[Minotaur-dev] minotaur daily test results
amahajan amahajan at iitb.ac.in
Fri Jan 26 11:31:09 CST 2018
Minotaur daily test report
Fri Jan 26 22:37:01 IST 2018
origin.ieor.iitb.ac.in
Linux origin 4.9.0-3-amd64 #1 SMP Debian 4.9.30-2+deb9u2 (2017-06-26) x86_64 GNU/Linux
Detailed log available at  http://www.ieor.iitb.ac.in/files/faculty/amahajan/minotaur/nightly/origin/index.html
Not using any user specified doxygen installation
Not using any user specified cmake installation
Minotaur src directory checked out.
Minotaur version: v0.2.1-34-g4d9cfe6
ls: cannot access 'build-ampl/bin': No such file or directory
ls: cannot access 'build-ampl/lib': No such file or directory
ls: cannot access 'build-ampl/include/minotaur/*': No such file or directory
ls: cannot access 'build-ampl-debug/bin': No such file or directory
ls: cannot access 'build-ampl-debug/lib': No such file or directory
ls: cannot access 'build-ampl-debug/include/minotaur/*': No such file or directory
ls: cannot access 'build-ampl-static/bin': No such file or directory
ls: cannot access 'build-ampl-static/lib': No such file or directory
ls: cannot access 'build-ampl-static/include/minotaur/*': No such file or directory
ls: cannot access 'build-all/bin': No such file or directory
ls: cannot access 'build-all/lib': No such file or directory
ls: cannot access 'build-all/include/minotaur/*': No such file or directory
ls: cannot access 'build-all-debug/bin': No such file or directory
ls: cannot access 'build-all-debug/lib': No such file or directory
ls: cannot access 'build-all-debug/include/minotaur/*': No such file or directory
ls: cannot access 'build-all-static/bin': No such file or directory
ls: cannot access 'build-all-static/lib': No such file or directory
ls: cannot access 'build-all-static/include/minotaur/*': No such file or directory
Summary
compiling build-base: OK.
make utest output for build-base: ERROR
compiling build-base-debug: OK.
make utest output for build-base-debug: ERROR
compiling build-base-static: OK.
make utest output for build-base-static: OK (41)
compiling build-filter: OK.
make utest output for build-filter: ERROR
compiling build-filter-debug: OK.
make utest output for build-filter-debug: ERROR
compiling build-filter-static: OK.
make utest output for build-filter-static: OK (41)
compiling build-ipopt: OK.
make utest output for build-ipopt: ERROR
compiling build-ipopt-debug: OK.
make utest output for build-ipopt-debug: ERROR
compiling build-ipopt-static: OK.
make utest output for build-ipopt-static: OK (44)
compiling build-osi: OK.
make utest output for build-osi: ERROR
compiling build-osi-debug: OK.
make utest output for build-osi-debug: ERROR
compiling build-osi-static: OK.
make utest output for build-osi-static: OK (41)
compiling build-ampl: ERROR. lib/libminotaur.so not built.
make utest output for build-ampl: ERROR
compiling build-ampl-debug: ERROR. lib/libminotaur.so not built.
make utest output for build-ampl-debug: ERROR
compiling build-ampl-static: ERROR. lib/libminotaur.a not built.
make utest output for build-ampl-static: OK (60)
compiling build-all: ERROR. lib/libminotaur.so not built.
make utest output for build-all: ERROR
compiling build-all-debug: ERROR. lib/libminotaur.so not built.
make utest output for build-all-debug: ERROR
compiling build-all-static: ERROR. lib/libminotaur.a not built.
make utest output for build-all-static: OK (71)
compiling build-all-manual: OK.
Errors:
Errors in build-all-debug:
/home/amahajan/tmp/minotaur-test/src/base/NlWriter.cpp:30:0: warning: "SPEW" redefined
 #define SPEW 1
<command-line>:0:0: note: this is the location of the previous definition
../base/libminotaur.so: undefined reference to `Minotaur::PerspCutGenerator::generateCut()'
../base/libminotaur.so: undefined reference to `Minotaur::PerspCutGenerator::~PerspCutGenerator()'
../base/libminotaur.so: undefined reference to `Minotaur::PerspCutGenerator::PerspCutGenerator(unsigned int, boost::shared_ptr<Minotaur::Solution const>, boost::shared_ptr<Minotaur::Constraint const>, boost::shared_ptr<Minotaur::Variable>)'
collect2: error: ld returned 1 exit status
make[2]: *** [src/algorithms/qpd] Error 1
make[1]: *** [src/algorithms/CMakeFiles/qpd.dir/all] Error 2
make[1]: *** Waiting for unfinished jobs....
