+  /* 101110 29  4a */ {  8,   7 },
+  /* 011110 30  4b */ {  9,   0 },
+  /* 111110 31  5  */ { 10,   7 },
+  /* 000001 32  1  */ {  1,   7 },
+  /* 100001 33  2b */ {  3,   0 },
+  /* 010001 34  2a */ {  2,   7 },
+  /* 110001 35  3d */ {  7,   1 },
+  /* 001001 36  2a */ {  2,  11 },
+  /* 101001 37  3c */ {  6,   2 },
+  /* 011001 38  3a */ {  4,   2 },
+  /* 111001 39  4a */ {  8,   3 },
+  /* 000101 40  2a */ {  2,   9 },
+  /* 100101 41  3d */ {  7,  10 },
+  /* 010101 42  3c */ {  6,   7 },
+  /* 110101 43  4b */ {  9,   2 },
+  /* 001101 44  3b */ {  5,   7 },
+  /* 101101 45  4a */ {  8,   8 },
+  /* 011101 46  4a */ {  8,   4 },
+  /* 111101 47  5  */ { 10,   6 },
+  /* 000011 48  2a */ {  2,   6 },
+  /* 100011 49  3c */ {  6,   4 },
+  /* 010011 50  3b */ {  5,   1 },
+  /* 110011 51  4a */ {  8,  10 },
+  /* 001011 52  3d */ {  7,   7 },
+  /* 101011 53  4b */ {  9,   1 },
+  /* 011011 54  4a */ {  8,   5 },
+  /* 111011 55  5  */ { 10,  10 },
+  /* 000111 56  3a */ {  4,  10 },
+  /* 100111 57  4a */ {  8,   1 },
+  /* 010111 58  4a */ {  8,   2 },
+  /* 110111 59  5  */ { 10,   2 },
+  /* 001111 60  4a */ {  8,   0 },
+  /* 101111 61  5  */ { 10,   1 },
+  /* 011111 62  5  */ { 10,   0 },
+  /* 111111 63  6  */ { 11,   0 },
+/* Does this mean anything? If so, then you are either
+ * superstitious or much more clever than I (or both?).
+/* permutation index, P:  0  1  2  3  4  5  6  7  8  9 10 11 */
+/* number of references: 12  9  9  3  4  2  5  6  2  3  7  2 */
+ * The array below is a list of all the _positive_
+ * permutations of Tetrahedron 0-1-2-3. Given a
+ * permutation index, it returns a row of 14 values:
+ * these are the vertex numbers of the permuted
+ * tetrahedron. The first 4 values are the permuted
+ * corner indices, the next 6 values are the
+ * permuted edge midpoint indices, and the final
+ * entries reference mid-face points inserted
+ * to maintain a compatible tetrahedralization.
+ * There are 24 entries, 6 for each of the 4 faces of
+ * the tetrahedron.
+int MBSimplexTemplateRefiner::permutations_from_index[24][14] =
+  /* corners      midpoints          face points   */
+  /* POSITIVE ARRANGEMENTS                         */
+  { 0, 1, 2, 3,   4, 5, 6, 7, 8, 9,  10, 11, 12, 13 }, /* Face 0-1-2 */
+  { 1, 2, 0, 3,   5, 6, 4, 8, 9, 7,  10, 12, 13, 11 },
+  { 2, 0, 1, 3,   6, 4, 5, 9, 7, 8,  10, 13, 11, 12 },
+  { 0, 3, 1, 2,   7, 8, 4, 6, 9, 5,  11, 13, 12, 10 }, /* Face 0-3-1 */
+  { 3, 1, 0, 2,   8, 4, 7, 9, 5, 6,  11, 12, 10, 13 },
+  { 1, 0, 3, 2,   4, 7, 8, 5, 6, 9,  11, 10, 13, 12 },
+  { 1, 3, 2, 0,   8, 9, 5, 4, 7, 6,  12, 11, 13, 10 }, /* Face 1-3-2 */
+  { 3, 2, 1, 0,   9, 5, 8, 7, 6, 4,  12, 13, 10, 11 },
