[MOAB-dev] r1264 - MOAB/trunk
kraftche at mcs.anl.gov
Mon Aug 27 18:01:14 CDT 2007
Author: kraftche
Date: 2007-08-27 18:01:14 -0500 (Mon, 27 Aug 2007)
New Revision: 1264
Modified:
MOAB/trunk/TagServer.cpp
MOAB/trunk/TagServer.hpp
Log:
Make MB_TAG_MESH be different than MB_TAG_SPARSE.
Now if an application requests a tag of type MB_TAG_MESH
o it will get an error if it tries to get/set valus on anything other
than the mesh
o it will get back MB_TAG_MESH from MBInterface::tag_get_type().
Modified: MOAB/trunk/TagServer.cpp
--- MOAB/trunk/TagServer.cpp 2007-08-27 22:29:30 UTC (rev 1263)
+++ MOAB/trunk/TagServer.cpp 2007-08-27 23:01:14 UTC (rev 1264)
@@ -121,7 +121,7 @@
- MBErrorCode result;
+ MBErrorCode result = MB_FAILURE;;
MBTagId id;
// Input size must be a multiple of the size of the data type.
@@ -136,14 +136,14 @@
result = mBitServer->reserve_tag_id(data_size, id);
break;
case MB_TAG_SPARSE:
- case MB_TAG_MESH:
result = mSparseData->reserve_tag_id(data_size, id);
break;
case MB_TAG_DENSE:
result = mDenseData->reserve_tag_id(data_size, default_value, id);
break;
- default:
- result = MB_FAILURE;
+ case MB_TAG_MESH:
+ result = reserve_mesh_tag_id( id );
+ break;
if(result != MB_SUCCESS)
@@ -170,7 +170,7 @@
if(iterator == mTagTable.end())
return MB_TAG_NOT_FOUND;
- MBErrorCode status = MB_TAG_NOT_FOUND;
+ MBErrorCode status = MB_FAILURE;
MBTagId id = ID_FROM_TAG_HANDLE(tag_handle);
switch (PROP_FROM_TAG_HANDLE(tag_handle)) {
@@ -178,14 +178,14 @@
status = mBitServer->release_tag_id(id);
break;
case MB_TAG_SPARSE:
- case MB_TAG_MESH:
status = mSparseData->release_tag_id(id);
break;
case MB_TAG_DENSE:
status = mDenseData->release_tag_id(id);
break;
- default:
- status = MB_FAILURE;
+ case MB_TAG_MESH:
+ status = MB_SUCCESS;
+ break;
if (MB_SUCCESS == status) {
@@ -282,9 +282,10 @@
return mSparseData->set_data(id, entity_handle, data);
case MB_TAG_DENSE:
return mDenseData->set_data(id, entity_handle, data);
- default:
- return MB_TAG_NOT_FOUND;
+ case MB_TAG_MESH:
+ return MB_FAILURE;
@@ -436,6 +437,9 @@
case MB_TAG_BIT:
result = get_bits(tag_handle, entity_handle, *((unsigned char *)data));
break;
+ case MB_TAG_MESH:
+ result = MB_FAILURE;
+ break;
// if we couldn't get a value
@@ -690,32 +694,18 @@
MBErrorCode TagServer::remove_data( const MBTag tag_handle, const MBEntityHandle entity_handle )
- // there is no remove_data equivalent for Dense tags
- if( PROP_FROM_TAG_HANDLE(tag_handle) == MB_TAG_DENSE)
- return MB_SUCCESS;
+ switch (PROP_FROM_TAG_HANDLE(tag_handle)) {
+ case MB_TAG_DENSE:
+ return MB_SUCCESS;
+ case MB_TAG_SPARSE:
+ return mSparseData->remove_data(ID_FROM_TAG_HANDLE(tag_handle), entity_handle);
+ case MB_TAG_BIT:
+ case MB_TAG_MESH:
- else if(PROP_FROM_TAG_HANDLE(tag_handle) == MB_TAG_SPARSE)
- return mSparseData->remove_data(ID_FROM_TAG_HANDLE(tag_handle), entity_handle);
- else if(PROP_FROM_TAG_HANDLE(tag_handle) == MB_TAG_BIT)
- // can't take bit tags off entities currently
- return MB_FAILURE;
- // use the delete_tag function instead of this
