[Minotaur-dev] minotaur daily test results
Ashutosh Mahajan
mahajan at mcs.anl.gov
Fri Jan 26 23:17:16 CST 2018
Minotaur daily test report
Fri Jan 26 22:57:01 CST 2018
petsc.mcs.anl.gov
Linux petsc 3.13.0-121-generic #170-Ubuntu SMP Wed Jun 14 09:04:33 UTC 2017 x86_64 x86_64 x86_64 GNU/Linux
Detailed log available at http://www.mcs.anl.gov/research/projects/minotaur/nightly/build-log/petsc
Not using any user specified doxygen installation
Not using any user specified cmake installation
Minotaur src directory checked out.
Minotaur version: v0.2.1-34-g4d9cfe6
ls: cannot access build-ampl/bin: No such file or directory
ls: cannot access build-ampl/lib: No such file or directory
ls: cannot access build-ampl/include/minotaur/*: No such file or directory
ls: cannot access build-ampl-debug/bin: No such file or directory
ls: cannot access build-ampl-debug/lib: No such file or directory
ls: cannot access build-ampl-debug/include/minotaur/*: No such file or directory
ls: cannot access build-ampl-static/bin: No such file or directory
ls: cannot access build-ampl-static/lib: No such file or directory
ls: cannot access build-ampl-static/include/minotaur/*: No such file or directory
ls: cannot access build-all/bin: No such file or directory
ls: cannot access build-all/lib: No such file or directory
ls: cannot access build-all/include/minotaur/*: No such file or directory
ls: cannot access build-all-debug/bin: No such file or directory
ls: cannot access build-all-debug/lib: No such file or directory
ls: cannot access build-all-debug/include/minotaur/*: No such file or directory
ls: cannot access build-all-static/bin: No such file or directory
ls: cannot access build-all-static/lib: No such file or directory
ls: cannot access build-all-static/include/minotaur/*: No such file or directory
Summary
compiling build-base: OK.
make utest output for build-base: ERROR
compiling build-base-debug: OK.
make utest output for build-base-debug: ERROR
compiling build-base-static: OK.
make utest output for build-base-static: OK (41)
compiling build-filter: OK.
make utest output for build-filter: ERROR
compiling build-filter-debug: OK.
make utest output for build-filter-debug: ERROR
compiling build-filter-static: OK.
make utest output for build-filter-static: OK (41)
compiling build-ipopt: OK.
make utest output for build-ipopt: ERROR
compiling build-ipopt-debug: OK.
make utest output for build-ipopt-debug: ERROR
compiling build-ipopt-static: OK.
make utest output for build-ipopt-static: OK (44)
compiling build-osi: OK.
make utest output for build-osi: ERROR
compiling build-osi-debug: OK.
make utest output for build-osi-debug: ERROR
compiling build-osi-static: OK.
make utest output for build-osi-static: OK (41)
compiling build-ampl: ERROR. lib/libminotaur.so not built.
make utest output for build-ampl: ERROR
compiling build-ampl-debug: ERROR. lib/libminotaur.so not built.
make utest output for build-ampl-debug: ERROR
compiling build-ampl-static: ERROR. lib/libminotaur.a not built.
make utest output for build-ampl-static: OK (60)
compiling build-all: ERROR. lib/libminotaur.so not built.
make utest output for build-all: ERROR
compiling build-all-debug: ERROR. lib/libminotaur.so not built.
make utest output for build-all-debug: ERROR
compiling build-all-static: ERROR. lib/libminotaur.a not built.
make utest output for build-all-static: OK (71)
compiling build-all-manual: OK.