+  { 2, 1, 3, 0,   5, 8, 9, 6, 4, 7,  12, 10, 11, 13 },
+  { 2, 3, 0, 1,   9, 7, 6, 5, 8, 4,  13, 12, 11, 10 }, /* Face 2-3-0 */
+  { 3, 0, 2, 1,   7, 6, 9, 8, 4, 5,  13, 11, 10, 12 },
+  { 0, 2, 3, 1,   6, 9, 7, 4, 5, 8,  13, 10, 12, 11 },
+  /* NEGATIVE ARRANGEMENTS                         */
+  { 0, 2, 1, 3,   6, 5, 4, 7, 9, 8,  10, 13, 12, 11 }, /* Face 0-1-2 */
+  { 2, 1, 0, 3,   5, 4, 6, 9, 8, 7,  10, 12, 11, 13 },
+  { 1, 0, 2, 3,   4, 6, 5, 8, 7, 9,  10, 11, 13, 12 },
+  { 0, 1, 3, 2,   4, 8, 7, 6, 5, 9,  11, 10, 12, 13 }, /* Face 0-3-1 */
+  { 1, 3, 0, 2,   8, 7, 4, 5, 9, 6,  11, 12, 13, 10 },
+  { 3, 0, 1, 2,   7, 4, 8, 9, 6, 5,  11, 13, 10, 12 },
+  { 1, 2, 3, 0,   5, 9, 8, 4, 6, 7,  12, 10, 13, 11 }, /* Face 1-3-2 */
+  { 2, 3, 1, 0,   9, 8, 5, 6, 7, 4,  12, 13, 11, 10 },
+  { 3, 1, 2, 0,   8, 5, 9, 7, 4, 6,  12, 11, 10, 13 },
+  { 2, 0, 3, 1,   6, 7, 9, 5, 4, 8,  13, 10, 11, 12 }, /* Face 2-3-0 */
+  { 0, 3, 2, 1,   7, 9, 6, 4, 8, 5,  13, 11, 12, 10 },
+  { 3, 2, 0, 1,   9, 6, 7, 8, 5, 4,  13, 12, 10, 11 }
+ * Below is a list of output tetrahedra. The array is
+ * generated by TessellatorGenerator.py
+ * which also generates the code that references it.
+ * Each set of tetrahedra begins with a single integer
+ * that is the number of tetrahedra for that particular
+ * case. It is followed by 5 integers for each output
+ * tetrahedron; the first four numbers on each row are
+ * indices of the output tetrahedron. The final number
+ * is a bit vector specifying which edges of the
+ * tetrahedron are internal to the parent tetrahedron
+ * being decomposed.
+ * Multiple lists of output tetrahedra may be
+ * combined to create the tessellation of a single
+ * input tetrahedron.
+int MBSimplexTemplateRefiner::templates[] =
+// case 1_0
+   2,
+   0,  4,  2,  3,
+   4,  1,  2,  3,
+// case 2a_0
+   1,
+   3,  4,  5,  1,
+// case 2a, 0>1
+   2,
+   0,  4,  2,  3,
+   4,  5,  2,  3,
+// case 2a, 0=1
+   4,
+  10,  3,  0,  4,
+  10,  3,  4,  5,
+  10,  3,  5,  2,
+  10,  3,  2,  0,
+// case 2b_0
+   4,
+   0,  4,  9,  3,
+   4,  1,  9,  3,
+   0,  4,  2,  9,
+   4,  1,  2,  9,
+// case 3a_0
+   1,
+   4,  7,  6,  0,
+// case 3a, 0>2>3<0
+   3,
+   1,  3,  2,  4,
+   4,  6,  3,  2,
+   4,  6,  7,  3,
+// case 3a, 0=2>3<0
+   5,
+   4,  6,  7,  3,
+  10,  1,  2,  3,
+  10,  2,  6,  3,
+  10,  6,  4,  3,
+  10,  4,  1,  3,
+// case 3a, 3>0=2<3
+   5,
+   1,  3,  2,  7,
+  10,  1,  2,  7,
+  10,  2,  6,  7,
+  10,  6,  4,  7,
+  10,  4,  1,  7,
+// case 3a, 0=2=3=0
+  11,
+   2,  6, 10, 13,
+   3,  7, 13, 11,
+   4,  1, 10, 11,
+  11,  6, 10,  4,
+  11,  6, 13, 10,
+  11,  6,  7, 13,
+  11,  6,  4,  7,
+   2, 10, 11, 13,
+   1, 10, 11,  2,
+   2, 11,  3, 13,
