[MOAB-dev] r1231 - in MOAB/trunk: . tools/qvdual
tautges at mcs.anl.gov
Sun Aug 12 09:44:06 CDT 2007
Author: tautges
Date: 2007-08-12 09:44:06 -0500 (Sun, 12 Aug 2007)
New Revision: 1231
Modified:
MOAB/trunk/MBCore.cpp
MOAB/trunk/MBCore.hpp
MOAB/trunk/MBInterface.hpp
MOAB/trunk/configure.in
MOAB/trunk/moab.make.in
MOAB/trunk/tools/qvdual/DrawDual.cpp
MOAB/trunk/tools/qvdual/DrawDual.hpp
MOAB/trunk/tools/qvdual/uiQVDual.ui.h
Log:
MBCore, MBInterface: adding MBRange-based set_coords function.
qvdual files: fixed picking, by implementing my own hack (after wasting
about 2 days worth of effort trying to figure out vtk's picking then
giving up).
configure.in, moab.make.in: adding DAGMC_CONFIG_OPTIONS, needed by
applications to determine how to include dagmc.make.
Modified: MOAB/trunk/MBCore.cpp
--- MOAB/trunk/MBCore.cpp 2007-08-11 14:46:27 UTC (rev 1230)
+++ MOAB/trunk/MBCore.cpp 2007-08-12 14:44:06 UTC (rev 1231)
@@ -674,6 +674,34 @@
+//! set the coordinate information for this handle if it is of type Vertex
+//! otherwise, return an error
+MBErrorCode MBCore::set_coords(MBRange entity_handles, const double *coords)
+ MBErrorCode status = MB_SUCCESS;
+ int j = 0;
+ for (MBRange::iterator rit = entity_handles.begin(); rit != entity_handles.end(); rit++) {
+ if ( TYPE_FROM_HANDLE(*rit) == MBVERTEX )
+ MBEntitySequence* seq = 0;
+ status = sequence_manager()->find(*rit, seq);
+ if (seq != 0 && status == MB_SUCCESS) {
+ status = static_cast<VertexEntitySequence*>(seq)->set_coordinates(*rit, coords[j], coords[j+1], coords[j+2]);
+ j += 3;
+ else if (status == MB_SUCCESS)
+ status = MB_TYPE_OUT_OF_RANGE;
+ return status;
//! get global connectivity array for specified entity type
/** Assumes just vertices, no higher order nodes
Modified: MOAB/trunk/MBCore.hpp
--- MOAB/trunk/MBCore.hpp 2007-08-11 14:46:27 UTC (rev 1230)
+++ MOAB/trunk/MBCore.hpp 2007-08-12 14:44:06 UTC (rev 1231)
@@ -132,6 +132,11 @@
const int num_entities,
const double *coords);
+ //! set the coordinate information for this handle if it is of type Vertex
+ //! otherwise, return an error
+ virtual MBErrorCode set_coords(MBRange entity_handles,
+ const double *coords);
Modified: MOAB/trunk/MBInterface.hpp
--- MOAB/trunk/MBInterface.hpp 2007-08-11 14:46:27 UTC (rev 1230)
+++ MOAB/trunk/MBInterface.hpp 2007-08-12 14:44:06 UTC (rev 1231)
@@ -292,6 +292,19 @@
const double *coords)=0;
+ //! Sets the xyz coordinates for a vector of vertices
+ /** An error is returned if any entities in the vector are not vertices.
+ \param entity_handles MBEntityHandle's to set coordinates of. (Must be of type MeshVertex)
+ \param num_entities Number of entities in entity_handles
+ \param coords Array containing new xyz coordinates.
