[MOAB-dev] r1441 - in MOAB/trunk: . Refiner
pebay at mcs.anl.gov pebay at mcs.anl.gov
Thu Dec 6 19:26:16 CST 2007
Author: pebay
Date: 2007-12-06 19:26:15 -0600 (Thu, 06 Dec 2007)
New Revision: 1441
Added:
   MOAB/trunk/Refiner/
   MOAB/trunk/Refiner/MBRefiner.cpp
Log:
ENH: progress -- checkpoint.
Added: MOAB/trunk/Refiner/MBRefiner.cpp
--- MOAB/trunk/Refiner/MBRefiner.cpp	                        (rev 0)
+++ MOAB/trunk/Refiner/MBRefiner.cpp	2007-12-07 01:26:15 UTC (rev 1441)
@@ -0,0 +1,2259 @@
+ * Copyright 2003 Sandia Corporation.
+ * Under the terms of Contract DE-AC04-94AL85000, there is a non-exclusive
+ * license for use of this work by or on behalf of the
+ * U.S. Government. Redistribution and use in source and binary forms, with
+ * or without modification, are permitted provided that this Notice and any
+ * statement of authorship are reproduced on all copies.
+#include "MBRefiner.h"
+#include "MBEdgeEvaluator.h"
+#include "verdict.h"
+// how's this for avoiding namespace conflicts?! 8-)
+static vtkTetra* argyle = 0;
+static int argyleRef = 0;
+static vtkPoints* goCallTheCops;
+#undef UGLY_ASPECT_RATIO_HACK
+#undef DBG_MIDPTS
+#include <stack>
+#include <algorithm>
+#ifdef PARAVIEW_DEBUG_TESSELLATOR
+#  define VTK_TESSELLATOR_INCR_CASE_COUNT(cs) this->CaseCounts[cs]++
+#  define VTK_TESSELLATOR_INCR_SUBCASE_COUNT(cs,sc) this->SubcaseCounts[cs][sc]++
+#else // PARAVIEW_DEBUG_TESSELLATOR
+#endif // PARAVIEW_DEBUG_TESSELLATOR
+MBRefiner::MBRefiner()
+  this->PrivateData = 0;
+  this->ConstPrivateData = 0;
+  this->Algorithm = 0;
+  this->Callback1 = 0;
+  this->Callback2 = 0;
+  this->Callback3 = 0;
+  this->MaximumNumberOfSubdivisions = 3;
+  for ( int i=0; i<4; ++i )
+    this->EmbeddingDimension[i] = i;
+    this->PointDimension[i] = i+3; // By default, FieldSize = 0
+  if ( ! argyle )
+    argyle = vtkTetra::New();
+    argyleRef = 1;
+    goCallTheCops = argyle->GetPoints();
+  else
+    ++argyleRef;
+MBRefiner::~MBRefiner()
+  if ( this->Algorithm )
+    this->Algorithm->UnRegister( this );
+  if ( ! (--argyleRef) )
+    argyle->Delete();
+    argyle = 0;
+void MBRefiner::SetEmbeddingDimension( int k, int d )
+  if ( d > 8 )
+    MBErrorMacro( "Embedding dimension may not be > 8. (You asked for " << d << "). Truncating to 8." );
+    d = 8;
+  if ( k == 0 || k < -1 || k >= 4 )
+    vtkWarningMacro( "Invalid argument k=" << k );
+    return;
+  if ( k < 0 )
+    for ( k=0; k<4; k++ )
+      if ( this->EmbeddingDimension[k] != d )
+        this->PointDimension[k] += d - this->EmbeddingDimension[k] ;
+        this->EmbeddingDimension[k] = d;
+        this->Modified();
+    return;
+    this->Modified();
+void MBRefiner::SetFieldSize( int k, int s )
+  if ( s > MBRefiner::MaxFieldSize )
+    MBErrorMacro( "Embedding dimension may not be > " << MaxFieldSize << ". (You asked for " << s << "). Truncating to " << MaxFieldSize );
+    s = MBRefiner::MaxFieldSize;
+    return;
+  if ( k < 0 )
+    // Use field size for all facet types (point, line, triangle, tet, ...)
+      if ( this->PointDimension[k] != s + this->EmbeddingDimension[k] + 3 )
+        this->PointDimension[k] = s + this->EmbeddingDimension[k] + 3;
+        this->Modified();
+    return;
+    this->Modified();
+void MBRefiner::SetMaximumNumberOfSubdivisions( int num_subdiv_in )
+  if ( this->MaximumNumberOfSubdivisions == num_subdiv_in )
+    return;
+  if ( num_subdiv_in < 0 )
+    MBErrorMacro( "MaximumNumberOfSubdivisions must be 0 or greater (you requested " << num_subdiv_in << ")" );
+    return;
+  this->MaximumNumberOfSubdivisions = num_subdiv_in;
+  this->Modified();
+void MBRefiner::SetTriangleCallback( TriangleProcessorFunction f )
+  this->Callback2 = f;
+MBRefiner::TriangleProcessorFunction MBRefiner::GetTriangleCallback() const
+  return this->Callback2;
+void MBRefiner::SetTetrahedronCallback( TetrahedronProcessorFunction f )
+  this->Callback3 = f;
+MBRefiner::TetrahedronProcessorFunction MBRefiner::GetTetrahedronCallback() const
+  return this->Callback3;
+void MBRefiner::SetEdgeCallback( EdgeProcessorFunction f )
+  this->Callback1 = f;
+MBRefiner::EdgeProcessorFunction MBRefiner::GetEdgeCallback() const
+  return this->Callback1;
+void MBRefiner::SetPrivateData( void* Private )
+  this->PrivateData = Private;
+void* MBRefiner::GetPrivateData() const
+  return this->PrivateData;
+void MBRefiner::SetConstPrivateData( const void* ConstPrivate )
+  this->ConstPrivateData = ConstPrivate;
+const void* MBRefiner::GetConstPrivateData() const
+  return this->ConstPrivateData;
+void MBRefiner::SetSubdivisionAlgorithm( vtkSubdivisionAlgorithm* a )
+  if ( a != this->Algorithm )
+    this->Algorithm = a;
+    this->Modified();
+      this->Algorithm->Register( this );
+// Returns true if || a0a1 || < || b0b1 ||
+// We use this to test which triangulation has the best
+// aspect ratio when there are 2 to choose from.
+bool compare_Hopf_cross_string_dist( const double* a0, const double* a1, const double* b0, const double* b1 )
+  double SqMagA = 0.;
+  double SqMagB = 0.;
+  for (int i=0; i<3; i++)
+    double tmp;
+    tmp = a0[i] - a1[i];
+    SqMagA += tmp*tmp;
+    tmp = b0[i] - b1[i];
+    SqMagB += tmp*tmp;
+  return SqMagA < SqMagB;
+int MBRefiner::BestTets( int* connOffsets, double** verts, int permOffset, int sgn ) const
+  int bestOffset = -1;
+  double bestQuality = 0.;
+  double currQuality;
+  while ( *connOffsets >= 0 )
+    int nTets = TetrahedralDecompositions[*connOffsets];
+    vtkIdType* conn = &TetrahedralDecompositions[*connOffsets +1];
+    int v;
+    currQuality = 0.;
+    for (v=0; v<nTets; ++v)
+      goCallTheCops->SetPoint( 0, verts[ MBRefiner::PermutationsFromIndex[ permOffset ][ conn[sgn < 0 ? 1:0]] ] );
+      goCallTheCops->SetPoint( 1, verts[ MBRefiner::PermutationsFromIndex[ permOffset ][ conn[sgn < 0 ? 0:1]] ] );
+      goCallTheCops->SetPoint( 2, verts[ MBRefiner::PermutationsFromIndex[ permOffset ][ conn[2]] ] );
+      goCallTheCops->SetPoint( 3, verts[ MBRefiner::PermutationsFromIndex[ permOffset ][ conn[3]] ] );
+      currQuality += vtkMeshQuality::TetAspectFrobenius( argyle );
+      conn += 4;
+    currQuality /= nTets;
+    //std::cout << currQuality << " " << *connOffsets << " ";
+    if ( bestQuality > currQuality || bestOffset < 0 )
+      bestQuality = currQuality;
+      bestOffset = *connOffsets;
+      ++connOffsets;
+    //std::cout << "Choose " << bestOffset << "\n";
+  return bestOffset;
+void MBRefiner::AdaptivelySample1Facet( double* v0, double* v1, int maxDepth ) const
+  int edgeCode = 0;
+  double midpt0[11+MBRefiner::MaxFieldSize];
+  // make valgrind happy
+  std::fill(midpt0,midpt0+this->PointDimension[1],0.);
+  if ( maxDepth-- > 0 )
+      for ( int i=0; i<this->PointDimension[1]; i++ )
+        midpt0[i] = (v0[i] + v1[i])/2.;
+      if ( this->Algorithm->EvaluateEdge( v0, midpt0, v1, 3+this->EmbeddingDimension[1] ) )
+        edgeCode += 1;
+  switch (edgeCode) {
+    // No edges to subdivide
+    case 0:
+      Callback1( v0, v1, this->Algorithm, this->PrivateData, this->ConstPrivateData );
+      break ;
+      // One edge to subdivide
+    case 1:
+      this->AdaptivelySample1Facet( v0, midpt0, maxDepth );
+      this->AdaptivelySample1Facet( midpt0, v1, maxDepth );
+      break;
+void MBRefiner::AdaptivelySample2Facet( double* v0, double* v1, double* v2, int maxDepth, int move ) const
+  int edgeCode = 0;
+  double midpt1[11+MBRefiner::MaxFieldSize];
+  double midpt2[11+MBRefiner::MaxFieldSize];
+  // Make valgrind happy
