[MOAB-dev] r1472 - MOAB/trunk
kraftche at mcs.anl.gov kraftche at mcs.anl.gov
Fri Dec 14 14:16:15 CST 2007
Author: kraftche
Date: 2007-12-14 14:16:15 -0600 (Fri, 14 Dec 2007)
New Revision: 1472
Modified:
   MOAB/trunk/SequenceManager.cpp
   MOAB/trunk/SequenceManager.hpp
   MOAB/trunk/TypeSequenceManager.cpp
   MOAB/trunk/TypeSequenceManager.hpp
Log:
Consolidate small allocation requests from file readers.
Modified: MOAB/trunk/SequenceManager.cpp
--- MOAB/trunk/SequenceManager.cpp	2007-12-14 20:07:07 UTC (rev 1471)
+++ MOAB/trunk/SequenceManager.cpp	2007-12-14 20:16:15 UTC (rev 1472)
@@ -10,12 +10,16 @@
 #include <assert.h>
 #include <new>
+#include <algorithm>
-const int DEFAULT_VERTEX_SEQUENCE_SIZE = 4096;
-const int DEFAULT_ELEMENT_SEQUENCE_SIZE = DEFAULT_VERTEX_SEQUENCE_SIZE;
-const int DEFAULT_POLY_SEQUENCE_SIZE = 4 * DEFAULT_ELEMENT_SEQUENCE_SIZE;
-const int DEFAULT_MESHSET_SEQUENCE_SIZE = DEFAULT_VERTEX_SEQUENCE_SIZE;
+const MBEntityID DEFAULT_VERTEX_SEQUENCE_SIZE = 4096;
+const MBEntityID DEFAULT_ELEMENT_SEQUENCE_SIZE = DEFAULT_VERTEX_SEQUENCE_SIZE;
+const MBEntityID DEFAULT_POLY_SEQUENCE_SIZE = 4 * DEFAULT_ELEMENT_SEQUENCE_SIZE;
+const MBEntityID DEFAULT_MESHSET_SEQUENCE_SIZE = DEFAULT_VERTEX_SEQUENCE_SIZE;
+MBEntityID SequenceManager::default_poly_sequence_size( int conn_len )
+  {  return std::max( DEFAULT_POLY_SEQUENCE_SIZE / conn_len, (MBEntityID)1 ); }
 void SequenceManager::clear()
     // destroy all TypeSequenceManager instances
@@ -162,9 +166,7 @@
     SequenceData* seq_data = 0;
     unsigned size = DEFAULT_ELEMENT_SEQUENCE_SIZE;
     if (type == MBPOLYGON || type == MBPOLYHEDRON) {
-      size = DEFAULT_POLY_SEQUENCE_SIZE / conn_len;
-      if (!size)
-        size = 1;
+      size = default_poly_sequence_size( conn_len );
     handle = typeData[type].find_free_sequence( size, start, end, seq_data, conn_len );
@@ -361,6 +363,27 @@
   return handle;
+MBEntityID SequenceManager::new_sequence_size( MBEntityHandle start,
+                                               MBEntityID requested_size,
+                                               MBEntityID default_size ) const
+  if (requested_size >= default_size)
+    return requested_size;
+  MBEntityHandle last = typeData[TYPE_FROM_HANDLE(start)].last_free_handle( start );
+  if (!last) {
+    assert( false );
+    return 0;
+  MBEntityID available_size = last - start + 1;
+  if (default_size < available_size)
+    return default_size;
+  else
+    return available_size;
 MBErrorCode
 SequenceManager::create_entity_sequence( MBEntityType type,
                                          MBEntityID count,
@@ -390,7 +413,8 @@
     if (data)
       sequence = new VertexSequence( handle, count, data );
     else
-      sequence = new VertexSequence( handle, count, count );
+      sequence = new VertexSequence( handle, count,
+           new_sequence_size( handle, count, DEFAULT_VERTEX_SEQUENCE_SIZE ) );
     break;
@@ -402,7 +426,8 @@
     if (data)
       sequence = new PolyElementSeq( handle, count, size, data );
     else
-      sequence = new PolyElementSeq( handle, count, size, count );
+      sequence = new PolyElementSeq( handle, count, size,
+           new_sequence_size( handle, count, default_poly_sequence_size(size) ) );
     break;
@@ -413,7 +438,8 @@
     if (data)
       sequence = new UnstructuredElemSeq( handle, count, size, data );
     else
-      sequence = new UnstructuredElemSeq( handle, count, size, count );
+      sequence = new UnstructuredElemSeq( handle, count, size,
+           new_sequence_size( handle, count, DEFAULT_ELEMENT_SEQUENCE_SIZE ) );
     break;
Modified: MOAB/trunk/SequenceManager.hpp
--- MOAB/trunk/SequenceManager.hpp	2007-12-14 20:07:07 UTC (rev 1471)
+++ MOAB/trunk/SequenceManager.hpp	2007-12-14 20:16:15 UTC (rev 1472)
@@ -167,7 +167,14 @@
                                     unsigned long& total,
                                     unsigned long& per_entity ) const;
+      /**\brief Get default size of POLYGON and POLYHEDRON SequenceData */
+    static MBEntityID default_poly_sequence_size( int entity_connectivity_length );
+      /**\brief Size to allocate for new SquenceData */
+    MBEntityID new_sequence_size( MBEntityHandle start_handle,
+                                  MBEntityID reqested_size,
+                                  MBEntityID default_size ) const;
   private:
     /**\brief Utility function for allocate_mesh_set (and similar)
Modified: MOAB/trunk/TypeSequenceManager.cpp
--- MOAB/trunk/TypeSequenceManager.cpp	2007-12-14 20:07:07 UTC (rev 1471)
+++ MOAB/trunk/TypeSequenceManager.cpp	2007-12-14 20:16:15 UTC (rev 1472)
@@ -547,6 +547,18 @@
   return 0;
+MBEntityHandle TypeSequenceManager::last_free_handle( MBEntityHandle after_this ) const
+  int junk;
+  const_iterator it = lower_bound( after_this );
+  if (it == end())
+    return CREATE_HANDLE( TYPE_FROM_HANDLE(after_this), MB_END_ID, junk );
+  else if ((*it)->start_handle() > after_this)
+    return (*it)->start_handle() - 1;
+  else
+    return 0;
 MBErrorCode TypeSequenceManager::check_valid_handles( MBEntityHandle first,
                                                       MBEntityHandle last ) const
Modified: MOAB/trunk/TypeSequenceManager.hpp
--- MOAB/trunk/TypeSequenceManager.hpp	2007-12-14 20:07:07 UTC (rev 1471)
+++ MOAB/trunk/TypeSequenceManager.hpp	2007-12-14 20:16:15 UTC (rev 1472)
@@ -303,6 +303,8 @@
                               MBEntityHandle& block_end,
                               int values_per_ent = 0 );
+  MBEntityHandle last_free_handle( MBEntityHandle after_this ) const;
     /**\brief Notify that sequence was prepended to
      * Notify of sequence modifications so we can check if
