[MOAB-dev] r1473 - in MOAB/trunk: . parallel
tautges at mcs.anl.gov
Fri Dec 14 16:58:11 CST 2007
Author: tautges
Date: 2007-12-14 16:58:11 -0600 (Fri, 14 Dec 2007)
New Revision: 1473
Modified:
MOAB/trunk/DualTool.cpp
MOAB/trunk/Tqdcfr.cpp
MOAB/trunk/mbparallelcomm_test.cpp
MOAB/trunk/parallel/MBParallelComm.cpp
Log:
Some minor fixes:
mbparallelcomm_test.cpp: initializing result to fix exit code.
DualTool: more cleanup
Tqdcfr: fixed reading in cases where vertex handles aren't contiguous
MBParallelComm: rearranging counting in communication function to be a little easier to follow
Modified: MOAB/trunk/DualTool.cpp
--- MOAB/trunk/DualTool.cpp 2007-12-14 20:16:15 UTC (rev 1472)
+++ MOAB/trunk/DualTool.cpp 2007-12-14 22:58:11 UTC (rev 1473)
@@ -2698,7 +2698,6 @@
if (MB_SUCCESS != result) return result;
result = mbImpl->delete_entities(&quads[1], 1);
for (int i = 0; i < 4; i++) {
hconnect[i] = connects[3][i];
hconnect[4+i] = connects[2][i];
Modified: MOAB/trunk/Tqdcfr.cpp
--- MOAB/trunk/Tqdcfr.cpp 2007-12-14 20:16:15 UTC (rev 1472)
+++ MOAB/trunk/Tqdcfr.cpp 2007-12-14 22:58:11 UTC (rev 1473)
@@ -957,7 +957,7 @@
result = mdbImpl->get_entities_by_type(0, MBVERTEX, vrange); RR;
MBRange::const_iterator rit = vrange.lower_bound(vrange.begin(), vrange.end(),
currNodeIdOffset);
- for (; *rit != node_offset; rit++)
+ for (; *rit <= node_offset; rit++)
(*cubMOABVertexMap)[*rit] = *rit;
Modified: MOAB/trunk/mbparallelcomm_test.cpp
--- MOAB/trunk/mbparallelcomm_test.cpp 2007-12-14 20:16:15 UTC (rev 1472)
+++ MOAB/trunk/mbparallelcomm_test.cpp 2007-12-14 22:58:11 UTC (rev 1473)
@@ -50,7 +50,7 @@
MBInterface *mbImpl = new MBCore(rank, nprocs);
if (NULL == mbImpl) return 1;
- MBErrorCode result;
+ MBErrorCode result = MB_SUCCESS;
// each interior proc has a vector of N+M vertices, sharing
// M vertices each with lower- and upper-rank processors, except
Modified: MOAB/trunk/parallel/MBParallelComm.cpp
--- MOAB/trunk/parallel/MBParallelComm.cpp 2007-12-14 20:16:15 UTC (rev 1472)
+++ MOAB/trunk/parallel/MBParallelComm.cpp 2007-12-14 22:58:11 UTC (rev 1473)
@@ -118,9 +118,9 @@
std::vector<int> num_elements(procConfig.proc_size()*4);
#ifdef USE_MPI
if (procConfig.proc_size() > 1 && parallel) {
- int retval = MPI_Alltoall(local_num_elements, 4, MPI_INTEGER,
+ int retval = MPI_Alltoall(local_num_elements, 4, MPI_INT,
&num_elements[0], procConfig.proc_size()*4,
- MPI_INTEGER, procConfig.proc_comm());
+ MPI_INT, procConfig.proc_comm());
if (0 != retval) return MB_FAILURE;
else
@@ -393,7 +393,7 @@
allRanges.push_back(entities.subset_by_type(MBVERTEX));
else {
- PACK_INT(buff_ptr, MBVERTEX);
+ PACK_INT(buff_ptr, ((int) MBVERTEX));
PACK_RANGE(buff_ptr, allRanges[0]);
int num_verts = allRanges[0].size();
std::vector<double*> coords(3);
@@ -452,7 +452,6 @@
// put these entities in the last range
(*allRanges.rbegin()).insert( eseq->start_handle(), eseq->end_handle() );
- //eseq->get_entities(*allRanges.rbegin());
whole_range.merge(*allRanges.rbegin());
// now start where we last left off
@@ -471,22 +470,23 @@
std::vector<int>::iterator iit = vertsPerEntity.begin();
std::vector<MBEntityType>::iterator eit = entTypes.begin();
for (; vit != allRanges.end(); vit++, iit++, eit++) {
+ // entity type of this range, but passed as int
+ count += sizeof(int);
// subranges of entities
- count += 2*sizeof(MBEntityHandle)*num_subranges(*vit);
+ // number of subranges, begin/end handle of each subrange
+ count += sizeof(int) + 2*sizeof(MBEntityHandle)*num_subranges(*vit);
+ // nodes per entity
+ if (iit != vertsPerEntity.begin()) count += sizeof(int);
// connectivity of subrange
if (iit != vertsPerEntity.begin()) {
- //if (*eit != MBPOLYGON && *eit != MBPOLYHEDRON)
- // for non-poly's: #verts/ent * #ents * sizeof handle