+  std::fill(midpt0,midpt0+this->PointDimension[2],0.);
+  std::fill(midpt1,midpt1+this->PointDimension[2],0.);
+  std::fill(midpt2,midpt2+this->PointDimension[2],0.);
+    for ( int i=0; i<this->PointDimension[2]; i++ )
+      midpt1[i] = (v1[i] + v2[i])/2.;
+      midpt2[i] = (v2[i] + v0[i])/2.;
+    if ( (move & 1) && Algorithm->EvaluateEdge( v0, midpt0, v1, 3+this->EmbeddingDimension[2] ) )
+      edgeCode += 1;
+    if ( (move & 2) && Algorithm->EvaluateEdge( v1, midpt1, v2, 3+this->EmbeddingDimension[2] ) )
+      edgeCode += 2;
+    if ( (move & 4) && Algorithm->EvaluateEdge( v2, midpt2, v0, 3+this->EmbeddingDimension[2] ) )
+      edgeCode += 4;
+#ifdef UGLY_ASPECT_RATIO_HACK
+    double dist0=0.;
+    double dist1=0.;
+    double dist2=0.;
+    double tmp;
+    for ( int j=0; j<3; ++j )
+      tmp = v0[j] - v1[j];
+      dist0 += tmp*tmp;
+      tmp = v1[j] - v2[j];
+      dist1 += tmp*tmp;
+      tmp = v2[j] - v0[j];
+      dist2 += tmp*tmp;
+    if ( edgeCode & 1 ) dist0 /= 2.;
+    if ( edgeCode & 2 ) dist1 /= 2.;
+    if ( edgeCode & 4 ) dist2 /= 2.;
+#define MAR2 2.25
+    if ( (!(edgeCode & 1)) && (move&1) && ((dist0/dist1 > MAR2) || (dist0/dist2 > MAR2)) )
+      edgeCode += 1;
+      move &= 6;
+    if ( (!(edgeCode & 2)) && (move&2) && ((dist1/dist0 > MAR2) || (dist1/dist2 > MAR2)) )
+      edgeCode += 2;
+      move &= 5;
+    if ( (!(edgeCode & 4)) && (move&4) && ((dist2/dist1 > MAR2) || (dist2/dist0 > MAR2)) )
+      edgeCode += 4;
+      move &= 3;
+#endif // UGLY_ASPECT_RATIO_HACK
+#ifdef DBG_MIDPTS
+  if ( maxDepth == 0 )
+    fprintf( stderr, "midpoint of v%d (%g %g %g/%g %g %g)-v%d (%g %g %g/%g %g %g) = (%g %g %g/%g %g %g)\n",
+      0, v0[0], v0[1], v0[2], v0[3], v0[4], v0[5],
+      1, v1[0], v1[1], v1[2], v1[3], v1[4], v1[5],
+         midpt0[0], midpt0[1], midpt0[2], midpt0[3], midpt0[4], midpt0[5]
+      2, v2[0], v2[1], v2[2], v2[3], v2[4], v2[5],
+         midpt1[0], midpt1[1], midpt1[2], midpt1[3], midpt1[4], midpt1[5]
+    fprintf( stderr, "midpoint of v%d (%g %g %g/%g %g %g)-v%d (%g %g %g/%g %g %g) = (%g %g %g/%g %g %g)\n\n",
+         midpt2[0], midpt2[1], midpt2[2], midpt2[3], midpt2[4], midpt2[5]
+#endif // DBG_MIDPTS
+  switch (edgeCode)
+  case 0:
+    Callback2( v0, v1, v2, this->Algorithm, this->PrivateData, this->ConstPrivateData );
+    break ;
+  case 1:
+    this->AdaptivelySample2Facet( v0, midpt0, v2, maxDepth, move | 2 );
+    this->AdaptivelySample2Facet( midpt0, v1, v2, maxDepth, move | 4 );
+    break;
+  case 2:
+    this->AdaptivelySample2Facet( v0, v1, midpt1, maxDepth, move | 4 );
+    this->AdaptivelySample2Facet( v0, midpt1, v2, maxDepth, move | 1 );
+    break;
+  case 4:
+    this->AdaptivelySample2Facet( v0, v1, midpt2, maxDepth, move | 2 );
+    this->AdaptivelySample2Facet( midpt2, v1, v2, maxDepth, move | 1 );
+    break;
+    // Two edges to subdivide
+  case 3:
+    this->AdaptivelySample2Facet( midpt0, v1, midpt1, maxDepth, move | 4 );
+    if ( compare_Hopf_cross_string_dist( v2, midpt0, v0, midpt1 ) )
+      this->AdaptivelySample2Facet( midpt0, midpt1,   v2  , maxDepth, move | 5 );
+      this->AdaptivelySample2Facet(   v0,   midpt0,   v2  , maxDepth, move | 2 );
+    else
+      this->AdaptivelySample2Facet(   v0  , midpt0, midpt1, maxDepth, move | 6 );
+      this->AdaptivelySample2Facet(   v0,   midpt1,   v2  , maxDepth, move | 1 );
+    break;
+  case 5:
+    this->AdaptivelySample2Facet( v0, midpt0, midpt2, maxDepth, move | 2 );
+    if ( compare_Hopf_cross_string_dist( v2, midpt0, v1, midpt2 ) )
+      this->AdaptivelySample2Facet( midpt0,   v1,     v2  , maxDepth, move | 4 );
+      this->AdaptivelySample2Facet( midpt2, midpt0,   v2  , maxDepth, move | 3 );
+    else
+      this->AdaptivelySample2Facet( midpt0,   v1,   midpt2, maxDepth, move | 6 );
+    break;
+  case 6:
+    this->AdaptivelySample2Facet( midpt2, midpt1, v2, maxDepth, move | 1 );
+    if ( compare_Hopf_cross_string_dist( v0, midpt1, v1, midpt2 ) )
+      this->AdaptivelySample2Facet(   v0,   midpt1, midpt2, maxDepth, move | 3 );
+    else
+      this->AdaptivelySample2Facet( midpt2,   v1,   midpt1, maxDepth, move | 5 );
+    break;
+    // Three edges to subdivide
+  case 7:
+    this->AdaptivelySample2Facet( midpt0, midpt1, midpt2, maxDepth, 7 );
+    this->AdaptivelySample2Facet(   v0  , midpt0, midpt2, maxDepth, move | 2 );
+    this->AdaptivelySample2Facet( midpt0,   v1  , midpt1, maxDepth, move | 4 );
+    this->AdaptivelySample2Facet( midpt2, midpt1,   v2  , maxDepth, move | 1 );
+    break;
+void MBRefiner::AdaptivelySample3Facet( double* v0, double* v1, double* v2, double* v3, int maxDepth ) const
+  int edgeCode = 0;
+  double midpt3[11+MBRefiner::MaxFieldSize];
+  double midpt4[11+MBRefiner::MaxFieldSize];
+  double midpt5[11+MBRefiner::MaxFieldSize];
+#ifdef ALLOW_TET_INTERIOR_PT
+  double midpt6[11+MBRefiner::MaxFieldSize];
+#endif // ALLOW_TET_INTERIOR_PT
+  double facept0[11+MBRefiner::MaxFieldSize];
+  double facept1[11+MBRefiner::MaxFieldSize];
+  double facept2[11+MBRefiner::MaxFieldSize];
+  double facept3[11+MBRefiner::MaxFieldSize];
+  std::fill(midpt0,midpt0+this->PointDimension[3],0.);
+  std::fill(midpt1,midpt1+this->PointDimension[3],0.);
+  std::fill(midpt2,midpt2+this->PointDimension[3],0.);
+  std::fill(midpt3,midpt3+this->PointDimension[3],0.);
+  std::fill(midpt4,midpt4+this->PointDimension[3],0.);
+  std::fill(midpt5,midpt5+this->PointDimension[3],0.);
+  std::fill(midpt6,midpt6+this->PointDimension[3],0.);
+  double edgeLength2[6];
+    for ( int i=0; i<this->PointDimension[3]; i++ )
+      midpt3[i] = (v0[i] + v3[i])/2.;
+      midpt4[i] = (v1[i] + v3[i])/2.;
+      midpt5[i] = (v2[i] + v3[i])/2.;
+      midpt6[i] = (v1[i]+v2[i]-2*v0[i])/4. + (v3[i]-v0[i])/3. + v0[i];
+    if ( Algorithm->EvaluateEdge( v0, midpt0, v1, 3+this->EmbeddingDimension[3] ) )
+      edgeCode |=  1;
+    if ( Algorithm->EvaluateEdge( v1, midpt1, v2, 3+this->EmbeddingDimension[3] ) )
+      edgeCode |=  2;
+    if ( Algorithm->EvaluateEdge( v2, midpt2, v0, 3+this->EmbeddingDimension[3] ) )
+      edgeCode |=  4;
+    if ( Algorithm->EvaluateEdge( v0, midpt3, v3, 3+this->EmbeddingDimension[3] ) )
+      edgeCode |=  8;
+    if ( Algorithm->EvaluateEdge( v1, midpt4, v3, 3+this->EmbeddingDimension[3] ) )
+      edgeCode |= 16;
+    if ( Algorithm->EvaluateEdge( v2, midpt5, v3, 3+this->EmbeddingDimension[3] ) )
+      edgeCode |= 32;
+    edgeLength2[0] = edgeLength2[1] = edgeLength2[2] = edgeLength2[3]
+      = edgeLength2[4] = edgeLength2[5] = 0;
+    for ( int c=0; c<3; ++c )
+      double tmp;
+      tmp = v1[c] - v0[c];
+      edgeLength2[0] += tmp*tmp;
+      tmp = v2[c] - v1[c];
+      edgeLength2[1] += tmp*tmp;
+      tmp = v2[c] - v0[c];
+      edgeLength2[2] += tmp*tmp;
+      tmp = v3[c] - v0[c];
+      edgeLength2[3] += tmp*tmp;
+      tmp = v3[c] - v1[c];
+      edgeLength2[4] += tmp*tmp;
+      tmp = v3[c] - v2[c];
+      edgeLength2[5] += tmp*tmp;
+    // Find the longest/shortest edges
+    double shortest = edgeLength2[0];
+    double longest = edgeLength2[0];
+    for ( int e=1; e<6; e++ )
+      if ( edgeLength2[e] < shortest )
+        shortest = edgeLength2[e];
+      if ( edgeLength2[e] > longest )
+        longest = edgeLength2[e];
+    // Divide at center if aspect ratio is > 4:1 (remember these are squares of edge lengths):
+    if ( shortest / longest < 1./16. )
+      edgeCode |= 64;
+#if 0
+    // Dunno if we need to have the subdivision algorithm evaluate it, but I suspect
+    // it wouldn't be a bad idea.