+   3,  2,  1, 11,
+// case 3b_0
+   4,
+   0,  7,  4,  2,
+   4,  7,  8,  2,
+   4,  8,  1,  2,
+   7,  3,  8,  2,
+// case 3c, 0>1,0>3
+   5,
+   4,  2,  7,  5,
+   4,  2,  0,  7,
+   4,  3,  1,  5,
+   4,  3,  5,  7,
+   3,  5,  7,  2,
+// case 3c, 1>0,3>0
+   5,
+   0,  5,  2,  7,
+   0,  5,  7,  4,
+   7,  1,  4,  5,
+   7,  1,  5,  3,
+   3,  5,  7,  2,
+// case 3c, 0>1,3>0
+   5,
+   4,  2,  7,  5,
+   4,  2,  0,  7,
+   7,  1,  4,  5,
+   7,  1,  5,  3,
+   3,  5,  7,  2,
+// case 3c, 1>0,0>3
+   5,
+   0,  5,  2,  7,
+   0,  5,  7,  4,
+   4,  3,  1,  5,
+   4,  3,  5,  7,
+   3,  5,  7,  2,
+// case 3c, 0=1,0>3
+   7,
+   4,  1,  5,  3,
+  10,  0,  4,  7,
+  10,  2,  0,  7,
+  10,  7,  4,  3,
+  10,  2,  7,  3,
+  10,  5,  2,  3,
+  10,  4,  5,  3,
+// case 3c, 3>0,0=1
+   7,
+   7,  1,  5,  3,
+   7,  5,  2,  3,
+  10,  0,  4,  7,
+  10,  2,  0,  7,
+  10,  5,  2,  7,
+  10,  4,  5,  7,
+   1,  5,  4,  7,
+// case 3c, 0=1,0=3
+  10,
+   4,  1,  5, 11,
+  11,  1,  5,  3,
+  10,  0,  4,  7,
+  10,  2,  0,  7,
+  10,  5,  2,  3,
+  10,  2,  7,  3,
+  10,  7,  4, 11,
+  10,  7, 11,  3,
+  10,  4,  5, 11,
+  10, 11,  5,  3,
+// case 3d, 0>4,0>2
+   5,
+   4,  3,  6,  0,
+   4,  3,  8,  6,
+   4,  2,  8,  1,
+   4,  2,  6,  8,
+   2,  3,  6,  8,
+// case 3d, 4>0,2>0
+   5,
+   8,  0,  6,  4,
+   8,  0,  3,  6,
+   6,  1,  8,  4,
+   6,  1,  2,  8,
+   2,  3,  6,  8,
+// case 3d, 0>4,2>0
+   5,
+   4,  3,  6,  0,
+   4,  3,  8,  6,
+   6,  1,  8,  4,
+   6,  1,  2,  8,
+   2,  3,  6,  8,
+// case 3d, 4>0,0>2
+   5,
+   8,  0,  6,  4,
+   8,  0,  3,  6,
+   4,  2,  8,  1,
+   4,  2,  6,  8,
+   2,  3,  6,  8,
+// case 3d, 0=4,0>2
+   7,
+   4,  1,  2,  8,
+  11,  4,  0,  6,
+  11,  0,  3,  6,
+  11,  2,  4,  6,
+  11,  3,  2,  6,
+  11,  3,  8,  2,
+  11,  8,  4,  2,
+// case 3d, 2>0,0=4
+   7,
+   6,  2,  8,  1,
+   6,  8,  2,  3,
+  11,  4,  0,  6,
+  11,  0,  3,  6,
+   8, 11,  3,  6,
+   8,  4, 11,  6,
+   1,  6,  4,  8,
+// case 3d, 0=4,0=2
+  10,
+   4,  1, 10,  8,
+  10,  2,  8,  1,
+  11,  4,  0,  6,
+  11,  0,  3,  6,
+  11,  3,  8,  2,
+  11,  3,  2,  6,
+  11, 10,  4,  6,
+  11, 10,  6,  2,
+   8,  4, 11, 10,
+  11, 10,  2,  8,
+// case 4a_0
+   2,
+   7,  8,  9,  3,
+   7,  9,  8,  6,
+// case 4a, 5>4>3
+   4,
+   8,  0,  6,  1,
+   8,  0,  7,  6,
+   9,  1,  6,  2,
+   9,  1,  8,  6,
+// case 4a, 3<4>5
+   4,
+   8,  0,  6,  1,
+   8,  0,  7,  6,
+   8,  2,  6,  9,
+   8,  2,  1,  6,
+// case 4a, 3>4<5
+   4,
+   6,  9,  8,  1,
+   6,  9,  1,  2,
+   6,  7,  0,  1,
+   6,  7,  1,  8,
+// case 4a, 3=4>5
+   6,
+   6,  7,  0, 11,
+   6,  0,  1, 11,
+   6,  7, 11,  8,
+   6, 11,  1,  8,
+   1,  2,  6,  8,
+   2,  6,  8,  9,
