[MOAB-dev] r1260 - MOAB/trunk
kraftche at mcs.anl.gov
Mon Aug 27 16:08:21 CDT 2007
Author: kraftche
Date: 2007-08-27 16:08:21 -0500 (Mon, 27 Aug 2007)
New Revision: 1260
Modified:
MOAB/trunk/MBCore.cpp
Log:
implement file read option 'PARALLEL=SEND' w/out partitioning to send a copy of data to every processor
Modified: MOAB/trunk/MBCore.cpp
--- MOAB/trunk/MBCore.cpp 2007-08-27 21:07:34 UTC (rev 1259)
+++ MOAB/trunk/MBCore.cpp 2007-08-27 21:08:21 UTC (rev 1260)
@@ -56,6 +56,7 @@
#include "ExoIIUtil.hpp"
#include "EntitySequence.hpp"
#include "FileOptions.hpp"
+#include "MBParallelComm.hpp"
#ifdef LINUX
# include <dlfcn.h>
# include <dirent.h>
@@ -339,7 +340,7 @@
if (num_set_tag_values < 0)
return MB_INDEX_OUT_OF_RANGE;
- // feature not implemented yet
+ FileOptions opts(options);
file_set = 0;
MBErrorCode rval;
@@ -355,31 +356,103 @@
num_blocks = num_set_tag_values;
- // Try using the file extension to select a reader
- FileOptions opts(options);
- MBReaderIface* reader = set->get_file_extension_reader( file_name );
- if (reader)
- rval = reader->load_file( file_name, file_set, opts, block_id_list, num_blocks );
- delete reader;
+ // Get parallel settings
+ int parallel_mode;
+ const char* parallel_opts[] = { "NONE", "SEND", "FORMAT", 0 };
+ rval = opts.match_option( "PARALLEL", parallel_opts, parallel_mode );
+ if (MB_FAILURE == rval) {
+ mError->set_last_error( "Unexpected value for 'PARALLEL' option\n" );
+ return MB_FAILURE;
- else
- // Try all the readers
- MBReaderWriterSet::iterator iter;
- for (iter = set->begin(); iter != set->end(); ++iter)
- MBReaderIface* reader = iter->make_reader( this );
- if (NULL != reader)
+ else if (MB_ENTITY_NOT_FOUND == rval) {
+ parallel_mode = 0;
+ // Get partition setting
+ bool do_partition = false;
+ rval = opts.get_null_option( "PARTITION" );
+ if (MB_SUCCESS == rval)
+ do_partition = true;
+ else if (MB_ENTITY_NOT_FOUND != rval) {
+ mError->set_last_error( "Unexpected value for 'PARTITION' option\n" );
+ // get MPI IO processor rank
+ int reader_rank;
+ rval = opts.get_int_option( "MPI_IO_RANK", reader_rank );
+ if (MB_ENTITY_NOT_FOUND == rval)
+ reader_rank = 0;
+ else if (MB_SUCCESS != rval) {
+ mError->set_last_error( "Unexpected value for 'MPI_IO_RANK' option\n" );
+ // now that we've parsed all the parallel options, return
+ // failure for most of them because we haven't implemented
+ // most of them yet.
+ if (parallel_mode == 2) {
+ mError->set_last_error( "Access to format-specific parallel read not implemented.\n");
+ return MB_NOT_IMPLEMENTED;
+ if (do_partition && parallel_mode == 1) {
+ mError->set_last_error( "Partitioning for PARALLEL=SEND not supported yet.\n");
+ if (parallel_mode != 1 || reader_rank == (int)proc_config().rank()) {
+ // Try using the file extension to select a reader
+ MBReaderIface* reader = set->get_file_extension_reader( file_name );
+ if (reader)
+ rval = reader->load_file( file_name, file_set, opts, block_id_list, num_blocks );
+ delete reader;
+ else
+ // Try all the readers
+ MBReaderWriterSet::iterator iter;
+ for (iter = set->begin(); iter != set->end(); ++iter)
- delete reader;
- if (MB_SUCCESS == rval)
- break;
+ MBReaderIface* reader = iter->make_reader( this );
+ if (NULL != reader)
+ delete reader;
+ break;
+ else {
+ rval = MB_SUCCESS;
+ if (parallel_mode == 1) {
+ MBRange entities;
+ if (MB_SUCCESS == rval && reader_rank == (int)proc_config().rank()) {
+ rval = get_entities_by_handle( file_set, entities );
+ if (MB_SUCCESS != rval)
+ entities.clear();
+ MBParallelComm tool( this, tagServer, sequenceManager );
+ MBErrorCode tmp_rval = tool.broadcast_entities( reader_rank, entities );
+ tmp_rval = rval;
+ if (MB_SUCCESS == rval && reader_rank != (int)proc_config().rank()) {
+ rval = create_meshset( MESHSET_SET, file_set );
+ if (MB_SUCCESS == rval) {
+ rval = add_entities( file_set, entities );
+ if (MB_SUCCESS != rval) {
+ delete_entities( &file_set, 1 );
+ file_set = 0;
return rval;
@@ -457,7 +530,8 @@
rval = writer->write_file(file_name, overwrite, opts, &list[0], list.size(), qa_records );
delete writer;
- return rval;
+ std::cerr << "proc " << proc_config().rank() << " leaving MBCore::write_file" << std::endl;
+ return rval;
