[Meshkit-announce] Ask for help about using the MeshKit
Rajeev Jain jain at mcs.anl.gov
Fri Oct 18 18:08:16 CDT 2013
Hi Tang,
Thanks for your interest.
At present there is no support for CMake-based builds and Windows support.
Building on Linux would be the best option now.
At a minimum, you'd need CGM with OCC/CUBIT, MOAB with HDF5 and Lasso in order to use MeshKit.
Rajeev
----- Original Message -----
To: meshkit-announce at mcs.anl.gov
Sent: Friday, October 18, 2013 6:03:09 PM
Subject: [Meshkit-announce] Ask for help about using the MeshKit
Dear developer,
I am a student in China and I am studying the algorithm of quadrilateral mesh generation. I was required to develop the software to generate quadrilateral mesh for any 2-D input domains.
I am very exciting to get to know that you have very powerful open source mesh generator MeshKit. I am very interesting to the quadrilateral mesh generate part. From your document, I got to know that the ' JaalQuad ‘ algorithm is very suitable to me.
However, I also noticed that it is required to install some dependencies and I have to build them from Linux system. My question is: If I only use the quadrilateral mesh generation module, what's the simplest way to build the tool? Is it possible to port the code to Windows system?
I noticed that you said that 'On windows , try running cmake (though this is only indirectly supported, meaning it may not be up to date)'
from here:
https://trac.mcs.anl.gov/projects/fathom/wiki/BuildingMeshKit
Could you please tell me how to build it by CMake? I only know that we should provide CMakeLists.txt to CMake, is there any other method?
Tang Laoya
Meshkit-announce mailing list
Meshkit-announce at mcs.anl.gov
https://lists.mcs.anl.gov/mailman/listinfo/meshkit-announce
More information about the Meshkit-announce mailing list
