[MOAB-dev] r1232 - MOAB/trunk
kraftche at mcs.anl.gov kraftche at mcs.anl.gov
Mon Aug 13 17:24:33 CDT 2007
Author: kraftche
Date: 2007-08-13 17:24:33 -0500 (Mon, 13 Aug 2007)
New Revision: 1232
Modified:
   MOAB/trunk/MBAdaptiveKDTree.cpp
   MOAB/trunk/MBAdaptiveKDTree.hpp
Log:
add method to query sibling of current iterator position
Modified: MOAB/trunk/MBAdaptiveKDTree.cpp
--- MOAB/trunk/MBAdaptiveKDTree.cpp	2007-08-12 14:44:06 UTC (rev 1231)
+++ MOAB/trunk/MBAdaptiveKDTree.cpp	2007-08-13 22:24:33 UTC (rev 1232)
@@ -633,6 +633,31 @@
   return MB_SUCCESS;
+MBErrorCode MBAdaptiveKDTreeIter::sibling_side(
+                            MBAdaptiveKDTree::Axis& axis_out,
+                            bool& neg_out ) const
+  if (mStack.size() < 2) // at tree root
+    return MB_ENTITY_NOT_FOUND;
+  MBEntityHandle parent = mStack[mStack.size()-2].entity;
+  MBAdaptiveKDTree::Plane plane;
+  MBErrorCode rval = tool()->get_split_plane( parent, plane );
+  if (MB_SUCCESS != rval)
+    return MB_FAILURE;
+  childVect.clear();
+  rval = tool()->moab()->get_child_meshsets( parent, childVect );
+  if (MB_SUCCESS != rval || childVect.size() != 2)
+  axis_out = static_cast<MBAdaptiveKDTree::Axis>(plane.norm);
+  neg_out = (childVect[1] == handle());
+  assert(childVect[neg_out] == handle());
+  return MB_SUCCESS;
 static MBErrorCode intersect_children_with_elems( MBInterface* moab,
                                         const MBRange& elems,
                                         MBAdaptiveKDTree::Plane plane,
Modified: MOAB/trunk/MBAdaptiveKDTree.hpp
--- MOAB/trunk/MBAdaptiveKDTree.hpp	2007-08-12 14:44:06 UTC (rev 1231)
+++ MOAB/trunk/MBAdaptiveKDTree.hpp	2007-08-13 22:24:33 UTC (rev 1232)
@@ -54,10 +54,10 @@
   //! Get split plane for tree node
-  MBErrorCode get_split_plane( MBEntityHandle entity, Plane& plane );
+  MBErrorCode get_split_plane( MBEntityHandle node, Plane& plane );
   //! Set split plane for tree node
-  MBErrorCode set_split_plane( MBEntityHandle entity, const Plane& plane );
+  MBErrorCode set_split_plane( MBEntityHandle node, const Plane& plane );
   //! Get bounding box for entire tree
   MBErrorCode get_tree_box( MBEntityHandle root_node,
@@ -209,7 +209,7 @@
   double mBox[2][3];                //!< min and max corners of bounding box
   MBAdaptiveKDTree* treeTool;       //!< tool for tree
   std::vector<StackObj> mStack;     //!< stack storing path through tree
-  std::vector<MBEntityHandle> childVect; //!< tempory storage of child handles
+  mutable std::vector<MBEntityHandle> childVect; //!< tempory storage of child handles
   //! Descend tree to left most leaf from current position
   //! No-op if at leaf.
@@ -247,6 +247,20 @@
     //! Advance to next leaf
     //! Returns MB_ENTITY_NOT_FOUND if at end.
   MBErrorCode step();
+    //! Return the side of the box bounding this tree node
+    //! that is shared with the immediately adjacent sibling
+    //! (the tree node that shares a common parent node with
+    //! this node in the binary tree.)
+    //!\param axis_out The principal axis orthogonal to the side of the box
+    //!\param neg_out  true if the side of the box is toward the decreasing
+    //!                direction of the principal axis indicated by axis_out,
+    //!                false if it is toward the increasing direction.
+    //!\return MB_ENTITY_NOT FOUND if root node.
+    //!        MB_FAILURE if internal error.
+    //!        MB_SUCCESS otherwise.
+  MBErrorCode sibling_side( MBAdaptiveKDTree::Axis& axis_out, bool& neg_out ) const;
     //! Get adjacent leaf nodes on side indicated by norm and neg.
