[MOAB-dev] r1261 - MOAB/trunk/tools/converter
kraftche at mcs.anl.gov
Mon Aug 27 16:09:49 CDT 2007
Author: kraftche
Date: 2007-08-27 16:09:49 -0500 (Mon, 27 Aug 2007)
New Revision: 1261
Modified:
MOAB/trunk/tools/converter/convert.cpp
Log:
o Fix bug handling -o flag
o Add -O flag for specifying file read options
o If building in parallel, make mbconvert do MBI_Init and such so that
it can be used as a parallel application for testing.
Modified: MOAB/trunk/tools/converter/convert.cpp
--- MOAB/trunk/tools/converter/convert.cpp 2007-08-27 21:08:21 UTC (rev 1260)
+++ MOAB/trunk/tools/converter/convert.cpp 2007-08-27 21:09:49 UTC (rev 1261)
@@ -33,6 +33,9 @@
# include <unistd.h>
#endif
#include <time.h>
+#ifdef USE_MPI
+# include <mpi.h>
+#endif
/* Exit values */
#define USAGE_ERROR 1
@@ -53,11 +56,15 @@
<< "\t-a <acis_file> - ACIS SAT file dumped by .cub reader (same as \"-o SAT_FILE=acis_file\"" << std::endl
<< "\t-A - .cub file reader should not dump a SAT file (depricated default)" << std::endl
<< "\t-o option - Specify write option." << std::endl
+ << "\t-O option - Specify read option." << std::endl
<< "\t-t - Time read and write of files." << std::endl
<< "\t-g - Enable verbose/debug output." << std::endl
<< "\t-h - Print this help text and exit." << std::endl
<< "\t-l - List available file formats and exit." << std::endl
<< "\t-I <dim> - Generate internal entities of specified dimension." << std::endl
+#ifdef USE_MPI
+ << "\t-P - Append processor ID to file name" << std::endl
+#endif
<< "\t-- - treat all subsequent options as file names" << std::endl
<< "\t (allows file names beginning with '-')" << std::endl
<< " subset options: " << std::endl
@@ -115,16 +122,26 @@
void write_times( std::ostream& stream );
void remove_entities_from_sets( MBInterface* gMB, MBRange& dead_entities, MBRange& empty_sets );
void remove_from_vector( std::vector<MBEntityHandle>& vect, const MBRange& ents_to_remove );
+bool make_opts_string( std::vector<std::string> options, std::string& result );
int main(int argc, char* argv[])
MBInterface* gMB;
MBErrorCode result;
MBRange range;
- // Get MB instance
+#ifdef USE_MPI
+ MPI_Init( &argc, &argv );
+ int proc_id, num_proc;
+ MPI_Comm_rank( MPI_COMM_WORLD, &proc_id );
+ MPI_Comm_size( MPI_COMM_WORLD, &num_proc );
+ gMB = new MBCore( proc_id, num_proc );
+#else
+ int proc_id = 0;
gMB = new MBCore();
+#endif
+ bool append_rank = false;
int i, dim;
bool dims[4] = {false, false, false, false};
const char* format = NULL; // output file format
@@ -133,7 +150,7 @@
bool verbose = false;
std::set<int> geom[4], mesh[3]; // user-specified IDs
std::vector<MBEntityHandle> set_list; // list of user-specified sets to write
- std::vector<std::string> options;
+ std::vector<std::string> write_opts, read_opts;
const char* const mesh_tag_names[] = { DIRICHLET_SET_TAG_NAME,
NEUMANN_SET_TAG_NAME,
MATERIAL_SET_TAG_NAME };
@@ -167,6 +184,9 @@
case 'h':
case 'H': print_help( argv[0] ); break;
case 'l': list_formats( gMB ); break;
+#ifdef USE_MPI
+ case 'P': append_rank = true; break;
+#endif
case '1': case '2': case '3':
dims[argv[i][1] - '0'] = true; break;
// do options that require additional args:
@@ -189,11 +209,12 @@
switch ( argv[i-1][1] )
case 'a':
- options.push_back( std::string("SAT_FILE=") + argv[i] );
+ write_opts.push_back( std::string("SAT_FILE=") + argv[i] );
pval = true;
break;
- case 'f': format = argv[i]; pval = true; break;
- case 'o': options.push_back(argv[i]); pval = true; break;
+ case 'f': format = argv[i]; pval = true; break;
+ case 'o': write_opts.push_back(argv[i]); pval = true; break;
+ case 'O': read_opts.push_back(argv[i]); pval = true; break;
case 'v': pval = parse_id_list( argv[i], geom[3] ); break;