+ Example: \code
+ double coords[3] = {0.234, -2.52, 12.023};
+ set_coords( entity_handle, 1, coords ); \endcode
+ const double *coords)=0;
//! \name Connectivity functions
Modified: MOAB/trunk/configure.in
--- MOAB/trunk/configure.in 2007-08-11 14:46:27 UTC (rev 1230)
+++ MOAB/trunk/configure.in 2007-08-12 14:44:06 UTC (rev 1231)
@@ -706,6 +706,8 @@
esac
AC_SUBST(CGM_DIR)
AC_SUBST(CGM_CONFIG_OPTIONS)
+ DAGMC_CONFIG_OPTIONS="include \${MOAB_LIBDIR}/dagmc.make"
+ AC_SUBST(DAGMC_CONFIG_OPTIONS)
fi
AM_CONDITIONAL( HAVE_CGM, [test "x$CGM_MISSING" = "xno"] )
Modified: MOAB/trunk/moab.make.in
--- MOAB/trunk/moab.make.in 2007-08-11 14:46:27 UTC (rev 1230)
+++ MOAB/trunk/moab.make.in 2007-08-12 14:44:06 UTC (rev 1231)
@@ -9,3 +9,5 @@
MOAB_LIBS_LINK = ${MOAB_LDFLAGS} -L${MOAB_LIBDIR} -lMOAB @LIBS@
+DAGMC_CONFIG_OPTIONS = @DAGMC_CONFIG_OPTIONS@
Modified: MOAB/trunk/tools/qvdual/DrawDual.cpp
--- MOAB/trunk/tools/qvdual/DrawDual.cpp 2007-08-11 14:46:27 UTC (rev 1230)
+++ MOAB/trunk/tools/qvdual/DrawDual.cpp 2007-08-12 14:44:06 UTC (rev 1231)
@@ -2,6 +2,7 @@
#include "SheetDiagramPopup.h"
#include "MeshTopoUtil.hpp"
#include "MBTagConventions.hpp"
+#include "MBCartVect.hpp"
#include "MBCN.hpp"
#include "DualTool.hpp"
#include "vtkMOABUtils.h"
@@ -53,10 +54,10 @@
const int SHEET_WINDOW_SIZE = 500;
-const int RAD_PTS = 3*72;
-//const int RAD_PTS = 7;
-const int CENT_X = 250;
-const int CENT_Y = 250;
+//const int RAD_PTS = 400;
+const int RAD_PTS = 10;
+const int CENT_X = 0;
+const int CENT_Y = 0;
#define MBI vtkMOABUtils::mbImpl
#define RR if (MB_SUCCESS != result) return result
@@ -142,7 +143,7 @@
// create a cell picker
dualPicker = vtkCellPicker::New();
- dualPicker->SetTolerance(0.1);
+ dualPicker->SetTolerance(0.05);
// set up the callback handler for the picker
vtkMOABUtils::eventCallbackCommand = vtkCallbackCommand::New();
@@ -190,22 +191,41 @@
style->FindPokedRenderer(rwi->GetEventPosition()[0],
rwi->GetEventPosition()[1]);
rwi->StartPickCallback();
- dualPicker->Pick(rwi->GetEventPosition()[0],
- rwi->GetEventPosition()[1],
- 0.0,
- style->GetCurrentRenderer());
+ vtkRenderer *ren = style->GetCurrentRenderer();
+ MBEntityHandle dual_surf = gDrawDual->get_dual_surf(ren);
+ if (0 == dual_surf) return;
- vtkRenderer *ren = style->GetCurrentRenderer();
- ren->SetDisplayPoint(rwi->GetEventPosition()[0],
- rwi->GetEventPosition()[1], 0);
- ren->DisplayToWorld();
- double tmp_world[4];
- ren->GetWorldPoint(tmp_world);
+ int ix = rwi->GetEventPosition()[0],
+ iy = rwi->GetEventPosition()[1];
- process_pick();
-// if (dualPicker->GetProp()) style->HighlightProp(dualPicker->GetProp());
+ double x = (ix - 250) * RAD_PTS/170.0;
+ double y = iy * RAD_PTS/170.0;
+ if (my_debug)
+ std::cout << "Picked point: " << rwi->GetEventPosition()[0]
+ << ", " << rwi->GetEventPosition()[1] << "(screen), "
+ << dualPicker->GetMapperPosition()[0] << ", "
+ << dualPicker->GetMapperPosition()[1] << " (mapper)"
+ << x << ", "
+ << y << " (world)"
+ << std::endl;
+ MBRange picked_ents;
+ MBErrorCode result = gDrawDual->process_pick(dual_surf,
+ x, y,
+ picked_ents);
+ if (MB_SUCCESS != result) return;
+ gDrawDual->print_picked_ents(picked_ents);
