[MOAB-dev] r1460 - MOAB/trunk/tools/qvdual
tautges at mcs.anl.gov tautges at mcs.anl.gov
Fri Dec 7 17:38:20 CST 2007
Author: tautges
Date: 2007-12-07 17:38:20 -0600 (Fri, 07 Dec 2007)
New Revision: 1460
Modified:
   MOAB/trunk/tools/qvdual/uiQVDual.ui
Log:
Adding back in sheet printing stuff I'd removed.
Modified: MOAB/trunk/tools/qvdual/uiQVDual.ui
--- MOAB/trunk/tools/qvdual/uiQVDual.ui	2007-12-07 23:32:45 UTC (rev 1459)
+++ MOAB/trunk/tools/qvdual/uiQVDual.ui	2007-12-07 23:38:20 UTC (rev 1460)
@@ -485,6 +485,7 @@
         <action name="displayInvertSelectionAction"/>
         <action name="displayDisplayAllActions"/>
         <action name="displayDrawSheetAction"/>
+        <action name="displayPrintSheetAction"/>
     </item>
 </menubar>
 <toolbars>
@@ -752,6 +753,17 @@
             <string>Draw Sheet</string>
         </property>
     </action>
+    <action>
+        <property name="name">
+            <cstring>displayPrintSheetAction</cstring>
+        </property>
+        <property name="text">
+            <string>Print Sheet</string>
+        </property>
+        <property name="menuText">
+        </property>
+    </action>
 </actions>
 <connections>
     <connection>
@@ -893,6 +905,12 @@
         <slot>displayDrawSheetAction_activated()</slot>
     </connection>
     <connection>
+        <sender>displayPrintSheetAction</sender>
+        <signal>activated()</signal>
+        <receiver>uiQVDual</receiver>
+        <slot>displayPrintSheet()</slot>
+    </connection>
+    <connection>
         <sender>APbutton</sender>
         <signal>clicked()</signal>
@@ -998,6 +1016,7 @@
     <slot>displayDisplayAll()</slot>
     <slot>CropToolButton_clicked()</slot>
     <slot>APbutton_clicked()</slot>
     <slot>negAPbutton_clicked()</slot>
     <slot>FOCbutton_clicked()</slot>
