[MOAB-dev] r1459 - MOAB/trunk/tools/qvdual
    tautges at mcs.anl.gov
    Fri Dec  7 17:32:45 CST 2007
Author: tautges
Date: 2007-12-07 17:32:45 -0600 (Fri, 07 Dec 2007)
New Revision: 1459
Added:
   MOAB/trunk/tools/qvdual/uiQVDual.ui
Log:
Re-adding a file I shouldn't have removed.
Added: MOAB/trunk/tools/qvdual/uiQVDual.ui
--- MOAB/trunk/tools/qvdual/uiQVDual.ui	                        (rev 0)
+++ MOAB/trunk/tools/qvdual/uiQVDual.ui	2007-12-07 23:32:45 UTC (rev 1459)
@@ -0,0 +1,1029 @@
+<!DOCTYPE UI><UI version="3.3" stdsetdef="1">
+<class>uiQVDual</class>
+<widget class="QMainWindow">
+    <property name="name">
+        <cstring>uiQVDual</cstring>
+    </property>
+    <property name="geometry">
+        <rect>
+            <x>0</x>
+            <y>0</y>
+            <width>1010</width>
+            <height>771</height>
+        </rect>
+    </property>
+    <property name="sizePolicy">
+        <sizepolicy>
+            <hsizetype>5</hsizetype>
+            <vsizetype>5</vsizetype>
+            <horstretch>0</horstretch>
+            <verstretch>0</verstretch>
+        </sizepolicy>
+    </property>
+    <property name="minimumSize">
+        <size>
+            <width>21</width>
+            <height>160</height>
+        </size>
+    </property>
+    <property name="caption">
+        <string>QVDual</string>
+    </property>
+    <property name="mouseTracking">
+        <bool>false</bool>
+    </property>
+    <property name="focusPolicy">
+        <enum>NoFocus</enum>
+    </property>
+    <widget class="QLayoutWidget">
+            <cstring>layout13</cstring>
+        </property>
+            <rect>
+                <x>-19</x>
+                <y>1</y>
+                <width>412</width>
+                <height>635</height>
+            </rect>
+        </property>
+        <vbox>
+                <cstring>unnamed</cstring>
+            </property>
+            <widget class="QListView">
+                <column>
+                    <property name="text">
+                        <string>Actor</string>
+                    </property>
+                    <property name="clickable">
+                        <bool>true</bool>
+                    </property>
+                    <property name="resizable">
+                    </property>
+                </column>
+            <item>
+                    <string>New Item</string>
+                </property>
+                <property name="pixmap">
+                    <pixmap></pixmap>
+                </property>
+            </item>
+                    <cstring>ActorListView1</cstring>
+                </property>
+                    <sizepolicy>
+                        <hsizetype>7</hsizetype>
+                        <vsizetype>7</vsizetype>
+                        <verstretch>1</verstretch>
+                    </sizepolicy>
+                </property>
+                    <size>
+                        <width>100</width>
+                        <height>0</height>
+                    </size>
+                </property>
+                <property name="maximumSize">
+                    <size>
+                        <width>300</width>
+                        <height>32767</height>
+                    </size>
+                </property>
+                <property name="resizePolicy">
+                    <enum>Manual</enum>
+                </property>
+                <property name="hScrollBarMode">
+                    <enum>AlwaysOn</enum>
+                </property>
+                <property name="selectionMode">
+                    <enum>Extended</enum>
+                </property>
+                <property name="allColumnsShowFocus">
+                    <bool>true</bool>
+                </property>
+                <property name="showSortIndicator">
+                    <bool>true</bool>
+                </property>
+                <property name="rootIsDecorated">
+                    <bool>true</bool>
+                </property>
+                <property name="resizeMode">
+                    <enum>AllColumns</enum>
+                </property>
+            </widget>
+                <column>
+                        <string>Tag/Value</string>
+                    </property>
+                        <bool>true</bool>
+                    </property>
+                    </property>
+                </column>
+            <item>
+                </property>
+                    <pixmap></pixmap>
+                </property>
+            </item>
+                    <cstring>TagListView1</cstring>
+                </property>
+                    <sizepolicy>
+                    </sizepolicy>
+                </property>
+                    <size>
+                    </size>
+                </property>
+                    <size>
+                    </size>
+                </property>
+                </property>
+                </property>