+ if (!picked_ents.empty()) {
+ // now update the highlighted polydata
+ gDrawDual->update_high_polydatas();
+ gDrawDual->secondLastPickedEnt = gDrawDual->lastPickedEnt;
+ gDrawDual->lastPickedEnt = *picked_ents.begin();
rwi->EndPickCallback();
@@ -215,108 +235,114 @@
-void DrawDual::process_pick()
+void DrawDual::process_pick(vtkRenderer *ren)
- assert(0 != dualCurveTagHandle);
+ bool old_picking = false;
+ if (old_picking) {
+ assert(0 != dualCurveTagHandle);
- // get the actor through the prop, to make sure we get the leaf of an
- // assembly
- vtkActorCollection *actors = dualPicker->GetActors();
+ // get the actor through the prop, to make sure we get the leaf of an
+ // assembly
+ vtkActorCollection *actors = dualPicker->GetActors();
- vtkActor *picked_actor = NULL, *tmp_actor;
- MBEntityHandle picked_sheet = 0, picked_chord = 0;
+ vtkActor *picked_actor = NULL, *tmp_actor;
+ MBEntityHandle picked_sheet = 0, picked_chord = 0;
- if (actors->GetNumberOfItems() == 1) {
- picked_actor = vtkActor::SafeDownCast(dualPicker->GetViewProp());
- picked_sheet = vtkMOABUtils::propSetMap[dualPicker->GetActor()];
- else {
- // more than one - traverse, choosing the chord if any first
actors->InitTraversal();
+ int i = 0;
while ((tmp_actor = actors->GetNextItem())) {
MBEntityHandle this_set = vtkMOABUtils::propSetMap[tmp_actor];
- if (0 == this_set) continue;
+ if (0 == this_set || -1 == dualPicker->GetCellId()) continue;
// get whether it's a dual surface or dual curve
MBEntityHandle dum_handle = 0;
MBErrorCode result = MBI->tag_get_data(dualCurveTagHandle, &this_set, 1,
&dum_handle);
- if (MB_TAG_NOT_FOUND == result)
+ std::cout << "Picked point " << dualPicker->GetCellId() << std::endl;
+ MBEntityHandle picked_ent;
+ if (MB_TAG_NOT_FOUND == result || 0 == dum_handle)
// must be a sheet
- picked_sheet = this_set;
+ picked_ent = gDrawDual->get_picked_cell(this_set, 2, dualPicker->GetCellId());
else {
- picked_chord = this_set;
- picked_actor = tmp_actor;
+ picked_ent = gDrawDual->get_picked_cell(this_set, 1, dualPicker->GetCellId());
+ picked_ents.insert(picked_ent);
+ else {
+ dualPicker->GetPickPosition()[0],
+ dualPicker->GetPickPosition()[1],
+ picked_ents);
- if (0 == picked_actor) return;
+ if (picked_ents.empty()) return;
- if (dualPicker->GetCellId() != -1) {
- // get picked entity based on cell id and set
- MBEntityHandle picked_ent = 0;
- if (picked_chord != 0)
- picked_ent = gDrawDual->get_picked_cell(picked_chord, 1, dualPicker->GetCellId());
- else if (picked_sheet != 0)
- picked_ent = gDrawDual->get_picked_cell(picked_sheet, 2, dualPicker->GetCellId());
- if (0 != picked_ent)
- gDrawDual->print_picked_ent(picked_ent);
- else
- std::cout << "Couldn't identify picked entity." << std::endl;
// MBRange::iterator pit = pickRange.find(picked_ent);
// if (pit == pickRange.end()) pickRange.insert(picked_ent);
// else pickRange.erase(pit);
- // now update the highlighted polydata
- gDrawDual->update_high_polydatas();
- gDrawDual->secondLastPickedEnt = gDrawDual->lastPickedEnt;
- gDrawDual->lastPickedEnt = picked_ent;
- else
-void DrawDual::print_picked_ent(MBEntityHandle picked_ent)
+void DrawDual::print_picked_ents(MBRange &picked_ents)