+    if ( Algorithm->EvaluatePoint( midpt6 ) )
+      edgeCode |= 64;
+#endif // 0
+  if ( edgeCode == 0 )
+    Callback3( v0, v1, v2, v3, this->Algorithm, this->PrivateData, this->ConstPrivateData );
+  else
+    // Do the subdivision
+    double* vertices[11] =
+      v0, v1, v2, v3,     midpt0, midpt1, midpt2, midpt3, midpt4, midpt5, midpt6
+#else // ALLOW_TET_INTERIOR_PT
+    double* vertices[10] =
+    // Generate tetrahedra that are compatible except when edge
+    // lengths are equal on indeterminately subdivided faces.
+    double* permuted[14];
+    double permlen[6]; // permuted edge lengths
+    int C = MBRefiner::EdgeCodesToCaseCodesPlusPermutation[ edgeCode ][0];
+    int P = MBRefiner::EdgeCodesToCaseCodesPlusPermutation[ edgeCode ][1];
+    int i;
+    // 1. Permute the tetrahedron into our canonical configuration
+    for ( i=0; i<4; ++i )
+      permuted[i] = vertices[ MBRefiner::PermutationsFromIndex[P][i] ];
+    for ( i=4; i<10; ++i )
+      // permute the edge lengths, too
+      permlen[i-4]  = edgeLength2[ MBRefiner::PermutationsFromIndex[P][i] - 4 ];
+    // Add our local (heap) storage for face points to the list.
+    permuted[10] = facept0;
+    permuted[11] = facept1;
+    permuted[12] = facept2;
+    permuted[13] = facept3;
+    int comparisonBits;
+    std::stack<vtkIdType*> outputTets;
+    std::stack<vtkIdType*> outputPerm;
+    std::stack<int>        outputSign;
+    // cout << "Case " << C << "  Permutation " << P << endl;
+    // 2. Generate tetrahedra based on the configuration.
+    //    Note that case 0 is handled above (edgeCode == 0).
+    switch (C)
+    case 1: // Ruprecht-Müller Case 1
+      VTK_TESSELLATOR_INCR_CASE_COUNT(0);
+      outputTets.push( MBRefiner::TetrahedralDecompositions + 0 );
+      outputPerm.push( MBRefiner::PermutationsFromIndex[0] );
+      outputSign.push( 1 );
+      VTK_TESSELLATOR_INCR_SUBCASE_COUNT(0,0);
+      break;
+    case 2: // Ruprecht-Müller Case 2a
+      comparisonBits =
+        (permlen[0] <= permlen[1] ? 1 : 0) | (permlen[0] >= permlen[1] ? 2 : 0) |
+        0;
+      if ( (comparisonBits & 3) == 3 )
+        // Compute face point
+        for ( i=0; i<this->PointDimension[3]; i++ )
+          permuted[10][i] = (permuted[0][i] + permuted[2][i])*0.375 + permuted[1][i]/4.;
+      VTK_TESSELLATOR_INCR_CASE_COUNT(1);
+      outputTets.push( MBRefiner::TetrahedralDecompositions + 9 );
+      VTK_TESSELLATOR_INCR_SUBCASE_COUNT(1,0);
+      switch (comparisonBits)
+        case 2: // 0>1
+          outputTets.push( MBRefiner::TetrahedralDecompositions + 14 );
+          VTK_TESSELLATOR_INCR_SUBCASE_COUNT(1,1);
+          break;
+        case 1: // 1>0
+          outputPerm.push( MBRefiner::PermutationsFromIndex[13] );
+          outputSign.push( -1 );
+          VTK_TESSELLATOR_INCR_SUBCASE_COUNT(1,2);
+          break;
+        case 3: // 0=1
+          outputTets.push( MBRefiner::TetrahedralDecompositions + 23 );
+          VTK_TESSELLATOR_INCR_SUBCASE_COUNT(1,3);
+          break;
+      break;
+    case 3: // Ruprecht-Müller Case 2b
+      VTK_TESSELLATOR_INCR_CASE_COUNT(2);
+      outputTets.push( MBRefiner::TetrahedralDecompositions + 40 );
+      VTK_TESSELLATOR_INCR_SUBCASE_COUNT(2,0);
+      break;
+    case 4: // Ruprecht-Müller Case 3a
+      comparisonBits =
+        (permlen[0] <= permlen[3] ? 1 : 0) | (permlen[0] >= permlen[3] ? 2 : 0) |
+        (permlen[2] <= permlen[3] ? 4 : 0) | (permlen[2] >= permlen[3] ? 8 : 0) |
+        (permlen[0] <= permlen[2] ? 16 : 0) | (permlen[0] >= permlen[2] ? 32 : 0) |
+        0;
+          permuted[11][i] = (permuted[1][i] + permuted[3][i])*0.375 + permuted[0][i]/4.;
+      if ( (comparisonBits & 12) == 12 )
+          permuted[13][i] = (permuted[2][i] + permuted[3][i])*0.375 + permuted[0][i]/4.;
+      if ( (comparisonBits & 48) == 48 )
+          permuted[10][i] = (permuted[1][i] + permuted[2][i])*0.375 + permuted[0][i]/4.;
+      VTK_TESSELLATOR_INCR_CASE_COUNT(3);
+      outputTets.push( MBRefiner::TetrahedralDecompositions + 57 );
+      VTK_TESSELLATOR_INCR_SUBCASE_COUNT(3,0);
+        case 42: // 0>2>3<0
+          outputTets.push( MBRefiner::TetrahedralDecompositions + 62 );
+          VTK_TESSELLATOR_INCR_SUBCASE_COUNT(3,1);
+          break;
+        case 25: // 2>3>0<2
+          outputPerm.push( MBRefiner::PermutationsFromIndex[11] );
+          VTK_TESSELLATOR_INCR_SUBCASE_COUNT(3,2);
+          break;
+        case 37: // 3>0>2<3
+          outputPerm.push( MBRefiner::PermutationsFromIndex[3] );
+          VTK_TESSELLATOR_INCR_SUBCASE_COUNT(3,3);
+          break;
+        case 21: // 3>2>0<3
+          outputPerm.push( MBRefiner::PermutationsFromIndex[22] );
+          VTK_TESSELLATOR_INCR_SUBCASE_COUNT(3,4);
+          break;
+        case 26: // 2>0>3<2
+          outputPerm.push( MBRefiner::PermutationsFromIndex[12] );
+          VTK_TESSELLATOR_INCR_SUBCASE_COUNT(3,5);
+          break;
+        case 38: // 0>3>2<0
+          outputPerm.push( MBRefiner::PermutationsFromIndex[15] );
+          VTK_TESSELLATOR_INCR_SUBCASE_COUNT(3,6);
+          break;
+        case 58: // 0=2>3<0
+          outputTets.push( MBRefiner::TetrahedralDecompositions + 75 );
+          VTK_TESSELLATOR_INCR_SUBCASE_COUNT(3,7);
+          break;
+        case 29: // 2=3>0<2
+          VTK_TESSELLATOR_INCR_SUBCASE_COUNT(3,8);
+          break;
+        case 39: // 0=3>2<0
+          VTK_TESSELLATOR_INCR_SUBCASE_COUNT(3,9);
+          break;
+        case 53: // 3>0=2<3
+          outputTets.push( MBRefiner::TetrahedralDecompositions + 96 );
+          VTK_TESSELLATOR_INCR_SUBCASE_COUNT(3,10);
+          break;
+        case 46: // 0>2=3<0
+          VTK_TESSELLATOR_INCR_SUBCASE_COUNT(3,11);
+          break;
+        case 27: // 2>0=3<2
+          VTK_TESSELLATOR_INCR_SUBCASE_COUNT(3,12);
+          break;
+        case 63: // 0=2=3=0
+          outputTets.push( MBRefiner::TetrahedralDecompositions + 117 );
+          VTK_TESSELLATOR_INCR_SUBCASE_COUNT(3,13);
+          break;
+      break;
+    case 5: // Ruprecht-Müller Case 3b
+      VTK_TESSELLATOR_INCR_CASE_COUNT(4);
+      outputTets.push( MBRefiner::TetrahedralDecompositions + 162 );
+      VTK_TESSELLATOR_INCR_SUBCASE_COUNT(4,0);
+      break;
+    case 6: // Ruprecht-Müller Case 3c
+      comparisonBits =
+        (permlen[0] <= permlen[3] ? 4 : 0) | (permlen[0] >= permlen[3] ? 8 : 0) |
+        0;
+      VTK_TESSELLATOR_INCR_CASE_COUNT(5);
+        case 10: // 0>1,0>3
+          outputTets.push( MBRefiner::TetrahedralDecompositions + 179 );
