[MOAB-dev] r1263 - MOAB/trunk
kraftche at mcs.anl.gov
Mon Aug 27 17:29:30 CDT 2007
Author: kraftche
Date: 2007-08-27 17:29:30 -0500 (Mon, 27 Aug 2007)
New Revision: 1263
Modified:
MOAB/trunk/MBCore.cpp
MOAB/trunk/MBCore.hpp
MOAB/trunk/TagServer.cpp
MOAB/trunk/TagServer.hpp
MOAB/trunk/WriteHDF5.cpp
Log:
o Remove special entity set from MBCore for storing "mesh" values of tag
o Make MBCore::get_root_set() return 0.
o Store global/mesh value of tags in TagInfo structure of TagServer
o Add special methods to get/set global/mesh value of tag
o Remove code in WriteHDF5 that checks for and removes the old "root set"
from the results of calls to get all the mesh sets (and similar calls.)
Modified: MOAB/trunk/MBCore.cpp
--- MOAB/trunk/MBCore.cpp 2007-08-27 21:12:01 UTC (rev 1262)
+++ MOAB/trunk/MBCore.cpp 2007-08-27 22:29:30 UTC (rev 1263)
@@ -158,9 +158,6 @@
readerWriterSet = new MBReaderWriterSet( this, mError );
if (!readerWriterSet)
return MB_MEMORY_ALLOCATION_FAILED;
- MBErrorCode result = create_meshset(0, myMeshSet);
- if (MB_SUCCESS != result) return result;
material_tag();
neumannBC_tag();
@@ -173,7 +170,7 @@
MBEntityHandle MBCore::get_root_set()
- return myMeshSet;
+ return 0;
void MBCore::deinitialize()
@@ -552,8 +549,6 @@
delete sequenceManager;
sequenceManager = new EntitySequenceManager( procInfo );
- result = create_meshset(0, myMeshSet);
return result;
@@ -1430,11 +1425,8 @@
const int num_entities,
void *tag_data) const
- MBTagType tag_type;
- if (NULL == entity_handles && 0 == num_entities &&
- MB_SUCCESS == tag_get_type(tag_handle, tag_type))
- return tagServer->get_data(tag_handle, &myMeshSet, 1, tag_data);
+ if (NULL == entity_handles && 0 == num_entities)
+ return tagServer->get_mesh_data(tag_handle, tag_data);
else return tagServer->get_data(tag_handle, entity_handles, num_entities, tag_data);
@@ -1453,11 +1445,8 @@
const void *tag_data)
- return tagServer->set_data(tag_handle, &myMeshSet, 1, tag_data);
+ return tagServer->set_mesh_data(tag_handle, tag_data);
//verify handles
MBEntitySequence* seq;
@@ -1555,7 +1544,7 @@
MBErrorCode status = MB_SUCCESS, temp_status;
for (int i = 0; i < num_handles; i++) {
if (0 == entity_handles[i])
- temp_status = tagServer->remove_data(tag_handle, myMeshSet);
+ temp_status = tagServer->remove_mesh_data(tag_handle);
else
temp_status = tagServer->remove_data(tag_handle, entity_handles[i]);
if (temp_status != MB_SUCCESS) status = temp_status;
@@ -1673,7 +1662,7 @@
std::vector<MBTag> &tag_handles) const
if (0 == entity)
- return tagServer->get_tags(myMeshSet, tag_handles);
+ return tagServer->get_mesh_tags(tag_handles);
else return tagServer->get_tags(entity, tag_handles);
Modified: MOAB/trunk/MBCore.hpp
--- MOAB/trunk/MBCore.hpp 2007-08-27 21:12:01 UTC (rev 1262)
+++ MOAB/trunk/MBCore.hpp 2007-08-27 22:29:30 UTC (rev 1263)
@@ -1001,9 +1001,6 @@
MBReaderWriterSet* readerWriterSet;
- //! a meshset for the overall mesh; used primarily to set tags on entire mesh
- MBEntityHandle myMeshSet;
MBError* mError;
static const char *errorStrings[];
Modified: MOAB/trunk/TagServer.cpp
--- MOAB/trunk/TagServer.cpp 2007-08-27 21:12:01 UTC (rev 1262)
+++ MOAB/trunk/TagServer.cpp 2007-08-27 22:29:30 UTC (rev 1263)
@@ -170,7 +170,6 @@
if(iterator == mTagTable.end())
return MB_TAG_NOT_FOUND;
- mTagTable.erase(iterator);
MBErrorCode status = MB_TAG_NOT_FOUND;
MBTagId id = ID_FROM_TAG_HANDLE(tag_handle);
@@ -189,6 +188,10 @@
status = MB_FAILURE;
+ if (MB_SUCCESS == status) {
+ mTagTable.erase(iterator);
return status;
@@ -249,6 +252,17 @@
return mBitServer->get_bits(ID_FROM_TAG_HANDLE(tag_handle), entity_handle, data);