- // get the vertices
- std::ostringstream oss;
- const MBEntityHandle *connect;
- int num_connect;
- MBErrorCode result = MBI->get_connectivity(picked_ent, connect, num_connect);
- if (MB_SUCCESS != result) return;
- bool first = true;
- MBEntityHandle primals[20];
- std::vector<int> ids;
+ for (MBRange::iterator rit = picked_ents.begin(); rit != picked_ents.end(); rit++) {
+ MBEntityHandle picked_ent = *rit;
+ // get the vertices
+ std::ostringstream oss;
+ const MBEntityHandle *connect;
+ int num_connect;
+ MBErrorCode result = MBI->get_connectivity(picked_ent, connect, num_connect);
+ bool first = true;
+ MBEntityHandle primals[20];
+ std::vector<int> ids;
- assert(num_connect < 20);
- if (MBI->type_from_handle(picked_ent) == MBPOLYGON) oss << "2-cell: ";
- else if (MBI->type_from_handle(picked_ent) == MBEDGE) oss << "1-cell: ";
- else oss << "(unknown):";
- result = MBI->tag_get_data(dualEntityTagHandle, connect, num_connect, primals);
- ids.resize(num_connect);
- result = MBI->tag_get_data(vtkMOABUtils::globalId_tag(), primals, num_connect, &ids[0]);
- for (int i = 0; i < num_connect; i++) {
- if (!first) oss << "-";
- MBEntityType this_type = MBI->type_from_handle(primals[i]);
- if (this_type == MBHEX) oss << "h";
- else if (this_type == MBQUAD) oss << "f";
- else oss << "u";
+ assert(num_connect < 20);
+ if (MBI->type_from_handle(picked_ent) == MBPOLYGON) oss << "2-cell: ";
+ else if (MBI->type_from_handle(picked_ent) == MBEDGE) oss << "1-cell: ";
+ else oss << "(unknown):";
+ result = MBI->tag_get_data(dualEntityTagHandle, connect, num_connect, primals);
+ ids.resize(num_connect);
+ result = MBI->tag_get_data(vtkMOABUtils::globalId_tag(), primals, num_connect, &ids[0]);
+ for (int i = 0; i < num_connect; i++) {
+ if (!first) oss << "-";
+ MBEntityType this_type = MBI->type_from_handle(primals[i]);
+ if (this_type == MBHEX) oss << "h";
+ else if (this_type == MBQUAD) oss << "f";
+ else oss << "u";
- if (ids[i] != 0) oss << ids[i];
- else oss << MBI->id_from_handle(primals[i]);
+ if (ids[i] != 0) oss << ids[i];
+ else oss << MBI->id_from_handle(primals[i]);
- first = false;
+ first = false;
+ if (picked_ent == *picked_ents.begin()) {
+ std::cout << oss.str() << " (" << picked_ent << ")" << std::endl;
+ pickLine2->setText(pickLine1->displayText());
+ pickLine1->setText(QString(oss.str().c_str()));
+ gDrawDual->lastPickedEnt = picked_ent;
- std::cout << oss.str() << " (" << picked_ent << ")" << std::endl;
- pickLine2->setText(pickLine1->displayText());
- pickLine1->setText(QString(oss.str().c_str()));
void DrawDual::update_high_polydatas()
@@ -1175,9 +1201,9 @@
this_mapper->SetScalarModeToUseCellData();
// put an edge extractor before the mapper
-// vtkExtractEdges *ee = vtkExtractEdges::New();
-// ee->SetInput(pd);
-// this_mapper->SetInput(ee->GetOutput());
+ vtkExtractEdges *ee = vtkExtractEdges::New();
+ ee->SetInput(pd);
+ this_mapper->SetInput(ee->GetOutput());
this_mapper->SetInput(pd);
vtkActor2D *this_actor = vtkActor2D::New();
@@ -1194,13 +1220,11 @@
// need to set a coordinate system for this window, so that display coordinates
// are re-normalized to window size