+                </property>
+                    <bool>true</bool>
+                </property>
+                    <bool>true</bool>
+                </property>
+                    <bool>true</bool>
+                </property>
+                </property>
+            </widget>
+        </vbox>
+    </widget>
+    <widget class="QPushButton">
+            <cstring>APbutton</cstring>
+        </property>
+            <rect>
+                <x>400</x>
+                <y>580</y>
+                <width>40</width>
+                <height>25</height>
+            </rect>
+        </property>
+            <string>AP</string>
+        </property>
+    </widget>
+            <cstring>FOCbutton</cstring>
+        </property>
+            <rect>
+                <x>450</x>
+                <y>580</y>
+                <width>40</width>
+            </rect>
+        </property>
+            <string>FOC</string>
+        </property>
+    </widget>
+            <cstring>FSbutton</cstring>
+        </property>
+            <rect>
+                <x>500</x>
+                <y>580</y>
+                <width>30</width>
+            </rect>
+        </property>
+            <string>FS</string>
+        </property>
+    </widget>
+            <cstring>Create_Dual_Button</cstring>
+        </property>
+            <rect>
+                <x>400</x>
+                <y>640</y>
+                <width>77</width>
+                <height>26</height>
+            </rect>
+        </property>
+            <sizepolicy>
+                <hsizetype>0</hsizetype>
+                <vsizetype>0</vsizetype>
+            </sizepolicy>
+        </property>
+            <string>Make Dual</string>
+        </property>
+        <property name="toolTip" stdset="0">
+            <string>Create the dual</string>
+        </property>
+    </widget>
+            <cstring>DebugButton</cstring>
+        </property>
+            <rect>
+                <x>400</x>
+                <y>670</y>
+                <width>52</width>
+            </rect>
+        </property>
+            <sizepolicy>
+            </sizepolicy>
+        </property>
+            <string>Debug</string>
+        </property>
+    </widget>
+            <cstring>negAPbutton</cstring>
+        </property>
+            <rect>
+                <x>400</x>
+                <y>610</y>
+                <width>40</width>
+            </rect>
+        </property>
+            <string>-AP</string>
+        </property>
+    </widget>
+            <cstring>negFOCbutton</cstring>
+        </property>
+            <rect>
+                <x>450</x>
+                <y>610</y>
+                <width>40</width>
+            </rect>
+        </property>
+            <string>-FOC</string>
+        </property>
+    </widget>
+            <cstring>negFCbutton</cstring>
+        </property>
+            <rect>
+                <x>500</x>
+                <y>610</y>
+                <width>30</width>
+            </rect>
+        </property>
+            <string>-FS</string>
+        </property>
+    </widget>
+            <cstring>CropTool</cstring>
+        </property>
+            <rect>
+                <x>580</x>
+                <y>660</y>
+                <width>81</width>
+                <height>31</height>
+            </rect>
+        </property>
+            <string>CropTool</string>
+        </property>
+    </widget>
+            <cstring>CropToolButton</cstring>
+        </property>
+            <rect>
+                <x>490</x>
+                <y>660</y>
+                <width>71</width>
+            </rect>
+        </property>
+            <string>Crop</string>
+        </property>
+    </widget>
+            <cstring>layout6</cstring>
+        </property>
+            <rect>
+                <x>550</x>
+                <y>580</y>
+                <width>310</width>
+                <height>40</height>
+            </rect>
+        </property>
+        <hbox>
+            </property>
+            <widget class="QLabel">
+                    <cstring>picklabel1</cstring>
+                </property>
+                    <string>Pick 1:</string>
+                </property>
+            </widget>
+            <widget class="QLineEdit">
+                    <cstring>pickline1</cstring>
+                </property>
+            </widget>
+        </hbox>
+    </widget>
+            <cstring>layout7</cstring>
+        </property>
+            <rect>
+                <x>550</x>
+                <y>620</y>
+            </rect>
+        </property>
+        <hbox>
+            </property>
+                    <cstring>picklabel2</cstring>
+                </property>
+                    <string>Pick 2:</string>
+                </property>
+            </widget>
+                    <cstring>pickline2</cstring>
+                </property>
+            </widget>
+        </hbox>
+    </widget>
+    <widget class="QVTKWidget">