+MBErrorCode TagServer::set_mesh_data( const MBTag tag_handle,
+ const void* data )
+ TagInfo* info = get_tag_info( tag_handle );
+ if (!info)
+ return MB_TAG_NOT_FOUND;
+ info->set_mesh_value( data );
+ return MB_SUCCESS;
MBErrorCode TagServer::set_data(const MBTag tag_handle,
const MBEntityHandle entity_handle,
const void* data)
@@ -391,6 +405,17 @@
+MBErrorCode TagServer::get_mesh_data( const MBTag tag_handle,
+ void* data ) const
+ const TagInfo* info = get_tag_info( tag_handle );
+ if (!info || !info->get_mesh_value())
+ memcpy( data, info->get_mesh_value(), info->get_size() );
MBErrorCode TagServer::get_data(const MBTag tag_handle,
void* data)
@@ -603,6 +628,15 @@
return result;
+MBErrorCode TagServer::get_mesh_tags( std::vector<MBTag>& all_tags ) const
+ std::map<MBTag,TagInfo>::const_iterator i;
+ for (i = mTagTable.begin(); i != mTagTable.end(); ++i)
+ if (i->second.get_mesh_value())
+ all_tags.push_back( i->first );
MBErrorCode TagServer::get_default_data_ref(const MBTag tag_handle, const void *& data)
@@ -644,6 +678,16 @@
+MBErrorCode TagServer::remove_mesh_data( const MBTag tag_handle )
+ info->remove_mesh_value();
MBErrorCode TagServer::remove_data( const MBTag tag_handle, const MBEntityHandle entity_handle )
Modified: MOAB/trunk/TagServer.hpp
--- MOAB/trunk/TagServer.hpp 2007-08-27 21:12:01 UTC (rev 1262)
+++ MOAB/trunk/TagServer.hpp 2007-08-27 22:29:30 UTC (rev 1263)
@@ -52,19 +52,24 @@
public:
//! constructor
- TagInfo() : mTagName(""), mDataSize(0), mDefaultValue(NULL) {}
+ TagInfo() : mTagName(""),
+ mDataSize(0),
+ mDefaultValue(NULL),
+ mMeshValue(NULL),
+ dataType(MB_TYPE_OPAQUE)
//! destructor
- ~TagInfo();
+ inline ~TagInfo();
//! copy constructor
- TagInfo(const TagInfo&);
+ inline TagInfo(const TagInfo&);
//! constructor that takes all parameters
- TagInfo(const char *, int, MBDataType type, const void *);
+ inline TagInfo(const char *, int, MBDataType type, const void *);
//! assignment operator
- TagInfo &operator=(const TagInfo &rhs);
+ inline TagInfo &operator=(const TagInfo &rhs);
//! set the name of the tag
void set_name( const std::string& name) { mTagName = name; }
@@ -81,6 +86,15 @@
//! get the default data
const void *default_value() const { return mDefaultValue;}
+ //! set mesh value
+ void set_mesh_value( const void* data );
+ //! get mesh value
+ const void* get_mesh_value() const { return mMeshValue; }
+ //! remove mesh value
+ void remove_mesh_value();
inline MBDataType get_data_type() const { return dataType; }
inline void set_data_type( MBDataType t ) { dataType = t; }
@@ -98,6 +112,9 @@
//! stores the default data, if any
unsigned char *mDefaultValue;
+ //! store the mesh value, if any
+ unsigned char *mMeshValue;
//! type of tag data
MBDataType dataType;
@@ -138,6 +155,9 @@
//! cleans out all data tagged on all entities
MBErrorCode reset_all_data();
+ //! set global/mesh value of tag
+ MBErrorCode set_mesh_data( const MBTag tag_handle, const void* data );
//! set the value of a tag
MBErrorCode set_data(const MBTag tag_handle, const MBEntityHandle entity_handle, const void* data );
@@ -145,6 +165,9 @@
MBErrorCode set_data(const MBTag tag_handle, const MBRange& entity_handles, const void* data );
+ //! get global/mesh value of tag
+ MBErrorCode get_mesh_data( const MBTag tag_handle, void* data ) const;
//! get the value of a tag
MBErrorCode get_data(const MBTag tag_handle, const MBEntityHandle entity_handle, void* data );
@@ -158,6 +181,9 @@
MBErrorCode get_bits(const MBTag tag_handle, const MBEntityHandle entity_handle, unsigned char& data );
+ //! remove global/mesh value of tag
+ MBErrorCode remove_mesh_data( const MBTag tag_handle );