- // count += *iit * (*vit).size() * sizeof(MBEntityHandle);
- // for poly's: length of conn list * handle size + #ents * int size (for offsets)
- //else
- count += *iit * sizeof(MBEntityHandle) + (*vit).size() * sizeof(int);
+ count += *iit * sizeof(MBEntityHandle)*(*vit).size();
- // num_verts per subrange ent type in subrange
- count += (vertsPerEntity.size() + 1) * (sizeof(int) + sizeof(MBEntityType));
- // extra entity type at end
+ // extra entity type at end, passed as int
else {
@@ -498,7 +498,7 @@
for (; allr_it != allRanges.end(); allr_it++, nv_it++, et_it++) {
// pack the entity type
- PACK_INT(buff_ptr, *et_it);
+ PACK_INT(buff_ptr, ((int)*et_it));
// pack the range
PACK_RANGE(buff_ptr, (*allr_it));
@@ -532,7 +532,7 @@
// pack MBMAXTYPE to indicate end of ranges
- PACK_INT(buff_ptr, MBMAXTYPE);
+ PACK_INT(buff_ptr, ((int)MBMAXTYPE));
count = buff_ptr - orig_buff_ptr;
@@ -567,7 +567,7 @@
if (MBVERTEX == this_type) {
// unpack coords
int num_verts = this_range.size();
- std::vector<double*> coords(3*num_verts);
+ std::vector<double*> coords(3);
for (MBRange::const_pair_iterator pit = this_range.const_pair_begin();
pit != this_range.const_pair_end(); pit++) {
// allocate handles
@@ -612,31 +612,13 @@
MBEntityHandle actual_start;
int num_elems = (*pit).second - (*pit).first + 1;
MBEntityHandle *connect;
- int *connect_offsets;
- //if (this_type == MBPOLYGON || this_type == MBPOLYHEDRON) {
- // result = ru->get_poly_element_array(num_elems, verts_per_entity, this_type,
- // start_id, start_proc, actual_start,
- // connect_offsets, connect);
- // RR("Failed to allocate poly element arrays.");
+ result = ru->get_element_array(num_elems, verts_per_entity, this_type,
+ start_id, start_proc, actual_start,
+ connect);
+ RR("Failed to allocate element arrays.");
- //else {
- result = ru->get_element_array(num_elems, verts_per_entity, this_type,
- start_id, start_proc, actual_start,
- connect);
- RR("Failed to allocate element arrays.");
// copy connect arrays
- //if (this_type != MBPOLYGON && this_type != MBPOLYHEDRON) {
- // UNPACK_EH(buff_ptr, connect, num_elems * verts_per_entity);
- //else {
- UNPACK_EH(buff_ptr, connect, verts_per_entity);
- assert(NULL != connect_offsets);
- // and the offsets
- UNPACK_INTS(buff_ptr, connect_offsets, num_elems);
+ UNPACK_EH(buff_ptr, connect, (num_elems*verts_per_entity));
entities.insert((*pit).first, (*pit).second);
@@ -663,7 +645,6 @@
if (just_count) {
for (; start_rit != entities.end(); start_rit++) {
setRange.insert(*start_rit);
- count += sizeof(MBEntityHandle);
unsigned int options;
result = mbImpl->get_meshset_options(*start_rit, options);
@@ -684,8 +665,6 @@
result = mbImpl->get_number_entities_by_handle(*start_rit, num_ents);
RR("Failed to get number entities in ordered set.");
- count += sizeof(int);
setSizes.push_back(num_ents);
count += sizeof(MBEntityHandle) * num_ents + sizeof(int);
@@ -701,6 +680,8 @@
count += 2*sizeof(int) + (num_par + num_ch) * sizeof(MBEntityHandle);
+ count += sizeof(int) + 2*num_subranges(setRange)*sizeof(MBEntityHandle);
else {
@@ -1158,7 +1139,7 @@
result = mbImpl->get_number_entities_by_dimension(0, 0, nverts_local);
int failure = MPI_Allreduce(&nverts_local, &nverts_total, 1,
- MPI_INTEGER, MPI_SUM, procConfig.proc_comm());
+ MPI_INT, MPI_SUM, procConfig.proc_comm());
if (failure) {
result = MB_FAILURE;
RR("Allreduce for total number of vertices failed.");
@@ -1196,7 +1177,8 @@
tuple_list shared_verts;
tuple_list_init_max(&shared_verts, 0, 2, 0,
skin_ents[0].size()*MAX_SHARING_PROCS);
- int i = 0, j = 0;
+ int i = 0;
+ unsigned int j = 0;
for (unsigned int p = 0; p < gsd->nlinfo->np; p++)
for (unsigned int np = 0; np < gsd->nlinfo->nshared[p]; np++)
shared_verts.vl[i++] = gsd->nlinfo->sh_ind[j++],