case 's': pval = parse_id_list( argv[i], geom[2] ); break;
case 'c': pval = parse_id_list( argv[i], geom[1] ); break;
@@ -204,8 +225,10 @@
default: std::cerr << "Invalid option: " << argv[i] << std::endl;
- if (!pval)
+ if (!pval) {
+ std::cerr << "Invalid flag or flag value: " << argv[i-1] << " " << argv[i] << std::endl;
usage_error(argv[0]);
// do file names
@@ -213,51 +236,36 @@
in = argv[i];
else if (!out)
out = argv[i];
- else // too many file names
+ else { // too many file names
+ std::cerr << "Unexpexed argument: " << argv[i] << std::endl;
- if (!in || !out)
+ if (!in || !out) {
+ std::cerr << "No output file name specified." << std::endl;
+ std::string mod_out;
+ if (append_rank) {
+ char buffer[16];
+ sprintf(buffer,".%d",proc_id);
+ mod_out = out;
+ mod_out += buffer;
+ out = mod_out.c_str();
// construct options string from individual options
- std::string opts;
- if (!options.empty()) {
- std::vector<std::string>::const_iterator i;
- char separator = '\0';
- const char* alt_separators = ";+,:\t\n";
- for (const char* sep_ptr = alt_separators; *sep_ptr; ++sep_ptr) {
- bool seen = false;
- for (i = options.begin(); i != options.end(); ++i)
- if (i->find( *sep_ptr, 0 ) == std::string::npos) {
- seen = true;
- break;
- if (!seen) {
- separator = *sep_ptr;
- break;
- if (!separator) {
- std::cerr << "Error: cannot find separator character for options string" << std::endl;
- return 2;
- std::string opts;
- if (separator != ';') {
- opts = ";";
- opts += separator;
- i = options.begin();
- opts += *i;
- for (++i; i != options.end(); ++i) {
- opts += *i;
+ std::string read_options, write_options;
+ if (!make_opts_string( read_opts, read_options ) ||
+ !make_opts_string( write_opts, write_options ))
+ return USAGE_ERROR;
// Read the input file.
reset_times();
- result = gMB->load_mesh( in );
+ MBEntityHandle read_meshset;
+ result = gMB->load_file( in, read_meshset, read_options.c_str() );
if (MB_SUCCESS != result)
std::cerr << "Failed to load \"" << in << "\"." << std::endl;
@@ -477,11 +485,10 @@
// Write the output file
reset_times();
- const char* opt_str = opts.empty() ? NULL : opts.c_str();
if (have_sets)
- result = gMB->write_file( out, format, opt_str, &set_list[0], set_list.size() );
+ result = gMB->write_file( out, format, write_options.c_str(), &set_list[0], set_list.size() );
else
- result = gMB->write_file( out, format, opt_str );
+ result = gMB->write_file( out, format, write_options.c_str() );
std::cerr << "Failed to write \"" << out << "\"." << std::endl;
@@ -490,6 +497,9 @@
std::cerr << "Wrote \"" << out << "\"" << std::endl;
if (print_times) write_times( std::cerr );
+#ifdef USE_MPI
+ MPI_Finalize();
+#endif
return 0;
@@ -640,6 +650,49 @@
#endif
+bool make_opts_string( std::vector<std::string> options, std::string& opts )
+ opts.clear();
+ if (options.empty())
+ return true;
+ // choose a separator character
+ std::vector<std::string>::const_iterator i;
+ char separator = '\0';
+ const char* alt_separators = ";+,:\t\n";
+ for (const char* sep_ptr = alt_separators; *sep_ptr; ++sep_ptr) {
+ bool seen = false;
+ for (i = options.begin(); i != options.end(); ++i)
+ if (i->find( *sep_ptr, 0 ) != std::string::npos) {
+ seen = true;
+ break;
+ if (!seen) {
+ separator = *sep_ptr;
+ break;
+ if (!separator) {
+ std::cerr << "Error: cannot find separator character for options string" << std::endl;
+ return false;
+ if (separator != ';') {
+ opts = ";";
+ opts += separator;
+ // concatenate options
+ i = options.begin();
+ opts += *i;
+ for (++i; i != options.end(); ++i) {
+ opts += *i;
+ return true;
void list_formats( MBInterface* gMB )
const char iface_name[] = "MBReaderWriterSet";