- vtkCoordinate *this_coord = vtkCoordinate::New();
- this_coord->SetCoordinateSystemToWorld();
- this_mapper->SetTransformCoordinate(this_coord);
+// vtkCoordinate *this_coord = vtkCoordinate::New();
+// this_coord->SetCoordinateSystemToWorld();
+// this_mapper->SetTransformCoordinate(this_coord);
this_mapper->ScalarVisibilityOn();
- this_mapper->SetLookupTable(vtkMOABUtils::lookupTable);
+ //this_mapper->SetLookupTable(vtkMOABUtils::lookupTable);
this_mapper->UseLookupTableScalarRangeOn();
@@ -1215,27 +1239,27 @@
vtkMOABUtils::propSetMap[this_actor] = dual_surf;
this_actor->SetMapper(this_mapper);
this_actor->GetProperty()->SetLineWidth(2.0);
+ double red, green, blue;
+ int dum;
+ vtkMOABUtils::get_colors(dual_surf, vtkMOABUtils::totalColors, dum,
+ red, green, blue);
+ vtkProperty *this_property = this_actor->GetProperty();
+ this_property->SetColor(red, green, blue);
this_ren->AddActor(this_actor);
-// double red, green, blue;
-// int dum;
-// vtkMOABUtils::get_colors(dual_surf, vtkMOABUtils::totalColors, dum,
-// red, green, blue);
-// vtkProperty2D *this_property = this_actor->GetProperty();
-// this_property->SetColor(red, green, blue);
-// this_property->SetDisplayLocationToBackground();
-// this_property->SetOpacity(0.5);
-// vtkCamera *camera = vtkCamera::New();
-// camera->SetPosition(72.0,72.0,300);
-// camera->SetFocalPoint(72.0,72.0,0);
-// camera->SetViewUp(0,1,0);
+ vtkCamera *camera = vtkCamera::New();
+ camera->SetPosition(CENT_X, CENT_Y, 3);
+ camera->SetFocalPoint(CENT_X, CENT_Y, 0);
+ camera->SetViewUp(0,1,0);
this_sdpopup = new SheetDiagramPopup();
if (my_debug) {
//this_sdpopup->sheet_diagram()->GetRenderWindow()->DebugOn();
this_sdpopup->sheet_diagram()->GetRenderWindow()->AddRenderer(this_ren);
this_sdpopup->sheet_diagram()->GetRenderWindow()->SetSize(SHEET_WINDOW_SIZE, SHEET_WINDOW_SIZE);
@@ -1381,12 +1405,16 @@
result = MBI->create_element(MBEDGE, edge_verts, 2, edge1);
if (MB_SUCCESS != result) return result;
this_gv->gvizEdges[dsindex] = (void*)edge1;
+ result = MBI->tag_set_data(dualCurveTagHandle, &edge1, 1, &(*rit));
+ if (MB_SUCCESS != result) return result;
edge_verts[0] = (MBEntityHandle) mid_vert;
edge_verts[1] = (MBEntityHandle) dvert_gv[1]->gvizPoints[index1];
result = MBI->create_element(MBEDGE, edge_verts, 2, edge2);
this_gv->gvizEdges[dsindex+2] = (void*)edge2;
+ result = MBI->tag_set_data(dualCurveTagHandle, &edge2, 1, &(*rit));
else {
@@ -1403,6 +1431,8 @@
this_gv->gvizEdges[dsindex] = (void*) edge1;
@@ -1695,7 +1725,7 @@
double LABEL_FRACTION = .90;
vtkCoordinate *this_pos = text_actor->GetPositionCoordinate();
this_pos->SetCoordinateSystemToWorld();
- this_pos->SetValue(LABEL_FRACTION, LABEL_FRACTION, 0);
+ this_pos->SetValue(LABEL_FRACTION*RAD_PTS+CENT_X, LABEL_FRACTION*RAD_PTS+CENT_Y, 0);
text_actor->GetTextProperty()->SetColor(1.0, 1.0, 1.0);
text_actor->GetTextProperty()->BoldOn();
ren->AddActor(text_actor);
@@ -2098,7 +2128,7 @@
else old_coords.swap(new_coords);
- for (int j = 0; j < all_verts.size(); j++) {
+ for (unsigned int j = 0; j < all_verts.size(); j++) {
MBEntityHandle this_point = graph_points[j];
// get all neighbor verts
@@ -2140,4 +2170,120 @@
return MB_SUCCESS;