+// case 4a, 5>4,3=4
+   6,
+   6,  7,  0, 11,
+   6,  0,  1, 11,
+   6,  7, 11,  8,
+   6, 11,  1,  8,
+   1,  2,  6,  9,
+   1,  6,  8,  9,
+// case 4a, 3=4=5
+   8,
+   6,  7,  0, 11,
+   6,  0,  1, 11,
+   6,  7, 11,  8,
+   6, 11,  1,  8,
+   6,  1,  2, 12,
+   6,  2,  9, 12,
+   6,  9,  8, 12,
+   6,  8,  1, 12,
+// case 4b, 2>1,3>2,4>3,4>1
+   6,
+   6,  8,  1,  5,
+   6,  8,  0,  1,
+   6,  8,  7,  0,
+   6,  8,  2,  7,
+   7,  8,  2,  3,
+   6,  8,  5,  2,
+// case 4b, 2>1,3>2,3>4,4>1
+   6,
+   6,  8,  1,  5,
+   6,  8,  7,  1,
+   6,  7,  0,  1,
+   8,  7,  3,  2,
+   6,  8,  5,  2,
+   6,  8,  2,  7,
+// case 4b, 2>1,3>2,3>4,4>1, a
+   6,
+   7,  8,  1,  5,
+   6,  5,  7,  1,
+   6,  7,  0,  1,
+   8,  7,  3,  2,
+   7,  8,  5,  2,
+   6,  5,  2,  7,
+// case 4b, 2>1,2>3,4>3,4>1
+   6,
+   6,  8,  5,  2,
+   6,  8,  2,  3,
+   6,  8,  3,  7,
+   6,  8,  7,  0,
+   6,  8,  0,  1,
+   6,  8,  1,  5,
+// case 4b, 1=2,3>2,3>4,4>1
+   9,
+  10,  6,  0,  7,
+  10,  1,  5,  8,
+  10,  0,  1,  7,
+  10,  7,  1,  8,
+   6,  7, 10,  8,
+   6, 10,  5,  8,
+   6,  2,  7,  8,
+   6,  5,  2,  8,
+   7,  8,  2,  3,
+// case 4b, 1=2,2>3,4>3,1>4
+   9,
+  10,  6,  0,  7,
+  10,  1,  5,  8,
+  10,  0,  1,  8,
+  10,  7,  0,  8,
+   6,  7, 10,  8,
+   6, 10,  5,  8,
+   6,  3,  7,  8,
+   6,  5,  3,  8,
+   6,  5,  2,  3,
+// case 4b, 1=2,2>3,4>3,4>1
+   9,
+  10,  6,  0,  7,
+  10,  1,  5,  8,
+  10,  0,  1,  8,
+  10,  7,  0,  8,
+   6,  7, 10,  8,
+   6, 10,  5,  8,
+   6,  3,  7,  8,
+   6,  5,  2,  8,
+   6,  2,  3,  8,
+// case 4b, 1=2,3>2,3=4,4>1
+  11,
+  10,  6,  0,  7,
+  10,  1,  5,  8,
+  10,  0,  1, 11,
+  10, 11,  1,  8,
+  10,  0, 11,  7,
+  10,  7, 11,  8,
+   6,  7, 10,  8,
+   6, 10,  5,  8,
+   6,  2,  7,  8,
+   6,  5,  2,  8,
+   7,  8,  2,  3,
+// case 4b, 4>1=2=3,4>3
+  12,
+  10,  6,  0,  7,
+  10,  1,  5,  8,
+  10,  0,  1,  8,
+  10,  7,  0,  8,
+  13,  6,  2,  5,
+  13,  3,  7,  8,
+  13,  2,  3,  8,
+  13,  2,  8,  5,
+   6,  7, 10,  8,
+   6, 10,  5,  8,
+   6, 13,  7,  8,
+   6,  5, 13,  8,
+// case 4b, 1=2=3>4,1>4
+  12,
+  10,  6,  0,  7,
+  10,  1,  5,  8,
+  10,  0,  1,  7,
+  10,  7,  1,  8,
+  13,  6,  2,  5,
+  13,  3,  7,  8,
+  13,  2,  3,  5,
+  13,  3,  8,  5,
+   6,  7, 10,  8,
+   6, 10,  5,  8,
+   6, 13,  7,  8,
+   6,  5, 13,  8,
+// case 4b, 1=2=3=4=1
+  16,
+  10,  6,  0,  7,
+  10,  1,  5,  8,
+  10,  0,  1, 11,
+  10, 11,  1,  8,
+  10,  0, 11,  7,
+  10,  7, 11,  8,
+  13,  6,  2,  5,
+  13,  3,  7,  8,
+  13,  2,  3, 12,
+  13,  2, 12,  5,
+  13, 12,  3,  8,
+  13, 12,  5,  8,
+   6,  7, 10,  8,
+   6, 10,  5,  8,
+   6,  5, 13,  8,
+   6, 13,  7,  8,
+// case 5_0
+   2,
+   7,  8,  9,  3,
+   6,  5,  2,  9,