+          VTK_TESSELLATOR_INCR_SUBCASE_COUNT(5,0);
+          break;
+        case 5: // 1>0,3>0
+          outputTets.push( MBRefiner::TetrahedralDecompositions + 200 );
+          VTK_TESSELLATOR_INCR_SUBCASE_COUNT(5,1);
+          break;
+        case 6: // 0>1,3>0
+          outputTets.push( MBRefiner::TetrahedralDecompositions + 221 );
+          VTK_TESSELLATOR_INCR_SUBCASE_COUNT(5,2);
+          break;
+        case 9: // 1>0,0>3
+          outputTets.push( MBRefiner::TetrahedralDecompositions + 242 );
+          VTK_TESSELLATOR_INCR_SUBCASE_COUNT(5,3);
+          break;
+        case 11: // 0=1,0>3
+          outputTets.push( MBRefiner::TetrahedralDecompositions + 263 );
+          VTK_TESSELLATOR_INCR_SUBCASE_COUNT(5,4);
+          break;
+        case 14: // 0=3,0>1
+          outputPerm.push( MBRefiner::PermutationsFromIndex[5] );
+          VTK_TESSELLATOR_INCR_SUBCASE_COUNT(5,5);
+          break;
+        case 7: // 3>0,0=1
+          outputTets.push( MBRefiner::TetrahedralDecompositions + 292 );
+          VTK_TESSELLATOR_INCR_SUBCASE_COUNT(5,6);
+          break;
+        case 13: // 1>0,0=3
+          VTK_TESSELLATOR_INCR_SUBCASE_COUNT(5,7);
+          break;
+        case 15: // 0=1,0=3
+          outputTets.push( MBRefiner::TetrahedralDecompositions + 321 );
+          VTK_TESSELLATOR_INCR_SUBCASE_COUNT(5,8);
+          break;
+      break;
+    case 7: // Ruprecht-Müller Case 3d
+      comparisonBits =
+        (permlen[0] <= permlen[2] ? 1 : 0) | (permlen[0] >= permlen[2] ? 2 : 0) |
+        (permlen[0] <= permlen[4] ? 4 : 0) | (permlen[0] >= permlen[4] ? 8 : 0) |
+        0;
+          permuted[11][i] = (permuted[0][i] + permuted[3][i])*0.375 + permuted[1][i]/4.;
+      VTK_TESSELLATOR_INCR_CASE_COUNT(6);
+        case 10: // 0>4,0>2
+          outputTets.push( MBRefiner::TetrahedralDecompositions + 362 );
+          VTK_TESSELLATOR_INCR_SUBCASE_COUNT(6,0);
+          break;
+        case 5: // 4>0,2>0
+          outputTets.push( MBRefiner::TetrahedralDecompositions + 383 );
+          VTK_TESSELLATOR_INCR_SUBCASE_COUNT(6,1);
+          break;
+        case 9: // 0>4,2>0
+          outputTets.push( MBRefiner::TetrahedralDecompositions + 404 );
+          VTK_TESSELLATOR_INCR_SUBCASE_COUNT(6,2);
+          break;
+        case 6: // 4>0,0>2
+          outputTets.push( MBRefiner::TetrahedralDecompositions + 425 );
+          VTK_TESSELLATOR_INCR_SUBCASE_COUNT(6,3);
+          break;
+        case 14: // 0=4,0>2
+          outputTets.push( MBRefiner::TetrahedralDecompositions + 446 );
+          VTK_TESSELLATOR_INCR_SUBCASE_COUNT(6,4);
+          break;
+        case 11: // 0=2,0>4
+          VTK_TESSELLATOR_INCR_SUBCASE_COUNT(6,5);
+          break;
+        case 13: // 2>0,0=4
+          outputTets.push( MBRefiner::TetrahedralDecompositions + 475 );
+          VTK_TESSELLATOR_INCR_SUBCASE_COUNT(6,6);
+          break;
+        case 7: // 4>0,0=2
+          VTK_TESSELLATOR_INCR_SUBCASE_COUNT(6,7);
+          break;
+        case 15: // 0=4,0=2
+          outputTets.push( MBRefiner::TetrahedralDecompositions + 504 );
+          VTK_TESSELLATOR_INCR_SUBCASE_COUNT(6,8);
+          break;
+      break;
+    case 8: // Ruprecht-Müller Case 4a
+      comparisonBits =
+        (permlen[4] <= permlen[5] ? 1 : 0) | (permlen[4] >= permlen[5] ? 2 : 0) |
+        (permlen[3] <= permlen[4] ? 4 : 0) | (permlen[3] >= permlen[4] ? 8 : 0) |
+        0;
+          permuted[12][i] = (permuted[1][i] + permuted[2][i])*0.375 + permuted[3][i]/4.;
+          permuted[11][i] = (permuted[0][i] + permuted[1][i])*0.375 + permuted[3][i]/4.;
+      VTK_TESSELLATOR_INCR_CASE_COUNT(7);
+      outputTets.push( MBRefiner::TetrahedralDecompositions + 545 );
+      VTK_TESSELLATOR_INCR_SUBCASE_COUNT(7,0);
+        case 5: // 5>4>3
+          outputTets.push( MBRefiner::TetrahedralDecompositions + 554 );
+          VTK_TESSELLATOR_INCR_SUBCASE_COUNT(7,1);
+          break;
+        case 10: // 3>4>5
+          VTK_TESSELLATOR_INCR_SUBCASE_COUNT(7,2);
+          break;
+        case 6: // 3<4>5
+          outputTets.push( MBRefiner::TetrahedralDecompositions + 571 );
+          VTK_TESSELLATOR_INCR_SUBCASE_COUNT(7,3);
+          break;
+        case 9: // 3>4<5
+          outputTets.push( MBRefiner::TetrahedralDecompositions + 588 );
+          VTK_TESSELLATOR_INCR_SUBCASE_COUNT(7,4);
+          break;
+        case 14: // 3=4>5
+          outputTets.push( MBRefiner::TetrahedralDecompositions + 605 );
+          VTK_TESSELLATOR_INCR_SUBCASE_COUNT(7,5);
+          break;
+        case 7: // 4=5,4>3
+          VTK_TESSELLATOR_INCR_SUBCASE_COUNT(7,6);
+          break;
+        case 13: // 5>4,3=4
+          outputTets.push( MBRefiner::TetrahedralDecompositions + 630 );
+          VTK_TESSELLATOR_INCR_SUBCASE_COUNT(7,7);
+          break;
+        case 11: // 3>4=5
+          VTK_TESSELLATOR_INCR_SUBCASE_COUNT(7,8);
+          break;
+        case 15: // 3=4=5
+          outputTets.push( MBRefiner::TetrahedralDecompositions + 655 );
+          VTK_TESSELLATOR_INCR_SUBCASE_COUNT(7,9);
+          break;
+      break;
+    case 9: // Ruprecht-Müller Case 4b
+      comparisonBits =
+        (permlen[1] <= permlen[2] ? 1 : 0) | (permlen[1] >= permlen[2] ? 2 : 0) |
+        (permlen[3] <= permlen[4] ? 16 : 0) | (permlen[3] >= permlen[4] ? 32 : 0) |
+        (permlen[1] <= permlen[4] ? 64 : 0) | (permlen[1] >= permlen[4] ? 128 : 0) |
+        0;
+          permuted[10][i] = (permuted[1][i] + permuted[0][i])*0.375 + permuted[2][i]/4.;
+      if ( (comparisonBits & 192) == 192 )
+          permuted[12][i] = (permuted[2][i] + permuted[3][i])*0.375 + permuted[1][i]/4.;
+      VTK_TESSELLATOR_INCR_CASE_COUNT(8);
+        case 85: // 2>1,3>2,4>3,4>1
+          outputTets.push( MBRefiner::TetrahedralDecompositions + 688 );
+          VTK_TESSELLATOR_INCR_SUBCASE_COUNT(8,0);
+          break;
+        case 102: // 1>2,3>2,3>4,4>1
+          outputPerm.push( MBRefiner::PermutationsFromIndex[14] );
+          VTK_TESSELLATOR_INCR_SUBCASE_COUNT(8,1);
+          break;
+        case 170: // 1>2,2>3,3>4,1>4
+          VTK_TESSELLATOR_INCR_SUBCASE_COUNT(8,2);
+          break;
+        case 153: // 2>1,2>3,4>3,1>4
+          VTK_TESSELLATOR_INCR_SUBCASE_COUNT(8,3);
+          break;
+        case 90: // 1>2,2>3,4>3,4>1
+          outputPerm.push( MBRefiner::PermutationsFromIndex[9] );
+          VTK_TESSELLATOR_INCR_SUBCASE_COUNT(8,4);
+          break;
+        case 105: // 2>1,2>3,3>4,4>1
+          outputPerm.push( MBRefiner::PermutationsFromIndex[7] );