+MBErrorCode DrawDual::process_pick(MBEntityHandle dual_surf,
+ const double x, const double y,
+ MBRange &picked_ents)
+ // get vertices on interior of 3d sheet
+ MBRange int_verts, face_verts;
+ MBErrorCode result = dualTool->get_dual_entities(dual_surf, NULL, NULL,
+ &int_verts, &face_verts, NULL);
+ int_verts = int_verts.subtract(face_verts);
+ // get vertices on sheet drawing for that sheet, and their positions
+ std::vector<MBEntityHandle> int_points(int_verts.size());
+ get_graph_points(int_verts, false, dual_surf, (void**) &int_points[0]);
+ std::vector<double> point_coords(3*int_verts.size());
+ result = MBI->get_coords(&int_points[0], int_points.size(),
+ &point_coords[0]); RR;
+ // get the closest point to those
+ double dist, closest_coords[3];
+ MBEntityHandle closest_point;
+ for (unsigned int i = 0; i < int_verts.size(); i++) {
+ double this_dist = (point_coords[3*i] - x)*(point_coords[3*i] - x) +
+ (point_coords[3*i+1] - y)*(point_coords[3*i+1] - y);
+ if (0 == i || this_dist < dist) {
+ dist = this_dist;
+ closest_point = int_points[i];
+ for (int j = 0; j < 3; j++) closest_coords[j] = point_coords[3*i+j];
+ // get connected edges, points, in star order
+ std::vector<MBEntityHandle> conn_edges(4);
+ MBEntityHandle dual_edges_3d[4], dual_curves[4], conn_verts[4];
+ result = MBI->get_adjacencies(&closest_point, 1, 1, false, conn_edges); RR;
+ assert(4 == conn_edges.size());
+ // conn_edges are on sheet diag; each points to 3d dual edge through curve tag,
+ // and each 3d dual edge points to dual curve set through that same tag
+ result = MBI->tag_get_data(dualCurveTagHandle, &conn_edges[0], 4,
+ dual_edges_3d); RR;
+ result = MBI->tag_get_data(dualCurveTagHandle, dual_edges_3d, 4,
+ dual_curves); RR;
+ // should only be 2 distinct curves; don't handle all dual curves the same
+ // for now, to avoid geometric check
+ assert((dual_curves[0] == dual_curves[1] && dual_curves[0] != dual_curves[2]) ||
+ (dual_curves[0] == dual_curves[2]) && dual_curves[0] != dual_curves[1]);
+ // if same curves are next to each other, switch edges
+ if (dual_curves[0] == dual_curves[1]) {
+ MBEntityHandle tmp_handle = conn_edges[1];
+ conn_edges[1] = conn_edges[2];
+ conn_edges[2] = tmp_handle;
+ tmp_handle = dual_curves[1];
+ dual_curves[1] = dual_curves[2];
+ dual_curves[2] = tmp_handle;
+ tmp_handle = dual_edges_3d[1];
+ dual_edges_3d[1] = dual_edges_3d[2];
+ dual_edges_3d[2] = tmp_handle;
+ // get connected points & their coords
+ for (int i = 0; i < 4; i++) {
+ int num_connect;
+ result = MBI->get_connectivity(conn_edges[i], connect, num_connect); RR;
+ if (connect[0] == closest_point) conn_verts[i] = connect[1];
+ else if (connect[1] == closest_point) conn_verts[i] = connect[0];
+ else assert(false);
+ double conn_coords[12];
+ result = MBI->get_coords(conn_verts, 4, conn_coords); RR;
+ MBCartVect pick_closest(x - closest_coords[0], y - closest_coords[1], 0.0);
+ MBCartVect conn_vects[4];
+ // pre-compute normalized vectors from closest to each connected vertex
+ conn_vects[i] = MBCartVect(conn_coords[3*i]-closest_coords[0],
+ conn_coords[3*i+1]-closest_coords[1], 0.0);
+ conn_vects[i].normalize();
