[MOAB-dev] r1437 - MOAB/trunk
kraftche at mcs.anl.gov kraftche at mcs.anl.gov
Tue Dec 4 10:03:36 CST 2007
Author: kraftche
Date: 2007-12-04 10:03:26 -0600 (Tue, 04 Dec 2007)
New Revision: 1437
Added:
   MOAB/trunk/kd_tree_test.cpp
Modified:
   MOAB/trunk/Makefile.am
Log:
add ITS example/test code as MOAB unit test
Modified: MOAB/trunk/Makefile.am
--- MOAB/trunk/Makefile.am	2007-12-04 15:59:43 UTC (rev 1436)
+++ MOAB/trunk/Makefile.am	2007-12-04 16:03:26 UTC (rev 1437)
@@ -26,7 +26,8 @@
         obb_test \
 	vtk_test \
 	adaptive_kd_tree_tests \
-	file_options_test
+	file_options_test \
+        kd_tree_test
 #                 merge_test \         # input files no longer exist?
 #                 test_tag_server \    # fails
@@ -307,11 +308,12 @@
 kd_tree_time_LDADD = $(top_builddir)/libMOAB.la
 kd_tree_time_DEPENDENCIES = $(kd_tree_time_LDADD)
-if PARALLEL
+kd_tree_test_SOURCES = kd_tree_test.cpp
+kd_tree_test_LDADD = $(top_builddir)/libMOAB.la
 mbparallelcomm_test_SOURCES = mbparallelcomm_test.cpp
 mbparallelcomm_test_LDADD = $(top_builddir)/libMOAB.la
 mbparallelcomm_test_DEPENDENCIES = $(mbparallelcomm_test_LDADD)
-endif
 file_options_test_SOURCES = FileOptions.cpp
 file_options_test_CPPFLAGS = -DTEST
Added: MOAB/trunk/kd_tree_test.cpp
--- MOAB/trunk/kd_tree_test.cpp	                        (rev 0)
+++ MOAB/trunk/kd_tree_test.cpp	2007-12-04 16:03:26 UTC (rev 1437)
@@ -0,0 +1,195 @@
+#include "MBCore.hpp"
+#include "MBAdaptiveKDTree.hpp"
+#include <math.h>
+#include <assert.h>
+#include <float.h>
+const unsigned INTERVALS = 4;
+const unsigned DEPTH = 7; // 3*log2(INTERVALS)+1
+const char* TAG_NAME = "TEST_DATA";
+int main()
+  // Initialize MOAB & create tree tool
+  MBCore moab;
+  MBAdaptiveKDTree tool(&moab);
+  // Create tree root
+  MBErrorCode err;
+  MBEntityHandle root, leaf;
+  const double tree_box_min_corner[] = { 0, 0, 0 };
+    // Make each leaf box be 1x1x1.
+  const double tree_box_max_corner[] = { INTERVALS, INTERVALS, INTERVALS };
+  err = tool.create_tree( tree_box_min_corner, tree_box_max_corner, root );
+  assert(!err);
+  // Use iterator to create tree to fixed depth of DEPTH
+  MBAdaptiveKDTreeIter iter;
+  err = tool.get_tree_iterator( root, iter );
+  assert(!err);
+  while(err == MB_SUCCESS) {
+    if (iter.depth() < DEPTH) {
+        // bisect leaves along alternating axes
+      MBAdaptiveKDTree::Plane split;
+      split.norm = iter.depth() % 3;  // alternate split axes;
+      split.coord = 0.5 * (iter.box_min()[split.norm] + iter.box_max()[split.norm]);
+      err = tool.split_leaf( iter, split ); // advances iter to first new leaf
+      assert(!err);
+      // if current leaf is at desired depth, advance to next one
+    else {
+      err = iter.step();
+  assert(MB_ENTITY_NOT_FOUND == err);
+  // define a tag to use to store integer values on tree leaves
+  MBTag data;
+  err = moab.tag_create( TAG_NAME, sizeof(int), MB_TAG_DENSE, MB_TYPE_INTEGER, data, 0, false );
+  assert(!err);
+  // iterate over tree, verifying leaves and setting data
+  int counter = 0;
+  for (err = tool.get_tree_iterator( root, iter ); !err; err = iter.step()) {
+    // store integer value on leaf
+    ++counter;
+    leaf = iter.handle();
+    err = moab.tag_set_data( data, &leaf, 1, &counter );
+    assert(!err);
+    // check size of leaf
+    const double* min = iter.box_min();
+    const double* max = iter.box_max();
+    double dims[] = { max[0] - min[0], max[1] - min[1], max[2] - min[2] };
+    double volume = dims[0] * dims[1] * dims[2];
+    assert( fabs(volume - 1.0) <= DBL_EPSILON );
+    // check depth of leaf
+    assert( iter.depth() == DEPTH );
+    // check number of leaves
+  const int num_leaves = INTERVALS*INTERVALS*INTERVALS;
+  assert( num_leaves == counter );
+  // reduce tree depth to DEPTH-1 by merging adjacent leaf pairs,
+  // make new "leaf" have smaller of two data values on original pair
+    // get data for first leaf
+    int data1;
+    err = moab.tag_get_data( data, &leaf, 1, &data1 );
+    assert(!err);
+    // tree traversal is always such that two leaves with same parent are consective
+    assert(!err);
+    // get data for sibling
+    int data2;
+    err = moab.tag_get_data( data, &leaf, 1, &data2 );
+    assert(!err);
+    // as we stored increasing values, these had better be increasing
+    assert( data2 - data1 == 1 );
+    // merge leaf pair (iter can be at either one)
+    err = tool.merge_leaf( iter );  // changes iter to be new "merged" leaf
+    assert(!err);
+    // store smaller of two values on new leaf
+    err = moab.tag_set_data( data, &leaf, 1, &data1 );
+    assert(!err);
+  // write to file
+#if MB_VERSION_MAJOR <= 3
+  err = moab.write_mesh( "tree.h5m" );
+#else
+  err = moab.write_file( "tree.h5m" );
+#endif
+  assert(!err);
+  // clear everything
+  moab.delete_mesh();
+  // read tree from file
+  err = moab.load_mesh( "tree.h5m" );
+#else
+  MBEntityHandle file;
+  err = moab.load_file( "tree.h5m", file );
+#endif
+  assert(!err);
+  // get tag handle by name, because the handle may have changed
+  err = moab.tag_get_handle( TAG_NAME, data );
+  assert(!err);
+  // get root handle for tree
+  MBRange range;
+  err = tool.find_all_trees( range );
+  assert(!err);
+  assert(range.size() == 1);
+  root = range.front(); // first (only) handle
+  // Iterate over tree, verifying leaves and checking data
+  // Initial leaves had volume of 1 : merged pairs of leaves so volume should now be 2.
+  // Initial leaves were enumerated in order : merged pairs so new leaves should
+  //   have data incrementing in steps of 2.
+  counter = 1;
+    int data1;
+    assert(!err);
+    assert( counter == data1 );
+    counter += 2;
+    assert( fabs(volume - 2.0) <= DBL_EPSILON );
+    assert( iter.depth() == DEPTH-1 );
+    // (num_leaves is original number of leaves, twice current number,
+    //  but counter is incremented by 2 for each iteration, so just
+    //  compare them.)
+  assert( counter-1 == num_leaves );
+    // Delete data from tree
+  err = moab.tag_delete( data );
+  assert( !err );
+  // write to file
+#else
+#endif
+  assert(!err);
+#else
+#endif
+  assert(!err);
+  // check that tag doesn't exist
+  assert( MB_TAG_NOT_FOUND == err );
+  return 0;