+          VTK_TESSELLATOR_INCR_SUBCASE_COUNT(8,5);
+          break;
+        case 165: // 2>1,3>2,3>4,1>4
+          outputPerm.push( MBRefiner::PermutationsFromIndex[19] );
+          VTK_TESSELLATOR_INCR_SUBCASE_COUNT(8,6);
+          break;
+        case 150: // 1>2,3>2,4>3,1>4
+          outputPerm.push( MBRefiner::PermutationsFromIndex[23] );
+          VTK_TESSELLATOR_INCR_SUBCASE_COUNT(8,7);
+          break;
+        case 101: // 2>1,3>2,3>4,4>1
+            int alternates[] = { 713, 738, -1 };
+            outputTets.push( MBRefiner::TetrahedralDecompositions + this->BestTets( alternates, permuted, 0, 1 ) );
+          VTK_TESSELLATOR_INCR_SUBCASE_COUNT(8,8);
+          break;
+        case 86: // 1>2,3>2,4>3,4>1
+            int alternates[] = {713, 738, -1 };
+            outputTets.push( MBRefiner::TetrahedralDecompositions + this->BestTets( alternates, permuted, 14, -1 ) );
+          VTK_TESSELLATOR_INCR_SUBCASE_COUNT(8,9);
+          break;
+        case 154: // 1>2,2>3,4>3,1>4
+            outputTets.push( MBRefiner::TetrahedralDecompositions + this->BestTets( alternates, permuted, 5, 1 ) );
+          VTK_TESSELLATOR_INCR_SUBCASE_COUNT(8,10);
+          break;
+        case 169: // 2>1,2>3,3>4,1>4
+            outputTets.push( MBRefiner::TetrahedralDecompositions + this->BestTets( alternates, permuted, 15, -1 ) );
+          VTK_TESSELLATOR_INCR_SUBCASE_COUNT(8,11);
+          break;
+        case 89: // 2>1,2>3,4>3,4>1
+          outputTets.push( MBRefiner::TetrahedralDecompositions + 763 );
+          VTK_TESSELLATOR_INCR_SUBCASE_COUNT(8,12);
+          break;
+        case 166: // 1>2,3>2,3>4,1>4
+          VTK_TESSELLATOR_INCR_SUBCASE_COUNT(8,13);
+          break;
+        case 103: // 1=2,3>2,3>4,4>1
+          outputTets.push( MBRefiner::TetrahedralDecompositions + 788 );
+          VTK_TESSELLATOR_INCR_SUBCASE_COUNT(8,14);
+          break;
+        case 87: // 1=2,3>2,4>3,4>1
+          VTK_TESSELLATOR_INCR_SUBCASE_COUNT(8,15);
+          break;
+        case 185: // 2>1,2>3,3=4,1>4
+          VTK_TESSELLATOR_INCR_SUBCASE_COUNT(8,16);
+          break;
+        case 186: // 1>2,2>3,3=4,1>4
+          VTK_TESSELLATOR_INCR_SUBCASE_COUNT(8,17);
+          break;
+        case 158: // 1>2,2=3,4>3,1>4
+          VTK_TESSELLATOR_INCR_SUBCASE_COUNT(8,18);
+          break;
+        case 229: // 2>1,3>2,3>4,1=4
+          VTK_TESSELLATOR_INCR_SUBCASE_COUNT(8,19);
+          break;
+        case 233: // 2>1,2>3,3>4,1=4
+          VTK_TESSELLATOR_INCR_SUBCASE_COUNT(8,20);
+          break;
+        case 94: // 1>2,2=3,4>3,4>1
+          VTK_TESSELLATOR_INCR_SUBCASE_COUNT(8,21);
+          break;
+        case 155: // 1=2,2>3,4>3,1>4
+          outputTets.push( MBRefiner::TetrahedralDecompositions + 825 );
+          VTK_TESSELLATOR_INCR_SUBCASE_COUNT(8,22);
+          break;
+        case 171: // 1=2,2>3,3>4,1>4
+          VTK_TESSELLATOR_INCR_SUBCASE_COUNT(8,23);
+          break;
+        case 118: // 1>2,3>2,3=4,4>1
+          VTK_TESSELLATOR_INCR_SUBCASE_COUNT(8,24);
+          break;
+        case 117: // 2>1,3>2,3=4,4>1
+          VTK_TESSELLATOR_INCR_SUBCASE_COUNT(8,25);
+          break;
+        case 109: // 2>1,2=3,3>4,4>1
+          VTK_TESSELLATOR_INCR_SUBCASE_COUNT(8,26);
+          break;
+        case 218: // 1>2,2>3,4>3,1=4
+          VTK_TESSELLATOR_INCR_SUBCASE_COUNT(8,27);
+          break;
+        case 214: // 1>2,3>2,4>3,1=4
+          VTK_TESSELLATOR_INCR_SUBCASE_COUNT(8,28);
+          break;
+        case 173: // 2>1,2=3,3>4,1>4
+          VTK_TESSELLATOR_INCR_SUBCASE_COUNT(8,29);
+          break;
+        case 91: // 1=2,2>3,4>3,4>1
+          outputTets.push( MBRefiner::TetrahedralDecompositions + 862 );
+          VTK_TESSELLATOR_INCR_SUBCASE_COUNT(8,30);
+          break;
+        case 167: // 1=2,3>2,3>4,1>4
+          VTK_TESSELLATOR_INCR_SUBCASE_COUNT(8,31);
+          break;
+        case 182: // 1>2,3>2,3=4,1>4
+          VTK_TESSELLATOR_INCR_SUBCASE_COUNT(8,32);
+          break;
+        case 121: // 2>1,2>3,3=4,4>1
+          VTK_TESSELLATOR_INCR_SUBCASE_COUNT(8,33);
+          break;
+        case 93: // 2>1,2=3,4>3,4>1
+          VTK_TESSELLATOR_INCR_SUBCASE_COUNT(8,34);
+          break;
+        case 217: // 2>1,2>3,4>3,1=4
+          VTK_TESSELLATOR_INCR_SUBCASE_COUNT(8,35);
+          break;
+        case 230: // 1>2,3>2,3>4,1=4
+          VTK_TESSELLATOR_INCR_SUBCASE_COUNT(8,36);
+          break;
+        case 174: // 1>2,2=3,3>4,1>4
+          VTK_TESSELLATOR_INCR_SUBCASE_COUNT(8,37);
+          break;
+        case 119: // 1=2,3>2,3=4,4>1
+          outputTets.push( MBRefiner::TetrahedralDecompositions + 899 );
+          VTK_TESSELLATOR_INCR_SUBCASE_COUNT(8,38);
+          break;
+        case 187: // 1=2>3=4,1>4
+          VTK_TESSELLATOR_INCR_SUBCASE_COUNT(8,39);
+          break;
+        case 222: // 1>2,2=3,4>3,1=4
+          VTK_TESSELLATOR_INCR_SUBCASE_COUNT(8,40);
+          break;
+        case 237: // 2>1,2=3,3>4,1=4
+          VTK_TESSELLATOR_INCR_SUBCASE_COUNT(8,41);
+          break;
+        case 95: // 4>1=2=3,4>3
+          outputTets.push( MBRefiner::TetrahedralDecompositions + 944 );
+          VTK_TESSELLATOR_INCR_SUBCASE_COUNT(8,42);
+          break;
+        case 231: // 1=2,3>2,3>4,1=4
+          VTK_TESSELLATOR_INCR_SUBCASE_COUNT(8,43);
+          break;
+        case 190: // 1>2=3=4,1>4
+          VTK_TESSELLATOR_INCR_SUBCASE_COUNT(8,44);
+          break;
+        case 249: // 2>1,2>3,3=4,1=4
+          VTK_TESSELLATOR_INCR_SUBCASE_COUNT(8,45);
+          break;
+        case 175: // 1=2=3>4,1>4
+          outputTets.push( MBRefiner::TetrahedralDecompositions + 993 );
+          VTK_TESSELLATOR_INCR_SUBCASE_COUNT(8,46);
+          break;
+        case 219: // 1=2>3,4>3,1=4
+          VTK_TESSELLATOR_INCR_SUBCASE_COUNT(8,47);
+          break;
+        case 125: // 2>1,2=3=4>1
+          VTK_TESSELLATOR_INCR_SUBCASE_COUNT(8,48);
+          break;
+        case 246: // 1>2,3>2,3=4=1
+          VTK_TESSELLATOR_INCR_SUBCASE_COUNT(8,49);
+          break;
+        case 255: // 1=2=3=4=1
+          outputTets.push( MBRefiner::TetrahedralDecompositions + 1042 );
+          VTK_TESSELLATOR_INCR_SUBCASE_COUNT(8,50);
+          break;
+      break;
+    case 10: // Ruprecht-Müller Case 5
+      comparisonBits =
+        0;
+      VTK_TESSELLATOR_INCR_CASE_COUNT(9);
+      outputTets.push( MBRefiner::TetrahedralDecompositions + 1107 );
+      VTK_TESSELLATOR_INCR_SUBCASE_COUNT(9,0);
+        case 10: // 1>2,3>4
+          outputTets.push( MBRefiner::TetrahedralDecompositions + 1116 );