+            <cstring>vtkWidget</cstring>
+        </property>
+            <rect>
+                <x>400</x>
+                <y>10</y>
+                <width>600</width>
+                <height>569</height>
+            </rect>
+        </property>
+            <sizepolicy>
+            </sizepolicy>
+        </property>
+            <size>
+                <width>0</width>
+            </size>
+        </property>
+    </widget>
+</widget>
+<menubar>
+        <cstring>MenuBar</cstring>
+    </property>
+    <item text="&File" name="fileMenu">
+        <action name="fileNewAction"/>
+        <action name="fileOpenAction"/>
+        <action name="fileSaveAction"/>
+        <action name="fileSaveAsAction"/>
+        <separator/>
+        <action name="filePrintAction"/>
+        <separator/>
+        <action name="fileExitAction"/>
+    </item>
+    <item text="&Help" name="helpMenu">
+        <action name="helpContentsAction"/>
+        <action name="helpIndexAction"/>
+        <separator/>
+        <action name="helpAboutAction"/>
+    </item>
+    <item text="Window" name="Window">
+        <action name="windowTagViewAction"/>
+        <action name="windowSheetViewAction"/>
+        <action name="windowChordViewAction"/>
+    </item>
+    <item text="Display" name="Display">
+        <action name="displayVisibleAction"/>
+        <action name="displayInvisibleAction"/>
+        <action name="displayDrawAction"/>
+        <action name="displayWireframeShadedAction"/>
+        <action name="displayInvertSelectionAction"/>
+        <action name="displayDisplayAllActions"/>
+        <action name="displayDrawSheetAction"/>
+    </item>
+</menubar>
+<toolbars>
+</toolbars>
+<actions>
+    <action>
+            <cstring>fileNewAction</cstring>
+        </property>
+        <property name="iconSet">
+            <iconset></iconset>
+        </property>
+            <string>New</string>
+        </property>
+        <property name="menuText">
+            <string>&New</string>
+        </property>
+    </action>
+    <action>
+            <cstring>fileOpenAction</cstring>
+        </property>
+        </property>
+            <string>Open</string>
+        </property>
+            <string>&Open...</string>
+        </property>
+    </action>
+    <action>
+            <cstring>fileSaveAction</cstring>
+        </property>
+        </property>
+            <string>Save</string>
+        </property>
+            <string>&Save</string>
+        </property>
+    </action>
+    <action>
+            <cstring>fileSaveAsAction</cstring>
+        </property>
+            <string>Save As</string>
+        </property>
+            <string>Save &As...</string>
+        </property>
+        <property name="accel">
+            <string></string>
+        </property>
+    </action>
+    <action>
+            <cstring>filePrintAction</cstring>
+        </property>
+        </property>
+            <string>Print</string>
+        </property>
+            <string>&Print...</string>
+        </property>
+    </action>
+    <action>
+            <cstring>fileExitAction</cstring>
+        </property>
+            <string>Exit</string>
+        </property>
+            <string>E&xit</string>
+        </property>
+            <string></string>
+        </property>
+    </action>
+    <action>
+            <cstring>helpContentsAction</cstring>
+        </property>
+            <string>Contents</string>
+        </property>
+            <string>&Contents...</string>
+        </property>
+            <string></string>
+        </property>
+    </action>
+    <action>
+            <cstring>helpIndexAction</cstring>
+        </property>
+            <string>Index</string>
+        </property>
+            <string>&Index...</string>
+        </property>
+            <string></string>
+        </property>
+    </action>
+    <action>
+            <cstring>helpAboutAction</cstring>
+        </property>
+            <string>About</string>
+        </property>
+            <string>&About</string>
+        </property>
+            <string></string>
+        </property>
+    </action>
+    <action>
+            <cstring>windowTagViewAction</cstring>
+        </property>
+            <string>Tag view</string>
+        </property>
+        </property>
+        <property name="whatsThis">
+            <string>Hierarchical tag view</string>
+        </property>
+    </action>
+    <action>
+            <cstring>windowSheetViewAction</cstring>
+        </property>
+            <string>Sheet view</string>
+        </property>
+        </property>
+            <string>Toggle sheet visibility</string>
+        </property>
+    </action>
+    <action>
+            <cstring>windowChordViewAction</cstring>
+        </property>
+            <string>Chord view</string>
+        </property>
+        </property>
+            <string>Toggle chord visibility</string>
+        </property>
+    </action>
+    <action>