- //else if(reinterpret_cast<long>(tag_handle) & TAG_BIT_PROPERTIES[MB_TAG_STATIC)
- //return mStaticSparseData.remove_data(ID_FROM_TAG_HANDLE(tag_handle));
@@ -752,6 +742,9 @@
case MB_TAG_BIT:
result = mBitServer->get_entities(id, type, entities);
break;
+ case MB_TAG_MESH:
+ result = MB_TYPE_OUT_OF_RANGE;
+ break;
return result;
@@ -774,6 +767,9 @@
case MB_TAG_BIT:
result = mBitServer->get_entities(range, id, type, entities);
break;
+ case MB_TAG_MESH:
+ break;
return result;
@@ -798,6 +794,9 @@
result = mBitServer->get_entities_with_tag_value(id, type,
entities, *((const unsigned char*)value));
break;
+ case MB_TAG_MESH:
+ break;
return result;
@@ -824,6 +823,9 @@
result = mBitServer->get_entities_with_tag_value(range, id, type,
break;
+ case MB_TAG_MESH:
+ break;
return result;
@@ -985,6 +987,8 @@
return mDenseData->get_number_entities(id, type, num_entities);
case MB_TAG_BIT:
return mBitServer->get_number_entities(id, type, num_entities);
+ case MB_TAG_MESH:
+ return MB_TYPE_OUT_OF_RANGE;
@@ -1002,6 +1006,8 @@
return mDenseData->get_number_entities(range, id, type, num_entities);
case MB_TAG_BIT:
return mBitServer->get_number_entities(range, id, type, num_entities);
+ case MB_TAG_MESH:
@@ -1023,12 +1029,12 @@
case MB_TAG_BIT:
mBitServer->get_memory_use( id, result, tmp );
break;
- default:
+ case MB_TAG_MESH:
break;
// add in size of entry in mTagTable
- return result + sizeof(MBTag) + sizeof(TagInfo) + 3*sizeof(void*);
+ return result + sizeof(MBTag) + sizeof(TagInfo) + 3*sizeof(void*);
MBErrorCode TagServer::get_memory_use( MBTag tag_handle,
@@ -1050,7 +1056,7 @@
case MB_TAG_BIT:
mBitServer->get_memory_use( id, total, per_entity );
break;
- default:
+ case MB_TAG_MESH:
break;
@@ -1058,11 +1064,33 @@
total += sizeof(MBTag) + sizeof(TagInfo) + 3*sizeof(void*);
if (tag_info->default_value())
total += tag_info->get_size();
+ if (tag_info->get_mesh_value())
+ total += tag_info->get_size();
total += tag_info->get_name().size();
return MB_SUCCESS;
+MBErrorCode TagServer::reserve_mesh_tag_id( MBTagId& id_out ) const
+ MBTag tag = TAG_HANDLE_FROM_ID( 1, MB_TAG_MESH );
+ std::map<MBTag,TagInfo>::const_iterator i = mTagTable.lower_bound( tag );
+ if (i == mTagTable.end() || i->first > tag) {
+ id_out = 1;
+ tag = i->first + 1;
+ for (++i; i != mTagTable.end() && tag == i->first; ++i)
+ id_out = ID_FROM_TAG_HANDLE( tag );
#ifdef TEST
#include <iostream>
Modified: MOAB/trunk/TagServer.hpp
--- MOAB/trunk/TagServer.hpp 2007-08-27 22:29:30 UTC (rev 1263)
+++ MOAB/trunk/TagServer.hpp 2007-08-27 23:01:14 UTC (rev 1264)
@@ -40,6 +40,7 @@
#include <map>
#include "MBTypes.h"
+#include "MBInternals.hpp"
class MBRange;
class DenseTagSuperCollection;
@@ -103,6 +104,8 @@
private:
+ MBErrorCode reserve_mesh_tag_id( int& id_out );
//! stores the tag name
std::string mTagName;
@@ -272,6 +275,8 @@
private:
+ MBErrorCode reserve_mesh_tag_id( MBTagId& id_out ) const;
//! table of tag ids and tag information
//! do we really need to do it this way?
//! we at least need a table between names and tag ids