Errors:
Errors in build-all-debug:
/sandbox/mahajan/minotaur-test/src/base/NlWriter.cpp:30:0: warning: "SPEW" redefined [enabled by default]
#define SPEW 1
<command-line>:0:0: note: this is the location of the previous definition
../base/libminotaur.so: undefined reference to `Minotaur::PerspCutGenerator::generateCut()'
../base/libminotaur.so: undefined reference to `Minotaur::PerspCutGenerator::~PerspCutGenerator()'
../base/libminotaur.so: undefined reference to `Minotaur::PerspCutGenerator::PerspCutGenerator(unsigned int, boost::shared_ptr<Minotaur::Solution const>, boost::shared_ptr<Minotaur::Constraint const>, boost::shared_ptr<Minotaur::Variable>)'
collect2: error: ld returned 1 exit status
make[2]: *** [src/algorithms/qpd] Error 1
make[1]: *** [src/algorithms/CMakeFiles/qpd.dir/all] Error 2
make[1]: *** Waiting for unfinished jobs....
make[2]: *** [src/algorithms/glob] Error 1
make[1]: *** [src/algorithms/CMakeFiles/glob.dir/all] Error 2
make[2]: *** [src/algorithms/qg] Error 1
make[1]: *** [src/algorithms/CMakeFiles/qg.dir/all] Error 2
make[2]: *** [src/algorithms/bnb] Error 1
make[1]: *** [src/algorithms/CMakeFiles/bnb.dir/all] Error 2
make[2]: *** [src/algorithms/msbnb] Error 1
make[1]: *** [src/algorithms/CMakeFiles/msbnb.dir/all] Error 2
make: *** [all] Error 2
make[3]: *** [src/testing/unittest] Error 1
make[2]: *** [src/testing/CMakeFiles/unittest.dir/all] Error 2
make[1]: *** [CMakeFiles/utest.dir/rule] Error 2
make: *** [utest] Error 2
valgrind: ./unittest: No such file or directory
Errors in build-all:
#define SPEW 1
Errors in build-all-manual:
Makefile:545: minotaur.d: No such file or directory
#define SPEW 1
Errors in build-all-static:
#define SPEW 1
../base/libminotaur.a(PerspCutHandler.o): In function `Minotaur::PerspCutHandler::separate(boost::shared_ptr<Minotaur::Solution const>, boost::shared_ptr<Minotaur::Node>, boost::shared_ptr<Minotaur::Relaxation>, Minotaur::CutManager*, boost::shared_ptr<Minotaur::SolutionPool>, bool*, Minotaur::SeparationStatus*)':
PerspCutHandler.cpp:(.text+0x6fe): undefined reference to `Minotaur::PerspCutGenerator::PerspCutGenerator(unsigned int, boost::shared_ptr<Minotaur::Solution const>, boost::shared_ptr<Minotaur::Constraint const>, boost::shared_ptr<Minotaur::Variable>)'
PerspCutHandler.cpp:(.text+0x7ae): undefined reference to `Minotaur::PerspCutGenerator::generateCut()'
PerspCutHandler.cpp:(.text+0x1186): undefined reference to `Minotaur::PerspCutGenerator::~PerspCutGenerator()'
../base/libminotaur.a(PerspCutHandler.o): In function `boost::detail::sp_counted_impl_p<Minotaur::PerspCutGenerator>::dispose()':
PerspCutHandler.cpp:(.text._ZN5boost6detail17sp_counted_impl_pIN8Minotaur17PerspCutGeneratorEE7disposeEv[_ZN5boost6detail17sp_counted_impl_pIN8Minotaur17PerspCutGeneratorEE7disposeEv]+0xe): undefined reference to `Minotaur::PerspCutGenerator::~PerspCutGenerator()'
: logger ok! OK (71)
Errors in build-ampl-debug:
#define SPEW 1
Errors in build-ampl:
#define SPEW 1
Errors in build-ampl-static:
#define SPEW 1
: logger ok! OK (60)
Errors in build-base-debug:
#define SPEW 1
Errors in build-base:
#define SPEW 1
Errors in build-base-static:
#define SPEW 1
: logger ok! OK (41)
Errors in build-filter-debug:
#define SPEW 1
Errors in build-filter:
#define SPEW 1
Errors in build-filter-static:
#define SPEW 1
Errors in build-ipopt-debug:
#define SPEW 1
Errors in build-ipopt:
#define SPEW 1
Errors in build-ipopt-static:
#define SPEW 1
: logger ok! OK (44)
Errors in build-osi-debug:
#define SPEW 1
Errors in build-osi:
#define SPEW 1
Errors in build-osi-static:
#define SPEW 1
End of tests
More information about the Minotaur-dev