+            <cstring>windowActorViewAction</cstring>
+        </property>
+            <string>Actor view</string>
+        </property>
+            <string>Toggle actor view</string>
+        </property>
+    </action>
+    <action>
+            <cstring>displayVisibleAction</cstring>
+        </property>
+        <property name="toggleAction">
+        </property>
+        <property name="on">
+        </property>
+            <string>Visible</string>
+        </property>
+        </property>
+    </action>
+    <action>
+            <cstring>displayDrawAction</cstring>
+        </property>
+            <string>Draw</string>
+        </property>
+        </property>
+    </action>
+    <action>
+            <cstring>displayWireframeShadedAction</cstring>
+        </property>
+            <string>Wireframe/Shaded</string>
+        </property>
+        </property>
+    </action>
+    <action>
+            <cstring>displayInvertSelectionAction</cstring>
+        </property>
+            <string>Invert selection</string>
+        </property>
+        </property>
+    </action>
+    <action>
+            <cstring>displayInvisibleAction</cstring>
+        </property>
+            <string>Invisible</string>
+        </property>
+        </property>
+    </action>
+    <action>
+            <cstring>displayDisplayAllActions</cstring>
+        </property>
+            <string>Display All</string>
+        </property>
+        </property>
+    </action>
+    <action>
+            <cstring>displayDrawSheetAction</cstring>
+        </property>
+            <string>Draw Sheet</string>
+        </property>
+        </property>
+    </action>
+</actions>
+<connections>
+    <connection>
+        <sender>ActorListView1</sender>
+        <signal>selectionChanged()</signal>
+        <receiver>uiQVDual</receiver>
+        <slot>ActorTreeView_selectionChanged()</slot>
+    </connection>
+    <connection>
+        <signal>rightButtonPressed(QListViewItem*,const QPoint&,int)</signal>
+        <slot>ActorListView1_rightButtonPressed(QListViewItem*,const QPoint&,int)</slot>
+    </connection>
+    <connection>
+        <sender>Create_Dual_Button</sender>
+        <signal>clicked()</signal>
+        <slot>constructDual()</slot>
+    </connection>
+    <connection>
+        <sender>DebugButton</sender>
+        <signal>pressed()</signal>
+        <slot>DebugButton_pressed()</slot>
+    </connection>
+    <connection>
+        <sender>displayDisplayAllActions</sender>
+        <signal>activated()</signal>
+        <slot>displayDisplayAll()</slot>
+    </connection>
+    <connection>
+        <sender>displayDrawAction</sender>
+        <slot>displayDraw()</slot>
+    </connection>
+    <connection>
+        <sender>displayInvertSelectionAction</sender>
+        <slot>displayInvertSelection()</slot>
+    </connection>
+    <connection>
+        <sender>displayVisibleAction</sender>
+        <slot>displayVisible()</slot>
+    </connection>
+    <connection>
+        <sender>displayWireframeShadedAction</sender>
+        <slot>displayWireframeShaded()</slot>
+    </connection>
+    <connection>
+        <sender>fileExitAction</sender>
+        <slot>fileExit()</slot>
+    </connection>
+    <connection>
+        <sender>fileNewAction</sender>
+        <slot>fileNew()</slot>
+    </connection>
+    <connection>
+        <sender>fileOpenAction</sender>
+        <slot>fileOpen()</slot>
+    </connection>
+    <connection>
+        <sender>filePrintAction</sender>
+        <slot>filePrint()</slot>
+    </connection>
+    <connection>
+        <sender>fileSaveAction</sender>
+        <slot>fileSave()</slot>
+    </connection>
+    <connection>
+        <sender>fileSaveAsAction</sender>
+        <slot>fileSaveAs()</slot>
+    </connection>
+    <connection>
+        <sender>helpAboutAction</sender>
+        <slot>helpAbout()</slot>
+    </connection>
+    <connection>
+        <sender>helpContentsAction</sender>
+        <slot>helpContents()</slot>
+    </connection>
+    <connection>
+        <sender>helpIndexAction</sender>
+        <slot>helpIndex()</slot>
+    </connection>
+    <connection>
+        <sender>TagListView1</sender>
+        <slot>TagTreeView_selectionChanged()</slot>
+    </connection>
+    <connection>
+        <slot>TagListView1_rightButtonPressed(QListViewItem*,const QPoint&,int)</slot>
+    </connection>
+    <connection>
+        <sender>displayInvisibleAction</sender>
+        <slot>displayInvisible()</slot>
+    </connection>
+    <connection>
+        <sender>CropToolButton</sender>
+        <slot>CropToolButton_clicked()</slot>
+    </connection>
+    <connection>
+        <sender>displayDrawSheetAction</sender>
+        <slot>displayDrawSheetAction_activated()</slot>
+    </connection>
+    <connection>
+        <sender>APbutton</sender>
+        <slot>APbutton_clicked()</slot>
+    </connection>
+    <connection>
+        <sender>negAPbutton</sender>