make[2]: *** [src/algorithms/glob] Error 1
make[1]: *** [src/algorithms/CMakeFiles/glob.dir/all] Error 2
make[2]: *** [src/algorithms/msbnb] Error 1
make[1]: *** [src/algorithms/CMakeFiles/msbnb.dir/all] Error 2
make[2]: *** [src/algorithms/qg] Error 1
make[1]: *** [src/algorithms/CMakeFiles/qg.dir/all] Error 2
make[2]: *** [src/algorithms/bnb] Error 1
make[1]: *** [src/algorithms/CMakeFiles/bnb.dir/all] Error 2
make: *** [all] Error 2
make[3]: *** [src/testing/unittest] Error 1
make[2]: *** [src/testing/CMakeFiles/unittest.dir/all] Error 2
make[1]: *** [CMakeFiles/utest.dir/rule] Error 2
make: *** [utest] Error 2
valgrind: ./unittest: No such file or directory
Errors in build-all:
 #define SPEW 1
/home/amahajan/tmp/minotaur-test/src/base/NlWriter.cpp: In member function ‘int Minotaur::NlWriter::writeHeader_(Minotaur::ProblemPtr, std::ofstream&)’:
/home/amahajan/tmp/minotaur-test/src/base/NlWriter.cpp:143:18: warning: ‘nl_in_o’ may be used uninitialized in this function [-Wmaybe-uninitialized]
     of << " " << nl_in_o << " " << nl_in_c << std::endl;
Errors in build-all-manual:
Makefile:545: minotaur.d: No such file or directory
 #define SPEW 1
Errors in build-all-static:
 #define SPEW 1
../base/libminotaur.a(PerspCutHandler.o): In function `Minotaur::PerspCutHandler::separate(boost::shared_ptr<Minotaur::Solution const>, boost::shared_ptr<Minotaur::Node>, boost::shared_ptr<Minotaur::Relaxation>, Minotaur::CutManager*, boost::shared_ptr<Minotaur::SolutionPool>, bool*, Minotaur::SeparationStatus*)':
PerspCutHandler.cpp:(.text+0xca2): undefined reference to `Minotaur::PerspCutGenerator::PerspCutGenerator(unsigned int, boost::shared_ptr<Minotaur::Solution const>, boost::shared_ptr<Minotaur::Constraint const>, boost::shared_ptr<Minotaur::Variable>)'
PerspCutHandler.cpp:(.text+0xd1b): undefined reference to `Minotaur::PerspCutGenerator::generateCut()'
PerspCutHandler.cpp:(.text+0x1559): undefined reference to `Minotaur::PerspCutGenerator::~PerspCutGenerator()'
../base/libminotaur.a(PerspCutHandler.o): In function `boost::detail::sp_counted_impl_p<Minotaur::PerspCutGenerator>::dispose()':
PerspCutHandler.cpp:(.text._ZN5boost6detail17sp_counted_impl_pIN8Minotaur17PerspCutGeneratorEE7disposeEv[_ZN5boost6detail17sp_counted_impl_pIN8Minotaur17PerspCutGeneratorEE7disposeEv]+0xe): undefined reference to `Minotaur::PerspCutGenerator::~PerspCutGenerator()'
: logger ok! OK (71)
Errors in build-ampl-debug:
 #define SPEW 1
Errors in build-ampl:
 #define SPEW 1
Errors in build-ampl-static:
 #define SPEW 1
: logger ok! OK (60)
Errors in build-base-debug:
 #define SPEW 1
Errors in build-base:
 #define SPEW 1
Errors in build-base-static:
 #define SPEW 1
: logger ok! OK (41)
Errors in build-filter-debug:
 #define SPEW 1
Errors in build-filter:
 #define SPEW 1
Errors in build-filter-static:
 #define SPEW 1
Errors in build-ipopt-debug:
 #define SPEW 1
Errors in build-ipopt:
 #define SPEW 1
Errors in build-ipopt-static:
 #define SPEW 1
: logger ok! OK (44)
Errors in build-osi-debug:
 #define SPEW 1
Errors in build-osi:
 #define SPEW 1
Errors in build-osi-static:
 #define SPEW 1
End of tests
Fri Jan 26 23:01:09 IST 2018
More information about the Minotaur-dev mailing list
