[AG-TECH] libcrypto.so.2 not found.
Pritesh shahpritesh_ag at excite.com
Fri Oct 29 18:10:31 CDT 2004
Thanks for the reply, but wooooff not working, been trying n trying, linked all the possible places, see this for more details
collinsia: {235} ll /home/psham/pkg/lib/libcrypt*
-rw-r--r--  1 psham  wheel  1282718 Oct 24 23:17 libcrypto.a
lrwxrwxr-x  1 psham  wheel       16 Oct 24 23:17 libcrypto.so -> libcrypto.so.300
lrwxrwxr-x  1 psham  wheel       38 Oct 29 17:02 libcrypto.so.2 -> /home/psham/pkg/lib/libcrypto.so.300.1
lrwxrwxr-x  1 psham  wheel       18 Oct 24 23:17 libcrypto.so.300 -> libcrypto.so.300.1
-r-xr-xr-x  1 psham  wheel   840008 Oct 24 23:17 libcrypto.so.300.1
collinsia: {12} ll /usr/pkg/lib/libcr*
-rw-r--r--  1 root  wheel  1315296 Dec 13  2003 /usr/pkg/lib/libcrypto.a
lrwxr-xr-x  1 root  wheel       16 Dec 13  2003 /usr/pkg/lib/libcrypto.so -> libcrypto.so.300
lrwxrwxr-x  1 root  wheel       38 Oct 29 17:03 /usr/pkg/lib/libcrypto.so.2 -> /home/psham/pkg/lib/libcrypto.so.300.1
lrwxr-xr-x  1 root  wheel       18 Dec 13  2003 /usr/pkg/lib/libcrypto.so.300 -> libcrypto.so.300.1
-r-xr-xr-x  1 root  wheel   858893 Dec 13  2003 /usr/pkg/lib/libcrypto.so.300.1
collinsia: {244} ll /home/psham/pkg/emul/linux/usr/lib/libcr*
lrwxrwxr-x  1 psham  wheel  38 Oct 29 17:04 /home/psham/pkg/emul/linux/usr/lib/libcrypto.so.2 -> /home/psham/pkg/lib/libcrypto.so.300.1
 --- On Fri 10/29, Many Ayromlou  wrote:
From: Many Ayromlou [mailto: mayromlo at ryerson.ca]
To: shahpritesh_ag at excite.com
     Cc: ag-tech at mcs.anl.gov, ag-users at mcs.anl.gov
Date: Fri, 29 Oct 2004 17:31:06 -0400
Subject: Re: [AG-TECH] libcrypto.so.2 not found.
Hi Pritesh,I had a similar problem "porting" Redhat FC2 rpm's into SuSE9.1. The  way I got around it was to create 2 symlinks to libcrypto and libssl.The RPM package I think needed version 4 of these libraries (which is  really 0.9.7 renamed) and I had 0.9.7.So here is what /usr/lib/libcrypt* looks like now:-rw-r--r--  1 root root  135776 Apr  5  2004 libcrypt.alrwxrwxrwx  1 root root      18 Oct 20 13:00 libcrypt.so ->  /lib/libcrypt.so.1lrwxrwxrwx  1 root root      18 Oct 20 13:00 libcrypto.so.0 ->  libcrypto.so.0.9.7-rwxr-xr-x  1 root root 1127119 Aug  4 11:44 libcrypto.so.0.9.7lrwxrwxrwx  1 root root      18 Oct 28 13:24 libcrypto.so.4 ->  libcrypto.so.0.9.7and libssllrwxrwxrwx  1 root root     15 Oct 20 13:00 libssl.so.0 ->  libssl.so.0.9.7-rwxr-xr-x  1 root root 221953 Aug  4 11:44 libssl.so.0.9.7lrwxrwxrwx  1 root root     15 Oct 28 13:21 libssl.so.4 ->  libssl.so.0.9.7Hope this helps,Contact me if you need more info....TTYLManyOn 29-Oct-04, at 3:02 PM, Pritesh wrote:>>> hi,>> i'm trying to build accessgrid on NetBSD platform. i have the binaries  > which are listed below:>> collinsia: {116} ls> AGNodeService.py           NodeManagement.py           > VenueManagement.py> AGServiceManager.py        NodeSetupWizard.py         VenueServer.py> BridgeServer.py            QuickBridge                agpm.py> CertificateRequestTool.py  VenueClient.py             certmgr.py>> I have python version installed which is present at the following  > location : /home/psham/pkg/bin/python2p2 . Its called python2p2 as the  > python 2.2.3 version is compiled with pthreads.>> i've got optik, fpconst and other python packages installed at the  > following location:> /home/psham/pkg/lib/python2p2/site-packages>> this is the problem that i'm facing:>> collinsia: {117} python2p2 AGNodeService.py> Traceback (most recent call last):>   File "AGNodeService.py", line 28, in ?>     from AccessGrid.Toolkit import Service>   File  > "/home/psham/pkg/lib/python2p2/site-packages/AccessGrid/Toolkit.py",  > line 22, in ?>     from AccessGrid.Security import CertificateManager>   File  > "/home/psham/pkg/lib/python2p2/site-packages/AccessGrid/Security/ > CertificateManager.py", line 48, in ?>     from OpenSSL_AG import crypto>   File  > "/home/psham/pkg/lib/python2p2/site-packages/OpenSSL_AG/__init__.py",  > line 11, in ?>     import rand, crypto, SSL> ImportError: Shared object "libcrypto.so.2" not found>>> its finding the python packages  > /home/psham/pkg/lib/python2p2/site-packages properly, but fails when  > it tries to find libraries. could somebody help me in case i'm doing  > anything wrong or is it that there's a specific place where the  > libraries should go.>> Cheers,> Pritesh>> _______________________________________________> Join Excite! - http://www.excite.com> The most personalized portal on the Web!>
URL: <http://lists.mcs.anl.gov/pipermail/kenstest/attachments/20041029/149ebb4e/attachment.htm>
More information about the Kenstest mailing list