+ // now evaluate to see if we picked an edge or 2cell
+ double this_dot = conn_vects[i] % pick_closest;
+ // if positive dot prod & dist < some tol, picked the edge
+ if (0.0 < this_dot &&
+ abs(dist - this_dot*this_dot) < 1)
+ picked_ents.insert(dual_edges_3d[i]);
+ // else if cross products w/ neighboring vectors opposite, we're in the 2cell
+ else if (0.0 < this_dot &&
+ (conn_vects[i] * pick_closest) % (conn_vects[(i+1)%4] * pick_closest)
+ < 0.0) {
+ MBRange common_2cell;
+ MBEntityHandle edges[2] = {dual_edges_3d[i], dual_edges_3d[(i+1)%4]};
+ result = MBI->get_adjacencies(edges, 2, 2, false, common_2cell);
+ assert(common_2cell.size() > 0);
+ picked_ents.insert(*common_2cell.begin());
+ return MB_SUCCESS;
+MBEntityHandle DrawDual::get_dual_surf(vtkRenderer *this_ren)
+ std::map<MBEntityHandle, GraphWindows>::iterator mit;
+ for (mit = surfDrawrings.begin(); mit != surfDrawrings.end(); mit++) {
+ vtkRenderer *gw_ren = (*mit).second.sheetDiagram->sheet_diagram()->GetRenderWindow()->
+ GetRenderers()->GetFirstRenderer();
+ if (gw_ren == this_ren) return (*mit).first;
+ return 0;
Modified: MOAB/trunk/tools/qvdual/DrawDual.hpp
--- MOAB/trunk/tools/qvdual/DrawDual.hpp 2007-08-11 14:46:27 UTC (rev 1230)
+++ MOAB/trunk/tools/qvdual/DrawDual.hpp 2007-08-12 14:44:06 UTC (rev 1231)
@@ -166,8 +166,14 @@
void* clientdata,
void* /*vtkNotUsed(calldata)*/);
- static void process_pick();
+ static void process_pick(vtkRenderer *ren);
+ //! given a dual surface and the pick point (in world coords), return a list
+ //! of picked entities on that sheet drawing
+ MBErrorCode process_pick(MBEntityHandle dual_surf,
+ MBRange &picked_ents);
//! map of dual surfaces and windows they're drawn in
std::map<MBEntityHandle, GraphWindows> surfDrawrings;
@@ -215,7 +221,7 @@
MBErrorCode fixup_degen_bchords(MBEntityHandle dual_surf);
- void print_picked_ent(MBEntityHandle picked_ent);
+ void print_picked_ents(MBRange &picked_ents);
//! given some entities, get the corresponding gviz points on the sheet
void get_points(const MBEntityHandle *ents, const int num_ents,
@@ -236,6 +242,9 @@
void get_graph_points(MBRange ents,
const bool extra,
MBEntityHandle dual_surf, void **points);
+ //! given a renderer, return the sheet that this renderer renders
+ MBEntityHandle get_dual_surf(vtkRenderer *this_ren);
Modified: MOAB/trunk/tools/qvdual/uiQVDual.ui.h
--- MOAB/trunk/tools/qvdual/uiQVDual.ui.h 2007-08-11 14:46:27 UTC (rev 1230)
+++ MOAB/trunk/tools/qvdual/uiQVDual.ui.h 2007-08-12 14:44:06 UTC (rev 1231)
@@ -155,9 +155,9 @@
if (NULL == vtkWidget) {
vtkWidget = new QVTKWidget( centralWidget(), "vtkWidget" );
-// vtkWidget->setGeometry( QRect( 400, 10, 470, 569 ) );
-// vtkWidget->setSizePolicy( QSizePolicy( (QSizePolicy::SizeType)7, (QSizePolicy::SizeType)7, 5, 1, vtkWidget->sizePolicy().hasHeightForWidth() ) );
-// vtkWidget->setMinimumSize( QSize( 0, 0 ) );
+ vtkWidget->setGeometry( QRect( 400, 10, 470, 569 ) );
+ vtkWidget->setSizePolicy( QSizePolicy( (QSizePolicy::SizeType)7, (QSizePolicy::SizeType)7, 5, 1, vtkWidget->sizePolicy().hasHeightForWidth() ) );
+ vtkWidget->setMinimumSize( QSize( 0, 0 ) );
vtkWidget->GetRenderWindow()->AddRenderer(ren);