+          VTK_TESSELLATOR_INCR_SUBCASE_COUNT(9,1);
+          break;
+        case 5: // 2>1,4>3
+          VTK_TESSELLATOR_INCR_SUBCASE_COUNT(9,2);
+          break;
+        case 6: // 1>2,4>3
+            int alternates[] = { 1137, 1158, -1 };
+          VTK_TESSELLATOR_INCR_SUBCASE_COUNT(9,3);
+          break;
+        case 9: // 2>1,3>4
+            int alternates[] = {1137, 1158, -1 };
+          VTK_TESSELLATOR_INCR_SUBCASE_COUNT(9,4);
+          break;
+        case 11: // 1=2,3>4
+            int alternates[] = { 1179, 1212, 1245, -1 };
+          VTK_TESSELLATOR_INCR_SUBCASE_COUNT(9,5);
+          break;
+        case 7: // 1=2,4>3
+            int alternates[] = {1179, 1212, 1245, -1 };
+          VTK_TESSELLATOR_INCR_SUBCASE_COUNT(9,6);
+          break;
+        case 14: // 3=4,1>2
+          VTK_TESSELLATOR_INCR_SUBCASE_COUNT(9,7);
+          break;
+        case 13: // 3=4,2>1
+          VTK_TESSELLATOR_INCR_SUBCASE_COUNT(9,8);
+          break;
+        case 15: // 1=2,3=4
+          outputTets.push( MBRefiner::TetrahedralDecompositions + 1278 );
+          VTK_TESSELLATOR_INCR_SUBCASE_COUNT(9,9);
+          break;
+      break;
+    case 11: // Ruprecht-Müller Case 6
+      VTK_TESSELLATOR_INCR_CASE_COUNT(10);
+      outputTets.push( MBRefiner::TetrahedralDecompositions + 1319 );
+      VTK_TESSELLATOR_INCR_SUBCASE_COUNT(10,0);
+        int alternates[] = { 1336, 1353, 1370, -1 };
+      VTK_TESSELLATOR_INCR_SUBCASE_COUNT(10,1);
+      break;
+    vtkIdType* tets;
+    vtkIdType  ntets;
+    vtkIdType* perm;
+    int        sgn;
+    if ( outputTets.empty() )
+    cout << "Argh! Case " << C << " Perm " << P << " has no output!" << endl;
+    while ( ! outputTets.empty() )
+      tets = outputTets.top();
+      ntets = *tets;
+      tets++;
+      perm = outputPerm.top();
+      sgn = outputSign.top();
+      outputTets.pop();
+      outputPerm.pop();
+      outputSign.pop();
+      int t;
+      if ( sgn > 0 )
+        for ( t = 0; t < ntets; ++t )
+          this->AdaptivelySample3Facet(
+            permuted[ perm[ tets[0] ] ], permuted[ perm[ tets[1] ] ],
+            permuted[ perm[ tets[2] ] ], permuted[ perm[ tets[3] ] ],
+            maxDepth );
+          tets += 4;
+      else
+        // we have an inverted tet... reverse the first 2 vertices
+        // so the orientation is positive.
+            permuted[ perm[ tets[1] ] ], permuted[ perm[ tets[0] ] ],
+            maxDepth );
+          tets += 4;
+ * The array below is indexed by the edge code for a tetrahedron.
+ * Looking up a row with a tet's edge code will return C and P.
+ * C is a configuration number and P is a permutation index.
+ * C is based on the case number from Ruprecht and
+ * Müller's (1998) paper on adaptive tetrahedra. (The case
+ * numbers are shown to the left of the row in the column
+ * labeled case. The only difference is that we introduce
+ * a case 3d which is part of case 3c in the paper.)
+ * P is an index into the MBRefiner::PermutationsFromIndex array below,
+ * and is used to transform the current tetrahedron into
+ * the canonical configuration associated with C.
+ * The 6-digit binary number to the left (which is shown in
+ * the horribly UNconventional LSB->MSB order) is the edge
+ * code for the row. The 6 digits correspond to the 6 edges
+ * of the tetrahedron; a '0' implies no subdivision while
+ * a '1' implies subdivision should occur. The ordering of
+ * the bits is
+ * Edge 0-1, Edge 1-2, Edge 2-0, Edge 0-3, Edge 1-3, Edge 2-3,
+ * where the numbers are vertices of the tetrahedron 0-1-2-3.
+ * Note that Tet 0-1-2-3 must be positive (i.e., the plane
+ * specified by Triangle 0-1-2 must have a normal pointing
+ * towards vertex 3, and Triangle 0-1-2's normal must be
+ * calculated using the cross-product (Edge 0-1) x (Edge 0-2)).
+ * References:
+ * (Ruprect and Müller, 1998) A Scheme for Edge-based Adaptive
+ *   Tetrahedron Subdivision, Mathematical Visualization (eds.
+ *   Hege and Polthier), pp. 61--70. Springer-Verlag. 1998.
+int MBRefiner::EdgeCodesToCaseCodesPlusPermutation[64][2] =
+  /*      code case      C    P */
+  /* 000000  0  0  */ {  0,   0 },
+  /* 100000  1  1  */ {  1,   0 },
+  /* 010000  2  1  */ {  1,   1 },
+  /* 110000  3  2a */ {  2,   0 },
+  /* 001000  4  1  */ {  1,   2 },
+  /* 101000  5  2a */ {  2,   2 },
+  /* 011000  6  2a */ {  2,   1 },
+  /* 111000  7  3b */ {  5,  11 },
+  /* 000100  8  1  */ {  1,  10 },
+  /* 100100  9  2a */ {  2,   5 },
+  /* 010100 10  2b */ {  3,   1 },
+  /* 110100 11  3c */ {  6,   0 },
+  /* 001100 12  2a */ {  2,  10 },
+  /* 101100 13  3a */ {  4,   0 },
+  /* 011100 14  3d */ {  7,   2 },
+  /* 111100 15  4a */ {  8,   6 },
+  /* 000010 16  1  */ {  1,   6 },
+  /* 100010 17  2a */ {  2,   4 },
+  /* 010010 18  2a */ {  2,   8 },
+  /* 110010 19  3a */ {  4,   1 },
+  /* 001010 20  2b */ {  3,   2 },
+  /* 101010 21  3d */ {  7,   0 },
+  /* 011010 22  3c */ {  6,   1 },
+  /* 111010 23  4a */ {  8,   9 },
+  /* 000110 24  2a */ {  2,   3 },
+  /* 100110 25  3b */ {  5,   0 },
+  /* 010110 26  3d */ {  7,   4 },
+  /* 110110 27  4a */ {  8,  11 },
+  /* 001110 28  3c */ {  6,  10 },
+  /* 101110 29  4a */ {  8,   7 },
+  /* 011110 30  4b */ {  9,   0 },
+  /* 111110 31  5  */ { 10,   7 },
+  /* 000001 32  1  */ {  1,   7 },
+  /* 100001 33  2b */ {  3,   0 },
+  /* 010001 34  2a */ {  2,   7 },
+  /* 110001 35  3d */ {  7,   1 },
+  /* 001001 36  2a */ {  2,  11 },
+  /* 101001 37  3c */ {  6,   2 },
+  /* 011001 38  3a */ {  4,   2 },
+  /* 111001 39  4a */ {  8,   3 },
+  /* 000101 40  2a */ {  2,   9 },
+  /* 100101 41  3d */ {  7,  10 },
+  /* 010101 42  3c */ {  6,   7 },
+  /* 110101 43  4b */ {  9,   2 },
+  /* 001101 44  3b */ {  5,   7 },
+  /* 101101 45  4a */ {  8,   8 },
+  /* 011101 46  4a */ {  8,   4 },
+  /* 111101 47  5  */ { 10,   6 },
+  /* 000011 48  2a */ {  2,   6 },
+  /* 100011 49  3c */ {  6,   4 },
+  /* 010011 50  3b */ {  5,   1 },
+  /* 110011 51  4a */ {  8,  10 },
+  /* 001011 52  3d */ {  7,   7 },
+  /* 101011 53  4b */ {  9,   1 },
+  /* 011011 54  4a */ {  8,   5 },
+  /* 111011 55  5  */ { 10,  10 },
+  /* 000111 56  3a */ {  4,  10 },
+  /* 100111 57  4a */ {  8,   1 },
+  /* 010111 58  4a */ {  8,   2 },
+  /* 110111 59  5  */ { 10,   2 },
+  /* 001111 60  4a */ {  8,   0 },
+  /* 101111 61  5  */ { 10,   1 },
+  /* 011111 62  5  */ { 10,   0 },
+  /* 111111 63  6  */ { 11,   0 },
+/* Does this mean anything? If so, then you are either
+ * superstitious or much more clever than I (or both?).