+        <slot>negAPbutton_clicked()</slot>
+    </connection>
+    <connection>
+        <sender>FOCbutton</sender>
+        <slot>FOCbutton_clicked()</slot>
+    </connection>
+    <connection>
+        <sender>FSbutton</sender>
+        <slot>FSbutton_clicked()</slot>
+    </connection>
+    <connection>
+        <sender>negFCbutton</sender>
+        <slot>negFCbutton_clicked()</slot>
+    </connection>
+    <connection>
+        <sender>pickline1</sender>
+        <signal>returnPressed()</signal>
+        <slot>pickline1_returnPressed()</slot>
+    </connection>
+</connections>
+<includes>
+    <include location="local" impldecl="in declaration">MBInterface.hpp</include>
+    <include location="global" impldecl="in declaration">map</include>
+    <include location="global" impldecl="in declaration">set</include>
+    <include location="local" impldecl="in implementation">vtkRenderer.h</include>
+    <include location="local" impldecl="in implementation">vtkRenderWindow.h</include>
+    <include location="local" impldecl="in implementation">vtkActor.h</include>
+    <include location="local" impldecl="in implementation">MBCore.hpp</include>
+    <include location="local" impldecl="in implementation">vtkDataSetMapper.h</include>
+    <include location="local" impldecl="in implementation">qfiledialog.h</include>
+    <include location="local" impldecl="in implementation">vtkMOABReader.h</include>
+    <include location="local" impldecl="in implementation">vtkUnstructuredGridSource.h</include>
+    <include location="local" impldecl="in implementation">vtkUnstructuredGrid.h</include>
+    <include location="local" impldecl="in implementation">vtkMOABUtils.h</include>
+    <include location="local" impldecl="in implementation">qapplication.h</include>
+    <include location="local" impldecl="in implementation">MBTagConventions.hpp</include>
+    <include location="local" impldecl="in implementation">vtkRenderWindowInteractor.h</include>
+    <include location="local" impldecl="in implementation">CropToolpopup.h</include>
+    <include location="local" impldecl="in implementation">CropTool.hpp</include>
+    <include location="local" impldecl="in implementation">DrawDual.hpp</include>
+    <include location="local" impldecl="in implementation">uiQVDual.ui.h</include>
+</includes>
+<forwards>
+    <forward>class vtkUnstructuredGrid</forward>
+    <forward>class vtkRenderer</forward>
+    <forward>class vtkRenderWindowInteractor</forward>
+    <forward>class vtkProperty</forward>
+    <forward>class CropToolPopup</forward>
+    <forward>class DrawDual</forward>
+</forwards>
+<variables>
+    <variable access="private">QString lastOpened;</variable>
+    <variable access="public">bool computeDual;</variable>
+    <variable>CropToolPopup *cropToolPopup;</variable>
+    <variable access="private">std::map<QListViewItem*,MBEntityHandle> itemSetMap;</variable>
+    <variable access="private">vtkUnstructuredGrid *myUG;</variable>
+    <variable>std::set<QListViewItem*> itemSelList;</variable>
+    <variable access="private">int currentWin;</variable>
+    <variable>DrawDual *drawDual;</variable>
+</variables>
+<signals>
+    <signal>toggled()</signal>
+</signals>
+<slots>
+    <slot>fileOpen( const QString & filename )</slot>
+    <slot>fileSaveAs( const QString & filename )</slot>
+    <slot>updateMesh()</slot>
+    <slot>ActorListView1_rightButtonPressed( QListViewItem * item, const QPoint &, int )</slot>
+    <slot>TagListView1_rightButtonPressed( QListViewItem *, const QPoint &, int )</slot>
+    <slot>resetDisplay()</slot>
+    <slot>redrawDisplay()</slot>
+</slots>
+<functions>
+    <function access="private" specifier="non virtual">init()</function>
+    <function access="private" specifier="non virtual">destroy()</function>
+    <function access="private">updateTagList()</function>
+    <function access="private">updateActorList()</function>
+    <function access="private">updateActorContainsList( QListViewItem * item, MBEntityHandle set_handle )</function>
+    <function access="private">updateActorParentList( QListViewItem * item, MBEntityHandle set_handle )</function>
+    <function access="private">changeSetProperty( std::set<QListViewItem *> & high_sets, std::set<QListViewItem *> & unhigh_sets )</function>
+    <function access="private">evalItem( QListViewItem * item, const bool high, MBRange & high_mbsets, MBRange & unhigh_mbsets )</function>
+    <function access="private">getSelected( QListView * listv, std::set<QListViewItem *> & selected, std::set<QListViewItem *> & unselected )</function>
+    <function access="private">getSelected( QListView * listv, MBRange & selected, MBRange & unselected )</function>
+    <function access="private">getItemSets( std::set<QListViewItem *> & items, MBRange & sets )</function>
+</functions>
+<pixmapinproject/>
+<layoutdefaults spacing="6" margin="11"/>
+<includehints>
+    <includehint>QVTKWidget.h</includehint>
+</includehints>
+</UI>
