[MOAB-announce] mbcn_test fail while doing "make check"
Tim Tautges
tautges at mcs.anl.gov
Tue Oct 11 13:59:30 CDT 2011
Hong-Jun,
Can you check this out? Tiantian, we haven't seen this problem anywhere. The output from your configure looks like
you're on a 64bit machine, but can you verify that? The only other thing that looks strange in your configure is the
LFLAGS=-static; you should be able to get the same thing, in a more standard way, using --disable-shared
--enable-static. Could you try that? Thanks.
- tim
On 10/11/2011 12:58 PM, Tiantian Xu wrote:
> Hi,
> I was trying to build moab but met with the "mbcn_test fail" during make
> check.
> The commands I used to build the library were:
> ./configure LFLAGS=-static
> --with-mpi=/home/tiantian/ITL/mpich2-1.4.1p1/gcc
> --with-hdf5=/home/tiantian/hdf5
> --with-netcdf=/home/tiantian/ITL/netcdf-4.1.3/gcc
> --with-zlib=/home/tiantian/ITL/zlib-1.2.5/gcc
> --with-szip=/home/tiantian/ITL/szip-2.1/gcc
> --prefix=/home/tiantian/ITL/moab 2>&1 | tee configure.log
> make 2>&1 | make.log
> make check 2>&1 | tee make.check.log
> Looks like the mbcn_test is about query on entities, I don't know why
> this went wrong. Later I ignored the make check errors and did "make
> install". I tried to perform parallel read/write and found mbconvert
> went wrong too:
> $mpiexec -np 2 ./mbconvert -O PARALLEL=READ_PART -O
> PARTITION=MATERIAL_SET -O PARALLEL_RESOLVE_SHARED_ENTS -O
> PARALLEL_GHOSTS=3.0.1 -o PARALLEL=WRITE_PART ./64bricks_512hex.h5m dummy.h5m
> Read "./64bricks_512hex.h5m"
> = BAD TERMINATION OF ONE OF YOUR APPLICATION PROCESSES
> = EXIT CODE: 139
> = CLEANING UP REMAINING PROCESSES
> = YOU CAN IGNORE THE BELOW CLEANUP MESSAGES
> APPLICATION TERMINATED WITH THE EXIT STRING: Segmentation fault (signal 11)
> I suspect some fundamental functions in moab were not properly made?
> I had attached the log files. Please take a look.
> Thanks a lot for your help!
> Best,
> Tiantian
steadfast, because he trusts in you." Isaiah 26:3
Tim Tautges Argonne National Laboratory
(tautges at mcs.anl.gov) (telecommuting from UW-Madison)
phone: (608) 263-8485 1500 Engineering Dr.
fax: (608) 263-4499 Madison, WI 53706
More information about the moab-announce