+/* permutation index, P:  0  1  2  3  4  5  6  7  8  9 10 11 */
+/* number of references: 12  9  9  3  4  2  5  6  2  3  7  2 */
+ * The array below is a list of all the _positive_
+ * permutations of Tetrahedron 0-1-2-3. Given a
+ * permutation index, it returns a row of 14 values:
+ * these are the vertex numbers of the permuted
+ * tetrahedron. The first 4 values are the permuted
+ * corner indices, the next 6 values are the
+ * permuted edge midpoint indices, and the final
+ * entries reference mid-face points inserted
+ * to maintain a compatible tetrahedralization.
+ * There are 24 entries, 6 for each of the 4 faces of
+ * the tetrahedron.
+vtkIdType MBRefiner::PermutationsFromIndex[24][14] =
+  /* corners      midpoints          face points   */
+  /* POSITIVE ARRANGEMENTS                         */
+  { 0, 1, 2, 3,   4, 5, 6, 7, 8, 9,  10, 11, 12, 13 }, /* Face 0-1-2 */
+  { 1, 2, 0, 3,   5, 6, 4, 8, 9, 7,  10, 12, 13, 11 },
+  { 2, 0, 1, 3,   6, 4, 5, 9, 7, 8,  10, 13, 11, 12 },
+  { 0, 3, 1, 2,   7, 8, 4, 6, 9, 5,  11, 13, 12, 10 }, /* Face 0-3-1 */
+  { 3, 1, 0, 2,   8, 4, 7, 9, 5, 6,  11, 12, 10, 13 },
+  { 1, 0, 3, 2,   4, 7, 8, 5, 6, 9,  11, 10, 13, 12 },
+  { 1, 3, 2, 0,   8, 9, 5, 4, 7, 6,  12, 11, 13, 10 }, /* Face 1-3-2 */
+  { 3, 2, 1, 0,   9, 5, 8, 7, 6, 4,  12, 13, 10, 11 },
+  { 2, 1, 3, 0,   5, 8, 9, 6, 4, 7,  12, 10, 11, 13 },
+  { 2, 3, 0, 1,   9, 7, 6, 5, 8, 4,  13, 12, 11, 10 }, /* Face 2-3-0 */
+  { 3, 0, 2, 1,   7, 6, 9, 8, 4, 5,  13, 11, 10, 12 },
+  { 0, 2, 3, 1,   6, 9, 7, 4, 5, 8,  13, 10, 12, 11 },
+  /* NEGATIVE ARRANGEMENTS                         */
+  { 0, 2, 1, 3,   6, 5, 4, 7, 9, 8,  10, 13, 12, 11 }, /* Face 0-1-2 */
+  { 2, 1, 0, 3,   5, 4, 6, 9, 8, 7,  10, 12, 11, 13 },
+  { 1, 0, 2, 3,   4, 6, 5, 8, 7, 9,  10, 11, 13, 12 },
+  { 0, 1, 3, 2,   4, 8, 7, 6, 5, 9,  11, 10, 12, 13 }, /* Face 0-3-1 */
+  { 1, 3, 0, 2,   8, 7, 4, 5, 9, 6,  11, 12, 13, 10 },
+  { 3, 0, 1, 2,   7, 4, 8, 9, 6, 5,  11, 13, 10, 12 },
+  { 1, 2, 3, 0,   5, 9, 8, 4, 6, 7,  12, 10, 13, 11 }, /* Face 1-3-2 */
+  { 2, 3, 1, 0,   9, 8, 5, 6, 7, 4,  12, 13, 11, 10 },
+  { 3, 1, 2, 0,   8, 5, 9, 7, 4, 6,  12, 11, 10, 13 },
+  { 2, 0, 3, 1,   6, 7, 9, 5, 4, 8,  13, 10, 11, 12 }, /* Face 2-3-0 */
+  { 0, 3, 2, 1,   7, 9, 6, 4, 8, 5,  13, 11, 12, 10 },
+  { 3, 2, 0, 1,   9, 6, 7, 8, 5, 4,  13, 12, 10, 11 }
+ * Below is a list of output tetrahedra. The array is
+ * generated by TessellatorGenerator.py
+ * which also generates the code that references it.
+ * Each set of tetrahedra begins with a single integer
+ * that is the number of tetrahedra for that particular
+ * case. It is followed by 5 integers for each output
+ * tetrahedron; the first four numbers on each row are
+ * indices of the output tetrahedron. The final number
+ * is a bit vector specifying which edges of the
+ * tetrahedron are internal to the parent tetrahedron
+ * being decomposed.
+ * Multiple lists of output tetrahedra may be
+ * combined to create the tessellation of a single
+ * input tetrahedron.
+vtkIdType MBRefiner::TetrahedralDecompositions[] =
+// case 1_0
+   2,
+   0,  4,  2,  3,
+   4,  1,  2,  3,
+// case 2a_0
+   1,
+   3,  4,  5,  1,
+// case 2a, 0>1
+   2,
+   0,  4,  2,  3,
+   4,  5,  2,  3,
+// case 2a, 0=1
+   4,
+  10,  3,  0,  4,
+  10,  3,  4,  5,
+  10,  3,  5,  2,
+  10,  3,  2,  0,
+// case 2b_0
+   4,
+   0,  4,  9,  3,
+   4,  1,  9,  3,
+   0,  4,  2,  9,
+   4,  1,  2,  9,
+// case 3a_0
+   1,
+   4,  7,  6,  0,
+// case 3a, 0>2>3<0
+   3,
+   1,  3,  2,  4,
+   4,  6,  3,  2,
+   4,  6,  7,  3,
+// case 3a, 0=2>3<0
+   5,
+   4,  6,  7,  3,
+  10,  1,  2,  3,
+  10,  2,  6,  3,
+  10,  6,  4,  3,
+  10,  4,  1,  3,
+// case 3a, 3>0=2<3
+   5,
+   1,  3,  2,  7,
+  10,  1,  2,  7,
+  10,  2,  6,  7,
+  10,  6,  4,  7,
+  10,  4,  1,  7,
+// case 3a, 0=2=3=0
+  11,
+   2,  6, 10, 13,
+   3,  7, 13, 11,
+   4,  1, 10, 11,
+  11,  6, 10,  4,
+  11,  6, 13, 10,
+  11,  6,  7, 13,
+  11,  6,  4,  7,
+   2, 10, 11, 13,
+   1, 10, 11,  2,
+   2, 11,  3, 13,
+   3,  2,  1, 11,
+// case 3b_0
+   4,
+   0,  7,  4,  2,
+   4,  7,  8,  2,
+   4,  8,  1,  2,
+   7,  3,  8,  2,
+// case 3c, 0>1,0>3
+   5,
+   4,  2,  7,  5,
+   4,  2,  0,  7,
+   4,  3,  1,  5,
+   4,  3,  5,  7,
+   3,  5,  7,  2,
+// case 3c, 1>0,3>0
+   5,
+   0,  5,  2,  7,
+   0,  5,  7,  4,
+   7,  1,  4,  5,
+   7,  1,  5,  3,
+   3,  5,  7,  2,
+// case 3c, 0>1,3>0
+   5,
+   4,  2,  7,  5,
+   4,  2,  0,  7,
+   7,  1,  4,  5,
+   7,  1,  5,  3,
+   3,  5,  7,  2,
+// case 3c, 1>0,0>3
+   5,
+   0,  5,  2,  7,
+   0,  5,  7,  4,
+   4,  3,  1,  5,
+   4,  3,  5,  7,
+   3,  5,  7,  2,
+// case 3c, 0=1,0>3
+   7,
+   4,  1,  5,  3,
+  10,  0,  4,  7,
+  10,  2,  0,  7,
+  10,  7,  4,  3,
+  10,  2,  7,  3,
+  10,  5,  2,  3,
+  10,  4,  5,  3,
+// case 3c, 3>0,0=1
+   7,
+   7,  1,  5,  3,
+   7,  5,  2,  3,
+  10,  0,  4,  7,
+  10,  2,  0,  7,
+  10,  5,  2,  7,
+  10,  4,  5,  7,
+   1,  5,  4,  7,
+// case 3c, 0=1,0=3
+  10,
+   4,  1,  5, 11,
+  11,  1,  5,  3,
+  10,  0,  4,  7,
+  10,  2,  0,  7,
+  10,  5,  2,  3,
+  10,  2,  7,  3,
+  10,  7,  4, 11,
+  10,  7, 11,  3,
+  10,  4,  5, 11,
+  10, 11,  5,  3,
+// case 3d, 0>4,0>2
+   5,
+   4,  3,  6,  0,
+   4,  3,  8,  6,
+   4,  2,  8,  1,
+   4,  2,  6,  8,
+   2,  3,  6,  8,
+// case 3d, 4>0,2>0
+   5,
+   8,  0,  6,  4,
+   8,  0,  3,  6,
+   6,  1,  8,  4,
+   6,  1,  2,  8,
+   2,  3,  6,  8,
+// case 3d, 0>4,2>0
+   5,
+   4,  3,  6,  0,