//! remove the tag data on an entity
MBErrorCode remove_data( const MBTag tag_handle, const MBEntityHandle entity_handle );
@@ -220,7 +246,10 @@
//! get all the tags which have been defined for this entity
MBErrorCode get_tags(const MBEntityHandle entity, std::vector<MBTag> &all_tags);
+ //! get all the tags which have a global/mesh value
+ MBErrorCode get_mesh_tags(std::vector<MBTag> &all_tags) const;
MBErrorCode get_tags(std::vector<MBTag> &all_tags);
@@ -233,6 +262,7 @@
//! get information about a tag
const TagInfo* get_tag_info(const char *tag_name ) const;
const TagInfo* get_tag_info( MBTag tag_handle ) const;
+ TagInfo* get_tag_info( MBTag tag_handle );
unsigned long get_memory_use( MBTag tag_handle ) const;
@@ -268,15 +298,19 @@
inline TagInfo::TagInfo(const TagInfo& copy)
: mTagName( copy.mTagName ),
mDataSize( copy.mDataSize ),
+ mDefaultValue( 0 ),
+ mMeshValue( 0 ),
dataType( copy.dataType )
- if (NULL != copy.mDefaultValue)
+ if (copy.mDefaultValue) {
mDefaultValue = new unsigned char[mDataSize];
memcpy(mDefaultValue, copy.mDefaultValue, mDataSize);
- else
- mDefaultValue = NULL;
+ if (copy.mMeshValue) {
+ mMeshValue = new unsigned char[mDataSize];
+ memcpy(mMeshValue, copy.mMeshValue, mDataSize);
inline TagInfo::TagInfo( const char* name,
@@ -285,35 +319,34 @@
const void* default_value)
: mTagName( name ),
mDataSize( size ),
+ mMeshValue( 0 ),
dataType( type )
- if (NULL != default_value)
+ if (default_value) {
mDefaultValue = new unsigned char[size];
memcpy(mDefaultValue, default_value, size);
- else
inline TagInfo &TagInfo::operator=(const TagInfo &rhs)
mTagName = rhs.mTagName;
mDataSize = rhs.mDataSize;
- if (NULL != rhs.mDefaultValue)
- // delete the old data and make a new one (could be different size)
- if(mDefaultValue != NULL)
- delete [] mDefaultValue;
+ delete [] mDefaultValue;
+ delete [] mMeshValue;
+ mDefaultValue = 0;
+ mMeshValue = 0;
+ if (rhs.mDefaultValue) {
- memcpy(mDefaultValue, rhs.mDefaultValue, mDataSize);
+ memcpy( mDefaultValue, rhs.mDefaultValue, mDataSize );
- else
- // delete old data
+ if (rhs.mMeshValue) {
+ memcpy( mMeshValue, rhs.mMeshValue, mDataSize );
return *this;
@@ -322,11 +355,24 @@
inline TagInfo::~TagInfo()
// clean up default value
- if (NULL != mDefaultValue)
+inline void TagInfo::set_mesh_value( const void* data )
+ if (!mMeshValue)
+ memcpy( mMeshValue, data, mDataSize );
+inline void TagInfo::remove_mesh_value()
+ mMeshValue = 0;
inline const TagInfo* TagServer::get_tag_info( const char *tag_name ) const
if(NULL == tag_name || strcmp(tag_name, "") == 0)
@@ -357,6 +403,11 @@
return NULL;
+inline TagInfo* TagServer::get_tag_info( MBTag tag_handle )
+ std::map<MBTag, TagInfo>::iterator i = mTagTable.find(tag_handle);
+ return (i == mTagTable.end()) ? (TagInfo*)0 : &(i->second);
#endif //TAG_SERVER_HPP
Modified: MOAB/trunk/WriteHDF5.cpp
--- MOAB/trunk/WriteHDF5.cpp 2007-08-27 21:12:01 UTC (rev 1262)
+++ MOAB/trunk/WriteHDF5.cpp 2007-08-27 22:29:30 UTC (rev 1263)
@@ -712,19 +712,6 @@
CHK_MB_ERR_0(rval);
setSet.type = MBENTITYSET;
setSet.num_nodes = 0;
- // MOAB always returns the default set / global mesh
- // Don't want it.
- int size;
- MBRange::iterator gs = setSet.range.begin();
- assert( gs != setSet.range.end() &&
- MB_SUCCESS == iFace->get_number_entities_by_handle( *gs, size ) &&
- 0 == size &&
- MB_SUCCESS == iFace->num_child_meshsets( *gs, &size ) &&
- 0 == size &&
- MB_SUCCESS == iFace->num_parent_meshsets( *gs, &size ) &&
- 0 == size );
- setSet.range.erase( gs );
// Get all elements, grouped by type and number of higher-order nodes
exportList.clear();