+// case 5, 1>2,3>4
+   5,
+   5,  7,  1,  8,
+   5,  7,  0,  1,
+   5,  7,  6,  0,
+   5,  7,  9,  6,
+   5,  7,  8,  9,
+// case 5, 1>2,4>3
+   5,
+   0,  5,  6,  7,
+   0,  5,  7,  8,
+   0,  5,  8,  1,
+   5,  7,  9,  6,
+   5,  7,  8,  9,
+// case 5, 1>2,4>3, a
+   5,
+   0,  5,  6,  8,
+   0,  6,  7,  8,
+   0,  5,  8,  1,
+   5,  8,  9,  6,
+   6,  7,  8,  9,
+// case 5, 1=2,3>4
+   8,
+  10,  6,  0,  7,
+  10,  1,  5,  8,
+  10,  0,  1,  7,
+  10,  7,  1,  8,
+  10,  8,  5,  9,
+  10,  6,  7,  9,
+  10,  7,  8,  9,
+  10,  5,  6,  9,
+// case 5, 1=2,3>4, a
+   8,
+  10,  6,  0,  7,
+  10,  1,  5,  8,
+  10,  0,  1,  7,
+  10,  7,  1,  8,
+   7,  8,  5,  9,
+  10,  6,  7,  5,
+  10,  7,  8,  5,
+   5,  9,  6,  7,
+// case 5, 1=2,3>4, b
+   8,
+  10,  6,  0,  7,
+  10,  1,  5,  8,
+  10,  0,  1,  7,
+  10,  7,  1,  8,
+   6,  8,  5,  9,
+  10,  6,  7,  8,
+  10,  6,  8,  5,
+   8,  9,  6,  7,
+// case 5, 1=2,3=4
+  10,
+  10,  6,  0,  7,
+  10,  1,  5,  8,
+  10,  0,  1, 11,
+  10, 11,  1,  8,
+  10,  0, 11,  7,
+  10,  7, 11,  8,
+  10,  8,  5,  9,
+  10,  6,  7,  9,
+  10,  7,  8,  9,
+  10,  5,  6,  9,
+// case 6_0
+   4,
+   7,  8,  9,  3,
+   6,  5,  2,  9,
+   4,  1,  5,  8,
+   0,  4,  6,  7,
+// case 6_1
+   4,
+   6,  4,  5,  8,
+   6,  5,  9,  8,
+   6,  9,  7,  8,
+   6,  7,  4,  8,
+// case 6_1, a
+   4,
+   5,  8,  9,  7,
+   5,  9,  6,  7,
+   5,  6,  4,  7,
+   5,  4,  8,  7,
+// case 6_1, b
+   4,
+   4,  5,  6,  9,
+   4,  6,  7,  9,
+   4,  7,  8,  9,
+   4,  8,  5,  9,
Modified: MOAB/trunk/refiner/MBSimplexTemplateRefiner.hpp
--- MOAB/trunk/refiner/MBSimplexTemplateRefiner.hpp	2007-12-27 19:42:29 UTC (rev 1492)
+++ MOAB/trunk/refiner/MBSimplexTemplateRefiner.hpp	2007-12-27 21:26:15 UTC (rev 1493)
@@ -41,15 +41,20 @@
   virtual unsigned long get_heap_size_bound( int max_recursions ) const { return 48 * 4 * ( 1 << max_recursions ); }
 protected:
-  static int* template_index;
-  static int* templates;
+  static int template_index[64][2];
+  static int permutations_from_index[24][14];
+  static int templates[];
   void refine_0_simplex( const double* v0, const void* t0 );
   bool refine_1_simplex( int max_depth,
     const double* v0, const void* t0, const double* v1, const void* t1 );
   bool refine_2_simplex( int max_depth, int move,
     const double* v0, const void* t0, const double* v1, const void* t1, const double* v2, const void* t2 );
-  bool refine_3_simplex();
+  bool refine_3_simplex( int max_depth,
+                         const double* v3, const void* t3 );
   static bool compare_Hopf_cross_string_dist( const double* v00, const double* v01, const double* v10, const double* v11 );
 #endif // MB_SIMPLEXTEMPLATEREFINER_H