+   4,  3,  8,  6,
+   6,  1,  8,  4,
+   6,  1,  2,  8,
+   2,  3,  6,  8,
+// case 3d, 4>0,0>2
+   5,
+   8,  0,  6,  4,
+   8,  0,  3,  6,
+   4,  2,  8,  1,
+   4,  2,  6,  8,
+   2,  3,  6,  8,
+// case 3d, 0=4,0>2
+   7,
+   4,  1,  2,  8,
+  11,  4,  0,  6,
+  11,  0,  3,  6,
+  11,  2,  4,  6,
+  11,  3,  2,  6,
+  11,  3,  8,  2,
+  11,  8,  4,  2,
+// case 3d, 2>0,0=4
+   7,
+   6,  2,  8,  1,
+   6,  8,  2,  3,
+  11,  4,  0,  6,
+  11,  0,  3,  6,
+   8, 11,  3,  6,
+   8,  4, 11,  6,
+   1,  6,  4,  8,
+// case 3d, 0=4,0=2
+  10,
+   4,  1, 10,  8,
+  10,  2,  8,  1,
+  11,  4,  0,  6,
+  11,  0,  3,  6,
+  11,  3,  8,  2,
+  11,  3,  2,  6,
+  11, 10,  4,  6,
+  11, 10,  6,  2,
+   8,  4, 11, 10,
+  11, 10,  2,  8,
+// case 4a_0
+   2,
+   7,  8,  9,  3,
+   7,  9,  8,  6,
+// case 4a, 5>4>3
+   4,
+   8,  0,  6,  1,
+   8,  0,  7,  6,
+   9,  1,  6,  2,
+   9,  1,  8,  6,
+// case 4a, 3<4>5
+   4,
+   8,  0,  6,  1,
+   8,  0,  7,  6,
+   8,  2,  6,  9,
+   8,  2,  1,  6,
+// case 4a, 3>4<5
+   4,
+   6,  9,  8,  1,
+   6,  9,  1,  2,
+   6,  7,  0,  1,
+   6,  7,  1,  8,
+// case 4a, 3=4>5
+   6,
+   6,  7,  0, 11,
+   6,  0,  1, 11,
+   6,  7, 11,  8,
+   6, 11,  1,  8,
+   1,  2,  6,  8,
+   2,  6,  8,  9,
+// case 4a, 5>4,3=4
+   6,
+   6,  7,  0, 11,
+   6,  0,  1, 11,
+   6,  7, 11,  8,
+   6, 11,  1,  8,
+   1,  2,  6,  9,
+   1,  6,  8,  9,
+// case 4a, 3=4=5
+   8,
+   6,  7,  0, 11,
+   6,  0,  1, 11,
+   6,  7, 11,  8,
+   6, 11,  1,  8,
+   6,  1,  2, 12,
+   6,  2,  9, 12,
+   6,  9,  8, 12,
+   6,  8,  1, 12,
+// case 4b, 2>1,3>2,4>3,4>1
+   6,
+   6,  8,  1,  5,
+   6,  8,  0,  1,
+   6,  8,  7,  0,
+   6,  8,  2,  7,
+   7,  8,  2,  3,
+   6,  8,  5,  2,
+// case 4b, 2>1,3>2,3>4,4>1
+   6,
+   6,  8,  1,  5,
+   6,  8,  7,  1,
+   6,  7,  0,  1,
+   8,  7,  3,  2,
+   6,  8,  5,  2,
+   6,  8,  2,  7,
+// case 4b, 2>1,3>2,3>4,4>1, a
+   6,
+   7,  8,  1,  5,
+   6,  5,  7,  1,
+   6,  7,  0,  1,
+   8,  7,  3,  2,
+   7,  8,  5,  2,
+   6,  5,  2,  7,
+// case 4b, 2>1,2>3,4>3,4>1
+   6,
+   6,  8,  5,  2,
+   6,  8,  2,  3,
+   6,  8,  3,  7,
+   6,  8,  7,  0,
+   6,  8,  0,  1,
+   6,  8,  1,  5,
+// case 4b, 1=2,3>2,3>4,4>1
+   9,
+  10,  6,  0,  7,
+  10,  1,  5,  8,
+  10,  0,  1,  7,
+  10,  7,  1,  8,
+   6,  7, 10,  8,
+   6, 10,  5,  8,
+   6,  2,  7,  8,
+   6,  5,  2,  8,
+   7,  8,  2,  3,
+// case 4b, 1=2,2>3,4>3,1>4
+   9,
+  10,  6,  0,  7,
+  10,  1,  5,  8,
+  10,  0,  1,  8,
+  10,  7,  0,  8,
+   6,  7, 10,  8,
+   6, 10,  5,  8,
+   6,  3,  7,  8,
+   6,  5,  3,  8,
+   6,  5,  2,  3,
+// case 4b, 1=2,2>3,4>3,4>1
+   9,
+  10,  6,  0,  7,
+  10,  1,  5,  8,
+  10,  0,  1,  8,
+  10,  7,  0,  8,
+   6,  7, 10,  8,
+   6, 10,  5,  8,
+   6,  3,  7,  8,
+   6,  5,  2,  8,
+   6,  2,  3,  8,
+// case 4b, 1=2,3>2,3=4,4>1
+  11,
+  10,  6,  0,  7,
+  10,  1,  5,  8,
+  10,  0,  1, 11,
+  10, 11,  1,  8,
+  10,  0, 11,  7,
+  10,  7, 11,  8,
+   6,  7, 10,  8,
+   6, 10,  5,  8,
+   6,  2,  7,  8,
+   6,  5,  2,  8,
+   7,  8,  2,  3,
+// case 4b, 4>1=2=3,4>3
+  12,
+  10,  6,  0,  7,
+  10,  1,  5,  8,
+  10,  0,  1,  8,
+  10,  7,  0,  8,
+  13,  6,  2,  5,
+  13,  3,  7,  8,
+  13,  2,  3,  8,
+  13,  2,  8,  5,
+   6,  7, 10,  8,
+   6, 10,  5,  8,
+   6, 13,  7,  8,
+   6,  5, 13,  8,
+// case 4b, 1=2=3>4,1>4
+  12,
+  10,  6,  0,  7,
+  10,  1,  5,  8,
+  10,  0,  1,  7,
+  10,  7,  1,  8,
+  13,  6,  2,  5,
+  13,  3,  7,  8,
+  13,  2,  3,  5,
+  13,  3,  8,  5,
+   6,  7, 10,  8,
+   6, 10,  5,  8,
+   6, 13,  7,  8,
+   6,  5, 13,  8,
+// case 4b, 1=2=3=4=1
+  16,
+  10,  6,  0,  7,
+  10,  1,  5,  8,
+  10,  0,  1, 11,
+  10, 11,  1,  8,
+  10,  0, 11,  7,
+  10,  7, 11,  8,
+  13,  6,  2,  5,
+  13,  3,  7,  8,
+  13,  2,  3, 12,
+  13,  2, 12,  5,
+  13, 12,  3,  8,
+  13, 12,  5,  8,
+   6,  7, 10,  8,
+   6, 10,  5,  8,
+   6,  5, 13,  8,
+   6, 13,  7,  8,
+// case 5_0
+   2,
+   7,  8,  9,  3,
+   6,  5,  2,  9,
+// case 5, 1>2,3>4
+   5,
+   5,  7,  1,  8,
+   5,  7,  0,  1,
+   5,  7,  6,  0,
+   5,  7,  9,  6,
+   5,  7,  8,  9,
+// case 5, 1>2,4>3
+   5,
+   0,  5,  6,  7,
+   0,  5,  7,  8,
+   0,  5,  8,  1,
+   5,  7,  9,  6,
+   5,  7,  8,  9,
+// case 5, 1>2,4>3, a
+   5,
+   0,  5,  6,  8,
+   0,  6,  7,  8,
+   0,  5,  8,  1,
+   5,  8,  9,  6,
+   6,  7,  8,  9,
+// case 5, 1=2,3>4
+   8,
+  10,  6,  0,  7,
+  10,  1,  5,  8,
+  10,  0,  1,  7,
+  10,  7,  1,  8,
+  10,  8,  5,  9,
+  10,  6,  7,  9,
+  10,  7,  8,  9,
+  10,  5,  6,  9,
+// case 5, 1=2,3>4, a
+   8,
+  10,  6,  0,  7,
+  10,  1,  5,  8,
+  10,  0,  1,  7,
+  10,  7,  1,  8,
+   7,  8,  5,  9,
+  10,  6,  7,  5,
+  10,  7,  8,  5,
+   5,  9,  6,  7,
+// case 5, 1=2,3>4, b
+   8,
+  10,  6,  0,  7,
+  10,  1,  5,  8,
+  10,  0,  1,  7,
+  10,  7,  1,  8,
+   6,  8,  5,  9,
+  10,  6,  7,  8,
+  10,  6,  8,  5,
+   8,  9,  6,  7,
+// case 5, 1=2,3=4
+  10,
+  10,  6,  0,  7,
+  10,  1,  5,  8,
+  10,  0,  1, 11,
+  10, 11,  1,  8,
+  10,  0, 11,  7,
+  10,  7, 11,  8,
+  10,  8,  5,  9,
+  10,  6,  7,  9,
+  10,  7,  8,  9,
+  10,  5,  6,  9,
+// case 6_0
+   4,
+   7,  8,  9,  3,
+   6,  5,  2,  9,
+   4,  1,  5,  8,
+   0,  4,  6,  7,
+// case 6_1
+   4,
+   6,  4,  5,  8,
+   6,  5,  9,  8,
+   6,  9,  7,  8,
+   6,  7,  4,  8,
+// case 6_1, a
+   4,
+   5,  8,  9,  7,
+   5,  9,  6,  7,
+   5,  6,  4,  7,
+   5,  4,  8,  7,
+// case 6_1, b
+   4,
+   4,  5,  6,  9,
+   4,  6,  7,  9,
+   4,  7,  8,  9,
+   4,  8,  5,  9,
